AHL - Developer's Guide Old Version
Solandsystel
Post by Solandsystel »
Hi everyone,
The AHL - Developer's Guide available in the BP site (AHL_Developers_Guide_ed03.pdf) is not applicable to old releases of the A4400.
So the ticket format described in it does not match the ticket format of the release 2.1 for example.
Anyone has the old AHL - Developer's Guide that describes the SMDR or telephone call ticket sent by the A4400 in the old Releases like 2.1
Would appreciate it very much if someone sends me that pdf doc.
And thanks a lot for your help.
Re: AHL - Developer's Guide Old Version
Best bet is to contact dspp@al-enterprise.com and ask for it..
alex
Post by alex »
Hm never heard about different versions of SMDR for Release 2.1. There are two formats - reduced and extended. Could it be that on PABX side extended format defined?
alex wrote: 22 Aug 2023 07:11 Hm never heard about different versions of SMDR for Release 2.1. There are two formats - reduced and extended. Could it be that on PABX side extended format defined?
That s a good point too.
Actually, in the version history, there is nothing at all about SMDR but rather new features here and there.
AHL did not change in 10+ years. Alex is probably right.
Return to “AHL / OHL”
