master :
THU MAY 25 17:18:09 2023 STACK-MANAGER info == SM == Stack Port B Status Changed: DOWN
THU MAY 25 17:18:09 2023 STACK-MANAGER info == SM == Stack Port A Status Changed: DOWN
THU MAY 25 17:18:10 2023 STACK-MANAGER info == SM == NI 2 down notification sent to LAG
THU MAY 25 17:18:10 2023 LINKAGG info Port Leave . port: 2025 agg: 1
THU MAY 25 17:18:11 2023 STP info Topology changed on VLAN/STP id 1
THU MAY 25 17:18:11 2023 STP info Topology changed on VLAN/STP id 4001
THU MAY 25 17:18:12 2023 HSM-CHASSIS info T8: Ni(2) extraction detected
THU MAY 25 17:18:12 2023 HSM-CHASSIS info == HSM == csHsmUtilNiCtxBrdSend() nsm CS_HSM_NSM_ST_OP, poweroff 0 Ni2
THU MAY 25 17:18:12 2023 HSM-CHASSIS info === HSM === Power Supply 3 has been REMOVED
THU MAY 25 17:18:12 2023 VLAN info CS_NI_DOWN/CS_NI_NOTPRESENT msg Rx for slot 2
THU MAY 25 17:18:12 2023 VLAN info Del connection for slot 2
THU MAY 25 17:18:12 2023 VLAN info VMC: Sent Pause for slot 2
THU MAY 25 17:18:12 2023 VLAN info Start Timer on ni_down 2 @ 1685006292
THU MAY 25 17:18:12 2023 INTERFACE info Close NI 2 ESM, socket 40 OK
THU MAY 25 17:18:12 2023 INTERFACE info Close NI 2 NiSUp, socket 19 OK
THU MAY 25 17:18:12 2023 GM info NI_DOWN 2
THU MAY 25 17:18:12 2023 GM info Del connection for slot 2
THU MAY 25 17:18:12 2023 GM info GMC: Sent Pause for slot 2
THU MAY 25 17:18:12 2023 GM info Start Timer on ni_down 2 @ 1685006292
THU MAY 25 17:18:12 2023 LINKAGG info EVT board down received slot 2 slice 0 recover 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 8: c failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alert pmSend: aborting send... 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 4f: 3 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 6: 4 failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: a: 1 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: b: 1 failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 31: 5 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 7: a failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 20: 29 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 9: b failed!! event 2 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 28: 2 failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: c: 1 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 12: 2 failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 17: 6 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 5b: 2 failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: d: 2 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 16: 0 failed!! event 2 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 96: 3 failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 29: 5 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 95: 5 failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: a3: 2 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: a4: 0 failed!! event 3 len 0
THU MAY 25 17:18:12 2023 PORT-MGR alarm sendPmMsg: sendTo 41 : 0: 4d: 1 failed!! event 4 len 0
THU MAY 25 17:18:12 2023 ETHERNET-OAM info Timer started Slot: 2, SocketID: 506
THU MAY 25 17:18:17 2023 GM info Timer closed skt on ni 1 @ 1685006297
THU MAY 25 17:18:17 2023 VLAN info Timer closed skt on ni 1 @ 1685006297
THU MAY 25 17:18:17 2023 VLAN info Timer closed skt for GVRP NI on ni 1 @ 1685006297
THU MAY 25 17:18:17 2023 ETHERNET-OAM info Timer expired Slot: 2, SocketID: 506
THU MAY 25 17:18:21 2023 STP info Topology changed on VLAN/STP id 1
THU MAY 25 17:18:21 2023 STP info Topology changed on VLAN/STP id 4001
THU MAY 25 17:28:12 2023 CSM-CHASSIS info == CSM == Stack topology changes have been updated to persistant file
THU MAY 25 17:28:12 2023 CCM-CHASSIS info === CCM === NI 2 has gone down/removed from host 'vxTarget'
I had changed a os6450 to test it , but it happend again. I also change the stacking module and stacking cable, but this event happened again.
and I change the power input to UPS , this event also exits. (my AOS=OS6450-24 6.7.2.19.R04).
Have anyone encountered this event?
OS6450 stacking (two os6450-24) and one os6450 would auto poweroff
oysterliu
Re: OS6450 stacking (two os6450-24) and one os6450 would auto poweroff
both switches are working standalone without problems?
If yes than check AOS and uboot/miniboot. show hardware-info, show microcode.
And use the newest release. Than stack again.
BR Silvio
BR Silvio
Jump to
- General topics
- ↳ Talk to the admins
- ↳ GENERAL
- ↳ Outside World
- ↳ PARTS
- ↳ Pre-Sales
- ↳ JOBS
- ↳ Remote assistance contracts
- ↳ Actis
- ↳ Equipement Pictures
- ↳ OT/OXE/OXO FEATURES REQUESTS
- ↳ Lucent Technologies
- IF YOU ARE NOT TECHNICALLY TRAINED ON THOSE PBX, PLEASE POST IN ONE OF THOSE FORUMS
- ↳ Beginner's questions about the Crystal Hardware
- ↳ Beginner's questions about the Common Hardware
- ↳ Beginner's questions about the (4400 / Enterprise) PHONE APPLICATION or OPERATING SYSTEM
- ↳ Beginner's questions about the OmniPCX OFFICE
- VOICE - Documentation
- ↳ OXE (Crystal / Common) - System Documentation
- ↳ 4760
- ↳ OXO - System Documentation
- ↳ Documentation
- VOICE - OXE (OmniPCX Enterprise)
- ↳ Shelf
- ↳ Media Gateway
- ↳ PWT/DECT System
- ↳ System
- ↳ Translator
- ↳ Classes of Services
- ↳ Attendant
- ↳ Users
- ↳ Users by profile
- ↳ Set Profile
- ↳ Groups
- ↳ Speed Dialing
- ↳ Phone Book
- ↳ Entities
- ↳ Trunk Groups
- ↳ External Services
- ↳ Inter-Node Links
- ↳ X25
- ↳ Data
- ↳ Application
- ↳ Specific Telephone Services
- ↳ ATM
- ↳ Event Routing Discriminator
- ↳ Security and Access Control
- ↳ IP
- ↳ SIP
- ↳ DHCP Configuration
- ↳ Alcatel-Lucent Series 8&9
- ↳ SIP Extension
- ↳ Encryption
- ↳ Passive Communication Server
- ↳ SNMP Configuration
- VOICE - OXE - Common topics
- ↳ MAIN
- ↳ ACTIS
- ↳ Asterisk
- ↳ Boards
- ↳ Bugs & Security issues
- ↳ Equipment Pictures
- ↳ Feature Request
- ↳ H323 / Sip
- ↳ IP / VoIP
- ↳ IP SECURITY / ENCRYPTION (Thales)
- ↳ ipTouch (40x8) issues and tricks
- ↳ Linux tricks
- ↳ MOH
- ↳ ON SITE TROUBLES
- ↳ Phones
- ↳ Sipfoundry
- ↳ Software Loading
- ↳ Swinst
- ↳ System Hacking
- ↳ Traces
- ↳ Usefull commands
- ↳ Voice Guides
- ↳ Wireless configuration and sets
- VOICE - OpenTouch
- ↳ MAIN
- ↳ OTEC - OpenTouch Enterprise Cloud
- ↳ OTBE - OpenTouch Business Edition
- ↳ OTMS - OpenTouch Multimedia Services
- ↳ OTSBC - OpenTouch Session Border Controller
- ↳ OTNS - OpenTouch Notification Service
- ↳ OTMC - OpenTouch Message Center
- ↳ OTFC - OpenTouch Fax Center
- ↳ OpenTouch Conversation
- ↳ Smart Guest Applications
- VOICE - BiCS
- ↳ MAIN
- VOICE - OXO
- ↳ MAIN
- ↳ Configuration
- ↳ 42xx Systems
- ↳ Networking
- ↳ H323 / IP / Pimphony
- ↳ Internet and related
- ↳ Applications
- ↳ Hotel mode
- ↳ DECT
- ↳ Hardware
- VOICE - Omni Suite
- ↳ OmniTouch 8400 Instant Communication Suite
- ↳ OmniTouch 8410 Instant Communication Web Services
- ↳ OmniTouch 8440 Messaging Software
- ↳ OmniTouch 8450 Fax Software
- ↳ OmniTouch 8460 Advanced Communication Server
- ↳ OmniTouch 8464 Meet-me Audio Conference Bridge
- ↳ OmniTouch 8660 My Teamwork Conferencing and Collaboration
- ↳ OmniTouch 8670 Automated Message Delivery System
- ↳ OmniTouch Contact Center Standard Edition
- ↳ OmniTouch Contact Center Premium Edition
- VOICE - Applications
- ↳ AECS - Alcatel Extended Communication Server
- ↳ Alcatel OpenTouch Customer Service
- ↳ Aviso
- ↳ Call Center SoftPanel (ALU ProServices)
- ↳ CCD / CCS / CCIVR
- ↳ Free Desktop
- ↳ GENESYS
- ↳ Hotel / Hospital
- ↳ Ip Desktop Softphone
- ↳ IpTouch Phones XML Applications
- ↳ MSAD
- ↳ MyIC (My Instant Communicator)
- ↳ My Messaging / IMAP
- ↳ My Teamwork (ex-eDial)
- ↳ OmniPCX Record
- ↳ OmniVista 4760
- ↳ OmniVista 8770
- ↳ OTUC
- ↳ PREMIUM / GCE
- ↳ Rainbow
- ↳ Ubiquity
- ↳ ENS - Emergency Notification Server
- ↳ VNA - Visual Notification Assistant
- ↳ VAA - Visual Auto Attendant
- ↳ VitalSuite
- ↳ VitalQIP
- ↳ Voicemail (46x5)
- ↳ XML Presentation Server & TAPI Server
- ↳ 4980 - WebSoftPhone
- ↳ 4625 Interactive Voice Response
- VOICE - Third Party Applications
- ↳ AGITO NETWORKS
- ↳ AUDIOCODES
- ↳ ASTERISK
- ↳ AVST
- ↳ CDR Real time on Ethernet
- ↳ CISCO
- ↳ NGINX
- ↳ NICE
- ↳ Notification Systems
- ↳ OAK
- ↳ SOURCE TECH
- ↳ systel
- ↳ IP Touch apps
- ↳ Click2Dial
- ↳ MYIC apps
- Voice - Virtualization
- ↳ AWS
- ↳ HyperV
- ↳ Linux KVM
- ↳ Proxmox
- ↳ VmWare
- ↳ Other
- Alcatel Unleashed tools, documentations, and misc files...
- ↳ GitHub Script Repository
- ↳ "Home Made" documentations
- ↳ Alcatel Misc Documentation
- ↳ OFFICIAL TC's
- ↳ DIALER
- ↳ infocollect
- ↳ ipview analyzer
- ↳ motview
- ↳ sngrep
- ↳ VM_BACKUP
- ↳ Other Alcatel-Lucent tools
- Developer's corner
- ↳ AHL / OHL
- ↳ Alarming, Notification & Location
- ↳ CCTI / CCA
- ↳ CSTA
- ↳ My IC Phone
- ↳ My IP Touch Service for Enterprise
- ↳ O2G
- ↳ OmniVista 8770 User Provisioning
- ↳ SIP
- ↳ TAPI
- ↳ TSAPI
- ↳ Web Services
- Alcatel Data Equipment
- ↳ Security
- ↳ OmniAccess 3500 Nonstop Laptop Guardian
- ↳ Mobility
- ↳ OmniAccess WLAN Switching Systems
- ↳ OmniAccess WLAN 4302
- ↳ OmniAccess Wireless Access Points 41
- ↳ OmniAccess Wireless Access Points 65
- ↳ OmniAccess Wireless Access Points 60/61/70
- ↳ OmniAccess Wireless Access Points 80M
- ↳ Mobile IP Phones
- ↳ OmniAccess Devices
- ↳ OmniAccess 5780
- ↳ OmniAccess 5740
- ↳ OmniAccess 5510
- ↳ Network Management
- ↳ Omnivista
- ↳ Omnivista Mobility Manager
- DATA - Documentation
- ↳ Technical papers
- ↳ Troubleshooting guides
- DATA - Lan Switching
- ↳ OmniSwitch 10k
- ↳ OmniSwitch 9900
- ↳ OmniSwitch 9000 / 9000E
- ↳ OmniSwitch 6900
- ↳ OmniSwitch 6865
- ↳ OmniSwitch 6870
- ↳ OmniSwitch 6860 / 6860E
- ↳ OmniSwitch 6855
- ↳ OmniSwitch 6850 / 6850E
- ↳ OmniSwitch 6560 / 6570M
- ↳ OmniSwitch 6465
- ↳ OmniSwitch 6450
- ↳ OmniSwitch 6400
- ↳ OmniSwitch 6360
- ↳ OmniSwitch 6350
- ↳ OmniSwitch 6250
- ↳ OmniSwitch 2220
- ↳ OmniSwitch 2260 / 2360
- ↳ Legacy Devices (OS4024, XOS, OmniCore)
- ↳ OmniSwitch 6600 / 7000 / 8800
- ↳ OmniSwitch 6800
- ↳ OmniStack LS 6200
- ↳ Misc
- DATA - WLAN, Mobility and WAN
- ↳ OmniAccess WLAN Switching Systems (OEM)
- ↳ Mobile IPTouch Phones (MIPT)
- ↳ OmniAccess Stellar Express
- ↳ OmniAccess Stellar Enterprise
- ↳ Brick VPN Firewall
- ↳ OmniAccess 5740/5780
- ↳ OmniAccess ESR 5720
- ↳ OmniAccess 5510
- DATA - Network Management
- ↳ OmniVIsta 3600 Air Manager
- ↳ OmniVista 2500 v4.x
- ↳ OmniVista 2500 v3.5
- ↳ OmniVista 2500/2700 v3.4 and older
- ↳ OmniVista Cirrus
- ↳ Alcatel Quarantine Manager
- ↳ Fortigate Security
- DATA - Service Provider
- ↳ 5520 ASAM
- ↳ 5620 SAM
- ↳ 5650 CPAM
- ↳ 5670 RAM
- ↳ 5750 SSC
- ↳ 7210 SAS
- ↳ 7360 ISAM
- ↳ 7450 ESS
- ↳ 7450 Ethernet Service Switch
- ↳ 7750 Service Router
- ↳ 7705 SAR
- ↳ 7750 SR
