OS6560 web management
mtcl
Post by mtcl »
In this OS6560 switch we use SFP-GIG-T in order to connect copper patch cords. We have activated web management, but the application is not working. Ping from the PC doesn't work either.
Please advise
Gleylancer
Re: OS6560 web management
Post by Gleylancer »
Most likely a missing route or misconfiguration of routes. Bit hard to say considering you posted nothing to work with, no configuration, no topology, no information where the client is located.
mtcl
Post by mtcl »
This is the initial configuration, before we send the product to the customer.
This switch will act as core switch where a few OS6360 will be connected
Gleylancer
Please post the configuration, IP Addresses you are using and which interfaces you are connected to.
mtcl
Post by mtcl »
I try with a few ports and different SFPs in order to avoid hardware failure.
I use 192.168.5.205/24 address and my PC is also in the same network. It seems that the ports of the switch are down
Thank you
