Upgrading OS2260 issues
Umer77
Post by Umer77 »
I am having a real issue upgrading an Ominiswitch 2260. I currently have 5.2.44.R01 but want to upgrade this to 5.1.43.R02. I have moved the Aros.img file using WinSCP to the working directory of the switch and removed the old one. I am not sure if I am missing a step, but I have done "reload from working no rollback-timeout". The switch does reboot, however once it has been rebooted I am not able to get into the switch or get the option to login. I have to then manually reboot the switch. Any advice?
Gleylancer
Re: Upgrading OS2260 issues
Post by Gleylancer »
That's a downgrade, 5.1.43.R02 is 2 years old.
You're not saying which method you are using to log in to the switch management after the downgrade. Check the console log while booting to see what's happening, everything else is needless guessing. If you need help, post the console log here.
Umer77
Post by Umer77 »
I am logging into the switch by using Putty and connected using the console port. I will try this again and post the console logs.
mebalat
Re: Upgrading OS2260-48 no PoE
Post by mebalat »
Redémarrage constant du OS2260-48 (non PoE) après configuration incorrecte... Au départ j'avais voulu réinstaller le Switch en étant d'usine mais j'ai supprimé Aros.img et boot à l’aide de WinSCP... :cry:
Bonjour à tous,
Moi aussi je suis sur Putty en port Console.
Je rencontre un problème sérieux avec mon OmniSwitch 2260-48. Après avoir effectué une mauvaise configuration, le switch redémarre constamment et je suis bloqué sur le prompt suivant :
RTL9310# #
Aucune des commandes habituelles comme `enable`, `show`, ou `write erase` ne fonctionne pas.
Voici un extrait des commandes disponibles que je peux utiliser :
? - alias for 'help'
allowRootAccess- allowRootAccess - Allow AOS access as root
base - print or set address offset
bdinfo - print Board Info structure
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
chpart - change active partition
cmp - memory compare
cp - memory copy
crc32 - checksum calculation
env - environment handling commands
erase - erase FLASH memory
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
flerase - Erase flash partition
flinfo - print FLASH memory information
flshow - Show flash partition layout
go - start application at address 'addr'
help - print command description/usage
iminfo - print header information for application image
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mm - memory modify (auto-incrementing address)
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mw - memory write (fill)
nand - NAND sub-system
nand_badblock- test/set block health status
nboot - boot from NAND device
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
printsys- printsys - print system information variables
protect - enable or disable FLASH write protection
reset - Perform RESET of the CPU
reset_all- Perform whole chip RESET of the CPU
rtk - rtk - Realtek commands
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
savesys - savesys - save system information variables
setAdminPasswordDefault- setAdminPasswordDefault - Reset AOS admin user password to default
setenv - set environment variables
setsys - setsys - set system information variables
sleep - delay execution for some time
spi_nand- SPI-NAND sub-system
tftpboot- boot image via network using TFTP protocol
ubi - ubi commands
ubifsload- load file from an UBIFS filesystem
ubifsls - list files in a directory
ubifsmount- mount UBIFS volume
ubifsumount- unmount UBIFS volume
upgrade - Upgrade loader or runtime image
usb - USB sub-system
usbboot - boot from USB device
version - print monitor, compiler and linker version
J'ai essayé plusieurs commandes pour réinitialiser ou charger une nouvelle configuration, mais rien ne semble fonctionner. Je n'ai pas encore téléchargé d'image de firmware pour essayer de la recharger via TFTP.
1. Est-ce que quelqu'un peut me guider sur les étapes à suivre pour télécharger et charger une nouvelle image de firmware via TFTP ?
2. Y a-t-il des étapes spécifiques que j'aurais manquées ou des conseils pour éviter que le switch redémarre constamment ?
Merci d'avance pour votre aide !
Return to “OmniSwitch 2260 / 2360”
