Load balancing and L2VPN
Ryland
Post by Ryland »
I am a French engineering student currently working on a project to build an MPLS backbone (VPLS). My objective is to implement ECMP (Equal Cost Multipath) and entropy label-based load balancing. Although everything seems to be functioning correctly, I am encountering an issue when attempting to send traffic from CE1 to CE2 (as depicted in the figure [https://meslab.freeboxos.fr/share/VpRqK ... finale.png]). Router P1 does not seem to perform load balancing in this particular scenario. However, when the traffic originates from PE1 to PE2, load balancing works properly on P1.
The lab environment I am using is EVE NG, and the routers in question are 7750 SR . I would greatly appreciate your assistance in resolving this problem.
Thank you for your attention to this matter.
Return to “GENERAL”
