Incidents SYNCHRONIZATION
aflores
Post by aflores »
Hello Friends, Hope all you are fine.
Have an issue with an OV4760 rel: 5.2.01.04
Have two nodes declared.
The incidents synchronization only work fine with one node.
On Directory menu, I can see both nodes, I can also administrate the configiration of both too.
I can make calls reports of both nodes.
In the Alarms Menu I can only see one node.
I have compare both configuration on Directory Menu and all configuration are OK.
Any hint will be apreccated.
regards.
AFLORES
Re: Incidents SYNCHRONIZATION
Hello Aflores
Compare the event routing discriminator in both oxe
aflores
Post by aflores »
Hello Haroum.
When I tryed to see the event routing discriminator on the node that did not appear on Omnivista Alarmams I got the windows that says:
Error: Press CANCEL to remove this window
Got no answer
This node has twin configuration so I basculled and got the same error on the twin (now became master) CPU.
This is a Common Hardware configuration.
The systems wich is is working fine, is and Appliance Servers with duplication too.
Any suggestion?
AFlores
Return to “OmniVista 4760”
