Please help OS6900-V72
midwestbob2000
Post by midwestbob2000 »
I have a OS6900-V72 and I need to use some of the ports at 1GB as some of my older edge switches on have 1GB uplinks. The documentation does not specifically say the V72 is capable of 1GB on ports 1-48. Could someone please tell me definitively whether this is possible or not?
Thanks you in advance for any help!
Jim
Re: Please help OS6900-V72
In the transciver guide page 81 you find the answer. No 1Gig-module is there supported. You need an other switch (connected via 10G) to use there the 1G ports.
midwestbob2000
Thanks so much for your help Silvio!
Jim
Return to “OmniSwitch 6900”
