Logs are not displayed in console port
zepeki
Post by zepeki »
My problem is that I don't see any log on my switch 2260 in console port. This is not the case when I connect to an Aos6 switch. Even by inserting the command "swlog console level info" or other, it does not change anything.
Thanks in advance for your help.
Sincerely
Zepeki
Re: Logs are not displayed in console port
You need an other adapter and other serial speed. Adapter like Cisco (or Alcatel OAW-controller) and speed 115.200 baud.
Return to “OmniSwitch 2260 / 2360”
