Using of GCID from SIP message
nikolai_chashchin
Post by nikolai_chashchin »
I'm new to ALE. And there are so many things to check out regarding ALE and solutions that it provides so I would appreciate if you can give me a direction to go.
I'm working on an integration solution that should allow to get RTP stream along with some call information from OXE PBX using SIP Trunk.
As per documentation that I was able to find there is an option to get so called GCID identifier for a call from SIP INVITE message that can be used to
retrieve extra information from the PBX about the call that is not available in SIP message. For my purpose I need to retrieve caller/calee identifier.
I was suggested to use CSTA to retreive the information i need. So I checked this https://www.al-enterprise.com/en/partners/dspp and this https://api.dspp.al-enterprise.com/. At https://api.dspp.al-enterprise.com/ i found some Api documentation for CSTA for OXE but no sdk. I would preferably use Golang to communicate with PBX. Can you please tell if there is an sdk at all? Or maybe I should not use CSTA at all for my purpose? Or do my company need to become a partner as per https://www.al-enterprise.com/en/partners/dspp to get access to sdks?
Is there a sandbox environment that I can use to test the scenario I have just shared?
Thanks!
Best,
Nikolai
Re: Using of GCID from SIP message
Hi Nikolai,
You can request the DSPP to give you a sandbox.
I would recommend using their O2G API for what you need (https://api.dspp.al-enterprise.com/omni ... teway-02g/)
Return to “CSTA”
