Hi all
i have problem in oxe , i created user extension sip , but upon entering information (server sip and login + password) failed connected .
i have licence extension sip 1/93 and And connectivity test ping between ALE-2 and Oxe goes very well
Help sip extension ale-2 not registered alcatel oxe
proomh
Re: Help sip extension ale-2 not registered alcatel oxe
Problem has been solved but problem has emerged communication failure in phones
> 12/01/22 - 09:29:51 Minor alarm
[CSubscriptionState::receiveSubscribeMessage] Call: 0931647e eqt: -1 SUBSCRIPTION_STATE failed to emit a Query event.
> 12/01/22 - 12:11:17 Minor alarm
[CSubscriptionState::receiveSubscribeMessage] Call: 9c844d15 eqt: -1 SUBSCRIPTION_STATE failed to emit a Query event.
> 12/01/22 - 12:11:48 Minor alarm
[CSubscriptionState::receiveSubscribeMessage] Call: c8b0692c eqt: -1 SUBSCRIPTION_STATE failed to emit a Query event.
You need to run a sipmotor trace to check why that alarm is being triggered
BRegards
BRegards
proomh
I made a connection between 8977 to 8013 that did not open a communication channel as shown at the bottom.
********************************* TRACE OPTIONS USED IN THIS FILE ****************************************
motortrace 8
traced -a +motor -f 99 -s 10000000 -1 /tmpd/OMtrace0512SIP_05_Dec_22-105354/Sip_Motor_Traces/xa000000_SIP_105344 -d &
1670237637 -> Mon Dec 5 10:53:56 2022 Degraded mode activated : No
Mon Dec 5 10:53:56 2022 -------------------------------------------
Mon Dec 5 10:53:56 2022 [fnInit] *************************** Init timeout.
Mon Dec 5 10:53:56 2022 [fnInit] treatTimeout.
Mon Dec 5 10:53:56 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:53:56 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:53:56 2022 [startRegistration] timer value=6000.
Mon Dec 5 10:53:57 2022 102 [CCallManager::removeGarbage] at index i = 0
Mon Dec 5 10:53:57 2022 117c [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:53:57 2022 117c[CMotorCall::~CMotorCall] Call : 7c4075f1 is being destructed.
Mon Dec 5 10:53:57 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
Mon Dec 5 10:53:57 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:53:57 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:53:57 2022 117c [CCall::~CCall] resources number: 142
Mon Dec 5 10:53:57 2022 117c [CCall::TestDegradedModeEnd] resources number: 141
Mon Dec 5 10:53:57 2022 117c [CCall::removeGarbage]
Mon Dec 5 10:53:57 2022 156c [CDialog::~CDialog] resources number: 280
Mon Dec 5 10:53:57 2022 [CResponse::~CResponse]
Mon Dec 5 10:53:57 2022 35C89 [~CResponse] resp(200) 7c4075f1 318368361 OPTIONS
Mon Dec 5 10:53:57 2022 [CRequest::~CRequest]
1670237638 -> Mon Dec 5 10:53:57 2022 35720 [~CRequest] req 7c4075f1 318368361 OPTIONS
Mon Dec 5 10:53:57 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:53:57 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:53:57 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:53:57 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:53:57 2022 [CCall::~CCall] Ends
Mon Dec 5 10:53:58 2022 214c [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:53:58 2022 214c [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:53:58 2022 214c [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:58 2022 214c [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
Mon Dec 5 10:53:58 2022 214d [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:53:58 2022 214d [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:53:58 2022 214d [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:58 2022 214d [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
Mon Dec 5 10:53:58 2022 214e [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:53:58 2022 214e [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:53:58 2022 214e [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:58 2022 214e [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
1670237638 -> Mon Dec 5 10:53:58 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:53:58 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:53:58 2022 15a6 [CDialog::onTransactionState(pTrans = 214c, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:53:58 2022 214C [~CTransaction] transaction 367136563 NOTIFY
Mon Dec 5 10:53:58 2022 [CResponse::~CResponse]
Mon Dec 5 10:53:58 2022 35C91 [~CResponse] resp(200) 156b5267 367136563 NOTIFY
Mon Dec 5 10:53:58 2022 [CRequest::~CRequest]
Mon Dec 5 10:53:58 2022 35727 [~CRequest] req 156b5267 367136563 NOTIFY
Mon Dec 5 10:53:58 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:53:58 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:53:58 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:53:58 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:53:58 2022 15a6 [CDialog::onTransactionState(pTrans = 214d, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:53:58 2022 214D [~CTransaction] transaction 367136564 NOTIFY
Mon Dec 5 10:53:58 2022 35C92 [~CResponse] resp(200) 156b5267 367136564 NOTIFY
Mon Dec 5 10:53:58 2022 35728 [~CRequest] req 156b5267 367136564 NOTIFY
1670237638 -> Mon Dec 5 10:53:58 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:53:58 2022 15a6 [CDialog::onTransactionState(pTrans = 214e, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:53:58 2022 214E [~CTransaction] transaction 367136565 NOTIFY
Mon Dec 5 10:53:58 2022 35C93 [~CResponse] resp(200) 156b5267 367136565 NOTIFY
Mon Dec 5 10:53:58 2022 2150 [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:53:58 2022 2150 [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:53:58 2022 2150 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:58 2022 2150 [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
1670237639 -> Mon Dec 5 10:53:58 2022 15a4 [CDialog::onTransactionState(pTrans = 2150, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:53:58 2022 2150 [~CTransaction] transaction 212720029 NOTIFY
Mon Dec 5 10:53:58 2022 35C95 [~CResponse] resp(200) 4f783cda 212720029 NOTIFY
1670237639 -> Mon Dec 5 10:53:59 2022 udp_recv fd:5
Mon Dec 5 10:53:59 2022 udp_recv fd:5 iBytesRead:578
Mon Dec 5 10:53:59 2022 UdpInputProc iSock:5 iBytesRead:578 Host:192.168.1.181 Port:5060
Mon Dec 5 10:53:59 2022 [CTransportUdp::receiveMessage] from 192.168.1.181:5060 rc:578
Mon Dec 5 10:53:59 2022 [CTransport::findConnection] pConnection = 779b remoteHost=192.168.1.181, remotePort=5060
Mon Dec 5 10:53:59 2022 [CIOCom::onReceiveMessage] received from 192.168.1.181:5060, proto=0, length=578, mtls = 0
Mon Dec 5 10:53:59 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.181:5060 [UDP])
BYE sip:192.168.1.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.181;branch=z9hG4bK0dc18529f50188176
Max-Forwards: 70
From: "Hajib" <sip:8302@oxe.ma:5060>;tag=50f72f941b
To: "3" <sip:3@oxe.ma:5060>;tag=305ffc499e8dbb3b77dae75426e4b459
Call-ID: 9da148ce
CSeq: 1500548361 BYE
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, PUBLISH, REFER, REGISTER, SUBSCRIBE, UPDATE
Allow-Events: conference, refer, talk, hold
Supported: 100rel, eventlist, join, replaces, sdp-anat, tdialog
User-Agent: ALE ALE-2 2.12.20.000.2036 3c28a608b7bd
Content-Length: 0
Mon Dec 5 10:53:59 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:53:59 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:53:59 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:53:59 2022 3572E [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
1670237639 -> Mon Dec 5 10:53:59 2022 [CIOCom::receiveRequest] Received CRequest 3572E ref=1
Mon Dec 5 10:53:59 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.181 alcResult= 0
Mon Dec 5 10:53:59 2022 [CIOCom::receiveRequest] rport1 not empty
Mon Dec 5 10:53:59 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:53:59 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:53:59 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:53:59 2022 117a [CCall::receiveRequest] BYE
Mon Dec 5 10:53:59 2022 117a [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:53:59 2022 156b [CDialog::receiveRequest]
Mon Dec 5 10:53:59 2022 156b [CDialog::receiveBasicRequest]
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:53:59 2022 156b [CDialog::onTransactionState(pTrans = 2153, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:53:59 2022 2153 [CTransInitialState::receiveRequest] Transaction changes to Trying state
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:53:59 2022 156b [CDialog::onTransactionState(pTrans = 2153, previousState = Initial, currentState = Trying, reason = Request reception]
1670237639 -> Mon Dec 5 10:53:59 2022 156b [CDialog::addTransaction] added transaction 2153 with branch z9hG4bK0dc18529f50188176, with CSeq 1500548361
Mon Dec 5 10:53:59 2022 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Mon Dec 5 10:53:59 2022 117a [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:53:59 2022 117a [CCall::checkAuthentication] BYE
Mon Dec 5 10:53:59 2022 117a[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:53:59 2022 117a[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:53:59 2022 117a [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:53:59 2022 117a [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:53:59 2022 117a [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:53:59 2022 117a [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:53:59 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:53:59 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onReceiveRequest] state = COMPLETED_STATE.
Mon Dec 5 10:53:59 2022 [receiveByeMessage] Call: 9da148ce eqt: 1448 COMPLETED_STATE received a message.
Mon Dec 5 10:53:59 2022 [CGenericState::getAOCInfo] INFO NULL content !!!
Mon Dec 5 10:53:59 2022 117a[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
1670237639 -> Mon Dec 5 10:53:59 2022 117a[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:53:59 2022 117a[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:53:59 2022 117a[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:53:59 2022 ** SEPLOS **
Mon Dec 5 10:53:59 2022 [sendLgEvtSip] seplos Event sent on eqt : 1448 Id :1
Mon Dec 5 10:53:59 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:53:59 2022 Id : 1
Mon Dec 5 10:53:59 2022 BYE
Mon Dec 5 10:53:59 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:53:59 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:53:59 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:53:59 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:53:59 2022 [exec_ipc] in 5615.
Mon Dec 5 10:53:59 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:53:59 2022 neqt : 1448 Id : 1
Mon Dec 5 10:53:59 2022 SUCCESSFUL
Mon Dec 5 10:53:59 2022 xx : 0
Mon Dec 5 10:53:59 2022 RELATIVE REQUEST : BYE
Mon Dec 5 10:53:59 2022 CLIR : 0
Mon Dec 5 10:53:59 2022 COLP : 0
Mon Dec 5 10:53:59 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:53:59 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1448 1.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] seplos station.
1670237639 -> Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Mon Dec 5 10:53:59 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:53:59 2022 [onIncomingEvent] relative_request = 10755
Mon Dec 5 10:53:59 2022 [receiveSuccessfulEvent] Call: 9da148ce eqt: 1448 TERMINATED_STATE received an event.
Mon Dec 5 10:53:59 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
Mon Dec 5 10:53:59 2022 156b [CCall::findFirstServerTrans]
Mon Dec 5 10:53:59 2022 156b [CCallLeg::findFirstOpenServerTrans] Current Request in transactionMapByBranch
Mon Dec 5 10:53:59 2022 117a [CCall::makeGenericResponse] 200
Mon Dec 5 10:53:59 2022 156b [CDialog::createResponse] 200
Mon Dec 5 10:53:59 2022 2153 [CTransTryingState::createResponse] CResponse 35C98 ref=1
Mon Dec 5 10:53:59 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:53:59 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:53:59 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:53:59 2022 35C98 [CMessage::send] sip_sendMessage (192.168.1.181:5060)
Mon Dec 5 10:53:59 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:53:59 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 434)
SIP/2.0 200 OK
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
Supported: replaces,timer,path,100rel
User-Agent: OmniPCX Enterprise R100.0 n1.291.68.a
Call-ID: 9da148ce
Content-Length: 0
1670237639 -> Mon Dec 5 10:53:59 2022 [CTransport::findConnection] pConnection = 779b remoteHost=192.168.1.181, remotePort=5060
Mon Dec 5 10:53:59 2022 [CTransport::getConnection] RemoteHost=(192.168.1.181 5060) already exist, using connection 779b
Mon Dec 5 10:53:59 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:53:59 2022 udp_send fd:3
Mon Dec 5 10:53:59 2022 udp_send fd:3 port 5060 iBytesSend:434
Mon Dec 5 10:53:59 2022 779b [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:53:59 2022 35C98 [CMessage::onSendSuccess]
Mon Dec 5 10:53:59 2022 2153 [CTransaction::onSendSuccess] CMessage 35C98 send Success
Mon Dec 5 10:53:59 2022 156b [CDialog::onSendSuccess]
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:53:59 2022 2153 [CTransTryingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:53:59 2022 156b [CDialog::onTransactionState(pTrans = 2153, previousState = Trying, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:53:59 2022 2153 [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
Mon Dec 5 10:53:59 2022 156b [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:53:59 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:53:59 2022 [ipc_thread] Normal case : evt 10773
1670237639 -> Mon Dec 5 10:53:59 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:53:59 2022 SIP EQT RELEASED
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1448 1.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1448 has released its equipment.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::unRegister] Remove eqt : 1448 diag : 1 from the map.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::eraseCallwithEqt] erase 1448 1.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] killSession.
Mon Dec 5 10:53:59 2022 117a [CCall::killSession]
Mon Dec 5 10:53:59 2022 2140 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:59 2022 2140 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:59 2022 2153 [CTransaction::freeTimerToken] Timer J is freed
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] no transaction state, terminated reason : None
1670237639 -> Mon Dec 5 10:53:59 2022 156b [CDialog::removeSubscriptionTimer]
Mon Dec 5 10:53:59 2022 117a [CCall::killSession] notifying the call manager
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed]
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed()] Call 117a closed. Removing call 148946336 from the maps
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onNotifyCallClosed] Call : 9da148ce is closed.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onNotifyCallClosed] call processResponse.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::chooseBestResponse] pForkedBranch=0x8e113d0 iResponseCode=2000.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::processResponse] no response found.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed] pCall: 117a added in the Garbage List
Mon Dec 5 10:53:59 2022 [ipc_thread] Normal case : evt 10755
Mon Dec 5 10:53:59 2022 neqt : 1443 Id : 1
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] an event 10755 arrived on the eqt 1443 1.
1670237639 -> Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] state = COMPLETED_STATE.
Mon Dec 5 10:53:59 2022 [onIncomingEvent] BYE arrived.
Mon Dec 5 10:53:59 2022 [receiveByeEvent] Call: 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 eqt: 1443 COMPLETED_STATE received an event.
Mon Dec 5 10:53:59 2022 117b [CCall::makeGenericRequest] BYE
Mon Dec 5 10:53:59 2022 117b [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:53:59 2022 156a [CDialog::createRequest]
Mon Dec 5 10:53:59 2022 156a [CDialog::buildServicesForAllRequest]
Mon Dec 5 10:53:59 2022 156a [CDialog::createByeRequest]
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:53:59 2022 156a [CDialog::onTransactionState(pTrans = 2154, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:53:59 2022 3572F [CRequest::CRequest] Creation of a request
Mon Dec 5 10:53:59 2022 [DBG: CRequest::freeAttributes]
Mon Dec 5 10:53:59 2022 [DBG: CRequest::freeAttributes Ends]
Mon Dec 5 10:53:59 2022 CRequest::createRequestLine Protocol UDP
Mon Dec 5 10:53:59 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
1670237639 -> Mon Dec 5 10:53:59 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:53:59 2022 3572F [CMessage::send] sip_sendMessage (192.168.1.172:5060)
Mon Dec 5 10:53:59 2022 SEND MESSAGE TO NETWORK (192.168.1.172:5060 [UDP]) (BUFF LEN = 483)
BYE sip:8509@192.168.1.172:5060;transport=udp SIP/2.0
To: <sip:8509@192.168.1.10:5060;user=phone>;tag=1482112415
From: <sip:8302@192.168.1.10:5060;user=phone>;tag=3f2f68783cec4fdfdd1ee8455c837780
Call-ID: 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10
CSeq: 377336083 BYE
Via: SIP/2.0/UDP 192.168.1.10;branch=z9hG4bKc1a8c56db81cd512ce06d34a9735e809
Max-Forwards: 70
Content-Length: 0
Mon Dec 5 10:53:59 2022 [CTransport::findConnection] pConnection = f47 remoteHost=192.168.1.172, remotePort=5060
Mon Dec 5 10:53:59 2022 [CTransport::getConnection] RemoteHost=(192.168.1.172 5060) already exist, using connection f47
Mon Dec 5 10:53:59 2022 udp_send fd:5
Mon Dec 5 10:53:59 2022 udp_send fd:5 port 5060 iBytesSend:483
Mon Dec 5 10:53:59 2022 f47 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:53:59 2022 3572F [CMessage::onSendSuccess]
Mon Dec 5 10:53:59 2022 2154 [CTransaction::onSendSuccess] CMessage 3572F send Success
1670237639 -> Mon Dec 5 10:53:59 2022 156a [CDialog::onSendSuccess]
Mon Dec 5 10:53:59 2022 117b[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:53:59 2022 2154 [CTransInitialState::createRequest] Transaction changes to Trying state
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:53:59 2022 156a [CDialog::onTransactionState(pTrans = 2154, previousState = Initial, currentState = Trying, reason = Request creation]
Mon Dec 5 10:53:59 2022 2154 [CTransTryingState::enterInState] Init timers E and F
Mon Dec 5 10:53:59 2022 2154 [CTransaction::startTimer] Timer E is started (delay = 500 ms)
Mon Dec 5 10:53:59 2022 2154 [CTransaction::startTimer] Timer F is started (delay = 16000 ms)
Mon Dec 5 10:53:59 2022 156a [CDialog::addTransaction] added transaction 2154 with branch z9hG4bKc1a8c56db81cd512ce06d34a9735e809, with CSeq 377336083
Mon Dec 5 10:53:59 2022 117b[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:53:59 2022 udp_recv fd:5 iBytesRead:563
Mon Dec 5 10:53:59 2022 UdpInputProc iSock:5 iBytesRead:563 Host:192.168.1.172 Port:5060
Mon Dec 5 10:53:59 2022 [CTransportUdp::receiveMessage] from 192.168.1.172:5060 rc:563
1670237639 -> Mon Dec 5 10:53:59 2022 [CTransport::findConnection] pConnection = f47 remoteHost=192.168.1.172, remotePort=5060
Mon Dec 5 10:53:59 2022 [CIOCom::onReceiveMessage] received from 192.168.1.172:5060, proto=0, length=563, mtls = 0
Mon Dec 5 10:53:59 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.172:5060 [UDP])
SIP/2.0 200 OK
CSeq: 377336083 BYE
Content-Length: 0
Mon Dec 5 10:53:59 2022 [CIOCom::receiveResponse] CResponse 35C99 ref=1
Mon Dec 5 10:53:59 2022 [CDispatcher::processResponseFromManagerIndex] start at index 0
Mon Dec 5 10:53:59 2022 102 [CCallManager::onIncomingResponse]
Mon Dec 5 10:53:59 2022 117b [CCall::receiveResponse] 200
1670237639 -> Mon Dec 5 10:53:59 2022 156a [CDialog::receiveResponse]
Mon Dec 5 10:53:59 2022 2154 [CTransTryingState::receiveResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:53:59 2022 156a [CDialog::onTransactionState(pTrans = 2154, previousState = Trying, currentState = Completed, reason = Final resp reception]
Mon Dec 5 10:53:59 2022 2154 [CTransaction::freeTimerToken] Timer E is freed
Mon Dec 5 10:53:59 2022 2154 [CTransaction::freeTimerToken] Timer F is freed
Mon Dec 5 10:53:59 2022 2154 [CTransaction::startTimer] Timer K is started (delay = 5000 ms)
Mon Dec 5 10:53:59 2022 117b[CMotorCall::onReceiveResponse] Update2 the Other context.
Mon Dec 5 10:53:59 2022 [CTerminatedState::receiveSuccessfulMessage] Call: 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 eqt: 1443 TERMINATED_STATE received a message.
Mon Dec 5 10:53:59 2022 [CTerminatedState::receiveSuccessfulMessage] relative request: 2
Mon Dec 5 10:53:59 2022 117b[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:53:59 2022 117b[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:53:59 2022 117b[emitEventToMonitel] cacUsed=0 eqtCac=-1
1670237639 -> Mon Dec 5 10:53:59 2022 117b[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:53:59 2022 [sendLgEvtSip] seplos Event sent on eqt : 1443 Id :1
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1443 1.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1443 has released its equipment.
1670237639 -> Mon Dec 5 10:53:59 2022 117b[CMotorCall::unRegister] Remove eqt : 1443 diag : 1 from the map.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::eraseCallwithEqt] erase 1443 1.
Mon Dec 5 10:53:59 2022 117b [CCall::killSession]
Mon Dec 5 10:53:59 2022 2141 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:59 2022 2141 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:59 2022 2154 [CTransaction::freeTimerToken] Timer K is freed
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:53:59 2022 156a [CDialog::removeSubscriptionTimer]
Mon Dec 5 10:53:59 2022 117b [CCall::killSession] notifying the call manager
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed()] Call 117b closed. Removing call 148763224 from the maps
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onNotifyCallClosed] Call : 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 is closed.
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed] pCall: 117b added in the Garbage List
Mon Dec 5 10:53:59 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:53:59 2022 [CTransaction::notifyDialog] notify parent dialog
1670237639 -> Mon Dec 5 10:53:59 2022 1568 [CDialog::onTransactionState(pTrans = 2140, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:53:59 2022 1568 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:53:59 2022 1568 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed]
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed] not only initial *********
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed]: the dialog 156b is NOT closed
Mon Dec 5 10:53:59 2022 2140 [~CTransaction] transaction 1500548360 INVITE
Mon Dec 5 10:53:59 2022 [CResponse::~CResponse]
Mon Dec 5 10:53:59 2022 35C82 [~CResponse] resp(180) 9da148ce 1500548360 INVITE
Mon Dec 5 10:53:59 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:53:59 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:53:59 2022 156b [CDialog::onTransactionState(pTrans = 2153, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed]: the dialog 156b is closed
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed] All the dialogs in the Call are closed
Mon Dec 5 10:53:59 2022 2153 [~CTransaction] transaction 1500548361 BYE
1670237639 -> Mon Dec 5 10:53:59 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:53:59 2022 1569 [CDialog::onTransactionState(pTrans = 2141, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:53:59 2022 1569 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:53:59 2022 1569 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed]
Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed] not only initial *********
Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed]: the dialog 156a is NOT closed
Mon Dec 5 10:53:59 2022 2141 [~CTransaction] transaction 377336082 INVITE
Mon Dec 5 10:53:59 2022 35C83 [~CResponse] resp(180) 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336082 INVITE
Mon Dec 5 10:53:59 2022 156a [CDialog::onTransactionState(pTrans = 2154, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed]: the dialog 156a is closed
1670237640 -> Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed] All the dialogs in the Call are closed
Mon Dec 5 10:53:59 2022 2154 [~CTransaction] transaction 377336083 BYE
Mon Dec 5 10:53:59 2022 35C99 [~CResponse] resp(200) 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336083 BYE
Mon Dec 5 10:54:00 2022 102 [CCallManager::removeGarbage] at index i = 1
Mon Dec 5 10:54:00 2022 117b [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:00 2022 117b[CMotorCall::~CMotorCall] Call : 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 is being destructed.
Mon Dec 5 10:54:00 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
Mon Dec 5 10:54:00 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:00 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:00 2022 117b [CCall::~CCall] resources number: 141
Mon Dec 5 10:54:00 2022 117b [CCall::TestDegradedModeEnd] resources number: 140
Mon Dec 5 10:54:00 2022 117b [CCall::removeGarbage]
Mon Dec 5 10:54:00 2022 156a [CDialog::~CDialog] resources number: 279
Mon Dec 5 10:54:00 2022 156a [~CDialog] delete ack request # 0
1670237640 -> Mon Dec 5 10:54:00 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:00 2022 3571C [~CRequest] req 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336082 ACK
Mon Dec 5 10:54:00 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:00 2022 35C85 [~CResponse] resp(200) 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336082 INVITE
Mon Dec 5 10:54:00 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:00 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:00 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:00 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:00 2022 1569 [CDialog::~CDialog] resources number: 278
Mon Dec 5 10:54:00 2022 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Mon Dec 5 10:54:00 2022 3571A [~CRequest] req 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336082 INVITE
Mon Dec 5 10:54:00 2022 3572F [~CRequest] req 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336083 BYE
Mon Dec 5 10:54:00 2022 [CCall::~CCall] Ends
Mon Dec 5 10:54:00 2022 102 [CCallManager::removeGarbage] at index i = 0
1670237640 -> Mon Dec 5 10:54:00 2022 117a [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:00 2022 117a[CMotorCall::~CMotorCall] Call : 9da148ce is being destructed.
Mon Dec 5 10:54:00 2022 117a [CCall::~CCall] resources number: 140
Mon Dec 5 10:54:00 2022 117a [CCall::TestDegradedModeEnd] resources number: 139
Mon Dec 5 10:54:00 2022 117a [CCall::removeGarbage]
Mon Dec 5 10:54:00 2022 156b [CDialog::~CDialog] resources number: 277
Mon Dec 5 10:54:00 2022 1568 [CDialog::~CDialog] resources number: 276
Mon Dec 5 10:54:00 2022 35C86 [~CResponse] resp(200) 9da148ce 1500548360 INVITE
Mon Dec 5 10:54:00 2022 35719 [~CRequest] req 9da148ce 1500548360 INVITE
1670237642 -> Mon Dec 5 10:54:00 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:00 2022 35C98 [~CResponse] resp(200) 9da148ce 1500548361 BYE
Mon Dec 5 10:54:00 2022 3572E [~CRequest] req 9da148ce 1500548361 BYE
Mon Dec 5 10:54:02 2022 udp_recv fd:5
Mon Dec 5 10:54:02 2022 udp_recv fd:5 iBytesRead:2
Mon Dec 5 10:54:02 2022 UdpInputProc iSock:5 iBytesRead:2 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:02 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:2
Mon Dec 5 10:54:02 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:02 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=2, mtls = 0
Mon Dec 5 10:54:02 2022 [CKeepaliveManager::receiveSignal]
Mon Dec 5 10:54:02 2022 udp_recv fd:5 iBytesRead:1055
Mon Dec 5 10:54:02 2022 UdpInputProc iSock:5 iBytesRead:1055 Host:192.168.1.181 Port:5060
Mon Dec 5 10:54:02 2022 [CTransportUdp::receiveMessage] from 192.168.1.181:5060 rc:1055
1670237642 -> Mon Dec 5 10:54:02 2022 [CTransport::findConnection] pConnection = 779b remoteHost=192.168.1.181, remotePort=5060
Mon Dec 5 10:54:02 2022 [CIOCom::onReceiveMessage] received from 192.168.1.181:5060, proto=0, length=1055, mtls = 0
Mon Dec 5 10:54:02 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.181:5060 [UDP])
INVITE sip:8008@oxe.ma:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.181;branch=z9hG4bK5a8f8d314c36aa2d2
Max-Forwards: 70
From: "Hajib" <sip:8302@oxe.ma:5060>;tag=61f4317ecd
To: "8008" <sip:8008@oxe.ma:5060>
Call-ID: c706eb47
CSeq: 1090543851 INVITE
Contact: <sip:8302@192.168.1.181:5060;transport=udp>
Content-Disposition: session
Content-Type: application/sdp
Content-Length: 386
v=0
o=- 2269360466076651974 2269360466076651975 IN IP4 192.168.1.181
s=SDP data
c=IN IP4 192.168.1.181
t=0 0
m=audio 6000 RTP/AVP 8 0 18 9 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:9 G722/8000
a=rtpmap:101 telephone-event/8000
a=silenceSupp:off - - - -
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=mptime:20 20 20 20 -
a=sendrecv
Mon Dec 5 10:54:02 2022 [CIOCom::receiveRequest] optimisation value 1
1670237642 -> Mon Dec 5 10:54:02 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:02 2022 35730 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:02 2022 [CIOCom::receiveRequest] Received CRequest 35730 ref=1
Mon Dec 5 10:54:02 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.181 alcResult= 0
Mon Dec 5 10:54:02 2022 [CIOCom::receiveRequest] rport1 not empty
Mon Dec 5 10:54:02 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:02 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:02 2022 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
Mon Dec 5 10:54:02 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:02 2022 [CMotorCallManager::callFactory] For call : c706eb47.
Mon Dec 5 10:54:02 2022 1180 [CCall::CCall] resources number: 141
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:02 2022 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.68.a
Mon Dec 5 10:54:02 2022 [CMotorCallManager::callFactory]=8dc7868.
Mon Dec 5 10:54:02 2022 1180 [CCall::receiveRequest] INVITE
Mon Dec 5 10:54:02 2022 1180 [CCall::getDialog] Confirmed Dialog is not found (ID = ;61f4317ecd)
Mon Dec 5 10:54:02 2022 1180 [CCall::getDialog] Initial Dialog Server not found
Mon Dec 5 10:54:02 2022 1570 [CDialog::CDialog] resources number: 277
1670237642 -> Mon Dec 5 10:54:02 2022 1570 [CDialog::receiveRequest]
Mon Dec 5 10:54:02 2022 1570 [CDialog::receiveInviteRequest]
Mon Dec 5 10:54:02 2022 2155 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:02 2022 2155 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:02 2022 1570 [CDialog::onTransactionState(pTrans = 2155, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:02 2022 2155 [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Dec 5 10:54:02 2022 2155 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:02 2022 1570 [CDialog::onTransactionState(pTrans = 2155, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Dec 5 10:54:02 2022 2155 [CTransProceedingState::createResponse] CResponse 35C9A ref=1
Mon Dec 5 10:54:02 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:02 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:02 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:02 2022 35C9A [CMessage::send] sip_sendMessage (192.168.1.181:5060)
Mon Dec 5 10:54:02 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:02 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 237)
SIP/2.0 100 Trying
Call-ID: c706eb47
Content-Length: 0
Mon Dec 5 10:54:02 2022 [CTransport::getConnection] RemoteHost=(192.168.1.181 5060) already exist, using connection 779b
Mon Dec 5 10:54:02 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:02 2022 udp_send fd:3
Mon Dec 5 10:54:02 2022 udp_send fd:3 port 5060 iBytesSend:237
Mon Dec 5 10:54:02 2022 779b [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:02 2022 35C9A [CMessage::onSendSuccess]
Mon Dec 5 10:54:02 2022 2155 [CTransaction::onSendSuccess] CMessage 35C9A send Success
Mon Dec 5 10:54:02 2022 1570 [CDialog::onSendSuccess]
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:02 2022 1570 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 0
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:02 2022 1570 [CDialog::addTransaction] added transaction 2155 with branch z9hG4bK5a8f8d314c36aa2d2, with CSeq 1090543851
Mon Dec 5 10:54:02 2022 1180 [CCall::receiveRequest] iErrorCode=488.
1670237642 -> Mon Dec 5 10:54:02 2022 1180 [CCall::checkAuthentication] INVITE
Mon Dec 5 10:54:02 2022 1180[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:02 2022 [getFromHeader] look at the From.
Mon Dec 5 10:54:02 2022 [getFromHeader] displayName="Hajib".
Mon Dec 5 10:54:02 2022 [convertCSipURLIntoSipuri] uri = sip:8302@oxe.ma:5060.
Mon Dec 5 10:54:02 2022 [getFromHeader] =8302@oxe.ma.
Mon Dec 5 10:54:02 2022 [getFromHeader] clirPresent=0.
Mon Dec 5 10:54:02 2022 [getReqUriHeader] look at the requri.
Mon Dec 5 10:54:02 2022 [convertCSipURLIntoSipuri] uri = sip:8008@oxe.ma:5060.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::getUserType] extGw=-1.
Mon Dec 5 10:54:02 2022 [CMotorCall::analyseRouting] TEL uri=0.
Mon Dec 5 10:54:02 2022 [CMotorCall::analyseRouting] 8302@oxe.ma is authenticable.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setExtGw] -1->-3
Mon Dec 5 10:54:02 2022 [isUserInDico] looking for 8302@oxe.ma ...
Mon Dec 5 10:54:02 2022 [isUserInDico] found in the dictionnary.
Mon Dec 5 10:54:02 2022 [isAddrInDico] seplos station OK
Mon Dec 5 10:54:02 2022 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::getUserType] From is seplos station crypto=0.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::getUserType] extGw=-3.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::controlAuthentication] m_other_calling=0 extgw=-3
1670237642 -> Mon Dec 5 10:54:02 2022 1180[CMotorCall::controlAuthentication] from:sip:8302@oxe.ma:5060
Mon Dec 5 10:54:02 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:02 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:02 2022 [CGwMngData::isAuthenticationRequiredForThisClient] 8302@192.168.1.10 .
Mon Dec 5 10:54:02 2022 [CGwMngData::isAuthenticationRequiredForThisClient] -3 need auth=0.
Mon Dec 5 10:54:02 2022 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway -3.
Mon Dec 5 10:54:02 2022 CGwMngData::isAuthenticationRequiredForThisClient: gateway=-3
Mon Dec 5 10:54:02 2022 1180[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setExtGw] -3->-3
Mon Dec 5 10:54:02 2022 1180 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:02 2022 1180 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:02 2022 1180 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:02 2022 1180 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setFilterUsedMode] To be traced = 0
1670237642 -> Mon Dec 5 10:54:02 2022 1180[CMotorCall::initOfUserType] station role already defined s=1 d=0 o=0.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onReceiveRequest] accepte? m_other_calling=0 gw=-1.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=2.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::toGatewayOrProxy] request for proxydomain=oxe.ma.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::toGatewayOrProxy] from = seplos station.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] nb available licenses=0 .
Mon Dec 5 10:54:02 2022 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Dec 5 10:54:02 2022 [CForkedBranch::CForkedBranch] context = 0x8dc7e2c.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] reqUri stored: sip:8302@192.168.1.181:5060;transport=udp
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] cacUsed = 0 before.
1670237642 -> Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] CAC = 0
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] Call: c706eb47 eqt: -1 INITIAL_STATE received a message.
Mon Dec 5 10:54:02 2022 [decodeInviteCLIR].
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] INFO present in Allow header
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] UPDATE present in Allow header
Mon Dec 5 10:54:02 2022 am_I_PCS SCSWorking : NO
Mon Dec 5 10:54:02 2022 check_PCSstate
Mon Dec 5 10:54:02 2022 check_PCSstate stat of PCS is : -1
Mon Dec 5 10:54:02 2022 1180[CMotorCall::analyseSessionTimer] Session Timer extGw=-1 sessionDelay=1800 .
Mon Dec 5 10:54:02 2022 1180[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:02 2022 1180[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:02 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:02 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:02 2022 [checkSdpValidity] Media 0 type 1 contains 5 formats.
Mon Dec 5 10:54:02 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:02 2022 [checkSdpValidity] Format : 8.
1670237642 -> Mon Dec 5 10:54:02 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:02 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:02 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] The audio media contains 5 format(s).
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 1 is 0 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 2 is 18 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format is G729.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 3 is 9 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 4 is 101 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] 101.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format is DTMF:101.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Connection address retrieved in sdp: 192.168.1.181.
Mon Dec 5 10:54:02 2022 [convertIPStrIntoTuipv] 192.168.1.181 => 192.168.1.181
1670237642 -> Mon Dec 5 10:54:02 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:02 2022 [display_sdp] address =192.168.1.181
Mon Dec 5 10:54:02 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:02 2022 [display_sdp] codecs =17.
Mon Dec 5 10:54:02 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:02 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Mon Dec 5 10:54:02 2022 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Dec 5 10:54:02 2022 [receiveinvitemessage] get requri.
Mon Dec 5 10:54:02 2022 [decodeInviteTo].
Mon Dec 5 10:54:02 2022 [decodeInviteReferredBy].
Mon Dec 5 10:54:02 2022 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
Mon Dec 5 10:54:02 2022 [decodeInviteACSBU].
Mon Dec 5 10:54:02 2022 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=1
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] concatenating from header
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] temp_fromuserinfo = 8302
1670237642 -> Mon Dec 5 10:54:02 2022 [receiveInviteMessage] From_userinfo = 8302
Mon Dec 5 10:54:02 2022 1180[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:02 2022 [ipc_thread] Normal case : evt 10764
Mon Dec 5 10:54:02 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:02 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1448 inserted.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::sendLgEvtSipCreate] Event sent on eqt : 1448
Mon Dec 5 10:54:02 2022 ** SEPLOS/IP-DECT **
Mon Dec 5 10:54:02 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:02 2022 Id : -1
Mon Dec 5 10:54:02 2022 INVITE
Mon Dec 5 10:54:02 2022 REQUEST URI : <> 8008@oxe.ma:5060 ; user=name
Mon Dec 5 10:54:02 2022 FROM : <Hajib> 8302@oxe.ma:5060 ; user=name
Mon Dec 5 10:54:02 2022 TO : <8008> 8008@oxe.ma:5060 ; user=name
Mon Dec 5 10:54:02 2022 CAC : 0
Mon Dec 5 10:54:02 2022 CAC ADDRESS :
Mon Dec 5 10:54:02 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:02 2022 CLIR : 0
Mon Dec 5 10:54:02 2022 Prack Required : 0
Mon Dec 5 10:54:02 2022 Allow Update : 0
Mon Dec 5 10:54:02 2022 SDP :
Mon Dec 5 10:54:02 2022 ADDRESS : 192.168.1.181 :6000
Mon Dec 5 10:54:02 2022 ALGOS :
Mon Dec 5 10:54:02 2022 PCMA
Mon Dec 5 10:54:02 2022 G729
Mon Dec 5 10:54:02 2022 101
Mon Dec 5 10:54:02 2022 DIRECTION : SEND & RECEIVE
1670237642 -> Mon Dec 5 10:54:02 2022 video index : 0
Mon Dec 5 10:54:02 2022 crypto index : 0
Mon Dec 5 10:54:02 2022 N_GW_EXT : -1
Mon Dec 5 10:54:02 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:02 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:02 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:02 2022 neqt : 1448 Id : 1
Mon Dec 5 10:54:02 2022 INFORMATIONAL
Mon Dec 5 10:54:02 2022 xx : 0
Mon Dec 5 10:54:02 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:02 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1448 1.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] an event arrived on an invalid eqt 1448 1.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::unRegister] Remove eqt : 1448 diag : -1 from the map.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::eraseCallwithEqt] erase 1448 -1.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] dialogId update done.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] NOE-SIP : No updates to Twin
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
1670237642 -> Mon Dec 5 10:54:02 2022 [onIncomingEvent] INFORMATIONAL arrived.
Mon Dec 5 10:54:02 2022 [onIncomingEvent] 100 TRYING ignored.
Mon Dec 5 10:54:02 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:02 2022 [ipc_thread] Normal case : evt 10752
Mon Dec 5 10:54:02 2022 neqt : 1432 Id : 1
Mon Dec 5 10:54:02 2022 REQUEST URI : <> 8008@oxe.ma:5060 ; user=phone
Mon Dec 5 10:54:02 2022 FROM : <Hajib> 8302@192.168.1.10:5060 ; user=phone
Mon Dec 5 10:54:02 2022 TO : <Samir> 8008@192.168.1.10:5060 ; user=phone
Mon Dec 5 10:54:02 2022 neqt CAC : -1
Mon Dec 5 10:54:02 2022 N_GW_EXT : 1000
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 1432 1.
1670237642 -> Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] New Call created.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::callFactory].
Mon Dec 5 10:54:02 2022 1181 [CCall::CCall] resources number: 142
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:02 2022 [CMotorCallManager::callFactory]=8df27d0.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1432 inserted.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildAurlRFCWithBelongingDomain]-->extGw=-1
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setExtGw] -1->1000
Mon Dec 5 10:54:02 2022 1181[CMotorCall::sipUriType] sip Uri.
Mon Dec 5 10:54:02 2022 [quoteString] => "Hajib"
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
Mon Dec 5 10:54:02 2022 [quoteString] => "Samir"
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
Mon Dec 5 10:54:02 2022 [onIncomingEvent] INVITE arrived.
Mon Dec 5 10:54:02 2022 [receiveInviteEvent] Call: eqt: 1432 INITIAL_STATE received an event.
1670237642 -> Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] begin. size=652 call_type: 1
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setExtGw] 1000->1000
Mon Dec 5 10:54:02 2022 1181[CMotorCall::getUserType] extGw=1000.
Mon Dec 5 10:54:02 2022 [isUserInDico] looking for 8008@oxe.ma ...
Mon Dec 5 10:54:02 2022 1181[CMotorCall::getUserType] Request URI is seplos station crypto=0.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] m_crypted FALSE
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildAurlRFCWithBelongingDomain]-->extGw=1000
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] From: "Hajib" <sip:8302@192.168.1.10:5060;user=phone>
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] reqUri :sip:8008@oxe.ma:5060;user=phone
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1 allow_update=1
1670237642 -> Mon Dec 5 10:54:02 2022 [quoteString] => "Samir"
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] To: "Samir" <sip:8008@192.168.1.10:5060;user=phone>
Mon Dec 5 10:54:02 2022 1181[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildContact] trunk_number=-1 extGw =1000.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildContact] userinfo : 8302
Mon Dec 5 10:54:02 2022 1181[CMotorCall::buildContactInvite] Contact: sip:8302@192.168.1.10:5060
Mon Dec 5 10:54:02 2022 1181[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildSessionTimer] uacGatewayMode=1 uacRefresher=1.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildAlertInfo] call_type:1
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeRequestSdpAudio] Begin sdp.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::is_RFC3264Mline] RFC3264Mline_GW =1
Mon Dec 5 10:54:02 2022 1181[CMotorCall::appendAudioAttributToMedia] Direction: 0.
1670237642 -> Mon Dec 5 10:54:02 2022 1181[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setAudioMediaToSdp] crypto index3=0 clearMediaLine=0.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setAudioMediaToSdp] appendMediaDescription ok.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setAudioMediaToSdp] Connection address: 192.168.1.181.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeRequestSdpAudio] audio end.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] The sdp build.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::new_determineTargetsForTheRequest] is Responsible For This URI.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::new_determineTargets] pcszNameToFind_1=8008.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] nb contacts=1.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 8008
1670237642 -> Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] contact : sip:8008@192.168.1.171:5060;transport=udp
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] nb available licenses=0 .
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0 and pSipAddSpec->getHost()=192.168.1.171
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] contact nb=1
Mon Dec 5 10:54:02 2022 [CGWMngData::isMainServer] CPU is MAIN.
Mon Dec 5 10:54:02 2022 [CGWMngData::isMainServer] checkwith PCS = 0
Mon Dec 5 10:54:02 2022 1181 [CCall::makeGenericRequest] INVITE
Mon Dec 5 10:54:02 2022 1181 [CCall::getDialog] Confirmed Dialog is not found (ID =
Mon Dec 5 10:54:02 2022 1181 [CCall::getDialog] Initial Dialog Client not found
Mon Dec 5 10:54:02 2022 1571 [CDialog::CDialog] resources number: 278
Mon Dec 5 10:54:02 2022 1571 [CDialog::createRequest]
Mon Dec 5 10:54:02 2022 1571 [CDialog::buildServicesForAllRequest]
Mon Dec 5 10:54:02 2022 1571 [CDialog::createInviteRequest]
Mon Dec 5 10:54:02 2022 2156 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:02 2022 2156 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:02 2022 1571 [CDialog::onTransactionState(pTrans = 2156, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:02 2022 35731 [CRequest::CRequest] Creation of a request
Mon Dec 5 10:54:02 2022 [DBG: CRequest::freeAttributes]
1670237642 -> Mon Dec 5 10:54:02 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:02 2022 [DBG: CRequest::freeAttributes Ends]
Mon Dec 5 10:54:02 2022 CRequest::createRequestLine Protocol UDP
Mon Dec 5 10:54:02 2022 35731 [CMessage::send] sip_sendMessage (192.168.1.171:5060)
Mon Dec 5 10:54:02 2022 SEND MESSAGE TO NETWORK (192.168.1.171:5060 [UDP]) (BUFF LEN = 963)
INVITE sip:8008@192.168.1.171:5060;transport=udp SIP/2.0
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFO
Session-Expires: 1800;refresher=uac
Min-SE: 900
Alert-Info: <urn:alert:tone:internal>
From: "Hajib" <sip:8302@192.168.1.10:5060;user=phone>;tag=560b51dae5d5d17c18c5b7b9739cd53c
Contact: <sip:8302@192.168.1.10:5060;transport=UDP>
Call-ID: f5c354965203ab46ddaf21e54fa82f3a@192.168.1.10
CSeq: 192632951 INVITE
Via: SIP/2.0/UDP 192.168.1.10;branch=z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1
Max-Forwards: 70
Content-Length: 216
v=0
o=OXE 1670237642 1670237642 IN IP4 192.168.1.10
s=abs
t=0 0
m=audio 6000 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
1670237642 -> Mon Dec 5 10:54:02 2022 [CTransport::findConnection] pConnection = 0 remoteHost=192.168.1.171, remotePort=5060
Mon Dec 5 10:54:02 2022 77d0 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:02 2022 [CTransportUdp::createConnection] new connection = 77d0
Mon Dec 5 10:54:02 2022 Tcl_OpenUdpClient (192.168.1.171,5060)
Mon Dec 5 10:54:02 2022 Tcl_OpenUdpClient reuse existing socket=3
Mon Dec 5 10:54:02 2022 77d0 [CTransport::addConnection] Insert connection with key = 192.168.1.171|5060
Mon Dec 5 10:54:02 2022 [CTransport::createConnection] OK
Mon Dec 5 10:54:02 2022 udp_send fd:3 port 5060 iBytesSend:963
Mon Dec 5 10:54:02 2022 35731 [CMessage::onSendSuccess]
Mon Dec 5 10:54:02 2022 2156 [CTransaction::onSendSuccess] CMessage 35731 send Success
Mon Dec 5 10:54:02 2022 1571 [CDialog::onSendSuccess]
Mon Dec 5 10:54:02 2022 1181[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:02 2022 2156 [CTransInitialState::createRequest] Transaction changes to Calling state
Mon Dec 5 10:54:02 2022 2156 [CTransaction::changeState] STATE CHANGED TO CALLING
Mon Dec 5 10:54:02 2022 1571 [CDialog::onTransactionState(pTrans = 2156, previousState = Initial, currentState = Calling, reason = Request creation]
1670237642 -> Mon Dec 5 10:54:02 2022 2156 [CTransaction::startTimer] Timer A is started (delay = 500 ms)
Mon Dec 5 10:54:02 2022 2156 [CTransaction::startTimer] Timer B is started (delay = 8000 ms)
Mon Dec 5 10:54:02 2022 1571 [CDialog::getTransactionByCSeq] CSeq = 192632951
Mon Dec 5 10:54:02 2022 1571 [CDialog::addTransaction] added transaction 2156 with branch z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1, with CSeq 192632951
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 900
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:02 2022 [CForkedBranch::CForkedBranch] context = 0x8df2d94.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::branchAllocation] pForkedBranch = 0x89f4258 and the branch number is.
Mon Dec 5 10:54:02 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:02 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:02 2022 NOE-SIP : StandByCallCreation not sent to twin CS
Mon Dec 5 10:54:02 2022 [onIncomingEvent] CallID must be inserted.
Mon Dec 5 10:54:02 2022 [onIncomingEvent] CallID inserted.
1670237642 -> Mon Dec 5 10:54:02 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:02 2022 xx : 80
Mon Dec 5 10:54:02 2022 [receiveInformationalEvent] Call: c706eb47 eqt: 1448 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::emitInformationalMessage] PAI
-Asserted-Identity: "Samir" <sip:8008@192.168.1.10:5060;user=phone>
1670237642 -> Mon Dec 5 10:54:02 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:02 2022 1180[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:02 2022 1180[CMotorCall::buildContact] Contact: sip:192.168.1.10:5060
Mon Dec 5 10:54:02 2022 1180[CMotorCall::emitInformationMessage] cause=-1
Mon Dec 5 10:54:02 2022 1180 [CCall::makeGenericResponse] 180
Mon Dec 5 10:54:02 2022 1180 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:02 2022 1570 [CDialog::createResponse] 180
Mon Dec 5 10:54:02 2022 2155 [CTransProceedingState::createResponse] CResponse 35C9B ref=1
Mon Dec 5 10:54:02 2022 35C9B [CMessage::send] sip_sendMessage (192.168.1.181:5060)
Mon Dec 5 10:54:02 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 511)
SIP/2.0 180 Ringing
P-Asserted-Identity: "Samir" <sip:8008@192.168.1.10:5060;user=phone>
To: "8008" <sip:8008@oxe.ma:5060>;tag=195918d3ab06a6381543d4ebe9a898ba
Call-ID: c706eb47
Content-Length: 0
Mon Dec 5 10:54:02 2022 udp_send fd:3 port 5060 iBytesSend:511
Mon Dec 5 10:54:02 2022 35C9B [CMessage::onSendSuccess]
Mon Dec 5 10:54:02 2022 2155 [CTransaction::onSendSuccess] CMessage 35C9B send Success
Mon Dec 5 10:54:02 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:02 2022 35C9A [~CResponse] resp(100) c706eb47 1090543851 INVITE
Mon Dec 5 10:54:02 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:02 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:02 2022 1570 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:02 2022 udp_recv fd:5 iBytesRead:641
Mon Dec 5 10:54:02 2022 UdpInputProc iSock:5 iBytesRead:641 Host:192.168.1.171 Port:5060
Mon Dec 5 10:54:02 2022 [CTransportUdp::receiveMessage] from 192.168.1.171:5060 rc:641
Mon Dec 5 10:54:02 2022 [CTransport::findConnection] pConnection = 77d0 remoteHost=192.168.1.171, remotePort=5060
1670237642 -> Mon Dec 5 10:54:02 2022 [CIOCom::onReceiveMessage] received from 192.168.1.171:5060, proto=0, length=641, mtls = 0
Mon Dec 5 10:54:02 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.171:5060 [UDP])
SIP/2.0 180 Ringing
To: "Samir" <sip:8008@192.168.1.10:5060;user=phone>;tag=1599039450
Contact: <sip:8008@192.168.1.171:5060;transport=udp>
Content-Length: 0
Mon Dec 5 10:54:02 2022 [CIOCom::receiveResponse] CResponse 35C9C ref=1
Mon Dec 5 10:54:02 2022 [CDispatcher::processResponseFromManagerIndex] start at index 0
Mon Dec 5 10:54:02 2022 102 [CCallManager::onIncomingResponse]
Mon Dec 5 10:54:02 2022 1181 [CCall::receiveResponse] 180
Mon Dec 5 10:54:02 2022 1181 [CCall::getDialog] Confirmed Dialog is not found (ID = 560b51dae5d5d17c18c5b7b9739cd53c;1599039450)
1670237642 -> Mon Dec 5 10:54:02 2022 1181 [CCall::getDialog] Returning Initial Dialog Client
Mon Dec 5 10:54:02 2022 1571 [CDialog::receiveResponse]
Mon Dec 5 10:54:02 2022 2156 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
Mon Dec 5 10:54:02 2022 2156 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:02 2022 1571 [CDialog::onTransactionState(pTrans = 2156, previousState = Calling, currentState = Proceeding, reason = 1xx response reception]
Mon Dec 5 10:54:02 2022 2156 [CTransaction::freeTimerToken] Timer A is freed
Mon Dec 5 10:54:02 2022 2156 [CTransaction::freeTimerToken] Timer B is freed
Mon Dec 5 10:54:02 2022 1571 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:02 2022 1181[CMotorCall::searchForkedBranch]pForkedBranch=0x89f4258.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::onReceiveResponse] lastInviteContext got updated
Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] Call: f5c354965203ab46ddaf21e54fa82f3a@192.168.1.10 eqt: 1432 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] setting COLP to true in preferred
Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] 0 AlertInfo header(s) found
Mon Dec 5 10:54:02 2022 [CPoceedingState::receiveInformationalMessage]-->nof of PEM hdrs 0
1670237643 -> Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] No P-Early-Media header received
Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] is in the else part of SDP not present
Mon Dec 5 10:54:02 2022 [methodAllowedByDistant] INFO allowed by distant.
Mon Dec 5 10:54:02 2022 1181[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:02 2022 1181[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:02 2022 1181[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:02 2022 1181[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:02 2022 ** SEPLOS **
Mon Dec 5 10:54:02 2022 [sendLgEvtSip] seplos Event sent on eqt : 1432 Id :1
Mon Dec 5 10:54:02 2022 Id : 1
Mon Dec 5 10:54:02 2022 [fnInit] *************************** Init timeout.
Mon Dec 5 10:54:02 2022 [fnInit] treatTimeout.
Mon Dec 5 10:54:02 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:54:02 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:54:02 2022 [startRegistration] timer value=6000.
1670237643 -> Mon Dec 5 10:54:03 2022 udp_recv fd:5
Mon Dec 5 10:54:03 2022 udp_recv fd:5 iBytesRead:963
Mon Dec 5 10:54:03 2022 UdpInputProc iSock:5 iBytesRead:963 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:03 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:963
Mon Dec 5 10:54:03 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:03 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=963, mtls = 0
Mon Dec 5 10:54:03 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
INVITE sip:8013@192.168.1.10 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.18:59400;rport;branch=z9hG4bKPj55be59c9ffd0479591032575c39daccf
Max-Forwards: 70
From: <sip:8977@192.168.1.10>;tag=8cd80b611f0d474fbb11f683f655f043
To: <sip:8013@192.168.1.10>
Contact: <sip:8977@192.168.1.18:59400;ob>
Call-ID: d3cb51948f8c4d0280ca3bb145661901
CSeq: 14859 INVITE
Route: <sip:192.168.1.10;lr>
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Supported: replaces, 100rel, timer, norefersub
Min-SE: 90
User-Agent: MicroSIP/3.21.3
Content-Length: 316
v=0
o=- 3879226472 3879226472 IN IP4 128.203.52.4
s=pjmedia
b=AS:84
t=0 0
a=X-nat:0
m=audio 4004 RTP/AVP 8 101
c=IN IP4 128.203.52.4
b=TIAS:64000
a=rtcp:4005 IN IP4 128.203.52.4
a=sendrecv
a=fmtp:101 0-16
a=ssrc:1646068843 cname:733863bc17152acd
1670237643 -> Mon Dec 5 10:54:03 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:03 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:03 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:03 2022 35732 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:03 2022 [CIOCom::receiveRequest] Received CRequest 35732 ref=1
Mon Dec 5 10:54:03 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:03 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:03 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:03 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:03 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:03 2022 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
Mon Dec 5 10:54:03 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:03 2022 [CMotorCallManager::callFactory] For call : d3cb51948f8c4d0280ca3bb145661901.
Mon Dec 5 10:54:03 2022 1182 [CCall::CCall] resources number: 143
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:03 2022 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.68.a
Mon Dec 5 10:54:03 2022 [CMotorCallManager::callFactory]=8de05f8.
1670237643 -> Mon Dec 5 10:54:03 2022 1182 [CCall::receiveRequest] INVITE
Mon Dec 5 10:54:03 2022 1182 [CCall::getDialog] Confirmed Dialog is not found (ID = ;8cd80b611f0d474fbb11f683f655f043)
Mon Dec 5 10:54:03 2022 1182 [CCall::getDialog] Initial Dialog Server not found
Mon Dec 5 10:54:03 2022 1572 [CDialog::CDialog] resources number: 279
Mon Dec 5 10:54:03 2022 1572 [CDialog::receiveRequest]
Mon Dec 5 10:54:03 2022 1572 [CDialog::receiveInviteRequest]
Mon Dec 5 10:54:03 2022 2157 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:03 2022 2157 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:03 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:03 2022 2157 [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Dec 5 10:54:03 2022 2157 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:03 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Dec 5 10:54:03 2022 2157 [CTransProceedingState::createResponse] CResponse 35C9D ref=1
Mon Dec 5 10:54:03 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:03 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:03 2022 [DBG: CResponse::freeAttributes] Ends
1670237643 -> Mon Dec 5 10:54:03 2022 35C9D [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:03 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:03 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 321)
SIP/2.0 100 Trying
CSeq: 14859 INVITE
Via: SIP/2.0/UDP 192.168.1.18:59400;received=192.168.1.18;rport=59400;branch=z9hG4bKPj55be59c9ffd0479591032575c39daccf
Content-Length: 0
Mon Dec 5 10:54:03 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:03 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:03 2022 udp_send fd:5
Mon Dec 5 10:54:03 2022 udp_send fd:5 port 59400 iBytesSend:321
Mon Dec 5 10:54:03 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:03 2022 35C9D [CMessage::onSendSuccess]
Mon Dec 5 10:54:03 2022 2157 [CTransaction::onSendSuccess] CMessage 35C9D send Success
Mon Dec 5 10:54:03 2022 1572 [CDialog::onSendSuccess]
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:03 2022 1572 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
1670237643 -> Mon Dec 5 10:54:03 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 90
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:03 2022 1572 [CDialog::addTransaction] added transaction 2157 with branch z9hG4bKPj55be59c9ffd0479591032575c39daccf, with CSeq 14859
Mon Dec 5 10:54:03 2022 1182 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:03 2022 1182 [CCall::checkAuthentication] INVITE
Mon Dec 5 10:54:03 2022 1182[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:03 2022 [getFromHeader] look at the From.
Mon Dec 5 10:54:03 2022 [getFromHeader] displayName=.
Mon Dec 5 10:54:03 2022 [convertCSipURLIntoSipuri] uri = sip:8977@192.168.1.10.
Mon Dec 5 10:54:03 2022 [getFromHeader] =8977@192.168.1.10.
Mon Dec 5 10:54:03 2022 [getFromHeader] clirPresent=0.
Mon Dec 5 10:54:03 2022 [getReqUriHeader] look at the requri.
Mon Dec 5 10:54:03 2022 [convertCSipURLIntoSipuri] uri = sip:8013@192.168.1.10.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::getUserType] extGw=-1.
1670237643 -> Mon Dec 5 10:54:03 2022 [CMotorCall::analyseRouting] TEL uri=0.
Mon Dec 5 10:54:03 2022 [CMotorCall::analyseRouting] 8977@192.168.1.10 is authenticable.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setExtGw] -1->-3
Mon Dec 5 10:54:03 2022 [isUserInDico] looking for 8977@192.168.1.10 ...
Mon Dec 5 10:54:03 2022 [isUserInDico] found in the dictionnary.
Mon Dec 5 10:54:03 2022 [isAddrInDico] seplos station OK
Mon Dec 5 10:54:03 2022 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::getUserType] From is seplos station crypto=0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::getUserType] extGw=-3.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::controlAuthentication] m_other_calling=0 extgw=-3
Mon Dec 5 10:54:03 2022 1182[CMotorCall::controlAuthentication] from:sip:8977@192.168.1.10:5060
Mon Dec 5 10:54:03 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:03 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:03 2022 [CGwMngData::isAuthenticationRequiredForThisClient] 8977@192.168.1.10 .
Mon Dec 5 10:54:03 2022 [CGwMngData::isAuthenticationRequiredForThisClient] -3 need auth=0.
Mon Dec 5 10:54:03 2022 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway -3.
Mon Dec 5 10:54:03 2022 CGwMngData::isAuthenticationRequiredForThisClient: gateway=-3
1670237643 -> Mon Dec 5 10:54:03 2022 1182[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setExtGw] -3->-3
Mon Dec 5 10:54:03 2022 1182 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:03 2022 1182 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:03 2022 1182 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:03 2022 1182 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Dec 5 10:54:03 2022 1182[CMotorCall::initOfUserType] station role already defined s=1 d=0 o=0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onReceiveRequest] accepte? m_other_calling=0 gw=-1.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=2.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::toGatewayOrProxy] request for proxydomain=192.168.1.10.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::toGatewayOrProxy] from = seplos station.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] nb available licenses=0 .
1670237643 -> Mon Dec 5 10:54:03 2022 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Dec 5 10:54:03 2022 [CForkedBranch::CForkedBranch] context = 0x8de0bbc.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] reqUri stored: sip:8977@192.168.1.18:59400;ob
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] CAC = 0
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: -1 INITIAL_STATE received a message.
Mon Dec 5 10:54:03 2022 [decodeInviteCLIR].
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] UPDATE present in Allow header
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] INFO present in Allow header
Mon Dec 5 10:54:03 2022 am_I_PCS SCSWorking : NO
Mon Dec 5 10:54:03 2022 check_PCSstate
Mon Dec 5 10:54:03 2022 check_PCSstate stat of PCS is : -1
Mon Dec 5 10:54:03 2022 1182[CMotorCall::analyseSessionTimer] Session Timer extGw=-1 sessionDelay=1800 .
1670237643 -> Mon Dec 5 10:54:03 2022 1182[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:03 2022 1182[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:03 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] Format : 8.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:03 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:03 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] The audio media contains 2 format(s).
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] 101.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Format is DTMF:101.
1670237643 -> Mon Dec 5 10:54:03 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Connection address retrieved in sdp: 128.203.52.4.
Mon Dec 5 10:54:03 2022 [convertIPStrIntoTuipv] 128.203.52.4 => 128.203.52.4
Mon Dec 5 10:54:03 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:03 2022 [display_sdp] address =128.203.52.4
Mon Dec 5 10:54:03 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:03 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:03 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Mon Dec 5 10:54:03 2022 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Dec 5 10:54:03 2022 [receiveinvitemessage] get requri.
Mon Dec 5 10:54:03 2022 [decodeInviteTo].
Mon Dec 5 10:54:03 2022 [decodeInviteReferredBy].
Mon Dec 5 10:54:03 2022 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
Mon Dec 5 10:54:03 2022 [decodeInviteACSBU].
Mon Dec 5 10:54:03 2022 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=1
1670237643 -> Mon Dec 5 10:54:03 2022 [receiveInviteMessage] concatenating from header
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] temp_fromuserinfo = 8977
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] From_userinfo = 8977
Mon Dec 5 10:54:03 2022 1182[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:03 2022 [ipc_thread] Normal case : evt 10764
Mon Dec 5 10:54:03 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:03 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1464 inserted.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::sendLgEvtSipCreate] Event sent on eqt : 1464
Mon Dec 5 10:54:03 2022 ** SEPLOS/IP-DECT **
Mon Dec 5 10:54:03 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:03 2022 Id : -1
Mon Dec 5 10:54:03 2022 INVITE
Mon Dec 5 10:54:03 2022 REQUEST URI : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:03 2022 FROM : <> 8977@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:03 2022 TO : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:03 2022 CAC : 0
Mon Dec 5 10:54:03 2022 CAC ADDRESS :
Mon Dec 5 10:54:03 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:03 2022 CLIR : 0
Mon Dec 5 10:54:03 2022 Prack Required : 0
Mon Dec 5 10:54:03 2022 Allow Update : 0
Mon Dec 5 10:54:03 2022 SDP :
Mon Dec 5 10:54:03 2022 ADDRESS : 128.203.52.4 :4004
1670237643 -> Mon Dec 5 10:54:03 2022 ALGOS :
Mon Dec 5 10:54:03 2022 PCMA
Mon Dec 5 10:54:03 2022 101
Mon Dec 5 10:54:03 2022 DIRECTION : SEND & RECEIVE
Mon Dec 5 10:54:03 2022 video index : 0
Mon Dec 5 10:54:03 2022 crypto index : 0
Mon Dec 5 10:54:03 2022 N_GW_EXT : -1
Mon Dec 5 10:54:03 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:03 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:03 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:03 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:03 2022 INFORMATIONAL
Mon Dec 5 10:54:03 2022 xx : 0
Mon Dec 5 10:54:03 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:03 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1464 1.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] an event arrived on an invalid eqt 1464 1.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::unRegister] Remove eqt : 1464 diag : -1 from the map.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 -1.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] dialogId update done.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] NOE-SIP : No updates to Twin
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] seplos station.
1670237643 -> Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:03 2022 [onIncomingEvent] INFORMATIONAL arrived.
Mon Dec 5 10:54:03 2022 [onIncomingEvent] 100 TRYING ignored.
Mon Dec 5 10:54:03 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:03 2022 xx : 83
Mon Dec 5 10:54:03 2022 ADDRESS : 192.168.1.11 :32524
1670237643 -> Mon Dec 5 10:54:03 2022 [receiveInformationalEvent] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:03 2022 1182[CMotorCall::buildContact] Contact: sip:192.168.1.10:5060
Mon Dec 5 10:54:03 2022 1182[CMotorCall::emitInformationMessage] cause=183
Mon Dec 5 10:54:03 2022 1182[CMotorCall::makeResponseSdpAudioOld] Audio media.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:03 2022 1182[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Mon Dec 5 10:54:03 2022 [sameCodec] accepted Format : 8.
Mon Dec 5 10:54:03 2022 [sameCodec] requested Format : 8.
Mon Dec 5 10:54:03 2022 [sameCodec] same Format.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::mediaAccepted] Media accepted: m=audio 32524 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:03 2022 1182[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
1670237643 -> Mon Dec 5 10:54:03 2022 1182[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Mon Dec 5 10:54:03 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:03 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:03 2022 1182[CMotorCall::emitInformationalMessage] Answer sdp.
Mon Dec 5 10:54:03 2022 [removeAudioMediaPortNull] media no=0.
Mon Dec 5 10:54:03 2022 1182 [CCall::makeGenericResponse] 183
Mon Dec 5 10:54:03 2022 1182 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:03 2022 1572 [CDialog::createResponse] 183
Mon Dec 5 10:54:03 2022 2157 [CTransProceedingState::createResponse] CResponse 35C9E ref=1
Mon Dec 5 10:54:03 2022 35C9E [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:03 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 834)
SIP/2.0 183 Session Progress
User-Agent: OmniPCX Enterprise R100.0 n1.291.68.a
Reason: SIP;cause=183;text="is busy "
To: <sip:8013@192.168.1.10>;tag=8d38cac76fe0a471d7ddc4b5ffcf9be7
CSeq: 14859 INVITE
Content-Length: 216
v=0
o=OXE 1670237643 1670237643 IN IP4 192.168.1.10
s=abs
c=IN IP4 192.168.1.11
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1670237644 -> Mon Dec 5 10:54:03 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:03 2022 udp_send fd:5 port 59400 iBytesSend:834
Mon Dec 5 10:54:03 2022 35C9E [CMessage::onSendSuccess]
Mon Dec 5 10:54:03 2022 2157 [CTransaction::onSendSuccess] CMessage 35C9E send Success
Mon Dec 5 10:54:03 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:03 2022 35C9D [~CResponse] resp(100) d3cb51948f8c4d0280ca3bb145661901 14859 INVITE
Mon Dec 5 10:54:03 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:03 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:03 2022 1572 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:04 2022 info [CServRegistrar::writeLocateFile]
Mon Dec 5 10:54:04 2022 udp_recv fd:5
Mon Dec 5 10:54:04 2022 udp_recv fd:5 iBytesRead:389
Mon Dec 5 10:54:04 2022 UdpInputProc iSock:5 iBytesRead:389 Host:192.168.1.18 Port:59400
1670237644 -> Mon Dec 5 10:54:04 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:389
Mon Dec 5 10:54:04 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:04 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=389, mtls = 0
Mon Dec 5 10:54:04 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
CANCEL sip:8013@192.168.1.10 SIP/2.0
Max-Forwards: 70
CSeq: 14859 CANCEL
Content-Length: 0
Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:04 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:04 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:04 2022 35733 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] Received CRequest 35733 ref=1
Mon Dec 5 10:54:04 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] rport1 empty
1670237644 -> Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:04 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:04 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:04 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] CANCEL
Mon Dec 5 10:54:04 2022 1182 [CCall::getDialog] Confirmed Dialog is not found (ID = ;8cd80b611f0d474fbb11f683f655f043)
Mon Dec 5 10:54:04 2022 1182 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:04 2022 1572 [CDialog::receiveRequest]
Mon Dec 5 10:54:04 2022 1572 [CDialog::receiveCancelRequest]
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2158, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:04 2022 2158 [CTransInitialState::receiveRequest] Transaction changes to Trying state
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2158, previousState = Initial, currentState = Trying, reason = Request reception]
Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] iErrorCode=488.
1670237644 -> Mon Dec 5 10:54:04 2022 1182 [CCall::checkAuthentication] CANCEL
Mon Dec 5 10:54:04 2022 1182[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:04 2022 1182[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:54:04 2022 1182 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:04 2022 1182 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:04 2022 1182 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:04 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:04 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] state = PROCEEDING_STATE.
Mon Dec 5 10:54:04 2022 [receiveCancelMessage] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:04 2022 ** SEPLOS **
Mon Dec 5 10:54:04 2022 [sendLgEvtSip] seplos Event sent on eqt : 1464 Id :1
1670237644 -> Mon Dec 5 10:54:04 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:04 2022 Id : 1
Mon Dec 5 10:54:04 2022 CANCEL
Mon Dec 5 10:54:04 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:04 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:54:04 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:04 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:04 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:04 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:04 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:04 2022 SUCCESSFUL
Mon Dec 5 10:54:04 2022 xx : 0
Mon Dec 5 10:54:04 2022 RELATIVE REQUEST : CANCEL
Mon Dec 5 10:54:04 2022 CLIR : 0
Mon Dec 5 10:54:04 2022 COLP : 0
Mon Dec 5 10:54:04 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:04 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1464 1.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:04 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:54:04 2022 [onIncomingEvent] relative_request = 10756
Mon Dec 5 10:54:04 2022 [CProceedingState::receiveSuccessfulEvent] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:04 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
1670237644 -> Mon Dec 5 10:54:04 2022 1572 [CCall::findFirstServerTrans]
Mon Dec 5 10:54:04 2022 1572 [CDialog::findFirstServerTrans] Current Request in cancelTransactionMap
Mon Dec 5 10:54:04 2022 1182 [CCall::makeGenericResponse] 200
Mon Dec 5 10:54:04 2022 1572 [CDialog::createResponse] 200
Mon Dec 5 10:54:04 2022 2158 [CTransTryingState::createResponse] CResponse 35C9F ref=1
Mon Dec 5 10:54:04 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:04 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:04 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:04 2022 35C9F [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:04 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:04 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 407)
SIP/2.0 200 OK
Supported: replaces,timer,path,100rel
CSeq: 14859 CANCEL
Content-Length: 0
1670237644 -> Mon Dec 5 10:54:04 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:04 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:04 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:04 2022 udp_send fd:5
Mon Dec 5 10:54:04 2022 udp_send fd:5 port 59400 iBytesSend:407
Mon Dec 5 10:54:04 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:04 2022 35C9F [CMessage::onSendSuccess]
Mon Dec 5 10:54:04 2022 2158 [CTransaction::onSendSuccess] CMessage 35C9F send Success
Mon Dec 5 10:54:04 2022 1572 [CDialog::onSendSuccess]
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:04 2022 2158 [CTransTryingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2158, previousState = Trying, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:04 2022 2158 [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
Mon Dec 5 10:54:04 2022 1572 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:04 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:04 2022 [ipc_thread] Normal case : evt 10767
1670237644 -> Mon Dec 5 10:54:04 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:04 2022 REQUEST FAILURE
Mon Dec 5 10:54:04 2022 xx : 87
Mon Dec 5 10:54:04 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] an event 10767 arrived on the eqt 1464 1.
Mon Dec 5 10:54:04 2022 [onIncomingEvent] REQUEST FAILURE arrived.
Mon Dec 5 10:54:04 2022 [receiveRequestFailureEvent] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::getOutgoingCall] outgoingCall:0
Mon Dec 5 10:54:04 2022 [receiveRequestFailureEvent] incoming call.
Mon Dec 5 10:54:04 2022 1182 [CCall::makeGenericResponse] 487
Mon Dec 5 10:54:04 2022 1182 [CCall::getDialog] Confirmed Dialog is not found (ID = 8d38cac76fe0a471d7ddc4b5ffcf9be7;8cd80b611f0d474fbb11f683f655f043)
Mon Dec 5 10:54:04 2022 1572 [CDialog::createResponse] 487
Mon Dec 5 10:54:04 2022 2157 [CTransProceedingState::createResponse] CResponse 35CA0 ref=1
1670237644 -> Mon Dec 5 10:54:04 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:04 2022 35CA0 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:04 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 504)
SIP/2.0 487 Request Terminated
CSeq: 14859 INVITE
Content-Length: 0
Mon Dec 5 10:54:04 2022 udp_send fd:5 port 59400 iBytesSend:504
1670237644 -> Mon Dec 5 10:54:04 2022 35CA0 [CMessage::onSendSuccess]
Mon Dec 5 10:54:04 2022 2157 [CTransaction::onSendSuccess] CMessage 35CA0 send Success
Mon Dec 5 10:54:04 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:04 2022 35C9E [~CResponse] resp(183) d3cb51948f8c4d0280ca3bb145661901 14859 INVITE
Mon Dec 5 10:54:04 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:04 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:04 2022 2157 [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:04 2022 2157 [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Dec 5 10:54:04 2022 2157 [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Dec 5 10:54:04 2022 1182[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:04 2022 udp_recv fd:5 iBytesRead:391
1670237644 -> Mon Dec 5 10:54:04 2022 UdpInputProc iSock:5 iBytesRead:391 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:04 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:391
Mon Dec 5 10:54:04 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=391, mtls = 0
ACK sip:8013@192.168.1.10 SIP/2.0
Max-Forwards: 70
CSeq: 14859 ACK
Content-Length: 0
Mon Dec 5 10:54:04 2022 35734 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] Received CRequest 35734 ref=1
1670237644 -> Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] ACK
Mon Dec 5 10:54:04 2022 1572 [CDialog::receiveAckRequest]
Mon Dec 5 10:54:04 2022 2157 [CTransCompletedState::receiveRequest] ACK(UDP) : Transaction changes to Confirmed state
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] STATE CHANGED TO CONFIRMED
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = Completed, currentState = Confirmed, reason = Request reception]
Mon Dec 5 10:54:04 2022 2157 [CTransaction::freeTimerToken] Timer G is freed
Mon Dec 5 10:54:04 2022 2157 [CTransaction::freeTimerToken] Timer H is freed
Mon Dec 5 10:54:04 2022 2157 [CTransaction::startTimer] Timer I is started (delay = 5000 ms)
Mon Dec 5 10:54:04 2022 1572 [CDialog::receiveAckRequest] receiving an ACK on a previously rejected INVITE
1670237644 -> Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:04 2022 1182 [CCall::checkAuthentication] ACK
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] state = TERMINATED_STATE.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::compareDialogFromContext] same Dialog
Mon Dec 5 10:54:04 2022 1182[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Dec 5 10:54:04 2022 [receiveAckMessage] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 TERMINATED_STATE received a message.
Mon Dec 5 10:54:04 2022 [receiveAckMessage] boolean flag check 0
1670237644 -> Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:04 2022 ACK
Mon Dec 5 10:54:04 2022 [ipc_thread] Normal case : evt 10773
Mon Dec 5 10:54:04 2022 SIP EQT RELEASED
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1464 1.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1464 has released its equipment.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::unRegister] Remove eqt : 1464 diag : 1 from the map.
1670237644 -> Mon Dec 5 10:54:04 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 1.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] killSession.
Mon Dec 5 10:54:04 2022 1182 [CCall::killSession]
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:04 2022 2158 [CTransaction::freeTimerToken] Timer J is freed
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:04 2022 2157 [CTransaction::freeTimerToken] Timer I is freed
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:04 2022 1182 [CCall::killSession] notifying the call manager
Mon Dec 5 10:54:04 2022 102 [CCallManager::onCallClosed]
Mon Dec 5 10:54:04 2022 102 [CCallManager::onCallClosed()] Call 1182 closed. Removing call 148768248 from the maps
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onNotifyCallClosed] Call : d3cb51948f8c4d0280ca3bb145661901 is closed.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onNotifyCallClosed] call processResponse.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::chooseBestResponse] pForkedBranch=0x8ad0380 iResponseCode=2000.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::processResponse] no response found.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1670237645 -> Mon Dec 5 10:54:04 2022 102 [CCallManager::onCallClosed] pCall: 1182 added in the Garbage List
Mon Dec 5 10:54:05 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:05 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:05 2022 1572 [CDialog::onTransactionState(pTrans = 2158, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:05 2022 2158 [~CTransaction] transaction 14859 CANCEL
Mon Dec 5 10:54:05 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:05 2022 35C9F [~CResponse] resp(200) d3cb51948f8c4d0280ca3bb145661901 14859 CANCEL
Mon Dec 5 10:54:05 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:05 2022 35733 [~CRequest] req d3cb51948f8c4d0280ca3bb145661901 14859 CANCEL
Mon Dec 5 10:54:05 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:05 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:05 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:05 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:05 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:05 2022 1572 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:54:05 2022 1572 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:54:05 2022 1182 [CCall::onDialogClosed]
1670237646 -> Mon Dec 5 10:54:05 2022 1182 [CCall::onDialogClosed] only initial *********
Mon Dec 5 10:54:05 2022 1182 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
Mon Dec 5 10:54:05 2022 2157 [~CTransaction] transaction 14859 INVITE
Mon Dec 5 10:54:05 2022 35734 [~CRequest] req d3cb51948f8c4d0280ca3bb145661901 14859 ACK
Mon Dec 5 10:54:06 2022 udp_recv fd:5
Mon Dec 5 10:54:06 2022 udp_recv fd:5 iBytesRead:981
Mon Dec 5 10:54:06 2022 UdpInputProc iSock:5 iBytesRead:981 Host:192.168.1.171 Port:5060
Mon Dec 5 10:54:06 2022 [CTransportUdp::receiveMessage] from 192.168.1.171:5060 rc:981
Mon Dec 5 10:54:06 2022 [CTransport::findConnection] pConnection = 77d0 remoteHost=192.168.1.171, remotePort=5060
Mon Dec 5 10:54:06 2022 [CIOCom::onReceiveMessage] received from 192.168.1.171:5060, proto=0, length=981, mtls = 0
Mon Dec 5 10:54:06 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.171:5060 [UDP])
SIP/2.0 200 OK
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, PUBLISH, REFER, REGISTER, SUBSCRIBE, UPDATE
Allow-Events: conference, refer, talk, hold
Supported: 100rel, eventlist, join, replaces, sdp-anat, tdialog
Content-Disposition: session
Content-Type: application/sdp
Content-Length: 282
v=0
o=- 2351778037827138401 2351778037827138402 IN IP4 192.168.1.171
s=SDP data
c=IN IP4 192.168.1.171
t=0 0
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=silenceSupp:off - - - -
a=fmtp:101 0-15
a=ptime:20
a=mptime:20 -
a=sendrecv
1670237646 -> Mon Dec 5 10:54:06 2022 [CIOCom::receiveResponse] CResponse 35CA1 ref=1
Mon Dec 5 10:54:06 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:06 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:06 2022 [CDispatcher::processResponseFromManagerIndex] start at index 0
Mon Dec 5 10:54:06 2022 102 [CCallManager::onIncomingResponse]
Mon Dec 5 10:54:06 2022 1181 [CCall::receiveResponse] 200
Mon Dec 5 10:54:06 2022 1181 [CCall::getDialog] Confirmed Dialog is not found (ID = 560b51dae5d5d17c18c5b7b9739cd53c;1599039450)
Mon Dec 5 10:54:06 2022 1181 [CCall::getDialog] Returning Initial Dialog Client
Mon Dec 5 10:54:06 2022 1571 [CDialog::receiveResponse]
Mon Dec 5 10:54:06 2022 1571 [CDialog::receiveResponse] create a CONFIRMED dialog
Mon Dec 5 10:54:06 2022 1573 [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1
Mon Dec 5 10:54:06 2022 1573 [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1
Mon Dec 5 10:54:06 2022 2159 [CTransaction::CTransaction] Transaction is cloned in 4 state
Mon Dec 5 10:54:06 2022 1573 [CDialog::addTransaction] added transaction 2159 with branch z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1, with CSeq 192632951
Mon Dec 5 10:54:06 2022 1573 [CDialog::startDialogTTL]
Mon Dec 5 10:54:06 2022 1573 [CDialog::CDialog] resources number: 280
1670237646 -> Mon Dec 5 10:54:06 2022 1573 [CDialog::receiveResponse]
Mon Dec 5 10:54:06 2022 2159 [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:06 2022 2159 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:06 2022 2159 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:06 2022 1573 [CDialog::onTransactionState(pTrans = 2159, previousState = Proceeding, currentState = Completed, reason = Final resp reception]
Mon Dec 5 10:54:06 2022 2159 [CTransaction::startTimer] Timer D is started (delay = 32382 ms)
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Client, UA)
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 900
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::startTimers] Start session timer will expires : 900000
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:06 2022 1573 [CDialog::updateRouteSet] there are 0 record-route headers
1670237646 -> Mon Dec 5 10:54:06 2022 1181 [CCall::insertInDialogMap] added dialog #1573 with the key 560b51dae5d5d17c18c5b7b9739cd53c;1599039450
Mon Dec 5 10:54:06 2022 1571 [CDialog::getTransactionByCSeq] CSeq = 192632952
Mon Dec 5 10:54:06 2022 1571 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:06 2022 1181[CMotorCall::searchForkedBranch]pForkedBranch=0x89f4258.
Mon Dec 5 10:54:06 2022 [CForkedBranch::setFinalResponse] response=200.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::chooseBestResponse] pForkedBranch=0x89f4258 iResponseCode=2000.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::chooseBestResponse] last iResponseCode=200.
Mon Dec 5 10:54:06 2022 [CForkedBranch::setFinalResponse] pResponse=0x8b2e770.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:06 2022 [receiveSuccessfulMessage] Call: f5c354965203ab46ddaf21e54fa82f3a@192.168.1.10 eqt: 1432 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:06 2022 1181[CMotorCall::analyseSessionTimer] Session Timer extGw=1000 sessionDelay=1800 .
Mon Dec 5 10:54:06 2022 1181[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
1670237646 -> Mon Dec 5 10:54:06 2022 1181[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=1 uacRefresher=1.
Mon Dec 5 10:54:06 2022 [decodeACACALU] no header.
Mon Dec 5 10:54:06 2022 [receiveSuccessfulMessage] setting COLP to true in preferred
Mon Dec 5 10:54:06 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:06 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:06 2022 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Dec 5 10:54:06 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:06 2022 [checkSdpValidity] Format : 8.
Mon Dec 5 10:54:06 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:06 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:06 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] The audio media contains 2 format(s).
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] 101.
1670237646 -> Mon Dec 5 10:54:06 2022 [convertAudioMedia] Format is DTMF:101.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Connection address retrieved in sdp: 192.168.1.171.
Mon Dec 5 10:54:06 2022 [convertIPStrIntoTuipv] 192.168.1.171 => 192.168.1.171
Mon Dec 5 10:54:06 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:06 2022 [display_sdp] address =192.168.1.171
Mon Dec 5 10:54:06 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:06 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:06 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbffff0c8 crypto_index=0 clear media=1
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbffff0c8 crypto_index=0 clear media=1
Mon Dec 5 10:54:06 2022 [methodAllowedByDistant] INFO allowed by distant.
Mon Dec 5 10:54:06 2022 1181[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:06 2022 1181[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:06 2022 1181[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:06 2022 1181[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:06 2022 ** SEPLOS **
Mon Dec 5 10:54:06 2022 [sendLgEvtSip] seplos Event sent on eqt : 1432 Id :1
Mon Dec 5 10:54:06 2022 [display_ipc_out] ------------ Begin ---------------
1670237646 -> Mon Dec 5 10:54:06 2022 Id : 1
Mon Dec 5 10:54:06 2022 SUCCESSFUL
Mon Dec 5 10:54:06 2022 xx : 0
Mon Dec 5 10:54:06 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:06 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:06 2022 CLIR : 0
Mon Dec 5 10:54:06 2022 COLP : 0
Mon Dec 5 10:54:06 2022 SDP :
Mon Dec 5 10:54:06 2022 ADDRESS : 192.168.1.171 :6000
Mon Dec 5 10:54:06 2022 ALGOS :
Mon Dec 5 10:54:06 2022 PCMA
Mon Dec 5 10:54:06 2022 101
Mon Dec 5 10:54:06 2022 DIRECTION : SEND & RECEIVE
Mon Dec 5 10:54:06 2022 video index : 0
Mon Dec 5 10:54:06 2022 crypto index : 0
Mon Dec 5 10:54:06 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:06 2022 [ipc_thread] Normal case : evt 10754
Mon Dec 5 10:54:06 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:06 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:06 2022 1181[CMotorCall::onReceiveResponse] retrans=0, status=200 extGw=1000.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::cancelAllCancelableForkedBranch] retrans=0.
Mon Dec 5 10:54:06 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:06 2022 [display_ipc_in] ------------ Begin ---------------
1670237646 -> Mon Dec 5 10:54:06 2022 neqt : 1432 Id : 1
Mon Dec 5 10:54:06 2022 ACK
Mon Dec 5 10:54:06 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 1432 1.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] state = ACCEPTED_STATE.
Mon Dec 5 10:54:06 2022 [onIncomingEvent] ACK arrived.
Mon Dec 5 10:54:06 2022 [receiveAckEvent] Call: f5c354965203ab46ddaf21e54fa82f3a@192.168.1.10 eqt: 1432 ACCEPTED_STATE received an event.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::emitAckMessage]
Mon Dec 5 10:54:06 2022 1181[CMotorCall::emitAckMessage] SDP ok.
Mon Dec 5 10:54:06 2022 1181 [CCall::makeGenericRequest] ACK
Mon Dec 5 10:54:06 2022 1181 [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:54:06 2022 1573 [CDialog::createRequest]
Mon Dec 5 10:54:06 2022 1573 [CDialog::buildServicesForAllRequest]
Mon Dec 5 10:54:06 2022 1573 [CDialog::createAckRequest]
Mon Dec 5 10:54:06 2022 1573 [CDialog::createAckRequest], previous trans 2159 is found
Mon Dec 5 10:54:06 2022 1573 [CDialog::createAckRequest], previous trans 2159 is client
Mon Dec 5 10:54:06 2022 35735 [CRequest::CRequest] Creation of a request
Mon Dec 5 10:54:06 2022 1573 [CDialog::buildServicesForAck]
Mon Dec 5 10:54:06 2022 [DBG: CRequest::freeAttributes]
Mon Dec 5 10:54:06 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
1670237646 -> Mon Dec 5 10:54:06 2022 [DBG: CRequest::freeAttributes Ends]
Mon Dec 5 10:54:06 2022 CRequest::createRequestLine Protocol UDP
Mon Dec 5 10:54:06 2022 35735 [CMessage::send] sip_sendMessage (192.168.1.171:5060)
Mon Dec 5 10:54:06 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:06 2022 SEND MESSAGE TO NETWORK (192.168.1.171:5060 [UDP]) (BUFF LEN = 513)
ACK sip:8008@192.168.1.171:5060;transport=udp SIP/2.0
CSeq: 192632951 ACK
Via: SIP/2.0/UDP 192.168.1.10;branch=z9hG4bK3199ae8b64346beba18b1aac6550132b
Max-Forwards: 70
Content-Length: 0
Mon Dec 5 10:54:06 2022 [CTransport::getConnection] RemoteHost=(192.168.1.171 5060) already exist, using connection 77d0
Mon Dec 5 10:54:06 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
1670237646 -> Mon Dec 5 10:54:06 2022 udp_send fd:3
Mon Dec 5 10:54:06 2022 udp_send fd:3 port 5060 iBytesSend:513
Mon Dec 5 10:54:06 2022 77d0 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:06 2022 35735 [CMessage::onSendSuccess]
Mon Dec 5 10:54:06 2022 1573 [CDialog::onSendSuccess]
Mon Dec 5 10:54:06 2022 1181[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:06 2022 2159 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:06 2022 2159 [CTransaction::freeTimerToken] Timer D is freed
Mon Dec 5 10:54:06 2022 2159 [CTransaction::changeState] no transaction state, terminated reason : Request creation
Mon Dec 5 10:54:06 2022 1573 [CDialog::createAckRequest] successful INVITE is terminated after the ACK is sent
Mon Dec 5 10:54:06 2022 [receiveAckEvent] continue with session Timer
Mon Dec 5 10:54:06 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:06 2022 [ipc_thread] Normal case : evt 10758
Mon Dec 5 10:54:06 2022 neqt : 1448 Id : 2
Mon Dec 5 10:54:06 2022 NOTIFY
Mon Dec 5 10:54:06 2022 TO : 8302@oxe.ma:5060
Mon Dec 5 10:54:06 2022 Message New : 0 Old : 0
1670237646 -> Mon Dec 5 10:54:06 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] an event 10758 arrived on the eqt 1448 2.
Mon Dec 5 10:54:06 2022 [onIncomingEvent] NOTIFY arrived.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1448 inserted.
Mon Dec 5 10:54:06 2022 [CSubscriptionState::receiveNotifyEvent] Call: 20433029 eqt: 1448 SUBSCRIPTION_STATE received an event.
Mon Dec 5 10:54:06 2022 11a1 [CCall::makeGenericRequest] NOTIFY
Mon Dec 5 10:54:06 2022 11a1 [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:54:06 2022 15b7 [CDialog::createRequest]
Mon Dec 5 10:54:06 2022 15b7 [CDialog::buildServicesForAllRequest]
Mon Dec 5 10:54:06 2022 15b7 [CDialog::createBasicRequest]
Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:06 2022 15b7 [CDialog::onTransactionState(pTrans = 215a, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:06 2022 35736 [CRequest::CRequest] Creation of a request
1670237646 -> Mon Dec 5 10:54:06 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:06 2022 35736 [CMessage::send] sip_sendMessage (192.168.1.181:5060)
Mon Dec 5 10:54:06 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 608)
NOTIFY sip:8302@192.168.1.181:5060;transport=udp SIP/2.0
Content-Type: application/simple-message-summary
Event: message-summary
Subscription-State: active
To: sip:8302@oxe.ma:5060;tag=dd32facf4b
From: <sip:8302@oxe.ma:5060;transport=udp>;tag=59b07455713b5cd6453ef50354e95cf7
Call-ID: 20433029
CSeq: 1340449647 NOTIFY
Via: SIP/2.0/UDP 192.168.1.10;branch=z9hG4bKf8de482945966b8b34f54156e8f9a490
Content-Length: 60
Messages-Waiting: no
voice-message: 0/0
fax-message: 0/0
Mon Dec 5 10:54:06 2022 [CTransport::findConnection] pConnection = 779b remoteHost=192.168.1.181, remotePort=5060
Mon Dec 5 10:54:06 2022 [CTransport::getConnection] RemoteHost=(192.168.1.181 5060) already exist, using connection 779b
Mon Dec 5 10:54:06 2022 udp_send fd:3 port 5060 iBytesSend:608
Mon Dec 5 10:54:06 2022 779b [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:06 2022 35736 [CMessage::onSendSuccess]
Mon Dec 5 10:54:06 2022 215a [CTransaction::onSendSuccess] CMessage 35736 send Success
Mon Dec 5 10:54:06 2022 15b7 [CDialog::onSendSuccess]
Mon Dec 5 10:54:06 2022 11a1[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:06 2022 215a [CTransInitialState::createRequest] Transaction changes to Trying state
Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:54:06 2022 15b7 [CDialog::onTransactionState(pTrans = 215a, previousState = Initial, currentState = Trying, reason = Request creation]
Mon Dec 5 10:54:06 2022 215a [CTransTryingState::enterInState] Init timers E and F
Mon Dec 5 10:54:06 2022 215a [CTransaction::startTimer] Timer E is started (delay = 500 ms)
Mon Dec 5 10:54:06 2022 215a [CTransaction::startTimer] Timer F is started (delay = 16000 ms)
Mon Dec 5 10:54:06 2022 15b7 [CDialog::addTransaction] added transaction 215a with branch z9hG4bKf8de482945966b8b34f54156e8f9a490, with CSeq 1340449647
Mon Dec 5 10:54:06 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:06 2022 3571D [~CRequest] req 20433029 1340449646 NOTIFY
Mon Dec 5 10:54:06 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:06 2022 [CMessage::~CMessage Ends]
1670237646 -> Mon Dec 5 10:54:06 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:06 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:54:06 2022 neqt : 1448 Id : 1
Mon Dec 5 10:54:06 2022 COLP : 1
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1448 1.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:06 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:54:06 2022 [onIncomingEvent] relative_request = 10752
Mon Dec 5 10:54:06 2022 [CProceedingState::receiveSuccessfulEvent] Call: c706eb47 eqt: 1448 PROCEEDING_STATE received an event.
1670237646 -> Mon Dec 5 10:54:06 2022 [quoteString] => "Samir"
Mon Dec 5 10:54:06 2022 1180[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::emitSuccessfulMessage] P-Asserted-Identity: "Samir" <sip:8008@192.168.1.10:5060;user=phone>
Mon Dec 5 10:54:06 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
Mon Dec 5 10:54:06 2022 1180[CMotorCall::emitSuccessfulMessage] uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::makeResponseSdpAudioOld] Audio media.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:06 2022 1180[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Mon Dec 5 10:54:06 2022 [sameCodec] accepted Format : 8.
Mon Dec 5 10:54:06 2022 [sameCodec] requested Format : 8.
Mon Dec 5 10:54:06 2022 [sameCodec] same Format.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::mediaAccepted] Media accepted: m=audio 6000 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:06 2022 1180[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Mon Dec 5 10:54:06 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:06 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:06 2022 1180[CMotorCall::emitSuccesfulMessage] Answer sdp.
1670237646 -> Mon Dec 5 10:54:06 2022 [removeAudioMediaPortNull] media no=0.
Mon Dec 5 10:54:06 2022 1180 [CCall::makeGenericResponse] 200
Mon Dec 5 10:54:06 2022 1180 [CCall::getDialog] Confirmed Dialog is not found (ID = 195918d3ab06a6381543d4ebe9a898ba;61f4317ecd)
Mon Dec 5 10:54:06 2022 1180 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:06 2022 1570 [CDialog::createResponse] 200
Mon Dec 5 10:54:06 2022 1570 [CDialog::createResponse] create a CONFIRMED dialog
Mon Dec 5 10:54:06 2022 1574 [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bK5a8f8d314c36aa2d2
Mon Dec 5 10:54:06 2022 1574 [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bK5a8f8d314c36aa2d2
Mon Dec 5 10:54:06 2022 215b [CTransaction::CTransaction] Transaction is cloned in 4 state
Mon Dec 5 10:54:06 2022 1574 [CDialog::addTransaction] added transaction 215b with branch z9hG4bK5a8f8d314c36aa2d2, with CSeq 1090543851
Mon Dec 5 10:54:06 2022 1574 [CDialog::startDialogTTL]
Mon Dec 5 10:54:06 2022 1574 [CDialog::CDialog] resources number: 281
Mon Dec 5 10:54:06 2022 1574 [CDialog::createResponse] 200
Mon Dec 5 10:54:06 2022 215b [CTransProceedingState::createResponse] CResponse 35CA2 ref=1
Mon Dec 5 10:54:06 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:06 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:06 2022 35CA2 [CMessage::send] sip_sendMessage (192.168.1.181:5060)
1670237646 -> Mon Dec 5 10:54:06 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:06 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 831)
SIP/2.0 200 OK
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
Session-Expires: 1800;refresher=uas
To: "8008" <sip:8008@oxe.ma:5060>;tag=195918d3ab06a6381543d4ebe9a898ba
From: "Hajib" <sip:8302@oxe.ma:5060>;tag=61f4317ecd
Call-ID: c706eb47
CSeq: 1090543851 INVITE
Via: SIP/2.0/UDP 192.168.1.181;branch=z9hG4bK5a8f8d314c36aa2d2
Content-Length: 216
v=0
o=OXE 1670237642 1670237642 IN IP4 192.168.1.10
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:06 2022 udp_send fd:3 port 5060 iBytesSend:831
1670237646 -> Mon Dec 5 10:54:06 2022 779b [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:06 2022 35CA2 [CMessage::onSendSuccess]
Mon Dec 5 10:54:06 2022 215b [CTransaction::onSendSuccess] CMessage 35CA2 send Success
Mon Dec 5 10:54:06 2022 1574 [CDialog::onSendSuccess]
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:06 2022 215b [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:06 2022 215b [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:06 2022 215b [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:06 2022 1574 [CDialog::onTransactionState(pTrans = 215b, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:06 2022 215b [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Dec 5 10:54:06 2022 215b [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Dec 5 10:54:06 2022 1574 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Server, UA)
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 0
1670237646 -> Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateAfterResponseRefreshCreation] Update CSessionTimerContext (response refresh creation)
Mon Dec 5 10:54:06 2022 1180 [CCall::insertInDialogMap] added dialog #1574 with the key 195918d3ab06a6381543d4ebe9a898ba;61f4317ecd
Mon Dec 5 10:54:06 2022 1570 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:06 2022 [CProceedingState::receiveSuccessfulEvent] emitSuccessfulMessage OK.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:06 2022 udp_recv fd:5 iBytesRead:421
Mon Dec 5 10:54:06 2022 UdpInputProc iSock:5 iBytesRead:421 Host:192.168.1.181 Port:5060
Mon Dec 5 10:54:06 2022 [CTransportUdp::receiveMessage] from 192.168.1.181:5060 rc:421
1670237646 -> Mon Dec 5 10:54:06 2022 [CIOCom::onReceiveMessage] received from 192.168.1.181:5060, proto=0, length=421, mtls = 0
Mon Dec 5 10:54:06 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.181:5060 [UDP])
SIP/2.0 200 OK
Accept: application/simple-message-summary
Call-ID: 20433029
Allow-Events: message-summary
Content-Length: 0
Mon Dec 5 10:54:06 2022 [CIOCom::receiveResponse] CResponse 35CA3 ref=1
Mon Dec 5 10:54:06 2022 11a1 [CCall::receiveResponse] 200
Mon Dec 5 10:54:06 2022 15b7 [CDialog::receiveResponse]
Mon Dec 5 10:54:06 2022 215a [CTransTryingState::receiveResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] STATE CHANGED TO COMPLETED
1670237646 -> Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:06 2022 15b7 [CDialog::onTransactionState(pTrans = 215a, previousState = Trying, currentState = Completed, reason = Final resp reception]
Mon Dec 5 10:54:06 2022 215a [CTransaction::freeTimerToken] Timer E is freed
Mon Dec 5 10:54:06 2022 215a [CTransaction::freeTimerToken] Timer F is freed
Mon Dec 5 10:54:06 2022 215a [CTransaction::startTimer] Timer K is started (delay = 5000 ms)
Mon Dec 5 10:54:06 2022 cc [CSubscription::update] update on request
Mon Dec 5 10:54:06 2022 11a1[CMotorCall::onReceiveResponse] Update1 the Other context.
Mon Dec 5 10:54:06 2022 [CSubscriptionState::receiveResponseMessage] Call: 20433029 eqt: 1448 SUBSCRIPTION_STATE received a message.
Mon Dec 5 10:54:06 2022 [CSubscriptionState::receiveResponseMessage] response for event
Mon Dec 5 10:54:06 2022 11a1[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:06 2022 11a1[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:06 2022 11a1[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:06 2022 11a1[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:06 2022 [sendLgEvtSip] seplos Event sent on eqt : 1448 Id :2
Mon Dec 5 10:54:06 2022 Id : 2
1670237646 -> Mon Dec 5 10:54:06 2022 SUCCESSFUL
Mon Dec 5 10:54:06 2022 RELATIVE REQUEST : NOTIFY
Mon Dec 5 10:54:06 2022 [ipc_thread] Normal case : evt 10773
Mon Dec 5 10:54:06 2022 11a1[CMotorCall::unRegister] Remove eqt : 1448 diag : 2 from the map.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::eraseCallwithEqt] erase 1448 2.
Mon Dec 5 10:54:06 2022 [CSubscriptionState::receiveResponseMessage] Final response => eqt released.
Mon Dec 5 10:54:06 2022 SIP EQT RELEASED
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1448 2.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] NO call with eqt: 1448 2 to release.
Mon Dec 5 10:54:06 2022 is_a_JONCT
Mon Dec 5 10:54:06 2022 udp_recv fd:5 iBytesRead:402
Mon Dec 5 10:54:06 2022 UdpInputProc iSock:5 iBytesRead:402 Host:192.168.1.181 Port:5060
1670237646 -> Mon Dec 5 10:54:06 2022 [CTransportUdp::receiveMessage] from 192.168.1.181:5060 rc:402
Mon Dec 5 10:54:06 2022 [CIOCom::onReceiveMessage] received from 192.168.1.181:5060, proto=0, length=402, mtls = 0
ACK sip:192.168.1.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.181;branch=z9hG4bK37d2e6257a1ecd2c2
Max-Forwards: 70
Call-ID: c706eb47
CSeq: 1090543851 ACK
User-Agent: ALE ALE-2 2.12.20.000.2036 3c28a608b7bd
Content-Length: 0
Mon Dec 5 10:54:06 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:06 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:06 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:06 2022 35737 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:06 2022 [CIOCom::receiveRequest] Received CRequest 35737 ref=1
Mon Dec 5 10:54:06 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.181 alcResult= 0
Mon Dec 5 10:54:06 2022 [CIOCom::receiveRequest] rport1 not empty
1670237646 -> Mon Dec 5 10:54:06 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:06 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:06 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:06 2022 1180 [CCall::receiveRequest] ACK
Mon Dec 5 10:54:06 2022 1180 [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:54:06 2022 1574 [CDialog::receiveRequest]
Mon Dec 5 10:54:06 2022 1574 [CDialog::receiveAckRequest]
Mon Dec 5 10:54:06 2022 1574 [CDialog::getTransactionByCSeq] CSeq = 1090543851
Mon Dec 5 10:54:06 2022 215b [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:06 2022 215b [CTransaction::freeTimerToken] Timer G is freed
Mon Dec 5 10:54:06 2022 215b [CTransaction::freeTimerToken] Timer H is freed
Mon Dec 5 10:54:06 2022 215b [CTransaction::changeState] no transaction state, terminated reason : Request reception
Mon Dec 5 10:54:06 2022 1574 [CDialog::receiveAckRequest] the INVITE request is terminated
Mon Dec 5 10:54:06 2022 1180 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:06 2022 1180 [CCall::checkAuthentication] ACK
Mon Dec 5 10:54:06 2022 1180[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:06 2022 1180[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:54:06 2022 1180 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:06 2022 1180 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:06 2022 1180 [CCall::checkAuthentication] iRetValue=0
1670237646 -> Mon Dec 5 10:54:06 2022 1180 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onReceiveRequest] state = ACCEPTED_STATE.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::compareDialogFromContext] same Dialog
Mon Dec 5 10:54:06 2022 1180[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Dec 5 10:54:06 2022 [receiveAckMessage] Call: c706eb47 eqt: 1448 ACCEPTED_STATE received a message.
Mon Dec 5 10:54:06 2022 [receiveAckMessage] g711u: 255 g711A: 255 g723: 255 g729: 255.
Mon Dec 5 10:54:06 2022 1180[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:06 2022 1180[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:06 2022 1180[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:06 2022 1180[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:06 2022 [sendLgEvtSip] seplos Event sent on eqt : 1448 Id :1
1670237646 -> Mon Dec 5 10:54:06 2022 1180[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:06 2022 [receiveAckMessage] continue with session Timer
Mon Dec 5 10:54:06 2022 35737 [~CRequest] req c706eb47 1090543851 ACK
Mon Dec 5 10:54:06 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:06 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:06 2022 1573 [CDialog::onTransactionState(pTrans = 2159, previousState = null, currentState = Terminated, reason = Request creation]
Mon Dec 5 10:54:06 2022 2159 [~CTransaction] transaction 192632951 INVITE
Mon Dec 5 10:54:06 2022 1574 [CDialog::onTransactionState(pTrans = 215b, previousState = null, currentState = Terminated, reason = Request reception]
Mon Dec 5 10:54:06 2022 215B [~CTransaction] transaction 1090543851 INVITE
Mon Dec 5 10:54:06 2022 102 [CCallManager::removeGarbage] at index i = 0
Mon Dec 5 10:54:06 2022 1182 [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:06 2022 1182[CMotorCall::~CMotorCall] Call : d3cb51948f8c4d0280ca3bb145661901 is being destructed.
Mon Dec 5 10:54:06 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
1670237647 -> Mon Dec 5 10:54:06 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:06 2022 1182 [CCall::~CCall] resources number: 142
Mon Dec 5 10:54:06 2022 1182 [CCall::TestDegradedModeEnd] resources number: 141
Mon Dec 5 10:54:06 2022 1182 [CCall::removeGarbage]
Mon Dec 5 10:54:06 2022 1572 [CDialog::~CDialog] resources number: 280
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Mon Dec 5 10:54:06 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:06 2022 35CA0 [~CResponse] resp(487) d3cb51948f8c4d0280ca3bb145661901 14859 INVITE
Mon Dec 5 10:54:06 2022 35732 [~CRequest] req d3cb51948f8c4d0280ca3bb145661901 14859 INVITE
Mon Dec 5 10:54:06 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:06 2022 [CCall::~CCall] Ends
1670237649 -> Mon Dec 5 10:54:08 2022 [fnInit] *************************** Init timeout.
Mon Dec 5 10:54:08 2022 [fnInit] treatTimeout.
Mon Dec 5 10:54:08 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:54:08 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:54:08 2022 [startRegistration] timer value=6000.
Mon Dec 5 10:54:09 2022 udp_recv fd:5
Mon Dec 5 10:54:09 2022 udp_recv fd:5 iBytesRead:961
Mon Dec 5 10:54:09 2022 UdpInputProc iSock:5 iBytesRead:961 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:09 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:961
Mon Dec 5 10:54:09 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:09 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=961, mtls = 0
Mon Dec 5 10:54:09 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
INVITE sip:8013@192.168.1.10 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.18:59400;rport;branch=z9hG4bKPj6206a64c632849188171df10980c184d
Max-Forwards: 70
From: <sip:8977@192.168.1.10>;tag=a2e0ad081f374441a75427342d80f265
Contact: <sip:8977@192.168.1.18:59400;ob>
Call-ID: 650144d220334e6aa23b392c117f65e9
CSeq: 379 INVITE
Route: <sip:192.168.1.10;lr>
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Supported: replaces, 100rel, timer, norefersub
Min-SE: 90
User-Agent: MicroSIP/3.21.3
Content-Length: 316
v=0
o=- 3879226478 3879226478 IN IP4 128.203.52.4
s=pjmedia
b=AS:84
t=0 0
a=X-nat:0
m=audio 4006 RTP/AVP 8 101
c=IN IP4 128.203.52.4
b=TIAS:64000
a=rtcp:4007 IN IP4 128.203.52.4
a=sendrecv
a=fmtp:101 0-16
a=ssrc:1812811380 cname:50c83f420a4318e2
1670237649 -> Mon Dec 5 10:54:09 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:09 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:09 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:09 2022 35738 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:09 2022 [CIOCom::receiveRequest] Received CRequest 35738 ref=1
Mon Dec 5 10:54:09 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:09 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:09 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:09 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:09 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:09 2022 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
Mon Dec 5 10:54:09 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:09 2022 [CMotorCallManager::callFactory] For call : 650144d220334e6aa23b392c117f65e9.
Mon Dec 5 10:54:09 2022 1183 [CCall::CCall] resources number: 143
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:09 2022 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.68.a
Mon Dec 5 10:54:09 2022 [CMotorCallManager::callFactory]=8de05f8.
1670237649 -> Mon Dec 5 10:54:09 2022 1183 [CCall::receiveRequest] INVITE
Mon Dec 5 10:54:09 2022 1183 [CCall::getDialog] Confirmed Dialog is not found (ID = ;a2e0ad081f374441a75427342d80f265)
Mon Dec 5 10:54:09 2022 1183 [CCall::getDialog] Initial Dialog Server not found
Mon Dec 5 10:54:09 2022 1575 [CDialog::CDialog] resources number: 281
Mon Dec 5 10:54:09 2022 1575 [CDialog::receiveRequest]
Mon Dec 5 10:54:09 2022 1575 [CDialog::receiveInviteRequest]
Mon Dec 5 10:54:09 2022 215c [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:09 2022 215c [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:09 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:09 2022 215c [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Dec 5 10:54:09 2022 215c [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:09 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Dec 5 10:54:09 2022 215c [CTransProceedingState::createResponse] CResponse 35CA4 ref=1
Mon Dec 5 10:54:09 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:09 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:09 2022 [DBG: CResponse::freeAttributes] Ends
1670237649 -> Mon Dec 5 10:54:09 2022 35CA4 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:09 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:09 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 319)
SIP/2.0 100 Trying
CSeq: 379 INVITE
Via: SIP/2.0/UDP 192.168.1.18:59400;received=192.168.1.18;rport=59400;branch=z9hG4bKPj6206a64c632849188171df10980c184d
Content-Length: 0
Mon Dec 5 10:54:09 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:09 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:09 2022 udp_send fd:5
Mon Dec 5 10:54:09 2022 udp_send fd:5 port 59400 iBytesSend:319
Mon Dec 5 10:54:09 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:09 2022 35CA4 [CMessage::onSendSuccess]
Mon Dec 5 10:54:09 2022 215c [CTransaction::onSendSuccess] CMessage 35CA4 send Success
Mon Dec 5 10:54:09 2022 1575 [CDialog::onSendSuccess]
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:09 2022 1575 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
1670237649 -> Mon Dec 5 10:54:09 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 90
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:09 2022 1575 [CDialog::addTransaction] added transaction 215c with branch z9hG4bKPj6206a64c632849188171df10980c184d, with CSeq 379
Mon Dec 5 10:54:09 2022 1183 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:09 2022 1183 [CCall::checkAuthentication] INVITE
Mon Dec 5 10:54:09 2022 1183[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:09 2022 [getFromHeader] look at the From.
Mon Dec 5 10:54:09 2022 [getFromHeader] displayName=.
Mon Dec 5 10:54:09 2022 [convertCSipURLIntoSipuri] uri = sip:8977@192.168.1.10.
Mon Dec 5 10:54:09 2022 [getFromHeader] =8977@192.168.1.10.
Mon Dec 5 10:54:09 2022 [getFromHeader] clirPresent=0.
Mon Dec 5 10:54:09 2022 [getReqUriHeader] look at the requri.
Mon Dec 5 10:54:09 2022 [convertCSipURLIntoSipuri] uri = sip:8013@192.168.1.10.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::getUserType] extGw=-1.
1670237649 -> Mon Dec 5 10:54:09 2022 [CMotorCall::analyseRouting] TEL uri=0.
Mon Dec 5 10:54:09 2022 [CMotorCall::analyseRouting] 8977@192.168.1.10 is authenticable.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setExtGw] -1->-3
Mon Dec 5 10:54:09 2022 [isUserInDico] looking for 8977@192.168.1.10 ...
Mon Dec 5 10:54:09 2022 [isUserInDico] found in the dictionnary.
Mon Dec 5 10:54:09 2022 [isAddrInDico] seplos station OK
Mon Dec 5 10:54:09 2022 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::getUserType] From is seplos station crypto=0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::getUserType] extGw=-3.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::controlAuthentication] m_other_calling=0 extgw=-3
Mon Dec 5 10:54:09 2022 1183[CMotorCall::controlAuthentication] from:sip:8977@192.168.1.10:5060
Mon Dec 5 10:54:09 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:09 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:09 2022 [CGwMngData::isAuthenticationRequiredForThisClient] 8977@192.168.1.10 .
Mon Dec 5 10:54:09 2022 [CGwMngData::isAuthenticationRequiredForThisClient] -3 need auth=0.
Mon Dec 5 10:54:09 2022 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway -3.
Mon Dec 5 10:54:09 2022 CGwMngData::isAuthenticationRequiredForThisClient: gateway=-3
1670237649 -> Mon Dec 5 10:54:09 2022 1183[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setExtGw] -3->-3
Mon Dec 5 10:54:09 2022 1183 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:09 2022 1183 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:09 2022 1183 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:09 2022 1183 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Dec 5 10:54:09 2022 1183[CMotorCall::initOfUserType] station role already defined s=1 d=0 o=0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onReceiveRequest] accepte? m_other_calling=0 gw=-1.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=2.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::toGatewayOrProxy] request for proxydomain=192.168.1.10.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::toGatewayOrProxy] from = seplos station.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] nb available licenses=0 .
1670237649 -> Mon Dec 5 10:54:09 2022 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Dec 5 10:54:09 2022 [CForkedBranch::CForkedBranch] context = 0x8de0bbc.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] reqUri stored: sip:8977@192.168.1.18:59400;ob
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] CAC = 0
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] Call: 650144d220334e6aa23b392c117f65e9 eqt: -1 INITIAL_STATE received a message.
Mon Dec 5 10:54:09 2022 [decodeInviteCLIR].
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] UPDATE present in Allow header
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] INFO present in Allow header
Mon Dec 5 10:54:09 2022 am_I_PCS SCSWorking : NO
Mon Dec 5 10:54:09 2022 check_PCSstate
Mon Dec 5 10:54:09 2022 check_PCSstate stat of PCS is : -1
Mon Dec 5 10:54:09 2022 1183[CMotorCall::analyseSessionTimer] Session Timer extGw=-1 sessionDelay=1800 .
1670237649 -> Mon Dec 5 10:54:09 2022 1183[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:09 2022 1183[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:09 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] Format : 8.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:09 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:09 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] The audio media contains 2 format(s).
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] 101.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Format is DTMF:101.
1670237649 -> Mon Dec 5 10:54:09 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Connection address retrieved in sdp: 128.203.52.4.
Mon Dec 5 10:54:09 2022 [convertIPStrIntoTuipv] 128.203.52.4 => 128.203.52.4
Mon Dec 5 10:54:09 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:09 2022 [display_sdp] address =128.203.52.4
Mon Dec 5 10:54:09 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:09 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:09 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Mon Dec 5 10:54:09 2022 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Dec 5 10:54:09 2022 [receiveinvitemessage] get requri.
Mon Dec 5 10:54:09 2022 [decodeInviteTo].
Mon Dec 5 10:54:09 2022 [decodeInviteReferredBy].
Mon Dec 5 10:54:09 2022 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
Mon Dec 5 10:54:09 2022 [decodeInviteACSBU].
Mon Dec 5 10:54:09 2022 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=1
1670237649 -> Mon Dec 5 10:54:09 2022 [receiveInviteMessage] concatenating from header
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] temp_fromuserinfo = 8977
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] From_userinfo = 8977
Mon Dec 5 10:54:09 2022 1183[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:09 2022 [ipc_thread] Normal case : evt 10764
Mon Dec 5 10:54:09 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:09 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1464 inserted.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::sendLgEvtSipCreate] Event sent on eqt : 1464
Mon Dec 5 10:54:09 2022 ** SEPLOS/IP-DECT **
Mon Dec 5 10:54:09 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:09 2022 Id : -1
Mon Dec 5 10:54:09 2022 INVITE
Mon Dec 5 10:54:09 2022 REQUEST URI : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:09 2022 FROM : <> 8977@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:09 2022 TO : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:09 2022 CAC : 0
Mon Dec 5 10:54:09 2022 CAC ADDRESS :
Mon Dec 5 10:54:09 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:09 2022 CLIR : 0
Mon Dec 5 10:54:09 2022 Prack Required : 0
Mon Dec 5 10:54:09 2022 Allow Update : 0
Mon Dec 5 10:54:09 2022 SDP :
Mon Dec 5 10:54:09 2022 ADDRESS : 128.203.52.4 :4006
1670237649 -> Mon Dec 5 10:54:09 2022 ALGOS :
Mon Dec 5 10:54:09 2022 PCMA
Mon Dec 5 10:54:09 2022 101
Mon Dec 5 10:54:09 2022 DIRECTION : SEND & RECEIVE
Mon Dec 5 10:54:09 2022 video index : 0
Mon Dec 5 10:54:09 2022 crypto index : 0
Mon Dec 5 10:54:09 2022 N_GW_EXT : -1
Mon Dec 5 10:54:09 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:09 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:09 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:09 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:09 2022 INFORMATIONAL
Mon Dec 5 10:54:09 2022 xx : 0
Mon Dec 5 10:54:09 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:09 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1464 1.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] an event arrived on an invalid eqt 1464 1.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::unRegister] Remove eqt : 1464 diag : -1 from the map.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 -1.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] dialogId update done.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] NOE-SIP : No updates to Twin
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] seplos station.
1670237649 -> Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:09 2022 [onIncomingEvent] INFORMATIONAL arrived.
Mon Dec 5 10:54:09 2022 [onIncomingEvent] 100 TRYING ignored.
Mon Dec 5 10:54:09 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:09 2022 xx : 83
Mon Dec 5 10:54:09 2022 ADDRESS : 192.168.1.11 :32528
1670237649 -> Mon Dec 5 10:54:09 2022 [receiveInformationalEvent] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:09 2022 1183[CMotorCall::buildContact] Contact: sip:192.168.1.10:5060
Mon Dec 5 10:54:09 2022 1183[CMotorCall::emitInformationMessage] cause=183
Mon Dec 5 10:54:09 2022 1183[CMotorCall::makeResponseSdpAudioOld] Audio media.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:09 2022 1183[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Mon Dec 5 10:54:09 2022 [sameCodec] accepted Format : 8.
Mon Dec 5 10:54:09 2022 [sameCodec] requested Format : 8.
Mon Dec 5 10:54:09 2022 [sameCodec] same Format.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::mediaAccepted] Media accepted: m=audio 32528 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:09 2022 1183[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
1670237649 -> Mon Dec 5 10:54:09 2022 1183[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Mon Dec 5 10:54:09 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:09 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:09 2022 1183[CMotorCall::emitInformationalMessage] Answer sdp.
Mon Dec 5 10:54:09 2022 [removeAudioMediaPortNull] media no=0.
Mon Dec 5 10:54:09 2022 1183 [CCall::makeGenericResponse] 183
Mon Dec 5 10:54:09 2022 1183 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:09 2022 1575 [CDialog::createResponse] 183
Mon Dec 5 10:54:09 2022 215c [CTransProceedingState::createResponse] CResponse 35CA5 ref=1
Mon Dec 5 10:54:09 2022 35CA5 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:09 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 832)
SIP/2.0 183 Session Progress
User-Agent: OmniPCX Enterprise R100.0 n1.291.68.a
Reason: SIP;cause=183;text="is busy "
To: <sip:8013@192.168.1.10>;tag=59a14315fc134fbad4d54280ec9af2e4
CSeq: 379 INVITE
Content-Length: 216
v=0
o=OXE 1670237649 1670237649 IN IP4 192.168.1.10
s=abs
c=IN IP4 192.168.1.11
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1670237650 -> Mon Dec 5 10:54:09 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:09 2022 udp_send fd:5 port 59400 iBytesSend:832
Mon Dec 5 10:54:09 2022 35CA5 [CMessage::onSendSuccess]
Mon Dec 5 10:54:09 2022 215c [CTransaction::onSendSuccess] CMessage 35CA5 send Success
Mon Dec 5 10:54:09 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:09 2022 35CA4 [~CResponse] resp(100) 650144d220334e6aa23b392c117f65e9 379 INVITE
Mon Dec 5 10:54:09 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:09 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:09 2022 1575 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:10 2022 udp_recv fd:5
Mon Dec 5 10:54:10 2022 udp_recv fd:5 iBytesRead:387
Mon Dec 5 10:54:10 2022 UdpInputProc iSock:5 iBytesRead:387 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:10 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:387
1670237650 -> Mon Dec 5 10:54:10 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:10 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=387, mtls = 0
Mon Dec 5 10:54:10 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
CANCEL sip:8013@192.168.1.10 SIP/2.0
Max-Forwards: 70
CSeq: 379 CANCEL
Content-Length: 0
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:10 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:10 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:10 2022 35739 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] Received CRequest 35739 ref=1
Mon Dec 5 10:54:10 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
1670237650 -> Mon Dec 5 10:54:10 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:10 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:10 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:10 2022 1183 [CCall::receiveRequest] CANCEL
Mon Dec 5 10:54:10 2022 1183 [CCall::getDialog] Confirmed Dialog is not found (ID = ;a2e0ad081f374441a75427342d80f265)
Mon Dec 5 10:54:10 2022 1183 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:10 2022 1575 [CDialog::receiveRequest]
Mon Dec 5 10:54:10 2022 1575 [CDialog::receiveCancelRequest]
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215d, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:10 2022 215d [CTransInitialState::receiveRequest] Transaction changes to Trying state
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215d, previousState = Initial, currentState = Trying, reason = Request reception]
Mon Dec 5 10:54:10 2022 1183 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:10 2022 1183 [CCall::checkAuthentication] CANCEL
Mon Dec 5 10:54:10 2022 1183[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
1670237650 -> Mon Dec 5 10:54:10 2022 1183[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:54:10 2022 1183 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:10 2022 1183 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:10 2022 1183 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:10 2022 1183 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:10 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:10 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] state = PROCEEDING_STATE.
Mon Dec 5 10:54:10 2022 [receiveCancelMessage] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:10 2022 ** SEPLOS **
Mon Dec 5 10:54:10 2022 [sendLgEvtSip] seplos Event sent on eqt : 1464 Id :1
Mon Dec 5 10:54:10 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:10 2022 Id : 1
Mon Dec 5 10:54:10 2022 CANCEL
1670237650 -> Mon Dec 5 10:54:10 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:10 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:54:10 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:10 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:10 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:10 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:10 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:10 2022 SUCCESSFUL
Mon Dec 5 10:54:10 2022 xx : 0
Mon Dec 5 10:54:10 2022 RELATIVE REQUEST : CANCEL
Mon Dec 5 10:54:10 2022 CLIR : 0
Mon Dec 5 10:54:10 2022 COLP : 0
Mon Dec 5 10:54:10 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:10 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1464 1.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:10 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:54:10 2022 [onIncomingEvent] relative_request = 10756
Mon Dec 5 10:54:10 2022 [CProceedingState::receiveSuccessfulEvent] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:10 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
Mon Dec 5 10:54:10 2022 1575 [CCall::findFirstServerTrans]
Mon Dec 5 10:54:10 2022 1575 [CDialog::findFirstServerTrans] Current Request in cancelTransactionMap
1670237650 -> Mon Dec 5 10:54:10 2022 1183 [CCall::makeGenericResponse] 200
Mon Dec 5 10:54:10 2022 1575 [CDialog::createResponse] 200
Mon Dec 5 10:54:10 2022 215d [CTransTryingState::createResponse] CResponse 35CA6 ref=1
Mon Dec 5 10:54:10 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:10 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:10 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:10 2022 35CA6 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:10 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:10 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 405)
SIP/2.0 200 OK
Supported: replaces,timer,path,100rel
CSeq: 379 CANCEL
Content-Length: 0
Mon Dec 5 10:54:10 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
1670237650 -> Mon Dec 5 10:54:10 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:10 2022 udp_send fd:5
Mon Dec 5 10:54:10 2022 udp_send fd:5 port 59400 iBytesSend:405
Mon Dec 5 10:54:10 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:10 2022 35CA6 [CMessage::onSendSuccess]
Mon Dec 5 10:54:10 2022 215d [CTransaction::onSendSuccess] CMessage 35CA6 send Success
Mon Dec 5 10:54:10 2022 1575 [CDialog::onSendSuccess]
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:10 2022 215d [CTransTryingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215d, previousState = Trying, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:10 2022 215d [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
Mon Dec 5 10:54:10 2022 1575 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:10 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:10 2022 [ipc_thread] Normal case : evt 10767
1670237650 -> Mon Dec 5 10:54:10 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:10 2022 REQUEST FAILURE
Mon Dec 5 10:54:10 2022 xx : 87
Mon Dec 5 10:54:10 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] an event 10767 arrived on the eqt 1464 1.
Mon Dec 5 10:54:10 2022 [onIncomingEvent] REQUEST FAILURE arrived.
Mon Dec 5 10:54:10 2022 [receiveRequestFailureEvent] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::getOutgoingCall] outgoingCall:0
Mon Dec 5 10:54:10 2022 [receiveRequestFailureEvent] incoming call.
Mon Dec 5 10:54:10 2022 1183 [CCall::makeGenericResponse] 487
Mon Dec 5 10:54:10 2022 1183 [CCall::getDialog] Confirmed Dialog is not found (ID = 59a14315fc134fbad4d54280ec9af2e4;a2e0ad081f374441a75427342d80f265)
Mon Dec 5 10:54:10 2022 1575 [CDialog::createResponse] 487
Mon Dec 5 10:54:10 2022 215c [CTransProceedingState::createResponse] CResponse 35CA7 ref=1
1670237650 -> Mon Dec 5 10:54:10 2022 35CA7 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:10 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 502)
SIP/2.0 487 Request Terminated
CSeq: 379 INVITE
Content-Length: 0
Mon Dec 5 10:54:10 2022 udp_send fd:5 port 59400 iBytesSend:502
Mon Dec 5 10:54:10 2022 35CA7 [CMessage::onSendSuccess]
Mon Dec 5 10:54:10 2022 215c [CTransaction::onSendSuccess] CMessage 35CA7 send Success
1670237650 -> Mon Dec 5 10:54:10 2022 1575 [CDialog::onSendSuccess]
Mon Dec 5 10:54:10 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:10 2022 35CA5 [~CResponse] resp(183) 650144d220334e6aa23b392c117f65e9 379 INVITE
Mon Dec 5 10:54:10 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:10 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:10 2022 215c [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:10 2022 215c [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Dec 5 10:54:10 2022 215c [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Dec 5 10:54:10 2022 1183[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:10 2022 udp_recv fd:5 iBytesRead:389
Mon Dec 5 10:54:10 2022 UdpInputProc iSock:5 iBytesRead:389 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:10 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:389
Mon Dec 5 10:54:10 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=389, mtls = 0
ACK sip:8013@192.168.1.10 SIP/2.0
Max-Forwards: 70
CSeq: 379 ACK
Content-Length: 0
Mon Dec 5 10:54:10 2022 3573A [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] Received CRequest 3573A ref=1
Mon Dec 5 10:54:10 2022 1183 [CCall::receiveRequest] ACK
Mon Dec 5 10:54:10 2022 1575 [CDialog::receiveAckRequest]
Mon Dec 5 10:54:10 2022 215c [CTransCompletedState::receiveRequest] ACK(UDP) : Transaction changes to Confirmed state
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] STATE CHANGED TO CONFIRMED
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = Completed, currentState = Confirmed, reason = Request reception]
Mon Dec 5 10:54:10 2022 215c [CTransaction::freeTimerToken] Timer G is freed
Mon Dec 5 10:54:10 2022 215c [CTransaction::freeTimerToken] Timer H is freed
Mon Dec 5 10:54:10 2022 215c [CTransaction::startTimer] Timer I is started (delay = 5000 ms)
Mon Dec 5 10:54:10 2022 1575 [CDialog::receiveAckRequest] receiving an ACK on a previously rejected INVITE
Mon Dec 5 10:54:10 2022 1183 [CCall::checkAuthentication] ACK
1670237650 -> Mon Dec 5 10:54:10 2022 1183[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] state = TERMINATED_STATE.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::compareDialogFromContext] same Dialog
Mon Dec 5 10:54:10 2022 1183[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Dec 5 10:54:10 2022 [receiveAckMessage] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 TERMINATED_STATE received a message.
Mon Dec 5 10:54:10 2022 [receiveAckMessage] boolean flag check 0
1670237650 -> Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:10 2022 ACK
Mon Dec 5 10:54:10 2022 [ipc_thread] Normal case : evt 10773
Mon Dec 5 10:54:10 2022 SIP EQT RELEASED
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1464 1.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1464 has released its equipment.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::unRegister] Remove eqt : 1464 diag : 1 from the map.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 1.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] killSession.
1670237650 -> Mon Dec 5 10:54:10 2022 1183 [CCall::killSession]
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:10 2022 215d [CTransaction::freeTimerToken] Timer J is freed
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:10 2022 215c [CTransaction::freeTimerToken] Timer I is freed
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:10 2022 1183 [CCall::killSession] notifying the call manager
Mon Dec 5 10:54:10 2022 102 [CCallManager::onCallClosed]
Mon Dec 5 10:54:10 2022 102 [CCallManager::onCallClosed()] Call 1183 closed. Removing call 148768248 from the maps
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onNotifyCallClosed] Call : 650144d220334e6aa23b392c117f65e9 is closed.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onNotifyCallClosed] call processResponse.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::chooseBestResponse] pForkedBranch=0x8adc9f8 iResponseCode=2000.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::processResponse] no response found.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
Mon Dec 5 10:54:10 2022 102 [CCallManager::onCallClosed] pCall: 1183 added in the Garbage List
1670237650 -> Mon Dec 5 10:54:10 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:10 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215d, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:10 2022 215D [~CTransaction] transaction 379 CANCEL
Mon Dec 5 10:54:10 2022 35CA6 [~CResponse] resp(200) 650144d220334e6aa23b392c117f65e9 379 CANCEL
Mon Dec 5 10:54:10 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:10 2022 35739 [~CRequest] req 650144d220334e6aa23b392c117f65e9 379 CANCEL
Mon Dec 5 10:54:10 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:54:10 2022 1183 [CCall::onDialogClosed]
Mon Dec 5 10:54:10 2022 1183 [CCall::onDialogClosed] only initial *********
Mon Dec 5 10:54:10 2022 1183 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
1670237651 -> Mon Dec 5 10:54:10 2022 215C [~CTransaction] transaction 379 INVITE
Mon Dec 5 10:54:10 2022 3573A [~CRequest] req 650144d220334e6aa23b392c117f65e9 379 ACK
Mon Dec 5 10:54:11 2022 215a [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:54:11 2022 215a [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:54:11 2022 215a [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:11 2022 215a [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
1670237652 -> Mon Dec 5 10:54:11 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:11 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:11 2022 15b7 [CDialog::onTransactionState(pTrans = 215a, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:54:11 2022 215A [~CTransaction] transaction 1340449647 NOTIFY
Mon Dec 5 10:54:11 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:11 2022 35CA3 [~CResponse] resp(200) 20433029 1340449647 NOTIFY
Mon Dec 5 10:54:11 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:11 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:11 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:12 2022 102 [CCallManager::removeGarbage] at index i = 0
Mon Dec 5 10:54:12 2022 1183 [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:12 2022 1183[CMotorCall::~CMotorCall] Call : 650144d220334e6aa23b392c117f65e9 is being destructed.
Mon Dec 5 10:54:12 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
Mon Dec 5 10:54:12 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:12 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:12 2022 1183 [CCall::~CCall] resources number: 142
Mon Dec 5 10:54:12 2022 1183 [CCall::TestDegradedModeEnd] resources number: 141
Mon Dec 5 10:54:12 2022 1183 [CCall::removeGarbage]
1670237654 -> Mon Dec 5 10:54:12 2022 1575 [CDialog::~CDialog] resources number: 280
Mon Dec 5 10:54:12 2022 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Mon Dec 5 10:54:12 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:12 2022 35CA7 [~CResponse] resp(487) 650144d220334e6aa23b392c117f65e9 379 INVITE
Mon Dec 5 10:54:12 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:12 2022 35738 [~CRequest] req 650144d220334e6aa23b392c117f65e9 379 INVITE
Mon Dec 5 10:54:12 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:12 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:12 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:12 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:12 2022 [CCall::~CCall] Ends
Mon Dec 5 10:54:14 2022 udp_recv fd:5
Mon Dec 5 10:54:14 2022 udp_recv fd:5 iBytesRead:2
Mon Dec 5 10:54:14 2022 UdpInputProc iSock:5 iBytesRead:2 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:14 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:2
Mon Dec 5 10:54:14 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:14 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=2, mtls = 0
Mon Dec 5 10:54:14 2022 [CKeepaliveManager::receiveSignal]
Mon Dec 5 10:54:14 2022 [fnInit] *************************** Init timeout.
1670237655 -> Mon Dec 5 10:54:14 2022 [fnInit] treatTimeout.
Mon Dec 5 10:54:14 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:54:14 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:54:14 2022 [startRegistration] timer value=6000.
1670237657 -> Mon Dec 5 10:54:17 2022 udp_recv fd:5
Mon Dec 5 10:54:17 2022 udp_recv fd:5 iBytesRead:963
Mon Dec 5 10:54:17 2022 UdpInputProc iSock:5 iBytesRead:963 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:17 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:963
Mon Dec 5 10:54:17 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:17 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=963, mtls = 0
Mon Dec 5 10:54:17 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
Via: SIP/2.0/UDP 192.168.1.18:59400;rport;branch=z9hG4bKPj9990e1d5be1541b7831111ff6b5b806d
Max-Forwards: 70
From: <sip:8977@192.168.1.10>;tag=81773224f44f4986a3b807271b8b4aa7
Call-ID: 84c32c4358944277aa0bb426f51564c1
CSeq: 23371 INVITE
Min-SE: 90
Content-Type: application/sdp
Content-Length: 316
v=0
o=- 3879226487 3879226487 IN IP4 128.203.52.4
s=pjmedia
b=AS:84
t=0 0
a=X-nat:0
m=audio 4008 RTP/AVP 8 101
b=TIAS:64000
a=rtcp:4009 IN IP4 128.203.52.4
a=sendrecv
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ssrc:1765374817 cname:57b226f2714b4f61
1670237657 -> Mon Dec 5 10:54:17 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:17 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:17 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:17 2022 3573B [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:17 2022 [CIOCom::receiveRequest] Received CRequest 3573B ref=1
Mon Dec 5 10:54:17 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:17 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:17 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:17 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:17 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:17 2022 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
Mon Dec 5 10:54:17 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:17 2022 [CMotorCallManager::callFactory] For call : 84c32c4358944277aa0bb426f51564c1.
Mon Dec 5 10:54:17 2022 1184 [CCall::CCall] resources number: 143
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:17 2022 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.68.a
Mon Dec 5 10:54:17 2022 [CMotorCallManager::callFactory]=8de05f8.
1670237657 -> Mon Dec 5 10:54:17 2022 1184 [CCall::receiveRequest] INVITE
Mon Dec 5 10:54:17 2022 1184 [CCall::getDialog] Confirmed Dialog is not found (ID = ;81773224f44f4986a3b807271b8b4aa7)
Mon Dec 5 10:54:17 2022 1184 [CCall::getDialog] Initial Dialog Server not found
Mon Dec 5 10:54:17 2022 1576 [CDialog::CDialog] resources number: 281
Mon Dec 5 10:54:17 2022 1576 [CDialog::receiveRequest]
Mon Dec 5 10:54:17 2022 1576 [CDialog::receiveInviteRequest]
Mon Dec 5 10:54:17 2022 215e [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:17 2022 215e [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:17 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:17 2022 215e [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Dec 5 10:54:17 2022 215e [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:17 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Dec 5 10:54:17 2022 215e [CTransProceedingState::createResponse] CResponse 35CA8 ref=1
Mon Dec 5 10:54:17 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:17 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:17 2022 [DBG: CResponse::freeAttributes] Ends
1670237657 -> Mon Dec 5 10:54:17 2022 35CA8 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:17 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:17 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 321)
SIP/2.0 100 Trying
CSeq: 23371 INVITE
Via: SIP/2.0/UDP 192.168.1.18:59400;received=192.168.1.18;rport=59400;branch=z9hG4bKPj9990e1d5be1541b7831111ff6b5b806d
Content-Length: 0
Mon Dec 5 10:54:17 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:17 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:17 2022 udp_send fd:5
Mon Dec 5 10:54:17 2022 udp_send fd:5 port 59400 iBytesSend:321
Mon Dec 5 10:54:17 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:17 2022 35CA8 [CMessage::onSendSuccess]
Mon Dec 5 10:54:17 2022 215e [CTransaction::onSendSuccess] CMessage 35CA8 send Success
Mon Dec 5 10:54:17 2022 1576 [CDialog::onSendSuccess]
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:17 2022 1576 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
1670237657 -> Mon Dec 5 10:54:17 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 90
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:17 2022 1576 [CDialog::addTransaction] added transaction 215e with branch z9hG4bKPj9990e1d5be1541b7831111ff6b5b806d, with CSeq 23371
Mon Dec 5 10:54:17 2022 1184 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:17 2022 1184 [CCall::checkAuthentication] INVITE
Mon Dec 5 10:54:17 2022 1184[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:17 2022 [getFromHeader] look at the From.
Mon Dec 5 10:54:17 2022 [getFromHeader] displayName=.
Mon Dec 5 10:54:17 2022 [convertCSipURLIntoSipuri] uri = sip:8977@192.168.1.10.
Mon Dec 5 10:54:17 2022 [getFromHeader] =8977@192.168.1.10.
Mon Dec 5 10:54:17 2022 [getFromHeader] clirPresent=0.
Mon Dec 5 10:54:17 2022 [getReqUriHeader] look at the requri.
Mon Dec 5 10:54:17 2022 [convertCSipURLIntoSipuri] uri = sip:8013@192.168.1.10.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::getUserType] extGw=-1.
1670237657 -> Mon Dec 5 10:54:17 2022 [CMotorCall::analyseRouting] TEL uri=0.
Mon Dec 5 10:54:17 2022 [CMotorCall::analyseRouting] 8977@192.168.1.10 is authenticable.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setExtGw] -1->-3
Mon Dec 5 10:54:17 2022 [isUserInDico] looking for 8977@192.168.1.10 ...
Mon Dec 5 10:54:17 2022 [isUserInDico] found in the dictionnary.
Mon Dec 5 10:54:17 2022 [isAddrInDico] seplos station OK
Mon Dec 5 10:54:17 2022 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::getUserType] From is seplos station crypto=0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::getUserType] extGw=-3.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::controlAuthentication] m_other_calling=0 extgw=-3
Mon Dec 5 10:54:17 2022 1184[CMotorCall::controlAuthentication] from:sip:8977@192.168.1.10:5060
Mon Dec 5 10:54:17 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:17 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:17 2022 [CGwMngData::isAuthenticationRequiredForThisClient] 8977@192.168.1.10 .
Mon Dec 5 10:54:17 2022 [CGwMngData::isAuthenticationRequiredForThisClient] -3 need auth=0.
Mon Dec 5 10:54:17 2022 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway -3.
Mon Dec 5 10:54:17 2022 CGwMngData::isAuthenticationRequiredForThisClient: gateway=-3
1670237657 -> Mon Dec 5 10:54:17 2022 1184[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setExtGw] -3->-3
Mon Dec 5 10:54:17 2022 1184 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:17 2022 1184 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:17 2022 1184 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:17 2022 1184 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Dec 5 10:54:17 2022 1184[CMotorCall::initOfUserType] station role already defined s=1 d=0 o=0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onReceiveRequest] accepte? m_other_calling=0 gw=-1.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=2.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::toGatewayOrProxy] request for proxydomain=192.168.1.10.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::toGatewayOrProxy] from = seplos station.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] nb available licenses=0 .
1670237657 -> Mon Dec 5 10:54:17 2022 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Dec 5 10:54:17 2022 [CForkedBranch::CForkedBranch] context = 0x8de0bbc.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] reqUri stored: sip:8977@192.168.1.18:59400;ob
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] CAC = 0
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] Call: 84c32c4358944277aa0bb426f51564c1 eqt: -1 INITIAL_STATE received a message.
Mon Dec 5 10:54:17 2022 [decodeInviteCLIR].
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] UPDATE present in Allow header
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] INFO present in Allow header
Mon Dec 5 10:54:17 2022 am_I_PCS SCSWorking : NO
Mon Dec 5 10:54:17 2022 check_PCSstate
Mon Dec 5 10:54:17 2022 check_PCSstate stat of PCS is : -1
Mon Dec 5 10:54:17 2022 1184[CMotorCall::analyseSessionTimer] Session Timer extGw=-1 sessionDelay=1800 .
1670237657 -> Mon Dec 5 10:54:17 2022 1184[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:17 2022 1184[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:17 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] Format : 8.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:17 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:17 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] The audio media contains 2 format(s).
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] 101.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Format is DTMF:101.
1670237657 -> Mon Dec 5 10:54:17 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Connection address retrieved in sdp: 128.203.52.4.
Mon Dec 5 10:54:17 2022 [convertIPStrIntoTuipv] 128.203.52.4 => 128.203.52.4
Mon Dec 5 10:54:17 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:17 2022 [display_sdp] address =128.203.52.4
Mon Dec 5 10:54:17 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:17 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:17 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Mon Dec 5 10:54:17 2022 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Dec 5 10:54:17 2022 [receiveinvitemessage] get requri.
Mon Dec 5 10:54:17 2022 [decodeInviteTo].
Mon Dec 5 10:54:17 2022 [decodeInviteReferredBy].
Mon Dec 5 10:54:17 2022 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
Mon Dec 5 10:54:17 2022 [decodeInviteACSBU].
Mon Dec 5 10:54:17 2022 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=1
1670237657 -> Mon Dec 5 10:54:17 2022 [receiveInviteMessage] concatenating from header
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] temp_fromuserinfo = 8977
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] From_userinfo = 8977
Mon Dec 5 10:54:17 2022 1184[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:17 2022 [ipc_thread] Normal case : evt 10764
Mon Dec 5 10:54:17 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:17 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1464 inserted.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::sendLgEvtSipCreate] Event sent on eqt : 1464
Mon Dec 5 10:54:17 2022 ** SEPLOS/IP-DECT **
Mon Dec 5 10:54:17 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:17 2022 Id : -1
Mon Dec 5 10:54:17 2022 INVITE
Mon Dec 5 10:54:17 2022 REQUEST URI : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:17 2022 FROM : <> 8977@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:17 2022 TO : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:17 2022 CAC : 0
Mon Dec 5 10:54:17 2022 CAC ADDRESS :
Mon Dec 5 10:54:17 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:17 2022 CLIR : 0
Mon Dec 5 10:54:17 2022 Prack Required : 0
Mon Dec 5 10:54:17 2022 Allow Update : 0
Mon Dec 5 10:54:17 2022 SDP :
Mon Dec 5 10:54:17 2022 ADDRESS : 128.203.52.4 :4008
1670237657 -> Mon Dec 5 10:54:17 2022 ALGOS :
Mon Dec 5 10:54:17 2022 PCMA
Mon Dec 5 10:54:17 2022 101
Mon Dec 5 10:54:17 2022 DIRECTION : SEND & RECEIVE
Mon Dec 5 10:54:17 2022 video index : 0
Mon Dec 5 10:54:17 2022 crypto index : 0
Mon Dec 5 10:54:17 2022 N_GW_EXT : -1
Mon Dec 5 10:54:17 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:17 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:17 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:17 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:17 2022 INFORMATIONAL
Mon Dec 5 10:54:17 2022 xx : 0
Mon Dec 5 10:54:17 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:17 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1464 1.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] an event arrived on an invalid eqt 1464 1.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::unRegister] Remove eqt : 1464 diag : -1 from the map.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 -1.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] dialogId update done.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] NOE-SIP : No updates to Twin
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] seplos station.
1670237657 -> Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:17 2022 [onIncomingEvent] INFORMATIONAL arrived.
Mon Dec 5 10:54:17 2022 [onIncomingEvent] 100 TRYING ignored.
Mon Dec 5 10:54:17 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:17 2022 xx : 83
Mon Dec 5 10:54:17 2022 ADDRESS : 192.168.1.11 :32532
1670237657 -> Mon Dec 5 10:54:17 2022 [receiveInformationalEvent] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:17 2022 1184[CMotorCall::buildContact] Contact: sip:192.168.1.10:5060
Mon Dec 5 10:54:17 2022 1184[CMotorCall::emitInformationMessage] cause=183
Mon Dec 5 10:54:17 2022 1184[CMotorCall::makeResponseSdpAudioOld] Audio media.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:17 2022 1184[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Mon Dec 5 10:54:17 2022 [sameCodec] accepted Format : 8.
Mon Dec 5 10:54:17 2022 [sameCodec] requested Format : 8.
Mon Dec 5 10:54:17 2022 [sameCodec] same Format.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::mediaAccepted] Media accepted: m=audio 32532 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:17 2022 1184[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
1670237657 -> Mon Dec 5 10:54:17 2022 1184[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Mon Dec 5 10:54:17 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:17 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:17 2022 1184[CMotorCall::emitInformationalMessage] Answer sdp.
Mon Dec 5 10:54:17 2022 [removeAudioMediaPortNull] media no=0.
Mon Dec 5 10:54:17 2022 1184 [CCall::makeGenericResponse] 183
Mon Dec 5 10:54:17 2022 1184 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:17 2022 1576 [CDialog::createResponse] 183
Mon Dec 5 10:54:17 2022 215e [CTransProceedingState::createResponse] CResponse 35CA9 ref=1
Mon Dec 5 10:54:17 2022 35CA9 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:17 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 834)
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
To: <sip:8013@192.168.1.10>;tag=991fdf61c064cb11a3be7f9e550ecd5e
CSeq: 23371 INVITE
Content-Length: 216
v=0
o=OXE 1670237657 1670237657 IN IP4 192.168.1.10
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1670237659 -> Mon Dec 5 10:54:17 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:17 2022 udp_send fd:5 port 59400 iBytesSend:834
Mon Dec 5 10:54:17 2022 35CA9 [CMessage::onSendSuccess]
Mon Dec 5 10:54:17 2022 215e [CTransaction::onSendSuccess] CMessage 35CA9 send Success
Mon Dec 5 10:54:17 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:17 2022 35CA8 [~CResponse] resp(100) 84c32c4358944277aa0bb426f51564c1 23371 INVITE
Mon Dec 5 10:54:17 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:17 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:17 2022 1576 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:19 2022 udp_recv fd:5
Mon Dec 5 10:54:19 2022 udp_recv fd:5 iBytesRead:389
Mon Dec 5 10:54:19 2022 UdpInputProc iSock:5 iBytesRead:389 Host:192.168.1.18 Port:59400
1670237659 -> Mon Dec 5 10:54:19 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:389
Mon Dec 5 10:54:19 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:19 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=389, mtls = 0
Mon Dec 5 10:54:19 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
Max-Forwards: 70
CSeq: 23371 CANCEL
Content-Length: 0
Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:19 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:19 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:19 2022 3573C [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] Received CRequest 3573C ref=1
Mon Dec 5 10:54:19 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] rport1 empty
1670237659 -> Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:19 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:19 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:19 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] CANCEL
Mon Dec 5 10:54:19 2022 1184 [CCall::getDialog] Confirmed Dialog is not found (ID = ;81773224f44f4986a3b807271b8b4aa7)
Mon Dec 5 10:54:19 2022 1184 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:19 2022 1576 [CDialog::receiveRequest]
Mon Dec 5 10:54:19 2022 1576 [CDialog::receiveCancelRequest]
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215f, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:19 2022 215f [CTransInitialState::receiveRequest] Transaction changes to Trying state
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215f, previousState = Initial, currentState = Trying, reason = Request reception]
Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] iErrorCode=488.
1670237659 -> Mon Dec 5 10:54:19 2022 1184 [CCall::checkAuthentication] CANCEL
Mon Dec 5 10:54:19 2022 1184[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:19 2022 1184[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:54:19 2022 1184 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:19 2022 1184 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:19 2022 1184 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:19 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:19 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] state = PROCEEDING_STATE.
Mon Dec 5 10:54:19 2022 [receiveCancelMessage] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:19 2022 ** SEPLOS **
Mon Dec 5 10:54:19 2022 [sendLgEvtSip] seplos Event sent on eqt : 1464 Id :1
1670237659 -> Mon Dec 5 10:54:19 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:19 2022 Id : 1
Mon Dec 5 10:54:19 2022 CANCEL
Mon Dec 5 10:54:19 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:19 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:54:19 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:19 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:19 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:19 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:19 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:19 2022 SUCCESSFUL
Mon Dec 5 10:54:19 2022 xx : 0
Mon Dec 5 10:54:19 2022 RELATIVE REQUEST : CANCEL
Mon Dec 5 10:54:19 2022 CLIR : 0
Mon Dec 5 10:54:19 2022 COLP : 0
Mon Dec 5 10:54:19 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:19 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1464 1.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:19 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:54:19 2022 [onIncomingEvent] relative_request = 10756
Mon Dec 5 10:54:19 2022 [CProceedingState::receiveSuccessfulEvent] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:19 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
1670237659 -> Mon Dec 5 10:54:19 2022 1576 [CCall::findFirstServerTrans]
Mon Dec 5 10:54:19 2022 1576 [CDialog::findFirstServerTrans] Current Request in cancelTransactionMap
Mon Dec 5 10:54:19 2022 1184 [CCall::makeGenericResponse] 200
Mon Dec 5 10:54:19 2022 1576 [CDialog::createResponse] 200
Mon Dec 5 10:54:19 2022 215f [CTransTryingState::createResponse] CResponse 35CAA ref=1
Mon Dec 5 10:54:19 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:19 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:19 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:19 2022 35CAA [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:19 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:19 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 407)
SIP/2.0 200 OK
CSeq: 23371 CANCEL
Content-Length: 0
1670237659 -> Mon Dec 5 10:54:19 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:19 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:19 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:19 2022 udp_send fd:5
Mon Dec 5 10:54:19 2022 udp_send fd:5 port 59400 iBytesSend:407
Mon Dec 5 10:54:19 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:19 2022 35CAA [CMessage::onSendSuccess]
Mon Dec 5 10:54:19 2022 215f [CTransaction::onSendSuccess] CMessage 35CAA send Success
Mon Dec 5 10:54:19 2022 1576 [CDialog::onSendSuccess]
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:19 2022 215f [CTransTryingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215f, previousState = Trying, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:19 2022 215f [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
Mon Dec 5 10:54:19 2022 1576 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:19 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:19 2022 [ipc_thread] Normal case : evt 10767
1670237659 -> Mon Dec 5 10:54:19 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:19 2022 REQUEST FAILURE
Mon Dec 5 10:54:19 2022 xx : 87
Mon Dec 5 10:54:19 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] an event 10767 arrived on the eqt 1464 1.
Mon Dec 5 10:54:19 2022 [onIncomingEvent] REQUEST FAILURE arrived.
Mon Dec 5 10:54:19 2022 [receiveRequestFailureEvent] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::getOutgoingCall] outgoingCall:0
Mon Dec 5 10:54:19 2022 [receiveRequestFailureEvent] incoming call.
Mon Dec 5 10:54:19 2022 1184 [CCall::makeGenericResponse] 487
Mon Dec 5 10:54:19 2022 1184 [CCall::getDialog] Confirmed Dialog is not found (ID = 991fdf61c064cb11a3be7f9e550ecd5e;81773224f44f4986a3b807271b8b4aa7)
Mon Dec 5 10:54:19 2022 1576 [CDialog::createResponse] 487
Mon Dec 5 10:54:19 2022 215e [CTransProceedingState::createResponse] CResponse 35CAB ref=1
1670237659 -> Mon Dec 5 10:54:19 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:19 2022 35CAB [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:19 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 504)
CSeq: 23371 INVITE
Content-Length: 0
Mon Dec 5 10:54:19 2022 udp_send fd:5 port 59400 iBytesSend:504
1670237659 -> Mon Dec 5 10:54:19 2022 35CAB [CMessage::onSendSuccess]
Mon Dec 5 10:54:19 2022 215e [CTransaction::onSendSuccess] CMessage 35CAB send Success
Mon Dec 5 10:54:19 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:19 2022 35CA9 [~CResponse] resp(183) 84c32c4358944277aa0bb426f51564c1 23371 INVITE
Mon Dec 5 10:54:19 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:19 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:19 2022 215e [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:19 2022 215e [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Dec 5 10:54:19 2022 215e [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Dec 5 10:54:19 2022 1184[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:19 2022 udp_recv fd:5 iBytesRead:391
1670237659 -> Mon Dec 5 10:54:19 2022 UdpInputProc iSock:5 iBytesRead:391 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:19 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:391
Mon Dec 5 10:54:19 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=391, mtls = 0
Max-Forwards: 70
CSeq: 23371 ACK
Route: <sip:192.168.1.10;lr>
Content-Length: 0
Mon Dec 5 10:54:19 2022 3573D [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] Received CRequest 3573D ref=1
1670237659 -> Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] ACK
Mon Dec 5 10:54:19 2022 1576 [CDialog::receiveAckRequest]
Mon Dec 5 10:54:19 2022 215e [CTransCompletedState::receiveRequest] ACK(UDP) : Transaction changes to Confirmed state
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] STATE CHANGED TO CONFIRMED
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = Completed, currentState = Confirmed, reason = Request reception]
Mon Dec 5 10:54:19 2022 215e [CTransaction::freeTimerToken] Timer G is freed
Mon Dec 5 10:54:19 2022 215e [CTransaction::freeTimerToken] Timer H is freed
Mon Dec 5 10:54:19 2022 215e [CTransaction::startTimer] Timer I is started (delay = 5000 ms)
Mon Dec 5 10:54:19 2022 1576 [CDialog::receiveAckRequest] receiving an ACK on a previously rejected INVITE
1670237659 -> Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:19 2022 1184 [CCall::checkAuthentication] ACK
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] state = TERMINATED_STATE.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::compareDialogFromContext] same Dialog
Mon Dec 5 10:54:19 2022 1184[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Dec 5 10:54:19 2022 [receiveAckMessage] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 TERMINATED_STATE received a message.
Mon Dec 5 10:54:19 2022 [receiveAckMessage] boolean flag check 0
1670237659 -> Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:19 2022 ACK
Mon Dec 5 10:54:19 2022 [ipc_thread] Normal case : evt 10773
Mon Dec 5 10:54:19 2022 SIP EQT RELEASED
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1464 1.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1464 has released its equipment.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::unRegister] Remove eqt : 1464 diag : 1 from the map.
1670237659 -> Mon Dec 5 10:54:19 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 1.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] killSession.
Mon Dec 5 10:54:19 2022 1184 [CCall::killSession]
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:19 2022 215f [CTransaction::freeTimerToken] Timer J is freed
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:19 2022 215e [CTransaction::freeTimerToken] Timer I is freed
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:19 2022 1184 [CCall::killSession] notifying the call manager
Mon Dec 5 10:54:19 2022 102 [CCallManager::onCallClosed]
Mon Dec 5 10:54:19 2022 102 [CCallManager::onCallClosed()] Call 1184 closed. Removing call 148768248 from the maps
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onNotifyCallClosed] Call : 84c32c4358944277aa0bb426f51564c1 is closed.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onNotifyCallClosed] call processResponse.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::chooseBestResponse] pForkedBranch=0x8ca1878 iResponseCode=2000.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::processResponse] no response found.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1670237659 -> Mon Dec 5 10:54:19 2022 102 [CCallManager::onCallClosed] pCall: 1184 added in the Garbage List
Mon Dec 5 10:54:19 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:19 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215f, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:19 2022 215F [~CTransaction] transaction 23371 CANCEL
Mon Dec 5 10:54:19 2022 35CAA [~CResponse] resp(200) 84c32c4358944277aa0bb426f51564c1 23371 CANCEL
Mon Dec 5 10:54:19 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:19 2022 3573C [~CRequest] req 84c32c4358944277aa0bb426f51564c1 23371 CANCEL
Mon Dec 5 10:54:19 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:54:19 2022 1184 [CCall::onDialogClosed]
1670237659 -> Mon Dec 5 10:54:19 2022 1184 [CCall::onDialogClosed] only initial *********
Mon Dec 5 10:54:19 2022 1184 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
Mon Dec 5 10:54:19 2022 215E [~CTransaction] transaction 23371 INVITE
Mon Dec 5 10:54:19 2022 3573D [~CRequest] req 84c32c4358944277aa0bb426f51564c1 23371 ACK
1670237661 -> Mon Dec 5 10:54:20 2022 [fnInit] *************************** Init timeout.
Mon Dec 5 10:54:20 2022 [fnInit] treatTimeout.
Mon Dec 5 10:54:20 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:54:20 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:54:20 2022 [startRegistration] timer value=6000.
Mon Dec 5 10:54:21 2022 102 [CCallManager::removeGarbage] at index i = 0
Mon Dec 5 10:54:21 2022 1184 [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:21 2022 1184[CMotorCall::~CMotorCall] Call : 84c32c4358944277aa0bb426f51564c1 is being destructed.
Mon Dec 5 10:54:21 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
Mon Dec 5 10:54:21 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:21 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:21 2022 1184 [CCall::~CCall] resources number: 142
Mon Dec 5 10:54:21 2022 1184 [CCall::TestDegradedModeEnd] resources number: 141
Mon Dec 5 10:54:21 2022 1184 [CCall::removeGarbage]
Mon Dec 5 10:54:21 2022 1576 [CDialog::~CDialog] resources number: 280
Mon Dec 5 10:54:21
********************************* TRACE OPTIONS USED IN THIS FILE ****************************************
motortrace 8
traced -a +motor -f 99 -s 10000000 -1 /tmpd/OMtrace0512SIP_05_Dec_22-105354/Sip_Motor_Traces/xa000000_SIP_105344 -d &
1670237637 -> Mon Dec 5 10:53:56 2022 Degraded mode activated : No
Mon Dec 5 10:53:56 2022 -------------------------------------------
Mon Dec 5 10:53:56 2022 [fnInit] *************************** Init timeout.
Mon Dec 5 10:53:56 2022 [fnInit] treatTimeout.
Mon Dec 5 10:53:56 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:53:56 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:53:56 2022 [startRegistration] timer value=6000.
Mon Dec 5 10:53:57 2022 102 [CCallManager::removeGarbage] at index i = 0
Mon Dec 5 10:53:57 2022 117c [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:53:57 2022 117c[CMotorCall::~CMotorCall] Call : 7c4075f1 is being destructed.
Mon Dec 5 10:53:57 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
Mon Dec 5 10:53:57 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:53:57 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:53:57 2022 117c [CCall::~CCall] resources number: 142
Mon Dec 5 10:53:57 2022 117c [CCall::TestDegradedModeEnd] resources number: 141
Mon Dec 5 10:53:57 2022 117c [CCall::removeGarbage]
Mon Dec 5 10:53:57 2022 156c [CDialog::~CDialog] resources number: 280
Mon Dec 5 10:53:57 2022 [CResponse::~CResponse]
Mon Dec 5 10:53:57 2022 35C89 [~CResponse] resp(200) 7c4075f1 318368361 OPTIONS
Mon Dec 5 10:53:57 2022 [CRequest::~CRequest]
1670237638 -> Mon Dec 5 10:53:57 2022 35720 [~CRequest] req 7c4075f1 318368361 OPTIONS
Mon Dec 5 10:53:57 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:53:57 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:53:57 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:53:57 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:53:57 2022 [CCall::~CCall] Ends
Mon Dec 5 10:53:58 2022 214c [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:53:58 2022 214c [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:53:58 2022 214c [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:58 2022 214c [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
Mon Dec 5 10:53:58 2022 214d [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:53:58 2022 214d [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:53:58 2022 214d [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:58 2022 214d [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
Mon Dec 5 10:53:58 2022 214e [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:53:58 2022 214e [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:53:58 2022 214e [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:58 2022 214e [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
1670237638 -> Mon Dec 5 10:53:58 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:53:58 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:53:58 2022 15a6 [CDialog::onTransactionState(pTrans = 214c, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:53:58 2022 214C [~CTransaction] transaction 367136563 NOTIFY
Mon Dec 5 10:53:58 2022 [CResponse::~CResponse]
Mon Dec 5 10:53:58 2022 35C91 [~CResponse] resp(200) 156b5267 367136563 NOTIFY
Mon Dec 5 10:53:58 2022 [CRequest::~CRequest]
Mon Dec 5 10:53:58 2022 35727 [~CRequest] req 156b5267 367136563 NOTIFY
Mon Dec 5 10:53:58 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:53:58 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:53:58 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:53:58 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:53:58 2022 15a6 [CDialog::onTransactionState(pTrans = 214d, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:53:58 2022 214D [~CTransaction] transaction 367136564 NOTIFY
Mon Dec 5 10:53:58 2022 35C92 [~CResponse] resp(200) 156b5267 367136564 NOTIFY
Mon Dec 5 10:53:58 2022 35728 [~CRequest] req 156b5267 367136564 NOTIFY
1670237638 -> Mon Dec 5 10:53:58 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:53:58 2022 15a6 [CDialog::onTransactionState(pTrans = 214e, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:53:58 2022 214E [~CTransaction] transaction 367136565 NOTIFY
Mon Dec 5 10:53:58 2022 35C93 [~CResponse] resp(200) 156b5267 367136565 NOTIFY
Mon Dec 5 10:53:58 2022 2150 [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:53:58 2022 2150 [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:53:58 2022 2150 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:58 2022 2150 [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
1670237639 -> Mon Dec 5 10:53:58 2022 15a4 [CDialog::onTransactionState(pTrans = 2150, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:53:58 2022 2150 [~CTransaction] transaction 212720029 NOTIFY
Mon Dec 5 10:53:58 2022 35C95 [~CResponse] resp(200) 4f783cda 212720029 NOTIFY
1670237639 -> Mon Dec 5 10:53:59 2022 udp_recv fd:5
Mon Dec 5 10:53:59 2022 udp_recv fd:5 iBytesRead:578
Mon Dec 5 10:53:59 2022 UdpInputProc iSock:5 iBytesRead:578 Host:192.168.1.181 Port:5060
Mon Dec 5 10:53:59 2022 [CTransportUdp::receiveMessage] from 192.168.1.181:5060 rc:578
Mon Dec 5 10:53:59 2022 [CTransport::findConnection] pConnection = 779b remoteHost=192.168.1.181, remotePort=5060
Mon Dec 5 10:53:59 2022 [CIOCom::onReceiveMessage] received from 192.168.1.181:5060, proto=0, length=578, mtls = 0
Mon Dec 5 10:53:59 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.181:5060 [UDP])
BYE sip:192.168.1.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.181;branch=z9hG4bK0dc18529f50188176
Max-Forwards: 70
From: "Hajib" <sip:8302@oxe.ma:5060>;tag=50f72f941b
To: "3" <sip:3@oxe.ma:5060>;tag=305ffc499e8dbb3b77dae75426e4b459
Call-ID: 9da148ce
CSeq: 1500548361 BYE
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, PUBLISH, REFER, REGISTER, SUBSCRIBE, UPDATE
Allow-Events: conference, refer, talk, hold
Supported: 100rel, eventlist, join, replaces, sdp-anat, tdialog
User-Agent: ALE ALE-2 2.12.20.000.2036 3c28a608b7bd
Content-Length: 0
Mon Dec 5 10:53:59 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:53:59 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:53:59 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:53:59 2022 3572E [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
1670237639 -> Mon Dec 5 10:53:59 2022 [CIOCom::receiveRequest] Received CRequest 3572E ref=1
Mon Dec 5 10:53:59 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.181 alcResult= 0
Mon Dec 5 10:53:59 2022 [CIOCom::receiveRequest] rport1 not empty
Mon Dec 5 10:53:59 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:53:59 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:53:59 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:53:59 2022 117a [CCall::receiveRequest] BYE
Mon Dec 5 10:53:59 2022 117a [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:53:59 2022 156b [CDialog::receiveRequest]
Mon Dec 5 10:53:59 2022 156b [CDialog::receiveBasicRequest]
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:53:59 2022 156b [CDialog::onTransactionState(pTrans = 2153, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:53:59 2022 2153 [CTransInitialState::receiveRequest] Transaction changes to Trying state
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:53:59 2022 156b [CDialog::onTransactionState(pTrans = 2153, previousState = Initial, currentState = Trying, reason = Request reception]
1670237639 -> Mon Dec 5 10:53:59 2022 156b [CDialog::addTransaction] added transaction 2153 with branch z9hG4bK0dc18529f50188176, with CSeq 1500548361
Mon Dec 5 10:53:59 2022 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Mon Dec 5 10:53:59 2022 117a [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:53:59 2022 117a [CCall::checkAuthentication] BYE
Mon Dec 5 10:53:59 2022 117a[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:53:59 2022 117a[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:53:59 2022 117a [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:53:59 2022 117a [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:53:59 2022 117a [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:53:59 2022 117a [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:53:59 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:53:59 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onReceiveRequest] state = COMPLETED_STATE.
Mon Dec 5 10:53:59 2022 [receiveByeMessage] Call: 9da148ce eqt: 1448 COMPLETED_STATE received a message.
Mon Dec 5 10:53:59 2022 [CGenericState::getAOCInfo] INFO NULL content !!!
Mon Dec 5 10:53:59 2022 117a[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
1670237639 -> Mon Dec 5 10:53:59 2022 117a[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:53:59 2022 117a[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:53:59 2022 117a[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:53:59 2022 ** SEPLOS **
Mon Dec 5 10:53:59 2022 [sendLgEvtSip] seplos Event sent on eqt : 1448 Id :1
Mon Dec 5 10:53:59 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:53:59 2022 Id : 1
Mon Dec 5 10:53:59 2022 BYE
Mon Dec 5 10:53:59 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:53:59 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:53:59 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:53:59 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:53:59 2022 [exec_ipc] in 5615.
Mon Dec 5 10:53:59 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:53:59 2022 neqt : 1448 Id : 1
Mon Dec 5 10:53:59 2022 SUCCESSFUL
Mon Dec 5 10:53:59 2022 xx : 0
Mon Dec 5 10:53:59 2022 RELATIVE REQUEST : BYE
Mon Dec 5 10:53:59 2022 CLIR : 0
Mon Dec 5 10:53:59 2022 COLP : 0
Mon Dec 5 10:53:59 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:53:59 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1448 1.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] seplos station.
1670237639 -> Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Mon Dec 5 10:53:59 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:53:59 2022 [onIncomingEvent] relative_request = 10755
Mon Dec 5 10:53:59 2022 [receiveSuccessfulEvent] Call: 9da148ce eqt: 1448 TERMINATED_STATE received an event.
Mon Dec 5 10:53:59 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
Mon Dec 5 10:53:59 2022 156b [CCall::findFirstServerTrans]
Mon Dec 5 10:53:59 2022 156b [CCallLeg::findFirstOpenServerTrans] Current Request in transactionMapByBranch
Mon Dec 5 10:53:59 2022 117a [CCall::makeGenericResponse] 200
Mon Dec 5 10:53:59 2022 156b [CDialog::createResponse] 200
Mon Dec 5 10:53:59 2022 2153 [CTransTryingState::createResponse] CResponse 35C98 ref=1
Mon Dec 5 10:53:59 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:53:59 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:53:59 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:53:59 2022 35C98 [CMessage::send] sip_sendMessage (192.168.1.181:5060)
Mon Dec 5 10:53:59 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:53:59 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 434)
SIP/2.0 200 OK
Supported: replaces,timer,path,100rel
User-Agent: OmniPCX Enterprise R100.0 n1.291.68.a
Call-ID: 9da148ce
Content-Length: 0
1670237639 -> Mon Dec 5 10:53:59 2022 [CTransport::findConnection] pConnection = 779b remoteHost=192.168.1.181, remotePort=5060
Mon Dec 5 10:53:59 2022 [CTransport::getConnection] RemoteHost=(192.168.1.181 5060) already exist, using connection 779b
Mon Dec 5 10:53:59 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:53:59 2022 udp_send fd:3
Mon Dec 5 10:53:59 2022 udp_send fd:3 port 5060 iBytesSend:434
Mon Dec 5 10:53:59 2022 779b [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:53:59 2022 35C98 [CMessage::onSendSuccess]
Mon Dec 5 10:53:59 2022 2153 [CTransaction::onSendSuccess] CMessage 35C98 send Success
Mon Dec 5 10:53:59 2022 156b [CDialog::onSendSuccess]
Mon Dec 5 10:53:59 2022 117a[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:53:59 2022 2153 [CTransTryingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:53:59 2022 156b [CDialog::onTransactionState(pTrans = 2153, previousState = Trying, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:53:59 2022 2153 [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
Mon Dec 5 10:53:59 2022 156b [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:53:59 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:53:59 2022 [ipc_thread] Normal case : evt 10773
1670237639 -> Mon Dec 5 10:53:59 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:53:59 2022 SIP EQT RELEASED
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1448 1.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1448 has released its equipment.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::unRegister] Remove eqt : 1448 diag : 1 from the map.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::eraseCallwithEqt] erase 1448 1.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] killSession.
Mon Dec 5 10:53:59 2022 117a [CCall::killSession]
Mon Dec 5 10:53:59 2022 2140 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:59 2022 2140 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:59 2022 2153 [CTransaction::freeTimerToken] Timer J is freed
Mon Dec 5 10:53:59 2022 2153 [CTransaction::changeState] no transaction state, terminated reason : None
1670237639 -> Mon Dec 5 10:53:59 2022 156b [CDialog::removeSubscriptionTimer]
Mon Dec 5 10:53:59 2022 117a [CCall::killSession] notifying the call manager
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed]
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed()] Call 117a closed. Removing call 148946336 from the maps
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onNotifyCallClosed] Call : 9da148ce is closed.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onNotifyCallClosed] call processResponse.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::chooseBestResponse] pForkedBranch=0x8e113d0 iResponseCode=2000.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:53:59 2022 117a[CMotorCall::processResponse] no response found.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed] pCall: 117a added in the Garbage List
Mon Dec 5 10:53:59 2022 [ipc_thread] Normal case : evt 10755
Mon Dec 5 10:53:59 2022 neqt : 1443 Id : 1
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] an event 10755 arrived on the eqt 1443 1.
1670237639 -> Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] state = COMPLETED_STATE.
Mon Dec 5 10:53:59 2022 [onIncomingEvent] BYE arrived.
Mon Dec 5 10:53:59 2022 [receiveByeEvent] Call: 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 eqt: 1443 COMPLETED_STATE received an event.
Mon Dec 5 10:53:59 2022 117b [CCall::makeGenericRequest] BYE
Mon Dec 5 10:53:59 2022 117b [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:53:59 2022 156a [CDialog::createRequest]
Mon Dec 5 10:53:59 2022 156a [CDialog::buildServicesForAllRequest]
Mon Dec 5 10:53:59 2022 156a [CDialog::createByeRequest]
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:53:59 2022 156a [CDialog::onTransactionState(pTrans = 2154, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:53:59 2022 3572F [CRequest::CRequest] Creation of a request
Mon Dec 5 10:53:59 2022 [DBG: CRequest::freeAttributes]
Mon Dec 5 10:53:59 2022 [DBG: CRequest::freeAttributes Ends]
Mon Dec 5 10:53:59 2022 CRequest::createRequestLine Protocol UDP
Mon Dec 5 10:53:59 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
1670237639 -> Mon Dec 5 10:53:59 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:53:59 2022 3572F [CMessage::send] sip_sendMessage (192.168.1.172:5060)
Mon Dec 5 10:53:59 2022 SEND MESSAGE TO NETWORK (192.168.1.172:5060 [UDP]) (BUFF LEN = 483)
BYE sip:8509@192.168.1.172:5060;transport=udp SIP/2.0
To: <sip:8509@192.168.1.10:5060;user=phone>;tag=1482112415
From: <sip:8302@192.168.1.10:5060;user=phone>;tag=3f2f68783cec4fdfdd1ee8455c837780
Call-ID: 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10
CSeq: 377336083 BYE
Via: SIP/2.0/UDP 192.168.1.10;branch=z9hG4bKc1a8c56db81cd512ce06d34a9735e809
Max-Forwards: 70
Content-Length: 0
Mon Dec 5 10:53:59 2022 [CTransport::findConnection] pConnection = f47 remoteHost=192.168.1.172, remotePort=5060
Mon Dec 5 10:53:59 2022 [CTransport::getConnection] RemoteHost=(192.168.1.172 5060) already exist, using connection f47
Mon Dec 5 10:53:59 2022 udp_send fd:5
Mon Dec 5 10:53:59 2022 udp_send fd:5 port 5060 iBytesSend:483
Mon Dec 5 10:53:59 2022 f47 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:53:59 2022 3572F [CMessage::onSendSuccess]
Mon Dec 5 10:53:59 2022 2154 [CTransaction::onSendSuccess] CMessage 3572F send Success
1670237639 -> Mon Dec 5 10:53:59 2022 156a [CDialog::onSendSuccess]
Mon Dec 5 10:53:59 2022 117b[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:53:59 2022 2154 [CTransInitialState::createRequest] Transaction changes to Trying state
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:53:59 2022 156a [CDialog::onTransactionState(pTrans = 2154, previousState = Initial, currentState = Trying, reason = Request creation]
Mon Dec 5 10:53:59 2022 2154 [CTransTryingState::enterInState] Init timers E and F
Mon Dec 5 10:53:59 2022 2154 [CTransaction::startTimer] Timer E is started (delay = 500 ms)
Mon Dec 5 10:53:59 2022 2154 [CTransaction::startTimer] Timer F is started (delay = 16000 ms)
Mon Dec 5 10:53:59 2022 156a [CDialog::addTransaction] added transaction 2154 with branch z9hG4bKc1a8c56db81cd512ce06d34a9735e809, with CSeq 377336083
Mon Dec 5 10:53:59 2022 117b[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:53:59 2022 udp_recv fd:5 iBytesRead:563
Mon Dec 5 10:53:59 2022 UdpInputProc iSock:5 iBytesRead:563 Host:192.168.1.172 Port:5060
Mon Dec 5 10:53:59 2022 [CTransportUdp::receiveMessage] from 192.168.1.172:5060 rc:563
1670237639 -> Mon Dec 5 10:53:59 2022 [CTransport::findConnection] pConnection = f47 remoteHost=192.168.1.172, remotePort=5060
Mon Dec 5 10:53:59 2022 [CIOCom::onReceiveMessage] received from 192.168.1.172:5060, proto=0, length=563, mtls = 0
Mon Dec 5 10:53:59 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.172:5060 [UDP])
SIP/2.0 200 OK
CSeq: 377336083 BYE
Content-Length: 0
Mon Dec 5 10:53:59 2022 [CIOCom::receiveResponse] CResponse 35C99 ref=1
Mon Dec 5 10:53:59 2022 [CDispatcher::processResponseFromManagerIndex] start at index 0
Mon Dec 5 10:53:59 2022 102 [CCallManager::onIncomingResponse]
Mon Dec 5 10:53:59 2022 117b [CCall::receiveResponse] 200
1670237639 -> Mon Dec 5 10:53:59 2022 156a [CDialog::receiveResponse]
Mon Dec 5 10:53:59 2022 2154 [CTransTryingState::receiveResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:53:59 2022 156a [CDialog::onTransactionState(pTrans = 2154, previousState = Trying, currentState = Completed, reason = Final resp reception]
Mon Dec 5 10:53:59 2022 2154 [CTransaction::freeTimerToken] Timer E is freed
Mon Dec 5 10:53:59 2022 2154 [CTransaction::freeTimerToken] Timer F is freed
Mon Dec 5 10:53:59 2022 2154 [CTransaction::startTimer] Timer K is started (delay = 5000 ms)
Mon Dec 5 10:53:59 2022 117b[CMotorCall::onReceiveResponse] Update2 the Other context.
Mon Dec 5 10:53:59 2022 [CTerminatedState::receiveSuccessfulMessage] Call: 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 eqt: 1443 TERMINATED_STATE received a message.
Mon Dec 5 10:53:59 2022 [CTerminatedState::receiveSuccessfulMessage] relative request: 2
Mon Dec 5 10:53:59 2022 117b[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:53:59 2022 117b[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:53:59 2022 117b[emitEventToMonitel] cacUsed=0 eqtCac=-1
1670237639 -> Mon Dec 5 10:53:59 2022 117b[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:53:59 2022 [sendLgEvtSip] seplos Event sent on eqt : 1443 Id :1
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1443 1.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1443 has released its equipment.
1670237639 -> Mon Dec 5 10:53:59 2022 117b[CMotorCall::unRegister] Remove eqt : 1443 diag : 1 from the map.
Mon Dec 5 10:53:59 2022 [CMotorCallManager::eraseCallwithEqt] erase 1443 1.
Mon Dec 5 10:53:59 2022 117b [CCall::killSession]
Mon Dec 5 10:53:59 2022 2141 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:59 2022 2141 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:53:59 2022 2154 [CTransaction::freeTimerToken] Timer K is freed
Mon Dec 5 10:53:59 2022 2154 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:53:59 2022 156a [CDialog::removeSubscriptionTimer]
Mon Dec 5 10:53:59 2022 117b [CCall::killSession] notifying the call manager
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed()] Call 117b closed. Removing call 148763224 from the maps
Mon Dec 5 10:53:59 2022 [CMotorCallManager::onNotifyCallClosed] Call : 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 is closed.
Mon Dec 5 10:53:59 2022 102 [CCallManager::onCallClosed] pCall: 117b added in the Garbage List
Mon Dec 5 10:53:59 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:53:59 2022 [CTransaction::notifyDialog] notify parent dialog
1670237639 -> Mon Dec 5 10:53:59 2022 1568 [CDialog::onTransactionState(pTrans = 2140, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:53:59 2022 1568 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:53:59 2022 1568 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed]
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed] not only initial *********
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed]: the dialog 156b is NOT closed
Mon Dec 5 10:53:59 2022 2140 [~CTransaction] transaction 1500548360 INVITE
Mon Dec 5 10:53:59 2022 [CResponse::~CResponse]
Mon Dec 5 10:53:59 2022 35C82 [~CResponse] resp(180) 9da148ce 1500548360 INVITE
Mon Dec 5 10:53:59 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:53:59 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:53:59 2022 156b [CDialog::onTransactionState(pTrans = 2153, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed]: the dialog 156b is closed
Mon Dec 5 10:53:59 2022 117a [CCall::onDialogClosed] All the dialogs in the Call are closed
Mon Dec 5 10:53:59 2022 2153 [~CTransaction] transaction 1500548361 BYE
1670237639 -> Mon Dec 5 10:53:59 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:53:59 2022 1569 [CDialog::onTransactionState(pTrans = 2141, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:53:59 2022 1569 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:53:59 2022 1569 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed]
Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed] not only initial *********
Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed]: the dialog 156a is NOT closed
Mon Dec 5 10:53:59 2022 2141 [~CTransaction] transaction 377336082 INVITE
Mon Dec 5 10:53:59 2022 35C83 [~CResponse] resp(180) 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336082 INVITE
Mon Dec 5 10:53:59 2022 156a [CDialog::onTransactionState(pTrans = 2154, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed]: the dialog 156a is closed
1670237640 -> Mon Dec 5 10:53:59 2022 117b [CCall::onDialogClosed] All the dialogs in the Call are closed
Mon Dec 5 10:53:59 2022 2154 [~CTransaction] transaction 377336083 BYE
Mon Dec 5 10:53:59 2022 35C99 [~CResponse] resp(200) 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336083 BYE
Mon Dec 5 10:54:00 2022 102 [CCallManager::removeGarbage] at index i = 1
Mon Dec 5 10:54:00 2022 117b [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:00 2022 117b[CMotorCall::~CMotorCall] Call : 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 is being destructed.
Mon Dec 5 10:54:00 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
Mon Dec 5 10:54:00 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:00 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:00 2022 117b [CCall::~CCall] resources number: 141
Mon Dec 5 10:54:00 2022 117b [CCall::TestDegradedModeEnd] resources number: 140
Mon Dec 5 10:54:00 2022 117b [CCall::removeGarbage]
Mon Dec 5 10:54:00 2022 156a [CDialog::~CDialog] resources number: 279
Mon Dec 5 10:54:00 2022 156a [~CDialog] delete ack request # 0
1670237640 -> Mon Dec 5 10:54:00 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:00 2022 3571C [~CRequest] req 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336082 ACK
Mon Dec 5 10:54:00 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:00 2022 35C85 [~CResponse] resp(200) 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336082 INVITE
Mon Dec 5 10:54:00 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:00 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:00 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:00 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:00 2022 1569 [CDialog::~CDialog] resources number: 278
Mon Dec 5 10:54:00 2022 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Mon Dec 5 10:54:00 2022 3571A [~CRequest] req 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336082 INVITE
Mon Dec 5 10:54:00 2022 3572F [~CRequest] req 333a4ee2ef0a300319cfa34dda632e0a@192.168.1.10 377336083 BYE
Mon Dec 5 10:54:00 2022 [CCall::~CCall] Ends
Mon Dec 5 10:54:00 2022 102 [CCallManager::removeGarbage] at index i = 0
1670237640 -> Mon Dec 5 10:54:00 2022 117a [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:00 2022 117a[CMotorCall::~CMotorCall] Call : 9da148ce is being destructed.
Mon Dec 5 10:54:00 2022 117a [CCall::~CCall] resources number: 140
Mon Dec 5 10:54:00 2022 117a [CCall::TestDegradedModeEnd] resources number: 139
Mon Dec 5 10:54:00 2022 117a [CCall::removeGarbage]
Mon Dec 5 10:54:00 2022 156b [CDialog::~CDialog] resources number: 277
Mon Dec 5 10:54:00 2022 1568 [CDialog::~CDialog] resources number: 276
Mon Dec 5 10:54:00 2022 35C86 [~CResponse] resp(200) 9da148ce 1500548360 INVITE
Mon Dec 5 10:54:00 2022 35719 [~CRequest] req 9da148ce 1500548360 INVITE
1670237642 -> Mon Dec 5 10:54:00 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:00 2022 35C98 [~CResponse] resp(200) 9da148ce 1500548361 BYE
Mon Dec 5 10:54:00 2022 3572E [~CRequest] req 9da148ce 1500548361 BYE
Mon Dec 5 10:54:02 2022 udp_recv fd:5
Mon Dec 5 10:54:02 2022 udp_recv fd:5 iBytesRead:2
Mon Dec 5 10:54:02 2022 UdpInputProc iSock:5 iBytesRead:2 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:02 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:2
Mon Dec 5 10:54:02 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:02 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=2, mtls = 0
Mon Dec 5 10:54:02 2022 [CKeepaliveManager::receiveSignal]
Mon Dec 5 10:54:02 2022 udp_recv fd:5 iBytesRead:1055
Mon Dec 5 10:54:02 2022 UdpInputProc iSock:5 iBytesRead:1055 Host:192.168.1.181 Port:5060
Mon Dec 5 10:54:02 2022 [CTransportUdp::receiveMessage] from 192.168.1.181:5060 rc:1055
1670237642 -> Mon Dec 5 10:54:02 2022 [CTransport::findConnection] pConnection = 779b remoteHost=192.168.1.181, remotePort=5060
Mon Dec 5 10:54:02 2022 [CIOCom::onReceiveMessage] received from 192.168.1.181:5060, proto=0, length=1055, mtls = 0
Mon Dec 5 10:54:02 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.181:5060 [UDP])
INVITE sip:8008@oxe.ma:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.181;branch=z9hG4bK5a8f8d314c36aa2d2
Max-Forwards: 70
From: "Hajib" <sip:8302@oxe.ma:5060>;tag=61f4317ecd
To: "8008" <sip:8008@oxe.ma:5060>
Call-ID: c706eb47
CSeq: 1090543851 INVITE
Contact: <sip:8302@192.168.1.181:5060;transport=udp>
Content-Disposition: session
Content-Type: application/sdp
Content-Length: 386
v=0
o=- 2269360466076651974 2269360466076651975 IN IP4 192.168.1.181
s=SDP data
c=IN IP4 192.168.1.181
t=0 0
m=audio 6000 RTP/AVP 8 0 18 9 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:9 G722/8000
a=rtpmap:101 telephone-event/8000
a=silenceSupp:off - - - -
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=mptime:20 20 20 20 -
a=sendrecv
Mon Dec 5 10:54:02 2022 [CIOCom::receiveRequest] optimisation value 1
1670237642 -> Mon Dec 5 10:54:02 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:02 2022 35730 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:02 2022 [CIOCom::receiveRequest] Received CRequest 35730 ref=1
Mon Dec 5 10:54:02 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.181 alcResult= 0
Mon Dec 5 10:54:02 2022 [CIOCom::receiveRequest] rport1 not empty
Mon Dec 5 10:54:02 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:02 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:02 2022 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
Mon Dec 5 10:54:02 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:02 2022 [CMotorCallManager::callFactory] For call : c706eb47.
Mon Dec 5 10:54:02 2022 1180 [CCall::CCall] resources number: 141
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:02 2022 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.68.a
Mon Dec 5 10:54:02 2022 [CMotorCallManager::callFactory]=8dc7868.
Mon Dec 5 10:54:02 2022 1180 [CCall::receiveRequest] INVITE
Mon Dec 5 10:54:02 2022 1180 [CCall::getDialog] Confirmed Dialog is not found (ID = ;61f4317ecd)
Mon Dec 5 10:54:02 2022 1180 [CCall::getDialog] Initial Dialog Server not found
Mon Dec 5 10:54:02 2022 1570 [CDialog::CDialog] resources number: 277
1670237642 -> Mon Dec 5 10:54:02 2022 1570 [CDialog::receiveRequest]
Mon Dec 5 10:54:02 2022 1570 [CDialog::receiveInviteRequest]
Mon Dec 5 10:54:02 2022 2155 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:02 2022 2155 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:02 2022 1570 [CDialog::onTransactionState(pTrans = 2155, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:02 2022 2155 [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Dec 5 10:54:02 2022 2155 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:02 2022 1570 [CDialog::onTransactionState(pTrans = 2155, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Dec 5 10:54:02 2022 2155 [CTransProceedingState::createResponse] CResponse 35C9A ref=1
Mon Dec 5 10:54:02 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:02 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:02 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:02 2022 35C9A [CMessage::send] sip_sendMessage (192.168.1.181:5060)
Mon Dec 5 10:54:02 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:02 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 237)
SIP/2.0 100 Trying
Call-ID: c706eb47
Content-Length: 0
Mon Dec 5 10:54:02 2022 [CTransport::getConnection] RemoteHost=(192.168.1.181 5060) already exist, using connection 779b
Mon Dec 5 10:54:02 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:02 2022 udp_send fd:3
Mon Dec 5 10:54:02 2022 udp_send fd:3 port 5060 iBytesSend:237
Mon Dec 5 10:54:02 2022 779b [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:02 2022 35C9A [CMessage::onSendSuccess]
Mon Dec 5 10:54:02 2022 2155 [CTransaction::onSendSuccess] CMessage 35C9A send Success
Mon Dec 5 10:54:02 2022 1570 [CDialog::onSendSuccess]
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:02 2022 1570 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 0
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:02 2022 1570 [CDialog::addTransaction] added transaction 2155 with branch z9hG4bK5a8f8d314c36aa2d2, with CSeq 1090543851
Mon Dec 5 10:54:02 2022 1180 [CCall::receiveRequest] iErrorCode=488.
1670237642 -> Mon Dec 5 10:54:02 2022 1180 [CCall::checkAuthentication] INVITE
Mon Dec 5 10:54:02 2022 1180[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:02 2022 [getFromHeader] look at the From.
Mon Dec 5 10:54:02 2022 [getFromHeader] displayName="Hajib".
Mon Dec 5 10:54:02 2022 [convertCSipURLIntoSipuri] uri = sip:8302@oxe.ma:5060.
Mon Dec 5 10:54:02 2022 [getFromHeader] =8302@oxe.ma.
Mon Dec 5 10:54:02 2022 [getFromHeader] clirPresent=0.
Mon Dec 5 10:54:02 2022 [getReqUriHeader] look at the requri.
Mon Dec 5 10:54:02 2022 [convertCSipURLIntoSipuri] uri = sip:8008@oxe.ma:5060.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::getUserType] extGw=-1.
Mon Dec 5 10:54:02 2022 [CMotorCall::analyseRouting] TEL uri=0.
Mon Dec 5 10:54:02 2022 [CMotorCall::analyseRouting] 8302@oxe.ma is authenticable.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setExtGw] -1->-3
Mon Dec 5 10:54:02 2022 [isUserInDico] looking for 8302@oxe.ma ...
Mon Dec 5 10:54:02 2022 [isUserInDico] found in the dictionnary.
Mon Dec 5 10:54:02 2022 [isAddrInDico] seplos station OK
Mon Dec 5 10:54:02 2022 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::getUserType] From is seplos station crypto=0.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::getUserType] extGw=-3.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::controlAuthentication] m_other_calling=0 extgw=-3
1670237642 -> Mon Dec 5 10:54:02 2022 1180[CMotorCall::controlAuthentication] from:sip:8302@oxe.ma:5060
Mon Dec 5 10:54:02 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:02 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:02 2022 [CGwMngData::isAuthenticationRequiredForThisClient] 8302@192.168.1.10 .
Mon Dec 5 10:54:02 2022 [CGwMngData::isAuthenticationRequiredForThisClient] -3 need auth=0.
Mon Dec 5 10:54:02 2022 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway -3.
Mon Dec 5 10:54:02 2022 CGwMngData::isAuthenticationRequiredForThisClient: gateway=-3
Mon Dec 5 10:54:02 2022 1180[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setExtGw] -3->-3
Mon Dec 5 10:54:02 2022 1180 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:02 2022 1180 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:02 2022 1180 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:02 2022 1180 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setFilterUsedMode] To be traced = 0
1670237642 -> Mon Dec 5 10:54:02 2022 1180[CMotorCall::initOfUserType] station role already defined s=1 d=0 o=0.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onReceiveRequest] accepte? m_other_calling=0 gw=-1.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=2.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::toGatewayOrProxy] request for proxydomain=oxe.ma.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::toGatewayOrProxy] from = seplos station.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] nb available licenses=0 .
Mon Dec 5 10:54:02 2022 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Dec 5 10:54:02 2022 [CForkedBranch::CForkedBranch] context = 0x8dc7e2c.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] reqUri stored: sip:8302@192.168.1.181:5060;transport=udp
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] cacUsed = 0 before.
1670237642 -> Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] CAC = 0
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] Call: c706eb47 eqt: -1 INITIAL_STATE received a message.
Mon Dec 5 10:54:02 2022 [decodeInviteCLIR].
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] INFO present in Allow header
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] UPDATE present in Allow header
Mon Dec 5 10:54:02 2022 am_I_PCS SCSWorking : NO
Mon Dec 5 10:54:02 2022 check_PCSstate
Mon Dec 5 10:54:02 2022 check_PCSstate stat of PCS is : -1
Mon Dec 5 10:54:02 2022 1180[CMotorCall::analyseSessionTimer] Session Timer extGw=-1 sessionDelay=1800 .
Mon Dec 5 10:54:02 2022 1180[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:02 2022 1180[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:02 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:02 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:02 2022 [checkSdpValidity] Media 0 type 1 contains 5 formats.
Mon Dec 5 10:54:02 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:02 2022 [checkSdpValidity] Format : 8.
1670237642 -> Mon Dec 5 10:54:02 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:02 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:02 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] The audio media contains 5 format(s).
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 1 is 0 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 2 is 18 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format is G729.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 3 is 9 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format 4 is 101 opt syst G711=0.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] 101.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Format is DTMF:101.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:02 2022 [convertAudioMedia] Connection address retrieved in sdp: 192.168.1.181.
Mon Dec 5 10:54:02 2022 [convertIPStrIntoTuipv] 192.168.1.181 => 192.168.1.181
1670237642 -> Mon Dec 5 10:54:02 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:02 2022 [display_sdp] address =192.168.1.181
Mon Dec 5 10:54:02 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:02 2022 [display_sdp] codecs =17.
Mon Dec 5 10:54:02 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:02 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:02 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Mon Dec 5 10:54:02 2022 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Dec 5 10:54:02 2022 [receiveinvitemessage] get requri.
Mon Dec 5 10:54:02 2022 [decodeInviteTo].
Mon Dec 5 10:54:02 2022 [decodeInviteReferredBy].
Mon Dec 5 10:54:02 2022 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
Mon Dec 5 10:54:02 2022 [decodeInviteACSBU].
Mon Dec 5 10:54:02 2022 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=1
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] concatenating from header
Mon Dec 5 10:54:02 2022 [receiveInviteMessage] temp_fromuserinfo = 8302
1670237642 -> Mon Dec 5 10:54:02 2022 [receiveInviteMessage] From_userinfo = 8302
Mon Dec 5 10:54:02 2022 1180[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:02 2022 [ipc_thread] Normal case : evt 10764
Mon Dec 5 10:54:02 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:02 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1448 inserted.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::sendLgEvtSipCreate] Event sent on eqt : 1448
Mon Dec 5 10:54:02 2022 ** SEPLOS/IP-DECT **
Mon Dec 5 10:54:02 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:02 2022 Id : -1
Mon Dec 5 10:54:02 2022 INVITE
Mon Dec 5 10:54:02 2022 REQUEST URI : <> 8008@oxe.ma:5060 ; user=name
Mon Dec 5 10:54:02 2022 FROM : <Hajib> 8302@oxe.ma:5060 ; user=name
Mon Dec 5 10:54:02 2022 TO : <8008> 8008@oxe.ma:5060 ; user=name
Mon Dec 5 10:54:02 2022 CAC : 0
Mon Dec 5 10:54:02 2022 CAC ADDRESS :
Mon Dec 5 10:54:02 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:02 2022 CLIR : 0
Mon Dec 5 10:54:02 2022 Prack Required : 0
Mon Dec 5 10:54:02 2022 Allow Update : 0
Mon Dec 5 10:54:02 2022 SDP :
Mon Dec 5 10:54:02 2022 ADDRESS : 192.168.1.181 :6000
Mon Dec 5 10:54:02 2022 ALGOS :
Mon Dec 5 10:54:02 2022 PCMA
Mon Dec 5 10:54:02 2022 G729
Mon Dec 5 10:54:02 2022 101
Mon Dec 5 10:54:02 2022 DIRECTION : SEND & RECEIVE
1670237642 -> Mon Dec 5 10:54:02 2022 video index : 0
Mon Dec 5 10:54:02 2022 crypto index : 0
Mon Dec 5 10:54:02 2022 N_GW_EXT : -1
Mon Dec 5 10:54:02 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:02 2022 1180[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:02 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:02 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:02 2022 neqt : 1448 Id : 1
Mon Dec 5 10:54:02 2022 INFORMATIONAL
Mon Dec 5 10:54:02 2022 xx : 0
Mon Dec 5 10:54:02 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:02 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1448 1.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] an event arrived on an invalid eqt 1448 1.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::unRegister] Remove eqt : 1448 diag : -1 from the map.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::eraseCallwithEqt] erase 1448 -1.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] dialogId update done.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] NOE-SIP : No updates to Twin
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
1670237642 -> Mon Dec 5 10:54:02 2022 [onIncomingEvent] INFORMATIONAL arrived.
Mon Dec 5 10:54:02 2022 [onIncomingEvent] 100 TRYING ignored.
Mon Dec 5 10:54:02 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:02 2022 [ipc_thread] Normal case : evt 10752
Mon Dec 5 10:54:02 2022 neqt : 1432 Id : 1
Mon Dec 5 10:54:02 2022 REQUEST URI : <> 8008@oxe.ma:5060 ; user=phone
Mon Dec 5 10:54:02 2022 FROM : <Hajib> 8302@192.168.1.10:5060 ; user=phone
Mon Dec 5 10:54:02 2022 TO : <Samir> 8008@192.168.1.10:5060 ; user=phone
Mon Dec 5 10:54:02 2022 neqt CAC : -1
Mon Dec 5 10:54:02 2022 N_GW_EXT : 1000
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] an event 10752 arrived on the eqt 1432 1.
1670237642 -> Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] New Call created.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::callFactory].
Mon Dec 5 10:54:02 2022 1181 [CCall::CCall] resources number: 142
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:02 2022 [CMotorCallManager::callFactory]=8df27d0.
Mon Dec 5 10:54:02 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1432 inserted.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildAurlRFCWithBelongingDomain]-->extGw=-1
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setExtGw] -1->1000
Mon Dec 5 10:54:02 2022 1181[CMotorCall::sipUriType] sip Uri.
Mon Dec 5 10:54:02 2022 [quoteString] => "Hajib"
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildFromAssertedId] no P_Asserted_Identity
Mon Dec 5 10:54:02 2022 [quoteString] => "Samir"
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Dec 5 10:54:02 2022 [CMotorCallManager::onIncomingEvent] state = INITIAL_STATE.
Mon Dec 5 10:54:02 2022 [onIncomingEvent] INVITE arrived.
Mon Dec 5 10:54:02 2022 [receiveInviteEvent] Call: eqt: 1432 INITIAL_STATE received an event.
1670237642 -> Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] begin. size=652 call_type: 1
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setExtGw] 1000->1000
Mon Dec 5 10:54:02 2022 1181[CMotorCall::getUserType] extGw=1000.
Mon Dec 5 10:54:02 2022 [isUserInDico] looking for 8008@oxe.ma ...
Mon Dec 5 10:54:02 2022 1181[CMotorCall::getUserType] Request URI is seplos station crypto=0.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] m_crypted FALSE
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildAurlRFCWithBelongingDomain]-->extGw=1000
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] From: "Hajib" <sip:8302@192.168.1.10:5060;user=phone>
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] reqUri :sip:8008@oxe.ma:5060;user=phone
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage]-->SIP_INFO_allowed=1 allow_update=1
1670237642 -> Mon Dec 5 10:54:02 2022 [quoteString] => "Samir"
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] To: "Samir" <sip:8008@192.168.1.10:5060;user=phone>
Mon Dec 5 10:54:02 2022 1181[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildContact] trunk_number=-1 extGw =1000.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildContact] userinfo : 8302
Mon Dec 5 10:54:02 2022 1181[CMotorCall::buildContactInvite] Contact: sip:8302@192.168.1.10:5060
Mon Dec 5 10:54:02 2022 1181[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildSessionTimer] uacGatewayMode=1 uacRefresher=1.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::inviteBuildAlertInfo] call_type:1
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeRequestSdpAudio] Begin sdp.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::is_RFC3264Mline] RFC3264Mline_GW =1
Mon Dec 5 10:54:02 2022 1181[CMotorCall::appendAudioAttributToMedia] Direction: 0.
1670237642 -> Mon Dec 5 10:54:02 2022 1181[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setAudioMediaToSdp] crypto index3=0 clearMediaLine=0.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setAudioMediaToSdp] appendMediaDescription ok.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setAudioMediaToSdp] Connection address: 192.168.1.181.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeRequestSdpAudio] audio end.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::emitInviteMessage] The sdp build.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::new_determineTargetsForTheRequest] is Responsible For This URI.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::new_determineTargets] pcszNameToFind_1=8008.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] nb contacts=1.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] *pcszNameToFind : 8008
1670237642 -> Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] contact : sip:8008@192.168.1.171:5060;transport=udp
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] nb available licenses=0 .
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] req_Uri_OK=0 and pSipAddSpec->getHost()=192.168.1.171
Mon Dec 5 10:54:02 2022 1181[CMotorCall::makeInitialMotorRequest] contact nb=1
Mon Dec 5 10:54:02 2022 [CGWMngData::isMainServer] CPU is MAIN.
Mon Dec 5 10:54:02 2022 [CGWMngData::isMainServer] checkwith PCS = 0
Mon Dec 5 10:54:02 2022 1181 [CCall::makeGenericRequest] INVITE
Mon Dec 5 10:54:02 2022 1181 [CCall::getDialog] Confirmed Dialog is not found (ID =
Mon Dec 5 10:54:02 2022 1181 [CCall::getDialog] Initial Dialog Client not found
Mon Dec 5 10:54:02 2022 1571 [CDialog::CDialog] resources number: 278
Mon Dec 5 10:54:02 2022 1571 [CDialog::createRequest]
Mon Dec 5 10:54:02 2022 1571 [CDialog::buildServicesForAllRequest]
Mon Dec 5 10:54:02 2022 1571 [CDialog::createInviteRequest]
Mon Dec 5 10:54:02 2022 2156 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:02 2022 2156 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:02 2022 1571 [CDialog::onTransactionState(pTrans = 2156, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:02 2022 35731 [CRequest::CRequest] Creation of a request
Mon Dec 5 10:54:02 2022 [DBG: CRequest::freeAttributes]
1670237642 -> Mon Dec 5 10:54:02 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:02 2022 [DBG: CRequest::freeAttributes Ends]
Mon Dec 5 10:54:02 2022 CRequest::createRequestLine Protocol UDP
Mon Dec 5 10:54:02 2022 35731 [CMessage::send] sip_sendMessage (192.168.1.171:5060)
Mon Dec 5 10:54:02 2022 SEND MESSAGE TO NETWORK (192.168.1.171:5060 [UDP]) (BUFF LEN = 963)
INVITE sip:8008@192.168.1.171:5060;transport=udp SIP/2.0
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE, INFO
Session-Expires: 1800;refresher=uac
Min-SE: 900
Alert-Info: <urn:alert:tone:internal>
From: "Hajib" <sip:8302@192.168.1.10:5060;user=phone>;tag=560b51dae5d5d17c18c5b7b9739cd53c
Contact: <sip:8302@192.168.1.10:5060;transport=UDP>
Call-ID: f5c354965203ab46ddaf21e54fa82f3a@192.168.1.10
CSeq: 192632951 INVITE
Via: SIP/2.0/UDP 192.168.1.10;branch=z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1
Max-Forwards: 70
Content-Length: 216
v=0
o=OXE 1670237642 1670237642 IN IP4 192.168.1.10
s=abs
t=0 0
m=audio 6000 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
1670237642 -> Mon Dec 5 10:54:02 2022 [CTransport::findConnection] pConnection = 0 remoteHost=192.168.1.171, remotePort=5060
Mon Dec 5 10:54:02 2022 77d0 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:02 2022 [CTransportUdp::createConnection] new connection = 77d0
Mon Dec 5 10:54:02 2022 Tcl_OpenUdpClient (192.168.1.171,5060)
Mon Dec 5 10:54:02 2022 Tcl_OpenUdpClient reuse existing socket=3
Mon Dec 5 10:54:02 2022 77d0 [CTransport::addConnection] Insert connection with key = 192.168.1.171|5060
Mon Dec 5 10:54:02 2022 [CTransport::createConnection] OK
Mon Dec 5 10:54:02 2022 udp_send fd:3 port 5060 iBytesSend:963
Mon Dec 5 10:54:02 2022 35731 [CMessage::onSendSuccess]
Mon Dec 5 10:54:02 2022 2156 [CTransaction::onSendSuccess] CMessage 35731 send Success
Mon Dec 5 10:54:02 2022 1571 [CDialog::onSendSuccess]
Mon Dec 5 10:54:02 2022 1181[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:02 2022 2156 [CTransInitialState::createRequest] Transaction changes to Calling state
Mon Dec 5 10:54:02 2022 2156 [CTransaction::changeState] STATE CHANGED TO CALLING
Mon Dec 5 10:54:02 2022 1571 [CDialog::onTransactionState(pTrans = 2156, previousState = Initial, currentState = Calling, reason = Request creation]
1670237642 -> Mon Dec 5 10:54:02 2022 2156 [CTransaction::startTimer] Timer A is started (delay = 500 ms)
Mon Dec 5 10:54:02 2022 2156 [CTransaction::startTimer] Timer B is started (delay = 8000 ms)
Mon Dec 5 10:54:02 2022 1571 [CDialog::getTransactionByCSeq] CSeq = 192632951
Mon Dec 5 10:54:02 2022 1571 [CDialog::addTransaction] added transaction 2156 with branch z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1, with CSeq 192632951
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Client, UA)
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 900
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
Mon Dec 5 10:54:02 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:02 2022 [CForkedBranch::CForkedBranch] context = 0x8df2d94.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::branchAllocation] pForkedBranch = 0x89f4258 and the branch number is.
Mon Dec 5 10:54:02 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:02 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:02 2022 1181[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:02 2022 NOE-SIP : StandByCallCreation not sent to twin CS
Mon Dec 5 10:54:02 2022 [onIncomingEvent] CallID must be inserted.
Mon Dec 5 10:54:02 2022 [onIncomingEvent] CallID inserted.
1670237642 -> Mon Dec 5 10:54:02 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:02 2022 xx : 80
Mon Dec 5 10:54:02 2022 [receiveInformationalEvent] Call: c706eb47 eqt: 1448 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:02 2022 1180[CMotorCall::emitInformationalMessage] PAI
1670237642 -> Mon Dec 5 10:54:02 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:02 2022 1180[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:02 2022 1180[CMotorCall::buildContact] Contact: sip:192.168.1.10:5060
Mon Dec 5 10:54:02 2022 1180[CMotorCall::emitInformationMessage] cause=-1
Mon Dec 5 10:54:02 2022 1180 [CCall::makeGenericResponse] 180
Mon Dec 5 10:54:02 2022 1180 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:02 2022 1570 [CDialog::createResponse] 180
Mon Dec 5 10:54:02 2022 2155 [CTransProceedingState::createResponse] CResponse 35C9B ref=1
Mon Dec 5 10:54:02 2022 35C9B [CMessage::send] sip_sendMessage (192.168.1.181:5060)
Mon Dec 5 10:54:02 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 511)
SIP/2.0 180 Ringing
P-Asserted-Identity: "Samir" <sip:8008@192.168.1.10:5060;user=phone>
To: "8008" <sip:8008@oxe.ma:5060>;tag=195918d3ab06a6381543d4ebe9a898ba
Call-ID: c706eb47
Content-Length: 0
Mon Dec 5 10:54:02 2022 udp_send fd:3 port 5060 iBytesSend:511
Mon Dec 5 10:54:02 2022 35C9B [CMessage::onSendSuccess]
Mon Dec 5 10:54:02 2022 2155 [CTransaction::onSendSuccess] CMessage 35C9B send Success
Mon Dec 5 10:54:02 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:02 2022 35C9A [~CResponse] resp(100) c706eb47 1090543851 INVITE
Mon Dec 5 10:54:02 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:02 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:02 2022 1570 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:02 2022 udp_recv fd:5 iBytesRead:641
Mon Dec 5 10:54:02 2022 UdpInputProc iSock:5 iBytesRead:641 Host:192.168.1.171 Port:5060
Mon Dec 5 10:54:02 2022 [CTransportUdp::receiveMessage] from 192.168.1.171:5060 rc:641
Mon Dec 5 10:54:02 2022 [CTransport::findConnection] pConnection = 77d0 remoteHost=192.168.1.171, remotePort=5060
1670237642 -> Mon Dec 5 10:54:02 2022 [CIOCom::onReceiveMessage] received from 192.168.1.171:5060, proto=0, length=641, mtls = 0
Mon Dec 5 10:54:02 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.171:5060 [UDP])
SIP/2.0 180 Ringing
To: "Samir" <sip:8008@192.168.1.10:5060;user=phone>;tag=1599039450
Contact: <sip:8008@192.168.1.171:5060;transport=udp>
Content-Length: 0
Mon Dec 5 10:54:02 2022 [CIOCom::receiveResponse] CResponse 35C9C ref=1
Mon Dec 5 10:54:02 2022 [CDispatcher::processResponseFromManagerIndex] start at index 0
Mon Dec 5 10:54:02 2022 102 [CCallManager::onIncomingResponse]
Mon Dec 5 10:54:02 2022 1181 [CCall::receiveResponse] 180
Mon Dec 5 10:54:02 2022 1181 [CCall::getDialog] Confirmed Dialog is not found (ID = 560b51dae5d5d17c18c5b7b9739cd53c;1599039450)
1670237642 -> Mon Dec 5 10:54:02 2022 1181 [CCall::getDialog] Returning Initial Dialog Client
Mon Dec 5 10:54:02 2022 1571 [CDialog::receiveResponse]
Mon Dec 5 10:54:02 2022 2156 [CTransCallingState::receiveResponse] Provisional : Transaction changes to Proceeding state
Mon Dec 5 10:54:02 2022 2156 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:02 2022 1571 [CDialog::onTransactionState(pTrans = 2156, previousState = Calling, currentState = Proceeding, reason = 1xx response reception]
Mon Dec 5 10:54:02 2022 2156 [CTransaction::freeTimerToken] Timer A is freed
Mon Dec 5 10:54:02 2022 2156 [CTransaction::freeTimerToken] Timer B is freed
Mon Dec 5 10:54:02 2022 1571 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:02 2022 1181[CMotorCall::searchForkedBranch]pForkedBranch=0x89f4258.
Mon Dec 5 10:54:02 2022 1181[CMotorCall::onReceiveResponse] lastInviteContext got updated
Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] Call: f5c354965203ab46ddaf21e54fa82f3a@192.168.1.10 eqt: 1432 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] setting COLP to true in preferred
Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] 0 AlertInfo header(s) found
Mon Dec 5 10:54:02 2022 [CPoceedingState::receiveInformationalMessage]-->nof of PEM hdrs 0
1670237643 -> Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] No P-Early-Media header received
Mon Dec 5 10:54:02 2022 [receiveInformationalMessage] is in the else part of SDP not present
Mon Dec 5 10:54:02 2022 [methodAllowedByDistant] INFO allowed by distant.
Mon Dec 5 10:54:02 2022 1181[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:02 2022 1181[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:02 2022 1181[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:02 2022 1181[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:02 2022 ** SEPLOS **
Mon Dec 5 10:54:02 2022 [sendLgEvtSip] seplos Event sent on eqt : 1432 Id :1
Mon Dec 5 10:54:02 2022 Id : 1
Mon Dec 5 10:54:02 2022 [fnInit] *************************** Init timeout.
Mon Dec 5 10:54:02 2022 [fnInit] treatTimeout.
Mon Dec 5 10:54:02 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:54:02 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:54:02 2022 [startRegistration] timer value=6000.
1670237643 -> Mon Dec 5 10:54:03 2022 udp_recv fd:5
Mon Dec 5 10:54:03 2022 udp_recv fd:5 iBytesRead:963
Mon Dec 5 10:54:03 2022 UdpInputProc iSock:5 iBytesRead:963 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:03 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:963
Mon Dec 5 10:54:03 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:03 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=963, mtls = 0
Mon Dec 5 10:54:03 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
INVITE sip:8013@192.168.1.10 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.18:59400;rport;branch=z9hG4bKPj55be59c9ffd0479591032575c39daccf
Max-Forwards: 70
From: <sip:8977@192.168.1.10>;tag=8cd80b611f0d474fbb11f683f655f043
To: <sip:8013@192.168.1.10>
Contact: <sip:8977@192.168.1.18:59400;ob>
Call-ID: d3cb51948f8c4d0280ca3bb145661901
CSeq: 14859 INVITE
Route: <sip:192.168.1.10;lr>
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Supported: replaces, 100rel, timer, norefersub
Min-SE: 90
User-Agent: MicroSIP/3.21.3
Content-Length: 316
v=0
o=- 3879226472 3879226472 IN IP4 128.203.52.4
s=pjmedia
b=AS:84
t=0 0
a=X-nat:0
m=audio 4004 RTP/AVP 8 101
c=IN IP4 128.203.52.4
b=TIAS:64000
a=rtcp:4005 IN IP4 128.203.52.4
a=sendrecv
a=fmtp:101 0-16
a=ssrc:1646068843 cname:733863bc17152acd
1670237643 -> Mon Dec 5 10:54:03 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:03 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:03 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:03 2022 35732 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:03 2022 [CIOCom::receiveRequest] Received CRequest 35732 ref=1
Mon Dec 5 10:54:03 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:03 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:03 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:03 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:03 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:03 2022 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
Mon Dec 5 10:54:03 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:03 2022 [CMotorCallManager::callFactory] For call : d3cb51948f8c4d0280ca3bb145661901.
Mon Dec 5 10:54:03 2022 1182 [CCall::CCall] resources number: 143
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:03 2022 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.68.a
Mon Dec 5 10:54:03 2022 [CMotorCallManager::callFactory]=8de05f8.
1670237643 -> Mon Dec 5 10:54:03 2022 1182 [CCall::receiveRequest] INVITE
Mon Dec 5 10:54:03 2022 1182 [CCall::getDialog] Confirmed Dialog is not found (ID = ;8cd80b611f0d474fbb11f683f655f043)
Mon Dec 5 10:54:03 2022 1182 [CCall::getDialog] Initial Dialog Server not found
Mon Dec 5 10:54:03 2022 1572 [CDialog::CDialog] resources number: 279
Mon Dec 5 10:54:03 2022 1572 [CDialog::receiveRequest]
Mon Dec 5 10:54:03 2022 1572 [CDialog::receiveInviteRequest]
Mon Dec 5 10:54:03 2022 2157 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:03 2022 2157 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:03 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:03 2022 2157 [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Dec 5 10:54:03 2022 2157 [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:03 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Dec 5 10:54:03 2022 2157 [CTransProceedingState::createResponse] CResponse 35C9D ref=1
Mon Dec 5 10:54:03 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:03 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:03 2022 [DBG: CResponse::freeAttributes] Ends
1670237643 -> Mon Dec 5 10:54:03 2022 35C9D [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:03 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:03 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 321)
SIP/2.0 100 Trying
CSeq: 14859 INVITE
Via: SIP/2.0/UDP 192.168.1.18:59400;received=192.168.1.18;rport=59400;branch=z9hG4bKPj55be59c9ffd0479591032575c39daccf
Content-Length: 0
Mon Dec 5 10:54:03 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:03 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:03 2022 udp_send fd:5
Mon Dec 5 10:54:03 2022 udp_send fd:5 port 59400 iBytesSend:321
Mon Dec 5 10:54:03 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:03 2022 35C9D [CMessage::onSendSuccess]
Mon Dec 5 10:54:03 2022 2157 [CTransaction::onSendSuccess] CMessage 35C9D send Success
Mon Dec 5 10:54:03 2022 1572 [CDialog::onSendSuccess]
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:03 2022 1572 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
1670237643 -> Mon Dec 5 10:54:03 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 90
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:03 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:03 2022 1572 [CDialog::addTransaction] added transaction 2157 with branch z9hG4bKPj55be59c9ffd0479591032575c39daccf, with CSeq 14859
Mon Dec 5 10:54:03 2022 1182 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:03 2022 1182 [CCall::checkAuthentication] INVITE
Mon Dec 5 10:54:03 2022 1182[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:03 2022 [getFromHeader] look at the From.
Mon Dec 5 10:54:03 2022 [getFromHeader] displayName=.
Mon Dec 5 10:54:03 2022 [convertCSipURLIntoSipuri] uri = sip:8977@192.168.1.10.
Mon Dec 5 10:54:03 2022 [getFromHeader] =8977@192.168.1.10.
Mon Dec 5 10:54:03 2022 [getFromHeader] clirPresent=0.
Mon Dec 5 10:54:03 2022 [getReqUriHeader] look at the requri.
Mon Dec 5 10:54:03 2022 [convertCSipURLIntoSipuri] uri = sip:8013@192.168.1.10.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::getUserType] extGw=-1.
1670237643 -> Mon Dec 5 10:54:03 2022 [CMotorCall::analyseRouting] TEL uri=0.
Mon Dec 5 10:54:03 2022 [CMotorCall::analyseRouting] 8977@192.168.1.10 is authenticable.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setExtGw] -1->-3
Mon Dec 5 10:54:03 2022 [isUserInDico] looking for 8977@192.168.1.10 ...
Mon Dec 5 10:54:03 2022 [isUserInDico] found in the dictionnary.
Mon Dec 5 10:54:03 2022 [isAddrInDico] seplos station OK
Mon Dec 5 10:54:03 2022 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::getUserType] From is seplos station crypto=0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::getUserType] extGw=-3.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::controlAuthentication] m_other_calling=0 extgw=-3
Mon Dec 5 10:54:03 2022 1182[CMotorCall::controlAuthentication] from:sip:8977@192.168.1.10:5060
Mon Dec 5 10:54:03 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:03 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:03 2022 [CGwMngData::isAuthenticationRequiredForThisClient] 8977@192.168.1.10 .
Mon Dec 5 10:54:03 2022 [CGwMngData::isAuthenticationRequiredForThisClient] -3 need auth=0.
Mon Dec 5 10:54:03 2022 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway -3.
Mon Dec 5 10:54:03 2022 CGwMngData::isAuthenticationRequiredForThisClient: gateway=-3
1670237643 -> Mon Dec 5 10:54:03 2022 1182[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setExtGw] -3->-3
Mon Dec 5 10:54:03 2022 1182 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:03 2022 1182 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:03 2022 1182 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:03 2022 1182 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Dec 5 10:54:03 2022 1182[CMotorCall::initOfUserType] station role already defined s=1 d=0 o=0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onReceiveRequest] accepte? m_other_calling=0 gw=-1.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=2.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::toGatewayOrProxy] request for proxydomain=192.168.1.10.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::toGatewayOrProxy] from = seplos station.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] nb available licenses=0 .
1670237643 -> Mon Dec 5 10:54:03 2022 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Dec 5 10:54:03 2022 [CForkedBranch::CForkedBranch] context = 0x8de0bbc.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] reqUri stored: sip:8977@192.168.1.18:59400;ob
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::methodInviteReceived] CAC = 0
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: -1 INITIAL_STATE received a message.
Mon Dec 5 10:54:03 2022 [decodeInviteCLIR].
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] UPDATE present in Allow header
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] INFO present in Allow header
Mon Dec 5 10:54:03 2022 am_I_PCS SCSWorking : NO
Mon Dec 5 10:54:03 2022 check_PCSstate
Mon Dec 5 10:54:03 2022 check_PCSstate stat of PCS is : -1
Mon Dec 5 10:54:03 2022 1182[CMotorCall::analyseSessionTimer] Session Timer extGw=-1 sessionDelay=1800 .
1670237643 -> Mon Dec 5 10:54:03 2022 1182[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:03 2022 1182[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:03 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] Format : 8.
Mon Dec 5 10:54:03 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:03 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:03 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] The audio media contains 2 format(s).
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] 101.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Format is DTMF:101.
1670237643 -> Mon Dec 5 10:54:03 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:03 2022 [convertAudioMedia] Connection address retrieved in sdp: 128.203.52.4.
Mon Dec 5 10:54:03 2022 [convertIPStrIntoTuipv] 128.203.52.4 => 128.203.52.4
Mon Dec 5 10:54:03 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:03 2022 [display_sdp] address =128.203.52.4
Mon Dec 5 10:54:03 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:03 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:03 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:03 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Mon Dec 5 10:54:03 2022 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Dec 5 10:54:03 2022 [receiveinvitemessage] get requri.
Mon Dec 5 10:54:03 2022 [decodeInviteTo].
Mon Dec 5 10:54:03 2022 [decodeInviteReferredBy].
Mon Dec 5 10:54:03 2022 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
Mon Dec 5 10:54:03 2022 [decodeInviteACSBU].
Mon Dec 5 10:54:03 2022 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=1
1670237643 -> Mon Dec 5 10:54:03 2022 [receiveInviteMessage] concatenating from header
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] temp_fromuserinfo = 8977
Mon Dec 5 10:54:03 2022 [receiveInviteMessage] From_userinfo = 8977
Mon Dec 5 10:54:03 2022 1182[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:03 2022 [ipc_thread] Normal case : evt 10764
Mon Dec 5 10:54:03 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:03 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1464 inserted.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::sendLgEvtSipCreate] Event sent on eqt : 1464
Mon Dec 5 10:54:03 2022 ** SEPLOS/IP-DECT **
Mon Dec 5 10:54:03 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:03 2022 Id : -1
Mon Dec 5 10:54:03 2022 INVITE
Mon Dec 5 10:54:03 2022 REQUEST URI : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:03 2022 FROM : <> 8977@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:03 2022 TO : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:03 2022 CAC : 0
Mon Dec 5 10:54:03 2022 CAC ADDRESS :
Mon Dec 5 10:54:03 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:03 2022 CLIR : 0
Mon Dec 5 10:54:03 2022 Prack Required : 0
Mon Dec 5 10:54:03 2022 Allow Update : 0
Mon Dec 5 10:54:03 2022 SDP :
Mon Dec 5 10:54:03 2022 ADDRESS : 128.203.52.4 :4004
1670237643 -> Mon Dec 5 10:54:03 2022 ALGOS :
Mon Dec 5 10:54:03 2022 PCMA
Mon Dec 5 10:54:03 2022 101
Mon Dec 5 10:54:03 2022 DIRECTION : SEND & RECEIVE
Mon Dec 5 10:54:03 2022 video index : 0
Mon Dec 5 10:54:03 2022 crypto index : 0
Mon Dec 5 10:54:03 2022 N_GW_EXT : -1
Mon Dec 5 10:54:03 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:03 2022 1182[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:03 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:03 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:03 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:03 2022 INFORMATIONAL
Mon Dec 5 10:54:03 2022 xx : 0
Mon Dec 5 10:54:03 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:03 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1464 1.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] an event arrived on an invalid eqt 1464 1.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::unRegister] Remove eqt : 1464 diag : -1 from the map.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 -1.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] dialogId update done.
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] NOE-SIP : No updates to Twin
Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] seplos station.
1670237643 -> Mon Dec 5 10:54:03 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:03 2022 [onIncomingEvent] INFORMATIONAL arrived.
Mon Dec 5 10:54:03 2022 [onIncomingEvent] 100 TRYING ignored.
Mon Dec 5 10:54:03 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:03 2022 xx : 83
Mon Dec 5 10:54:03 2022 ADDRESS : 192.168.1.11 :32524
1670237643 -> Mon Dec 5 10:54:03 2022 [receiveInformationalEvent] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:03 2022 1182[CMotorCall::buildContact] Contact: sip:192.168.1.10:5060
Mon Dec 5 10:54:03 2022 1182[CMotorCall::emitInformationMessage] cause=183
Mon Dec 5 10:54:03 2022 1182[CMotorCall::makeResponseSdpAudioOld] Audio media.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:03 2022 1182[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Mon Dec 5 10:54:03 2022 [sameCodec] accepted Format : 8.
Mon Dec 5 10:54:03 2022 [sameCodec] requested Format : 8.
Mon Dec 5 10:54:03 2022 [sameCodec] same Format.
Mon Dec 5 10:54:03 2022 1182[CMotorCall::mediaAccepted] Media accepted: m=audio 32524 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:03 2022 1182[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
1670237643 -> Mon Dec 5 10:54:03 2022 1182[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Mon Dec 5 10:54:03 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:03 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:03 2022 1182[CMotorCall::emitInformationalMessage] Answer sdp.
Mon Dec 5 10:54:03 2022 [removeAudioMediaPortNull] media no=0.
Mon Dec 5 10:54:03 2022 1182 [CCall::makeGenericResponse] 183
Mon Dec 5 10:54:03 2022 1182 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:03 2022 1572 [CDialog::createResponse] 183
Mon Dec 5 10:54:03 2022 2157 [CTransProceedingState::createResponse] CResponse 35C9E ref=1
Mon Dec 5 10:54:03 2022 35C9E [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:03 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 834)
SIP/2.0 183 Session Progress
User-Agent: OmniPCX Enterprise R100.0 n1.291.68.a
Reason: SIP;cause=183;text="is busy "
To: <sip:8013@192.168.1.10>;tag=8d38cac76fe0a471d7ddc4b5ffcf9be7
CSeq: 14859 INVITE
Content-Length: 216
v=0
o=OXE 1670237643 1670237643 IN IP4 192.168.1.10
s=abs
c=IN IP4 192.168.1.11
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1670237644 -> Mon Dec 5 10:54:03 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:03 2022 udp_send fd:5 port 59400 iBytesSend:834
Mon Dec 5 10:54:03 2022 35C9E [CMessage::onSendSuccess]
Mon Dec 5 10:54:03 2022 2157 [CTransaction::onSendSuccess] CMessage 35C9E send Success
Mon Dec 5 10:54:03 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:03 2022 35C9D [~CResponse] resp(100) d3cb51948f8c4d0280ca3bb145661901 14859 INVITE
Mon Dec 5 10:54:03 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:03 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:03 2022 1572 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:04 2022 info [CServRegistrar::writeLocateFile]
Mon Dec 5 10:54:04 2022 udp_recv fd:5
Mon Dec 5 10:54:04 2022 udp_recv fd:5 iBytesRead:389
Mon Dec 5 10:54:04 2022 UdpInputProc iSock:5 iBytesRead:389 Host:192.168.1.18 Port:59400
1670237644 -> Mon Dec 5 10:54:04 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:389
Mon Dec 5 10:54:04 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:04 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=389, mtls = 0
Mon Dec 5 10:54:04 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
CANCEL sip:8013@192.168.1.10 SIP/2.0
Max-Forwards: 70
CSeq: 14859 CANCEL
Content-Length: 0
Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:04 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:04 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:04 2022 35733 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] Received CRequest 35733 ref=1
Mon Dec 5 10:54:04 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] rport1 empty
1670237644 -> Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:04 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:04 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:04 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] CANCEL
Mon Dec 5 10:54:04 2022 1182 [CCall::getDialog] Confirmed Dialog is not found (ID = ;8cd80b611f0d474fbb11f683f655f043)
Mon Dec 5 10:54:04 2022 1182 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:04 2022 1572 [CDialog::receiveRequest]
Mon Dec 5 10:54:04 2022 1572 [CDialog::receiveCancelRequest]
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2158, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:04 2022 2158 [CTransInitialState::receiveRequest] Transaction changes to Trying state
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2158, previousState = Initial, currentState = Trying, reason = Request reception]
Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] iErrorCode=488.
1670237644 -> Mon Dec 5 10:54:04 2022 1182 [CCall::checkAuthentication] CANCEL
Mon Dec 5 10:54:04 2022 1182[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:04 2022 1182[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:54:04 2022 1182 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:04 2022 1182 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:04 2022 1182 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:04 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:04 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] state = PROCEEDING_STATE.
Mon Dec 5 10:54:04 2022 [receiveCancelMessage] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:04 2022 ** SEPLOS **
Mon Dec 5 10:54:04 2022 [sendLgEvtSip] seplos Event sent on eqt : 1464 Id :1
1670237644 -> Mon Dec 5 10:54:04 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:04 2022 Id : 1
Mon Dec 5 10:54:04 2022 CANCEL
Mon Dec 5 10:54:04 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:04 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:54:04 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:04 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:04 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:04 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:04 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:04 2022 SUCCESSFUL
Mon Dec 5 10:54:04 2022 xx : 0
Mon Dec 5 10:54:04 2022 RELATIVE REQUEST : CANCEL
Mon Dec 5 10:54:04 2022 CLIR : 0
Mon Dec 5 10:54:04 2022 COLP : 0
Mon Dec 5 10:54:04 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:04 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1464 1.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:04 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:54:04 2022 [onIncomingEvent] relative_request = 10756
Mon Dec 5 10:54:04 2022 [CProceedingState::receiveSuccessfulEvent] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:04 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
1670237644 -> Mon Dec 5 10:54:04 2022 1572 [CCall::findFirstServerTrans]
Mon Dec 5 10:54:04 2022 1572 [CDialog::findFirstServerTrans] Current Request in cancelTransactionMap
Mon Dec 5 10:54:04 2022 1182 [CCall::makeGenericResponse] 200
Mon Dec 5 10:54:04 2022 1572 [CDialog::createResponse] 200
Mon Dec 5 10:54:04 2022 2158 [CTransTryingState::createResponse] CResponse 35C9F ref=1
Mon Dec 5 10:54:04 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:04 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:04 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:04 2022 35C9F [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:04 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:04 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 407)
SIP/2.0 200 OK
Supported: replaces,timer,path,100rel
CSeq: 14859 CANCEL
Content-Length: 0
1670237644 -> Mon Dec 5 10:54:04 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:04 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:04 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:04 2022 udp_send fd:5
Mon Dec 5 10:54:04 2022 udp_send fd:5 port 59400 iBytesSend:407
Mon Dec 5 10:54:04 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:04 2022 35C9F [CMessage::onSendSuccess]
Mon Dec 5 10:54:04 2022 2158 [CTransaction::onSendSuccess] CMessage 35C9F send Success
Mon Dec 5 10:54:04 2022 1572 [CDialog::onSendSuccess]
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:04 2022 2158 [CTransTryingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2158, previousState = Trying, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:04 2022 2158 [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
Mon Dec 5 10:54:04 2022 1572 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:04 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:04 2022 [ipc_thread] Normal case : evt 10767
1670237644 -> Mon Dec 5 10:54:04 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:04 2022 REQUEST FAILURE
Mon Dec 5 10:54:04 2022 xx : 87
Mon Dec 5 10:54:04 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] an event 10767 arrived on the eqt 1464 1.
Mon Dec 5 10:54:04 2022 [onIncomingEvent] REQUEST FAILURE arrived.
Mon Dec 5 10:54:04 2022 [receiveRequestFailureEvent] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::getOutgoingCall] outgoingCall:0
Mon Dec 5 10:54:04 2022 [receiveRequestFailureEvent] incoming call.
Mon Dec 5 10:54:04 2022 1182 [CCall::makeGenericResponse] 487
Mon Dec 5 10:54:04 2022 1182 [CCall::getDialog] Confirmed Dialog is not found (ID = 8d38cac76fe0a471d7ddc4b5ffcf9be7;8cd80b611f0d474fbb11f683f655f043)
Mon Dec 5 10:54:04 2022 1572 [CDialog::createResponse] 487
Mon Dec 5 10:54:04 2022 2157 [CTransProceedingState::createResponse] CResponse 35CA0 ref=1
1670237644 -> Mon Dec 5 10:54:04 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:04 2022 35CA0 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:04 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 504)
SIP/2.0 487 Request Terminated
CSeq: 14859 INVITE
Content-Length: 0
Mon Dec 5 10:54:04 2022 udp_send fd:5 port 59400 iBytesSend:504
1670237644 -> Mon Dec 5 10:54:04 2022 35CA0 [CMessage::onSendSuccess]
Mon Dec 5 10:54:04 2022 2157 [CTransaction::onSendSuccess] CMessage 35CA0 send Success
Mon Dec 5 10:54:04 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:04 2022 35C9E [~CResponse] resp(183) d3cb51948f8c4d0280ca3bb145661901 14859 INVITE
Mon Dec 5 10:54:04 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:04 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:04 2022 2157 [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:04 2022 2157 [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Dec 5 10:54:04 2022 2157 [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Dec 5 10:54:04 2022 1182[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:04 2022 udp_recv fd:5 iBytesRead:391
1670237644 -> Mon Dec 5 10:54:04 2022 UdpInputProc iSock:5 iBytesRead:391 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:04 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:391
Mon Dec 5 10:54:04 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=391, mtls = 0
ACK sip:8013@192.168.1.10 SIP/2.0
Max-Forwards: 70
CSeq: 14859 ACK
Content-Length: 0
Mon Dec 5 10:54:04 2022 35734 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] Received CRequest 35734 ref=1
1670237644 -> Mon Dec 5 10:54:04 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] ACK
Mon Dec 5 10:54:04 2022 1572 [CDialog::receiveAckRequest]
Mon Dec 5 10:54:04 2022 2157 [CTransCompletedState::receiveRequest] ACK(UDP) : Transaction changes to Confirmed state
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] STATE CHANGED TO CONFIRMED
Mon Dec 5 10:54:04 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = Completed, currentState = Confirmed, reason = Request reception]
Mon Dec 5 10:54:04 2022 2157 [CTransaction::freeTimerToken] Timer G is freed
Mon Dec 5 10:54:04 2022 2157 [CTransaction::freeTimerToken] Timer H is freed
Mon Dec 5 10:54:04 2022 2157 [CTransaction::startTimer] Timer I is started (delay = 5000 ms)
Mon Dec 5 10:54:04 2022 1572 [CDialog::receiveAckRequest] receiving an ACK on a previously rejected INVITE
1670237644 -> Mon Dec 5 10:54:04 2022 1182 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:04 2022 1182 [CCall::checkAuthentication] ACK
Mon Dec 5 10:54:04 2022 1182[CMotorCall::onReceiveRequest] state = TERMINATED_STATE.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::compareDialogFromContext] same Dialog
Mon Dec 5 10:54:04 2022 1182[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Dec 5 10:54:04 2022 [receiveAckMessage] Call: d3cb51948f8c4d0280ca3bb145661901 eqt: 1464 TERMINATED_STATE received a message.
Mon Dec 5 10:54:04 2022 [receiveAckMessage] boolean flag check 0
1670237644 -> Mon Dec 5 10:54:04 2022 1182[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:04 2022 ACK
Mon Dec 5 10:54:04 2022 [ipc_thread] Normal case : evt 10773
Mon Dec 5 10:54:04 2022 SIP EQT RELEASED
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1464 1.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1464 has released its equipment.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::unRegister] Remove eqt : 1464 diag : 1 from the map.
1670237644 -> Mon Dec 5 10:54:04 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 1.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onIncomingEvent] killSession.
Mon Dec 5 10:54:04 2022 1182 [CCall::killSession]
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:04 2022 2158 [CTransaction::freeTimerToken] Timer J is freed
Mon Dec 5 10:54:04 2022 2158 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:04 2022 2157 [CTransaction::freeTimerToken] Timer I is freed
Mon Dec 5 10:54:04 2022 2157 [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:04 2022 1182 [CCall::killSession] notifying the call manager
Mon Dec 5 10:54:04 2022 102 [CCallManager::onCallClosed]
Mon Dec 5 10:54:04 2022 102 [CCallManager::onCallClosed()] Call 1182 closed. Removing call 148768248 from the maps
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onNotifyCallClosed] Call : d3cb51948f8c4d0280ca3bb145661901 is closed.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onNotifyCallClosed] call processResponse.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::chooseBestResponse] pForkedBranch=0x8ad0380 iResponseCode=2000.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:54:04 2022 1182[CMotorCall::processResponse] no response found.
Mon Dec 5 10:54:04 2022 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1670237645 -> Mon Dec 5 10:54:04 2022 102 [CCallManager::onCallClosed] pCall: 1182 added in the Garbage List
Mon Dec 5 10:54:05 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:05 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:05 2022 1572 [CDialog::onTransactionState(pTrans = 2158, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:05 2022 2158 [~CTransaction] transaction 14859 CANCEL
Mon Dec 5 10:54:05 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:05 2022 35C9F [~CResponse] resp(200) d3cb51948f8c4d0280ca3bb145661901 14859 CANCEL
Mon Dec 5 10:54:05 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:05 2022 35733 [~CRequest] req d3cb51948f8c4d0280ca3bb145661901 14859 CANCEL
Mon Dec 5 10:54:05 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:05 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:05 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:05 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:05 2022 1572 [CDialog::onTransactionState(pTrans = 2157, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:05 2022 1572 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:54:05 2022 1572 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:54:05 2022 1182 [CCall::onDialogClosed]
1670237646 -> Mon Dec 5 10:54:05 2022 1182 [CCall::onDialogClosed] only initial *********
Mon Dec 5 10:54:05 2022 1182 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
Mon Dec 5 10:54:05 2022 2157 [~CTransaction] transaction 14859 INVITE
Mon Dec 5 10:54:05 2022 35734 [~CRequest] req d3cb51948f8c4d0280ca3bb145661901 14859 ACK
Mon Dec 5 10:54:06 2022 udp_recv fd:5
Mon Dec 5 10:54:06 2022 udp_recv fd:5 iBytesRead:981
Mon Dec 5 10:54:06 2022 UdpInputProc iSock:5 iBytesRead:981 Host:192.168.1.171 Port:5060
Mon Dec 5 10:54:06 2022 [CTransportUdp::receiveMessage] from 192.168.1.171:5060 rc:981
Mon Dec 5 10:54:06 2022 [CTransport::findConnection] pConnection = 77d0 remoteHost=192.168.1.171, remotePort=5060
Mon Dec 5 10:54:06 2022 [CIOCom::onReceiveMessage] received from 192.168.1.171:5060, proto=0, length=981, mtls = 0
Mon Dec 5 10:54:06 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.171:5060 [UDP])
SIP/2.0 200 OK
Allow: ACK, BYE, CANCEL, INFO, INVITE, MESSAGE, NOTIFY, OPTIONS, PRACK, PUBLISH, REFER, REGISTER, SUBSCRIBE, UPDATE
Allow-Events: conference, refer, talk, hold
Supported: 100rel, eventlist, join, replaces, sdp-anat, tdialog
Content-Disposition: session
Content-Type: application/sdp
Content-Length: 282
v=0
o=- 2351778037827138401 2351778037827138402 IN IP4 192.168.1.171
s=SDP data
c=IN IP4 192.168.1.171
t=0 0
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=silenceSupp:off - - - -
a=fmtp:101 0-15
a=ptime:20
a=mptime:20 -
a=sendrecv
1670237646 -> Mon Dec 5 10:54:06 2022 [CIOCom::receiveResponse] CResponse 35CA1 ref=1
Mon Dec 5 10:54:06 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:06 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:06 2022 [CDispatcher::processResponseFromManagerIndex] start at index 0
Mon Dec 5 10:54:06 2022 102 [CCallManager::onIncomingResponse]
Mon Dec 5 10:54:06 2022 1181 [CCall::receiveResponse] 200
Mon Dec 5 10:54:06 2022 1181 [CCall::getDialog] Confirmed Dialog is not found (ID = 560b51dae5d5d17c18c5b7b9739cd53c;1599039450)
Mon Dec 5 10:54:06 2022 1181 [CCall::getDialog] Returning Initial Dialog Client
Mon Dec 5 10:54:06 2022 1571 [CDialog::receiveResponse]
Mon Dec 5 10:54:06 2022 1571 [CDialog::receiveResponse] create a CONFIRMED dialog
Mon Dec 5 10:54:06 2022 1573 [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1
Mon Dec 5 10:54:06 2022 1573 [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1
Mon Dec 5 10:54:06 2022 2159 [CTransaction::CTransaction] Transaction is cloned in 4 state
Mon Dec 5 10:54:06 2022 1573 [CDialog::addTransaction] added transaction 2159 with branch z9hG4bKa6e077bc42d5b035d3ca7638a2ec21f1, with CSeq 192632951
Mon Dec 5 10:54:06 2022 1573 [CDialog::startDialogTTL]
Mon Dec 5 10:54:06 2022 1573 [CDialog::CDialog] resources number: 280
1670237646 -> Mon Dec 5 10:54:06 2022 1573 [CDialog::receiveResponse]
Mon Dec 5 10:54:06 2022 2159 [CTransProceedingState::receiveResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:06 2022 2159 [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:06 2022 2159 [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:06 2022 1573 [CDialog::onTransactionState(pTrans = 2159, previousState = Proceeding, currentState = Completed, reason = Final resp reception]
Mon Dec 5 10:54:06 2022 2159 [CTransaction::startTimer] Timer D is started (delay = 32382 ms)
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Client, UA)
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 900
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateSessionExpires] Refresher updated : i
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::startTimers] Start session timer expiration : 1800000
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::startTimers] Start session timer will expires : 900000
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:06 2022 1573 [CDialog::updateRouteSet] there are 0 record-route headers
1670237646 -> Mon Dec 5 10:54:06 2022 1181 [CCall::insertInDialogMap] added dialog #1573 with the key 560b51dae5d5d17c18c5b7b9739cd53c;1599039450
Mon Dec 5 10:54:06 2022 1571 [CDialog::getTransactionByCSeq] CSeq = 192632952
Mon Dec 5 10:54:06 2022 1571 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:06 2022 1181[CMotorCall::searchForkedBranch]pForkedBranch=0x89f4258.
Mon Dec 5 10:54:06 2022 [CForkedBranch::setFinalResponse] response=200.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::responseToInviteOrCancel] call chooseBestResponse.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::chooseBestResponse] pForkedBranch=0x89f4258 iResponseCode=2000.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::chooseBestResponse] last iResponseCode=200.
Mon Dec 5 10:54:06 2022 [CForkedBranch::setFinalResponse] pResponse=0x8b2e770.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::responseToInviteOrCancel] inviteResponse => update the lastInviteContext.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:06 2022 [receiveSuccessfulMessage] Call: f5c354965203ab46ddaf21e54fa82f3a@192.168.1.10 eqt: 1432 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:06 2022 1181[CMotorCall::analyseSessionTimer] Session Timer extGw=1000 sessionDelay=1800 .
Mon Dec 5 10:54:06 2022 1181[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
1670237646 -> Mon Dec 5 10:54:06 2022 1181[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=1 uacRefresher=1.
Mon Dec 5 10:54:06 2022 [decodeACACALU] no header.
Mon Dec 5 10:54:06 2022 [receiveSuccessfulMessage] setting COLP to true in preferred
Mon Dec 5 10:54:06 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:06 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:06 2022 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Dec 5 10:54:06 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:06 2022 [checkSdpValidity] Format : 8.
Mon Dec 5 10:54:06 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:06 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:06 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] The audio media contains 2 format(s).
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] 101.
1670237646 -> Mon Dec 5 10:54:06 2022 [convertAudioMedia] Format is DTMF:101.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:06 2022 [convertAudioMedia] Connection address retrieved in sdp: 192.168.1.171.
Mon Dec 5 10:54:06 2022 [convertIPStrIntoTuipv] 192.168.1.171 => 192.168.1.171
Mon Dec 5 10:54:06 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:06 2022 [display_sdp] address =192.168.1.171
Mon Dec 5 10:54:06 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:06 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:06 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbffff0c8 crypto_index=0 clear media=1
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:06 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbffff0c8 crypto_index=0 clear media=1
Mon Dec 5 10:54:06 2022 [methodAllowedByDistant] INFO allowed by distant.
Mon Dec 5 10:54:06 2022 1181[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:06 2022 1181[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:06 2022 1181[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:06 2022 1181[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:06 2022 ** SEPLOS **
Mon Dec 5 10:54:06 2022 [sendLgEvtSip] seplos Event sent on eqt : 1432 Id :1
Mon Dec 5 10:54:06 2022 [display_ipc_out] ------------ Begin ---------------
1670237646 -> Mon Dec 5 10:54:06 2022 Id : 1
Mon Dec 5 10:54:06 2022 SUCCESSFUL
Mon Dec 5 10:54:06 2022 xx : 0
Mon Dec 5 10:54:06 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:06 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:06 2022 CLIR : 0
Mon Dec 5 10:54:06 2022 COLP : 0
Mon Dec 5 10:54:06 2022 SDP :
Mon Dec 5 10:54:06 2022 ADDRESS : 192.168.1.171 :6000
Mon Dec 5 10:54:06 2022 ALGOS :
Mon Dec 5 10:54:06 2022 PCMA
Mon Dec 5 10:54:06 2022 101
Mon Dec 5 10:54:06 2022 DIRECTION : SEND & RECEIVE
Mon Dec 5 10:54:06 2022 video index : 0
Mon Dec 5 10:54:06 2022 crypto index : 0
Mon Dec 5 10:54:06 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:06 2022 [ipc_thread] Normal case : evt 10754
Mon Dec 5 10:54:06 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:06 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:06 2022 1181[CMotorCall::onReceiveResponse] retrans=0, status=200 extGw=1000.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::onReceiveResponse] INVITE case => cancelAllCancelableForkedBranch.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::cancelAllCancelableForkedBranch] nb branch=1.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::cancelAllCancelableForkedBranch] retrans=0.
Mon Dec 5 10:54:06 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:06 2022 [display_ipc_in] ------------ Begin ---------------
1670237646 -> Mon Dec 5 10:54:06 2022 neqt : 1432 Id : 1
Mon Dec 5 10:54:06 2022 ACK
Mon Dec 5 10:54:06 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] an event 10754 arrived on the eqt 1432 1.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] state = ACCEPTED_STATE.
Mon Dec 5 10:54:06 2022 [onIncomingEvent] ACK arrived.
Mon Dec 5 10:54:06 2022 [receiveAckEvent] Call: f5c354965203ab46ddaf21e54fa82f3a@192.168.1.10 eqt: 1432 ACCEPTED_STATE received an event.
Mon Dec 5 10:54:06 2022 1181[CMotorCall::emitAckMessage]
Mon Dec 5 10:54:06 2022 1181[CMotorCall::emitAckMessage] SDP ok.
Mon Dec 5 10:54:06 2022 1181 [CCall::makeGenericRequest] ACK
Mon Dec 5 10:54:06 2022 1181 [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:54:06 2022 1573 [CDialog::createRequest]
Mon Dec 5 10:54:06 2022 1573 [CDialog::buildServicesForAllRequest]
Mon Dec 5 10:54:06 2022 1573 [CDialog::createAckRequest]
Mon Dec 5 10:54:06 2022 1573 [CDialog::createAckRequest], previous trans 2159 is found
Mon Dec 5 10:54:06 2022 1573 [CDialog::createAckRequest], previous trans 2159 is client
Mon Dec 5 10:54:06 2022 35735 [CRequest::CRequest] Creation of a request
Mon Dec 5 10:54:06 2022 1573 [CDialog::buildServicesForAck]
Mon Dec 5 10:54:06 2022 [DBG: CRequest::freeAttributes]
Mon Dec 5 10:54:06 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
1670237646 -> Mon Dec 5 10:54:06 2022 [DBG: CRequest::freeAttributes Ends]
Mon Dec 5 10:54:06 2022 CRequest::createRequestLine Protocol UDP
Mon Dec 5 10:54:06 2022 35735 [CMessage::send] sip_sendMessage (192.168.1.171:5060)
Mon Dec 5 10:54:06 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:06 2022 SEND MESSAGE TO NETWORK (192.168.1.171:5060 [UDP]) (BUFF LEN = 513)
ACK sip:8008@192.168.1.171:5060;transport=udp SIP/2.0
CSeq: 192632951 ACK
Via: SIP/2.0/UDP 192.168.1.10;branch=z9hG4bK3199ae8b64346beba18b1aac6550132b
Max-Forwards: 70
Content-Length: 0
Mon Dec 5 10:54:06 2022 [CTransport::getConnection] RemoteHost=(192.168.1.171 5060) already exist, using connection 77d0
Mon Dec 5 10:54:06 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
1670237646 -> Mon Dec 5 10:54:06 2022 udp_send fd:3
Mon Dec 5 10:54:06 2022 udp_send fd:3 port 5060 iBytesSend:513
Mon Dec 5 10:54:06 2022 77d0 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:06 2022 35735 [CMessage::onSendSuccess]
Mon Dec 5 10:54:06 2022 1573 [CDialog::onSendSuccess]
Mon Dec 5 10:54:06 2022 1181[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:06 2022 2159 [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:06 2022 2159 [CTransaction::freeTimerToken] Timer D is freed
Mon Dec 5 10:54:06 2022 2159 [CTransaction::changeState] no transaction state, terminated reason : Request creation
Mon Dec 5 10:54:06 2022 1573 [CDialog::createAckRequest] successful INVITE is terminated after the ACK is sent
Mon Dec 5 10:54:06 2022 [receiveAckEvent] continue with session Timer
Mon Dec 5 10:54:06 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:06 2022 [ipc_thread] Normal case : evt 10758
Mon Dec 5 10:54:06 2022 neqt : 1448 Id : 2
Mon Dec 5 10:54:06 2022 NOTIFY
Mon Dec 5 10:54:06 2022 TO : 8302@oxe.ma:5060
Mon Dec 5 10:54:06 2022 Message New : 0 Old : 0
1670237646 -> Mon Dec 5 10:54:06 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] an event 10758 arrived on the eqt 1448 2.
Mon Dec 5 10:54:06 2022 [onIncomingEvent] NOTIFY arrived.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1448 inserted.
Mon Dec 5 10:54:06 2022 [CSubscriptionState::receiveNotifyEvent] Call: 20433029 eqt: 1448 SUBSCRIPTION_STATE received an event.
Mon Dec 5 10:54:06 2022 11a1 [CCall::makeGenericRequest] NOTIFY
Mon Dec 5 10:54:06 2022 11a1 [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:54:06 2022 15b7 [CDialog::createRequest]
Mon Dec 5 10:54:06 2022 15b7 [CDialog::buildServicesForAllRequest]
Mon Dec 5 10:54:06 2022 15b7 [CDialog::createBasicRequest]
Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:06 2022 15b7 [CDialog::onTransactionState(pTrans = 215a, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:06 2022 35736 [CRequest::CRequest] Creation of a request
1670237646 -> Mon Dec 5 10:54:06 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:06 2022 35736 [CMessage::send] sip_sendMessage (192.168.1.181:5060)
Mon Dec 5 10:54:06 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 608)
NOTIFY sip:8302@192.168.1.181:5060;transport=udp SIP/2.0
Content-Type: application/simple-message-summary
Event: message-summary
Subscription-State: active
To: sip:8302@oxe.ma:5060;tag=dd32facf4b
From: <sip:8302@oxe.ma:5060;transport=udp>;tag=59b07455713b5cd6453ef50354e95cf7
Call-ID: 20433029
CSeq: 1340449647 NOTIFY
Via: SIP/2.0/UDP 192.168.1.10;branch=z9hG4bKf8de482945966b8b34f54156e8f9a490
Content-Length: 60
Messages-Waiting: no
voice-message: 0/0
fax-message: 0/0
Mon Dec 5 10:54:06 2022 [CTransport::findConnection] pConnection = 779b remoteHost=192.168.1.181, remotePort=5060
Mon Dec 5 10:54:06 2022 [CTransport::getConnection] RemoteHost=(192.168.1.181 5060) already exist, using connection 779b
Mon Dec 5 10:54:06 2022 udp_send fd:3 port 5060 iBytesSend:608
Mon Dec 5 10:54:06 2022 779b [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:06 2022 35736 [CMessage::onSendSuccess]
Mon Dec 5 10:54:06 2022 215a [CTransaction::onSendSuccess] CMessage 35736 send Success
Mon Dec 5 10:54:06 2022 15b7 [CDialog::onSendSuccess]
Mon Dec 5 10:54:06 2022 11a1[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:06 2022 215a [CTransInitialState::createRequest] Transaction changes to Trying state
Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:54:06 2022 15b7 [CDialog::onTransactionState(pTrans = 215a, previousState = Initial, currentState = Trying, reason = Request creation]
Mon Dec 5 10:54:06 2022 215a [CTransTryingState::enterInState] Init timers E and F
Mon Dec 5 10:54:06 2022 215a [CTransaction::startTimer] Timer E is started (delay = 500 ms)
Mon Dec 5 10:54:06 2022 215a [CTransaction::startTimer] Timer F is started (delay = 16000 ms)
Mon Dec 5 10:54:06 2022 15b7 [CDialog::addTransaction] added transaction 215a with branch z9hG4bKf8de482945966b8b34f54156e8f9a490, with CSeq 1340449647
Mon Dec 5 10:54:06 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:06 2022 3571D [~CRequest] req 20433029 1340449646 NOTIFY
Mon Dec 5 10:54:06 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:06 2022 [CMessage::~CMessage Ends]
1670237646 -> Mon Dec 5 10:54:06 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:06 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:54:06 2022 neqt : 1448 Id : 1
Mon Dec 5 10:54:06 2022 COLP : 1
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1448 1.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:06 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:54:06 2022 [onIncomingEvent] relative_request = 10752
Mon Dec 5 10:54:06 2022 [CProceedingState::receiveSuccessfulEvent] Call: c706eb47 eqt: 1448 PROCEEDING_STATE received an event.
1670237646 -> Mon Dec 5 10:54:06 2022 [quoteString] => "Samir"
Mon Dec 5 10:54:06 2022 1180[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::emitSuccessfulMessage] P-Asserted-Identity: "Samir" <sip:8008@192.168.1.10:5060;user=phone>
Mon Dec 5 10:54:06 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
Mon Dec 5 10:54:06 2022 1180[CMotorCall::emitSuccessfulMessage] uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::makeResponseSdpAudioOld] Audio media.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:06 2022 1180[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Mon Dec 5 10:54:06 2022 [sameCodec] accepted Format : 8.
Mon Dec 5 10:54:06 2022 [sameCodec] requested Format : 8.
Mon Dec 5 10:54:06 2022 [sameCodec] same Format.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::mediaAccepted] Media accepted: m=audio 6000 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:06 2022 1180[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Mon Dec 5 10:54:06 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:06 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:06 2022 1180[CMotorCall::emitSuccesfulMessage] Answer sdp.
1670237646 -> Mon Dec 5 10:54:06 2022 [removeAudioMediaPortNull] media no=0.
Mon Dec 5 10:54:06 2022 1180 [CCall::makeGenericResponse] 200
Mon Dec 5 10:54:06 2022 1180 [CCall::getDialog] Confirmed Dialog is not found (ID = 195918d3ab06a6381543d4ebe9a898ba;61f4317ecd)
Mon Dec 5 10:54:06 2022 1180 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:06 2022 1570 [CDialog::createResponse] 200
Mon Dec 5 10:54:06 2022 1570 [CDialog::createResponse] create a CONFIRMED dialog
Mon Dec 5 10:54:06 2022 1574 [CDialog::CDialog] look for the transaction #0, transaction key = z9hG4bK5a8f8d314c36aa2d2
Mon Dec 5 10:54:06 2022 1574 [CDialog::CDialog] copy the transaction #0, transaction key = z9hG4bK5a8f8d314c36aa2d2
Mon Dec 5 10:54:06 2022 215b [CTransaction::CTransaction] Transaction is cloned in 4 state
Mon Dec 5 10:54:06 2022 1574 [CDialog::addTransaction] added transaction 215b with branch z9hG4bK5a8f8d314c36aa2d2, with CSeq 1090543851
Mon Dec 5 10:54:06 2022 1574 [CDialog::startDialogTTL]
Mon Dec 5 10:54:06 2022 1574 [CDialog::CDialog] resources number: 281
Mon Dec 5 10:54:06 2022 1574 [CDialog::createResponse] 200
Mon Dec 5 10:54:06 2022 215b [CTransProceedingState::createResponse] CResponse 35CA2 ref=1
Mon Dec 5 10:54:06 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:06 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:06 2022 35CA2 [CMessage::send] sip_sendMessage (192.168.1.181:5060)
1670237646 -> Mon Dec 5 10:54:06 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:06 2022 SEND MESSAGE TO NETWORK (192.168.1.181:5060 [UDP]) (BUFF LEN = 831)
SIP/2.0 200 OK
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
Session-Expires: 1800;refresher=uas
To: "8008" <sip:8008@oxe.ma:5060>;tag=195918d3ab06a6381543d4ebe9a898ba
From: "Hajib" <sip:8302@oxe.ma:5060>;tag=61f4317ecd
Call-ID: c706eb47
CSeq: 1090543851 INVITE
Via: SIP/2.0/UDP 192.168.1.181;branch=z9hG4bK5a8f8d314c36aa2d2
Content-Length: 216
v=0
o=OXE 1670237642 1670237642 IN IP4 192.168.1.10
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:06 2022 udp_send fd:3 port 5060 iBytesSend:831
1670237646 -> Mon Dec 5 10:54:06 2022 779b [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:06 2022 35CA2 [CMessage::onSendSuccess]
Mon Dec 5 10:54:06 2022 215b [CTransaction::onSendSuccess] CMessage 35CA2 send Success
Mon Dec 5 10:54:06 2022 1574 [CDialog::onSendSuccess]
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:06 2022 215b [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:06 2022 215b [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:06 2022 215b [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:06 2022 1574 [CDialog::onTransactionState(pTrans = 215b, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:06 2022 215b [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Dec 5 10:54:06 2022 215b [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Dec 5 10:54:06 2022 1574 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from response (Server, UA)
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 0
1670237646 -> Mon Dec 5 10:54:06 2022 [CSessionTimerContext::updateAfterResponseRefreshCreation] Update CSessionTimerContext (response refresh creation)
Mon Dec 5 10:54:06 2022 1180 [CCall::insertInDialogMap] added dialog #1574 with the key 195918d3ab06a6381543d4ebe9a898ba;61f4317ecd
Mon Dec 5 10:54:06 2022 1570 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:06 2022 [CProceedingState::receiveSuccessfulEvent] emitSuccessfulMessage OK.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:06 2022 udp_recv fd:5 iBytesRead:421
Mon Dec 5 10:54:06 2022 UdpInputProc iSock:5 iBytesRead:421 Host:192.168.1.181 Port:5060
Mon Dec 5 10:54:06 2022 [CTransportUdp::receiveMessage] from 192.168.1.181:5060 rc:421
1670237646 -> Mon Dec 5 10:54:06 2022 [CIOCom::onReceiveMessage] received from 192.168.1.181:5060, proto=0, length=421, mtls = 0
Mon Dec 5 10:54:06 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.181:5060 [UDP])
SIP/2.0 200 OK
Accept: application/simple-message-summary
Call-ID: 20433029
Allow-Events: message-summary
Content-Length: 0
Mon Dec 5 10:54:06 2022 [CIOCom::receiveResponse] CResponse 35CA3 ref=1
Mon Dec 5 10:54:06 2022 11a1 [CCall::receiveResponse] 200
Mon Dec 5 10:54:06 2022 15b7 [CDialog::receiveResponse]
Mon Dec 5 10:54:06 2022 215a [CTransTryingState::receiveResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] STATE CHANGED TO COMPLETED
1670237646 -> Mon Dec 5 10:54:06 2022 215a [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:06 2022 15b7 [CDialog::onTransactionState(pTrans = 215a, previousState = Trying, currentState = Completed, reason = Final resp reception]
Mon Dec 5 10:54:06 2022 215a [CTransaction::freeTimerToken] Timer E is freed
Mon Dec 5 10:54:06 2022 215a [CTransaction::freeTimerToken] Timer F is freed
Mon Dec 5 10:54:06 2022 215a [CTransaction::startTimer] Timer K is started (delay = 5000 ms)
Mon Dec 5 10:54:06 2022 cc [CSubscription::update] update on request
Mon Dec 5 10:54:06 2022 11a1[CMotorCall::onReceiveResponse] Update1 the Other context.
Mon Dec 5 10:54:06 2022 [CSubscriptionState::receiveResponseMessage] Call: 20433029 eqt: 1448 SUBSCRIPTION_STATE received a message.
Mon Dec 5 10:54:06 2022 [CSubscriptionState::receiveResponseMessage] response for event
Mon Dec 5 10:54:06 2022 11a1[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:06 2022 11a1[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:06 2022 11a1[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:06 2022 11a1[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:06 2022 [sendLgEvtSip] seplos Event sent on eqt : 1448 Id :2
Mon Dec 5 10:54:06 2022 Id : 2
1670237646 -> Mon Dec 5 10:54:06 2022 SUCCESSFUL
Mon Dec 5 10:54:06 2022 RELATIVE REQUEST : NOTIFY
Mon Dec 5 10:54:06 2022 [ipc_thread] Normal case : evt 10773
Mon Dec 5 10:54:06 2022 11a1[CMotorCall::unRegister] Remove eqt : 1448 diag : 2 from the map.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::eraseCallwithEqt] erase 1448 2.
Mon Dec 5 10:54:06 2022 [CSubscriptionState::receiveResponseMessage] Final response => eqt released.
Mon Dec 5 10:54:06 2022 SIP EQT RELEASED
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1448 2.
Mon Dec 5 10:54:06 2022 [CMotorCallManager::onIncomingEvent] NO call with eqt: 1448 2 to release.
Mon Dec 5 10:54:06 2022 is_a_JONCT
Mon Dec 5 10:54:06 2022 udp_recv fd:5 iBytesRead:402
Mon Dec 5 10:54:06 2022 UdpInputProc iSock:5 iBytesRead:402 Host:192.168.1.181 Port:5060
1670237646 -> Mon Dec 5 10:54:06 2022 [CTransportUdp::receiveMessage] from 192.168.1.181:5060 rc:402
Mon Dec 5 10:54:06 2022 [CIOCom::onReceiveMessage] received from 192.168.1.181:5060, proto=0, length=402, mtls = 0
ACK sip:192.168.1.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.181;branch=z9hG4bK37d2e6257a1ecd2c2
Max-Forwards: 70
Call-ID: c706eb47
CSeq: 1090543851 ACK
User-Agent: ALE ALE-2 2.12.20.000.2036 3c28a608b7bd
Content-Length: 0
Mon Dec 5 10:54:06 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:06 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:06 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:06 2022 35737 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:06 2022 [CIOCom::receiveRequest] Received CRequest 35737 ref=1
Mon Dec 5 10:54:06 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.181 alcResult= 0
Mon Dec 5 10:54:06 2022 [CIOCom::receiveRequest] rport1 not empty
1670237646 -> Mon Dec 5 10:54:06 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:06 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:06 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:06 2022 1180 [CCall::receiveRequest] ACK
Mon Dec 5 10:54:06 2022 1180 [CCall::getDialog] Confirmed Dialog found
Mon Dec 5 10:54:06 2022 1574 [CDialog::receiveRequest]
Mon Dec 5 10:54:06 2022 1574 [CDialog::receiveAckRequest]
Mon Dec 5 10:54:06 2022 1574 [CDialog::getTransactionByCSeq] CSeq = 1090543851
Mon Dec 5 10:54:06 2022 215b [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:06 2022 215b [CTransaction::freeTimerToken] Timer G is freed
Mon Dec 5 10:54:06 2022 215b [CTransaction::freeTimerToken] Timer H is freed
Mon Dec 5 10:54:06 2022 215b [CTransaction::changeState] no transaction state, terminated reason : Request reception
Mon Dec 5 10:54:06 2022 1574 [CDialog::receiveAckRequest] the INVITE request is terminated
Mon Dec 5 10:54:06 2022 1180 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:06 2022 1180 [CCall::checkAuthentication] ACK
Mon Dec 5 10:54:06 2022 1180[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:06 2022 1180[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:54:06 2022 1180 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:06 2022 1180 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:06 2022 1180 [CCall::checkAuthentication] iRetValue=0
1670237646 -> Mon Dec 5 10:54:06 2022 1180 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::onReceiveRequest] state = ACCEPTED_STATE.
Mon Dec 5 10:54:06 2022 1180[CMotorCall::compareDialogFromContext] same Dialog
Mon Dec 5 10:54:06 2022 1180[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Dec 5 10:54:06 2022 [receiveAckMessage] Call: c706eb47 eqt: 1448 ACCEPTED_STATE received a message.
Mon Dec 5 10:54:06 2022 [receiveAckMessage] g711u: 255 g711A: 255 g723: 255 g729: 255.
Mon Dec 5 10:54:06 2022 1180[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:06 2022 1180[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:06 2022 1180[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:06 2022 1180[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:06 2022 [sendLgEvtSip] seplos Event sent on eqt : 1448 Id :1
1670237646 -> Mon Dec 5 10:54:06 2022 1180[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:06 2022 [receiveAckMessage] continue with session Timer
Mon Dec 5 10:54:06 2022 35737 [~CRequest] req c706eb47 1090543851 ACK
Mon Dec 5 10:54:06 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:06 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:06 2022 1573 [CDialog::onTransactionState(pTrans = 2159, previousState = null, currentState = Terminated, reason = Request creation]
Mon Dec 5 10:54:06 2022 2159 [~CTransaction] transaction 192632951 INVITE
Mon Dec 5 10:54:06 2022 1574 [CDialog::onTransactionState(pTrans = 215b, previousState = null, currentState = Terminated, reason = Request reception]
Mon Dec 5 10:54:06 2022 215B [~CTransaction] transaction 1090543851 INVITE
Mon Dec 5 10:54:06 2022 102 [CCallManager::removeGarbage] at index i = 0
Mon Dec 5 10:54:06 2022 1182 [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:06 2022 1182[CMotorCall::~CMotorCall] Call : d3cb51948f8c4d0280ca3bb145661901 is being destructed.
Mon Dec 5 10:54:06 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
1670237647 -> Mon Dec 5 10:54:06 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:06 2022 1182 [CCall::~CCall] resources number: 142
Mon Dec 5 10:54:06 2022 1182 [CCall::TestDegradedModeEnd] resources number: 141
Mon Dec 5 10:54:06 2022 1182 [CCall::removeGarbage]
Mon Dec 5 10:54:06 2022 1572 [CDialog::~CDialog] resources number: 280
Mon Dec 5 10:54:06 2022 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Mon Dec 5 10:54:06 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:06 2022 35CA0 [~CResponse] resp(487) d3cb51948f8c4d0280ca3bb145661901 14859 INVITE
Mon Dec 5 10:54:06 2022 35732 [~CRequest] req d3cb51948f8c4d0280ca3bb145661901 14859 INVITE
Mon Dec 5 10:54:06 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:06 2022 [CCall::~CCall] Ends
1670237649 -> Mon Dec 5 10:54:08 2022 [fnInit] *************************** Init timeout.
Mon Dec 5 10:54:08 2022 [fnInit] treatTimeout.
Mon Dec 5 10:54:08 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:54:08 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:54:08 2022 [startRegistration] timer value=6000.
Mon Dec 5 10:54:09 2022 udp_recv fd:5
Mon Dec 5 10:54:09 2022 udp_recv fd:5 iBytesRead:961
Mon Dec 5 10:54:09 2022 UdpInputProc iSock:5 iBytesRead:961 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:09 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:961
Mon Dec 5 10:54:09 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:09 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=961, mtls = 0
Mon Dec 5 10:54:09 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
INVITE sip:8013@192.168.1.10 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.18:59400;rport;branch=z9hG4bKPj6206a64c632849188171df10980c184d
Max-Forwards: 70
From: <sip:8977@192.168.1.10>;tag=a2e0ad081f374441a75427342d80f265
Contact: <sip:8977@192.168.1.18:59400;ob>
Call-ID: 650144d220334e6aa23b392c117f65e9
CSeq: 379 INVITE
Route: <sip:192.168.1.10;lr>
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, INFO, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
Supported: replaces, 100rel, timer, norefersub
Min-SE: 90
User-Agent: MicroSIP/3.21.3
Content-Length: 316
v=0
o=- 3879226478 3879226478 IN IP4 128.203.52.4
s=pjmedia
b=AS:84
t=0 0
a=X-nat:0
m=audio 4006 RTP/AVP 8 101
c=IN IP4 128.203.52.4
b=TIAS:64000
a=rtcp:4007 IN IP4 128.203.52.4
a=sendrecv
a=fmtp:101 0-16
a=ssrc:1812811380 cname:50c83f420a4318e2
1670237649 -> Mon Dec 5 10:54:09 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:09 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:09 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:09 2022 35738 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:09 2022 [CIOCom::receiveRequest] Received CRequest 35738 ref=1
Mon Dec 5 10:54:09 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:09 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:09 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:09 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:09 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:09 2022 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
Mon Dec 5 10:54:09 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:09 2022 [CMotorCallManager::callFactory] For call : 650144d220334e6aa23b392c117f65e9.
Mon Dec 5 10:54:09 2022 1183 [CCall::CCall] resources number: 143
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:09 2022 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.68.a
Mon Dec 5 10:54:09 2022 [CMotorCallManager::callFactory]=8de05f8.
1670237649 -> Mon Dec 5 10:54:09 2022 1183 [CCall::receiveRequest] INVITE
Mon Dec 5 10:54:09 2022 1183 [CCall::getDialog] Confirmed Dialog is not found (ID = ;a2e0ad081f374441a75427342d80f265)
Mon Dec 5 10:54:09 2022 1183 [CCall::getDialog] Initial Dialog Server not found
Mon Dec 5 10:54:09 2022 1575 [CDialog::CDialog] resources number: 281
Mon Dec 5 10:54:09 2022 1575 [CDialog::receiveRequest]
Mon Dec 5 10:54:09 2022 1575 [CDialog::receiveInviteRequest]
Mon Dec 5 10:54:09 2022 215c [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:09 2022 215c [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:09 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:09 2022 215c [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Dec 5 10:54:09 2022 215c [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:09 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Dec 5 10:54:09 2022 215c [CTransProceedingState::createResponse] CResponse 35CA4 ref=1
Mon Dec 5 10:54:09 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:09 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:09 2022 [DBG: CResponse::freeAttributes] Ends
1670237649 -> Mon Dec 5 10:54:09 2022 35CA4 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:09 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:09 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 319)
SIP/2.0 100 Trying
CSeq: 379 INVITE
Via: SIP/2.0/UDP 192.168.1.18:59400;received=192.168.1.18;rport=59400;branch=z9hG4bKPj6206a64c632849188171df10980c184d
Content-Length: 0
Mon Dec 5 10:54:09 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:09 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:09 2022 udp_send fd:5
Mon Dec 5 10:54:09 2022 udp_send fd:5 port 59400 iBytesSend:319
Mon Dec 5 10:54:09 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:09 2022 35CA4 [CMessage::onSendSuccess]
Mon Dec 5 10:54:09 2022 215c [CTransaction::onSendSuccess] CMessage 35CA4 send Success
Mon Dec 5 10:54:09 2022 1575 [CDialog::onSendSuccess]
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:09 2022 1575 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
1670237649 -> Mon Dec 5 10:54:09 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 90
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:09 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:09 2022 1575 [CDialog::addTransaction] added transaction 215c with branch z9hG4bKPj6206a64c632849188171df10980c184d, with CSeq 379
Mon Dec 5 10:54:09 2022 1183 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:09 2022 1183 [CCall::checkAuthentication] INVITE
Mon Dec 5 10:54:09 2022 1183[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:09 2022 [getFromHeader] look at the From.
Mon Dec 5 10:54:09 2022 [getFromHeader] displayName=.
Mon Dec 5 10:54:09 2022 [convertCSipURLIntoSipuri] uri = sip:8977@192.168.1.10.
Mon Dec 5 10:54:09 2022 [getFromHeader] =8977@192.168.1.10.
Mon Dec 5 10:54:09 2022 [getFromHeader] clirPresent=0.
Mon Dec 5 10:54:09 2022 [getReqUriHeader] look at the requri.
Mon Dec 5 10:54:09 2022 [convertCSipURLIntoSipuri] uri = sip:8013@192.168.1.10.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::getUserType] extGw=-1.
1670237649 -> Mon Dec 5 10:54:09 2022 [CMotorCall::analyseRouting] TEL uri=0.
Mon Dec 5 10:54:09 2022 [CMotorCall::analyseRouting] 8977@192.168.1.10 is authenticable.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setExtGw] -1->-3
Mon Dec 5 10:54:09 2022 [isUserInDico] looking for 8977@192.168.1.10 ...
Mon Dec 5 10:54:09 2022 [isUserInDico] found in the dictionnary.
Mon Dec 5 10:54:09 2022 [isAddrInDico] seplos station OK
Mon Dec 5 10:54:09 2022 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::getUserType] From is seplos station crypto=0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::getUserType] extGw=-3.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::controlAuthentication] m_other_calling=0 extgw=-3
Mon Dec 5 10:54:09 2022 1183[CMotorCall::controlAuthentication] from:sip:8977@192.168.1.10:5060
Mon Dec 5 10:54:09 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:09 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:09 2022 [CGwMngData::isAuthenticationRequiredForThisClient] 8977@192.168.1.10 .
Mon Dec 5 10:54:09 2022 [CGwMngData::isAuthenticationRequiredForThisClient] -3 need auth=0.
Mon Dec 5 10:54:09 2022 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway -3.
Mon Dec 5 10:54:09 2022 CGwMngData::isAuthenticationRequiredForThisClient: gateway=-3
1670237649 -> Mon Dec 5 10:54:09 2022 1183[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setExtGw] -3->-3
Mon Dec 5 10:54:09 2022 1183 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:09 2022 1183 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:09 2022 1183 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:09 2022 1183 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Dec 5 10:54:09 2022 1183[CMotorCall::initOfUserType] station role already defined s=1 d=0 o=0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onReceiveRequest] accepte? m_other_calling=0 gw=-1.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=2.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::toGatewayOrProxy] request for proxydomain=192.168.1.10.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::toGatewayOrProxy] from = seplos station.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] nb available licenses=0 .
1670237649 -> Mon Dec 5 10:54:09 2022 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Dec 5 10:54:09 2022 [CForkedBranch::CForkedBranch] context = 0x8de0bbc.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] reqUri stored: sip:8977@192.168.1.18:59400;ob
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::methodInviteReceived] CAC = 0
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] Call: 650144d220334e6aa23b392c117f65e9 eqt: -1 INITIAL_STATE received a message.
Mon Dec 5 10:54:09 2022 [decodeInviteCLIR].
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] UPDATE present in Allow header
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] INFO present in Allow header
Mon Dec 5 10:54:09 2022 am_I_PCS SCSWorking : NO
Mon Dec 5 10:54:09 2022 check_PCSstate
Mon Dec 5 10:54:09 2022 check_PCSstate stat of PCS is : -1
Mon Dec 5 10:54:09 2022 1183[CMotorCall::analyseSessionTimer] Session Timer extGw=-1 sessionDelay=1800 .
1670237649 -> Mon Dec 5 10:54:09 2022 1183[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:09 2022 1183[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:09 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] Format : 8.
Mon Dec 5 10:54:09 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:09 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:09 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] The audio media contains 2 format(s).
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] 101.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Format is DTMF:101.
1670237649 -> Mon Dec 5 10:54:09 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:09 2022 [convertAudioMedia] Connection address retrieved in sdp: 128.203.52.4.
Mon Dec 5 10:54:09 2022 [convertIPStrIntoTuipv] 128.203.52.4 => 128.203.52.4
Mon Dec 5 10:54:09 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:09 2022 [display_sdp] address =128.203.52.4
Mon Dec 5 10:54:09 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:09 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:09 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:09 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Mon Dec 5 10:54:09 2022 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Dec 5 10:54:09 2022 [receiveinvitemessage] get requri.
Mon Dec 5 10:54:09 2022 [decodeInviteTo].
Mon Dec 5 10:54:09 2022 [decodeInviteReferredBy].
Mon Dec 5 10:54:09 2022 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
Mon Dec 5 10:54:09 2022 [decodeInviteACSBU].
Mon Dec 5 10:54:09 2022 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=1
1670237649 -> Mon Dec 5 10:54:09 2022 [receiveInviteMessage] concatenating from header
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] temp_fromuserinfo = 8977
Mon Dec 5 10:54:09 2022 [receiveInviteMessage] From_userinfo = 8977
Mon Dec 5 10:54:09 2022 1183[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:09 2022 [ipc_thread] Normal case : evt 10764
Mon Dec 5 10:54:09 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:09 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1464 inserted.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::sendLgEvtSipCreate] Event sent on eqt : 1464
Mon Dec 5 10:54:09 2022 ** SEPLOS/IP-DECT **
Mon Dec 5 10:54:09 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:09 2022 Id : -1
Mon Dec 5 10:54:09 2022 INVITE
Mon Dec 5 10:54:09 2022 REQUEST URI : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:09 2022 FROM : <> 8977@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:09 2022 TO : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:09 2022 CAC : 0
Mon Dec 5 10:54:09 2022 CAC ADDRESS :
Mon Dec 5 10:54:09 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:09 2022 CLIR : 0
Mon Dec 5 10:54:09 2022 Prack Required : 0
Mon Dec 5 10:54:09 2022 Allow Update : 0
Mon Dec 5 10:54:09 2022 SDP :
Mon Dec 5 10:54:09 2022 ADDRESS : 128.203.52.4 :4006
1670237649 -> Mon Dec 5 10:54:09 2022 ALGOS :
Mon Dec 5 10:54:09 2022 PCMA
Mon Dec 5 10:54:09 2022 101
Mon Dec 5 10:54:09 2022 DIRECTION : SEND & RECEIVE
Mon Dec 5 10:54:09 2022 video index : 0
Mon Dec 5 10:54:09 2022 crypto index : 0
Mon Dec 5 10:54:09 2022 N_GW_EXT : -1
Mon Dec 5 10:54:09 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:09 2022 1183[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:09 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:09 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:09 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:09 2022 INFORMATIONAL
Mon Dec 5 10:54:09 2022 xx : 0
Mon Dec 5 10:54:09 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:09 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1464 1.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] an event arrived on an invalid eqt 1464 1.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::unRegister] Remove eqt : 1464 diag : -1 from the map.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 -1.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] dialogId update done.
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] NOE-SIP : No updates to Twin
Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] seplos station.
1670237649 -> Mon Dec 5 10:54:09 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:09 2022 [onIncomingEvent] INFORMATIONAL arrived.
Mon Dec 5 10:54:09 2022 [onIncomingEvent] 100 TRYING ignored.
Mon Dec 5 10:54:09 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:09 2022 xx : 83
Mon Dec 5 10:54:09 2022 ADDRESS : 192.168.1.11 :32528
1670237649 -> Mon Dec 5 10:54:09 2022 [receiveInformationalEvent] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:09 2022 1183[CMotorCall::buildContact] Contact: sip:192.168.1.10:5060
Mon Dec 5 10:54:09 2022 1183[CMotorCall::emitInformationMessage] cause=183
Mon Dec 5 10:54:09 2022 1183[CMotorCall::makeResponseSdpAudioOld] Audio media.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:09 2022 1183[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Mon Dec 5 10:54:09 2022 [sameCodec] accepted Format : 8.
Mon Dec 5 10:54:09 2022 [sameCodec] requested Format : 8.
Mon Dec 5 10:54:09 2022 [sameCodec] same Format.
Mon Dec 5 10:54:09 2022 1183[CMotorCall::mediaAccepted] Media accepted: m=audio 32528 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:09 2022 1183[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
1670237649 -> Mon Dec 5 10:54:09 2022 1183[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Mon Dec 5 10:54:09 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:09 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:09 2022 1183[CMotorCall::emitInformationalMessage] Answer sdp.
Mon Dec 5 10:54:09 2022 [removeAudioMediaPortNull] media no=0.
Mon Dec 5 10:54:09 2022 1183 [CCall::makeGenericResponse] 183
Mon Dec 5 10:54:09 2022 1183 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:09 2022 1575 [CDialog::createResponse] 183
Mon Dec 5 10:54:09 2022 215c [CTransProceedingState::createResponse] CResponse 35CA5 ref=1
Mon Dec 5 10:54:09 2022 35CA5 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:09 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 832)
SIP/2.0 183 Session Progress
User-Agent: OmniPCX Enterprise R100.0 n1.291.68.a
Reason: SIP;cause=183;text="is busy "
To: <sip:8013@192.168.1.10>;tag=59a14315fc134fbad4d54280ec9af2e4
CSeq: 379 INVITE
Content-Length: 216
v=0
o=OXE 1670237649 1670237649 IN IP4 192.168.1.10
s=abs
c=IN IP4 192.168.1.11
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1670237650 -> Mon Dec 5 10:54:09 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:09 2022 udp_send fd:5 port 59400 iBytesSend:832
Mon Dec 5 10:54:09 2022 35CA5 [CMessage::onSendSuccess]
Mon Dec 5 10:54:09 2022 215c [CTransaction::onSendSuccess] CMessage 35CA5 send Success
Mon Dec 5 10:54:09 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:09 2022 35CA4 [~CResponse] resp(100) 650144d220334e6aa23b392c117f65e9 379 INVITE
Mon Dec 5 10:54:09 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:09 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:09 2022 1575 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:10 2022 udp_recv fd:5
Mon Dec 5 10:54:10 2022 udp_recv fd:5 iBytesRead:387
Mon Dec 5 10:54:10 2022 UdpInputProc iSock:5 iBytesRead:387 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:10 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:387
1670237650 -> Mon Dec 5 10:54:10 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:10 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=387, mtls = 0
Mon Dec 5 10:54:10 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
CANCEL sip:8013@192.168.1.10 SIP/2.0
Max-Forwards: 70
CSeq: 379 CANCEL
Content-Length: 0
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:10 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:10 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:10 2022 35739 [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] Received CRequest 35739 ref=1
Mon Dec 5 10:54:10 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
1670237650 -> Mon Dec 5 10:54:10 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:10 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:10 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:10 2022 1183 [CCall::receiveRequest] CANCEL
Mon Dec 5 10:54:10 2022 1183 [CCall::getDialog] Confirmed Dialog is not found (ID = ;a2e0ad081f374441a75427342d80f265)
Mon Dec 5 10:54:10 2022 1183 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:10 2022 1575 [CDialog::receiveRequest]
Mon Dec 5 10:54:10 2022 1575 [CDialog::receiveCancelRequest]
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215d, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:10 2022 215d [CTransInitialState::receiveRequest] Transaction changes to Trying state
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215d, previousState = Initial, currentState = Trying, reason = Request reception]
Mon Dec 5 10:54:10 2022 1183 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:10 2022 1183 [CCall::checkAuthentication] CANCEL
Mon Dec 5 10:54:10 2022 1183[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
1670237650 -> Mon Dec 5 10:54:10 2022 1183[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:54:10 2022 1183 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:10 2022 1183 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:10 2022 1183 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:10 2022 1183 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:10 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:10 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] state = PROCEEDING_STATE.
Mon Dec 5 10:54:10 2022 [receiveCancelMessage] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:10 2022 ** SEPLOS **
Mon Dec 5 10:54:10 2022 [sendLgEvtSip] seplos Event sent on eqt : 1464 Id :1
Mon Dec 5 10:54:10 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:10 2022 Id : 1
Mon Dec 5 10:54:10 2022 CANCEL
1670237650 -> Mon Dec 5 10:54:10 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:10 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:54:10 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:10 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:10 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:10 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:10 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:10 2022 SUCCESSFUL
Mon Dec 5 10:54:10 2022 xx : 0
Mon Dec 5 10:54:10 2022 RELATIVE REQUEST : CANCEL
Mon Dec 5 10:54:10 2022 CLIR : 0
Mon Dec 5 10:54:10 2022 COLP : 0
Mon Dec 5 10:54:10 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:10 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1464 1.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:10 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:54:10 2022 [onIncomingEvent] relative_request = 10756
Mon Dec 5 10:54:10 2022 [CProceedingState::receiveSuccessfulEvent] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:10 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
Mon Dec 5 10:54:10 2022 1575 [CCall::findFirstServerTrans]
Mon Dec 5 10:54:10 2022 1575 [CDialog::findFirstServerTrans] Current Request in cancelTransactionMap
1670237650 -> Mon Dec 5 10:54:10 2022 1183 [CCall::makeGenericResponse] 200
Mon Dec 5 10:54:10 2022 1575 [CDialog::createResponse] 200
Mon Dec 5 10:54:10 2022 215d [CTransTryingState::createResponse] CResponse 35CA6 ref=1
Mon Dec 5 10:54:10 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:10 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:10 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:10 2022 35CA6 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:10 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:10 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 405)
SIP/2.0 200 OK
Supported: replaces,timer,path,100rel
CSeq: 379 CANCEL
Content-Length: 0
Mon Dec 5 10:54:10 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
1670237650 -> Mon Dec 5 10:54:10 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:10 2022 udp_send fd:5
Mon Dec 5 10:54:10 2022 udp_send fd:5 port 59400 iBytesSend:405
Mon Dec 5 10:54:10 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:10 2022 35CA6 [CMessage::onSendSuccess]
Mon Dec 5 10:54:10 2022 215d [CTransaction::onSendSuccess] CMessage 35CA6 send Success
Mon Dec 5 10:54:10 2022 1575 [CDialog::onSendSuccess]
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:10 2022 215d [CTransTryingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215d, previousState = Trying, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:10 2022 215d [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
Mon Dec 5 10:54:10 2022 1575 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:10 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:10 2022 [ipc_thread] Normal case : evt 10767
1670237650 -> Mon Dec 5 10:54:10 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:10 2022 REQUEST FAILURE
Mon Dec 5 10:54:10 2022 xx : 87
Mon Dec 5 10:54:10 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] an event 10767 arrived on the eqt 1464 1.
Mon Dec 5 10:54:10 2022 [onIncomingEvent] REQUEST FAILURE arrived.
Mon Dec 5 10:54:10 2022 [receiveRequestFailureEvent] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::getOutgoingCall] outgoingCall:0
Mon Dec 5 10:54:10 2022 [receiveRequestFailureEvent] incoming call.
Mon Dec 5 10:54:10 2022 1183 [CCall::makeGenericResponse] 487
Mon Dec 5 10:54:10 2022 1183 [CCall::getDialog] Confirmed Dialog is not found (ID = 59a14315fc134fbad4d54280ec9af2e4;a2e0ad081f374441a75427342d80f265)
Mon Dec 5 10:54:10 2022 1575 [CDialog::createResponse] 487
Mon Dec 5 10:54:10 2022 215c [CTransProceedingState::createResponse] CResponse 35CA7 ref=1
1670237650 -> Mon Dec 5 10:54:10 2022 35CA7 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:10 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 502)
SIP/2.0 487 Request Terminated
CSeq: 379 INVITE
Content-Length: 0
Mon Dec 5 10:54:10 2022 udp_send fd:5 port 59400 iBytesSend:502
Mon Dec 5 10:54:10 2022 35CA7 [CMessage::onSendSuccess]
Mon Dec 5 10:54:10 2022 215c [CTransaction::onSendSuccess] CMessage 35CA7 send Success
1670237650 -> Mon Dec 5 10:54:10 2022 1575 [CDialog::onSendSuccess]
Mon Dec 5 10:54:10 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:10 2022 35CA5 [~CResponse] resp(183) 650144d220334e6aa23b392c117f65e9 379 INVITE
Mon Dec 5 10:54:10 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:10 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:10 2022 215c [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:10 2022 215c [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Dec 5 10:54:10 2022 215c [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Dec 5 10:54:10 2022 1183[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:10 2022 udp_recv fd:5 iBytesRead:389
Mon Dec 5 10:54:10 2022 UdpInputProc iSock:5 iBytesRead:389 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:10 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:389
Mon Dec 5 10:54:10 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=389, mtls = 0
ACK sip:8013@192.168.1.10 SIP/2.0
Max-Forwards: 70
CSeq: 379 ACK
Content-Length: 0
Mon Dec 5 10:54:10 2022 3573A [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:10 2022 [CIOCom::receiveRequest] Received CRequest 3573A ref=1
Mon Dec 5 10:54:10 2022 1183 [CCall::receiveRequest] ACK
Mon Dec 5 10:54:10 2022 1575 [CDialog::receiveAckRequest]
Mon Dec 5 10:54:10 2022 215c [CTransCompletedState::receiveRequest] ACK(UDP) : Transaction changes to Confirmed state
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] STATE CHANGED TO CONFIRMED
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = Completed, currentState = Confirmed, reason = Request reception]
Mon Dec 5 10:54:10 2022 215c [CTransaction::freeTimerToken] Timer G is freed
Mon Dec 5 10:54:10 2022 215c [CTransaction::freeTimerToken] Timer H is freed
Mon Dec 5 10:54:10 2022 215c [CTransaction::startTimer] Timer I is started (delay = 5000 ms)
Mon Dec 5 10:54:10 2022 1575 [CDialog::receiveAckRequest] receiving an ACK on a previously rejected INVITE
Mon Dec 5 10:54:10 2022 1183 [CCall::checkAuthentication] ACK
1670237650 -> Mon Dec 5 10:54:10 2022 1183[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:10 2022 1183[CMotorCall::onReceiveRequest] state = TERMINATED_STATE.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::compareDialogFromContext] same Dialog
Mon Dec 5 10:54:10 2022 1183[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Dec 5 10:54:10 2022 [receiveAckMessage] Call: 650144d220334e6aa23b392c117f65e9 eqt: 1464 TERMINATED_STATE received a message.
Mon Dec 5 10:54:10 2022 [receiveAckMessage] boolean flag check 0
1670237650 -> Mon Dec 5 10:54:10 2022 1183[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:10 2022 ACK
Mon Dec 5 10:54:10 2022 [ipc_thread] Normal case : evt 10773
Mon Dec 5 10:54:10 2022 SIP EQT RELEASED
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1464 1.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1464 has released its equipment.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::unRegister] Remove eqt : 1464 diag : 1 from the map.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 1.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onIncomingEvent] killSession.
1670237650 -> Mon Dec 5 10:54:10 2022 1183 [CCall::killSession]
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:10 2022 215d [CTransaction::freeTimerToken] Timer J is freed
Mon Dec 5 10:54:10 2022 215d [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:10 2022 215c [CTransaction::freeTimerToken] Timer I is freed
Mon Dec 5 10:54:10 2022 215c [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:10 2022 1183 [CCall::killSession] notifying the call manager
Mon Dec 5 10:54:10 2022 102 [CCallManager::onCallClosed]
Mon Dec 5 10:54:10 2022 102 [CCallManager::onCallClosed()] Call 1183 closed. Removing call 148768248 from the maps
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onNotifyCallClosed] Call : 650144d220334e6aa23b392c117f65e9 is closed.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onNotifyCallClosed] call processResponse.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::chooseBestResponse] pForkedBranch=0x8adc9f8 iResponseCode=2000.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:54:10 2022 1183[CMotorCall::processResponse] no response found.
Mon Dec 5 10:54:10 2022 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
Mon Dec 5 10:54:10 2022 102 [CCallManager::onCallClosed] pCall: 1183 added in the Garbage List
1670237650 -> Mon Dec 5 10:54:10 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:10 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215d, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:10 2022 215D [~CTransaction] transaction 379 CANCEL
Mon Dec 5 10:54:10 2022 35CA6 [~CResponse] resp(200) 650144d220334e6aa23b392c117f65e9 379 CANCEL
Mon Dec 5 10:54:10 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:10 2022 35739 [~CRequest] req 650144d220334e6aa23b392c117f65e9 379 CANCEL
Mon Dec 5 10:54:10 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState(pTrans = 215c, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:54:10 2022 1575 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:54:10 2022 1183 [CCall::onDialogClosed]
Mon Dec 5 10:54:10 2022 1183 [CCall::onDialogClosed] only initial *********
Mon Dec 5 10:54:10 2022 1183 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
1670237651 -> Mon Dec 5 10:54:10 2022 215C [~CTransaction] transaction 379 INVITE
Mon Dec 5 10:54:10 2022 3573A [~CRequest] req 650144d220334e6aa23b392c117f65e9 379 ACK
Mon Dec 5 10:54:11 2022 215a [CTransCompletedState::timerFires] Timer K fires
Mon Dec 5 10:54:11 2022 215a [CTransCompletedState::timerFires] Timer K : Transaction changes to Terminated state
Mon Dec 5 10:54:11 2022 215a [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:11 2022 215a [CTransaction::changeState] no transaction state, terminated reason : Timer K fires
1670237652 -> Mon Dec 5 10:54:11 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:11 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:11 2022 15b7 [CDialog::onTransactionState(pTrans = 215a, previousState = null, currentState = Terminated, reason = Timer K fires]
Mon Dec 5 10:54:11 2022 215A [~CTransaction] transaction 1340449647 NOTIFY
Mon Dec 5 10:54:11 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:11 2022 35CA3 [~CResponse] resp(200) 20433029 1340449647 NOTIFY
Mon Dec 5 10:54:11 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:11 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:11 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:12 2022 102 [CCallManager::removeGarbage] at index i = 0
Mon Dec 5 10:54:12 2022 1183 [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:12 2022 1183[CMotorCall::~CMotorCall] Call : 650144d220334e6aa23b392c117f65e9 is being destructed.
Mon Dec 5 10:54:12 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
Mon Dec 5 10:54:12 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:12 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:12 2022 1183 [CCall::~CCall] resources number: 142
Mon Dec 5 10:54:12 2022 1183 [CCall::TestDegradedModeEnd] resources number: 141
Mon Dec 5 10:54:12 2022 1183 [CCall::removeGarbage]
1670237654 -> Mon Dec 5 10:54:12 2022 1575 [CDialog::~CDialog] resources number: 280
Mon Dec 5 10:54:12 2022 [CSessionTimerContext::~CSessionTimerContext] Free CSessionTimerContext
Mon Dec 5 10:54:12 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:12 2022 35CA7 [~CResponse] resp(487) 650144d220334e6aa23b392c117f65e9 379 INVITE
Mon Dec 5 10:54:12 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:12 2022 35738 [~CRequest] req 650144d220334e6aa23b392c117f65e9 379 INVITE
Mon Dec 5 10:54:12 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:12 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:12 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:12 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:12 2022 [CCall::~CCall] Ends
Mon Dec 5 10:54:14 2022 udp_recv fd:5
Mon Dec 5 10:54:14 2022 udp_recv fd:5 iBytesRead:2
Mon Dec 5 10:54:14 2022 UdpInputProc iSock:5 iBytesRead:2 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:14 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:2
Mon Dec 5 10:54:14 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:14 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=2, mtls = 0
Mon Dec 5 10:54:14 2022 [CKeepaliveManager::receiveSignal]
Mon Dec 5 10:54:14 2022 [fnInit] *************************** Init timeout.
1670237655 -> Mon Dec 5 10:54:14 2022 [fnInit] treatTimeout.
Mon Dec 5 10:54:14 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:54:14 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:54:14 2022 [startRegistration] timer value=6000.
1670237657 -> Mon Dec 5 10:54:17 2022 udp_recv fd:5
Mon Dec 5 10:54:17 2022 udp_recv fd:5 iBytesRead:963
Mon Dec 5 10:54:17 2022 UdpInputProc iSock:5 iBytesRead:963 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:17 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:963
Mon Dec 5 10:54:17 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:17 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=963, mtls = 0
Mon Dec 5 10:54:17 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
Via: SIP/2.0/UDP 192.168.1.18:59400;rport;branch=z9hG4bKPj9990e1d5be1541b7831111ff6b5b806d
Max-Forwards: 70
From: <sip:8977@192.168.1.10>;tag=81773224f44f4986a3b807271b8b4aa7
Call-ID: 84c32c4358944277aa0bb426f51564c1
CSeq: 23371 INVITE
Min-SE: 90
Content-Type: application/sdp
Content-Length: 316
v=0
o=- 3879226487 3879226487 IN IP4 128.203.52.4
s=pjmedia
b=AS:84
t=0 0
a=X-nat:0
m=audio 4008 RTP/AVP 8 101
b=TIAS:64000
a=rtcp:4009 IN IP4 128.203.52.4
a=sendrecv
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ssrc:1765374817 cname:57b226f2714b4f61
1670237657 -> Mon Dec 5 10:54:17 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:17 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:17 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:17 2022 3573B [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:17 2022 [CIOCom::receiveRequest] Received CRequest 3573B ref=1
Mon Dec 5 10:54:17 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:17 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:17 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:17 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:17 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:17 2022 [CDispatcher::processRequestFromManagerIndex] Call does not exist or manager changed: Find the new manager to handle
Mon Dec 5 10:54:17 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:17 2022 [CMotorCallManager::callFactory] For call : 84c32c4358944277aa0bb426f51564c1.
Mon Dec 5 10:54:17 2022 1184 [CCall::CCall] resources number: 143
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setSessionTimer] main gw sessionTimer=1800
Mon Dec 5 10:54:17 2022 [CMotorCall :: CMotorCall()] Oxe_Version_Name = OmniPCX Enterprise R100.0 n1.291.68.a
Mon Dec 5 10:54:17 2022 [CMotorCallManager::callFactory]=8de05f8.
1670237657 -> Mon Dec 5 10:54:17 2022 1184 [CCall::receiveRequest] INVITE
Mon Dec 5 10:54:17 2022 1184 [CCall::getDialog] Confirmed Dialog is not found (ID = ;81773224f44f4986a3b807271b8b4aa7)
Mon Dec 5 10:54:17 2022 1184 [CCall::getDialog] Initial Dialog Server not found
Mon Dec 5 10:54:17 2022 1576 [CDialog::CDialog] resources number: 281
Mon Dec 5 10:54:17 2022 1576 [CDialog::receiveRequest]
Mon Dec 5 10:54:17 2022 1576 [CDialog::receiveInviteRequest]
Mon Dec 5 10:54:17 2022 215e [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:17 2022 215e [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:17 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:17 2022 215e [CTransInitialState::receiveRequest] Transaction changes to Proceeding state
Mon Dec 5 10:54:17 2022 215e [CTransaction::changeState] STATE CHANGED TO PROCEEDING
Mon Dec 5 10:54:17 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = Initial, currentState = Proceeding, reason = Request reception]
Mon Dec 5 10:54:17 2022 215e [CTransProceedingState::createResponse] CResponse 35CA8 ref=1
Mon Dec 5 10:54:17 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:17 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:17 2022 [DBG: CResponse::freeAttributes] Ends
1670237657 -> Mon Dec 5 10:54:17 2022 35CA8 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:17 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:17 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 321)
SIP/2.0 100 Trying
CSeq: 23371 INVITE
Via: SIP/2.0/UDP 192.168.1.18:59400;received=192.168.1.18;rport=59400;branch=z9hG4bKPj9990e1d5be1541b7831111ff6b5b806d
Content-Length: 0
Mon Dec 5 10:54:17 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:17 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:17 2022 udp_send fd:5
Mon Dec 5 10:54:17 2022 udp_send fd:5 port 59400 iBytesSend:321
Mon Dec 5 10:54:17 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:17 2022 35CA8 [CMessage::onSendSuccess]
Mon Dec 5 10:54:17 2022 215e [CTransaction::onSendSuccess] CMessage 35CA8 send Success
Mon Dec 5 10:54:17 2022 1576 [CDialog::onSendSuccess]
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:17 2022 1576 [CDialog::receiveInviteRequest] a new Server INVITE transaction is in progress
1670237657 -> Mon Dec 5 10:54:17 2022 [CSessionTimerContext::CSessionTimerContext] New CSessionTimerContext from request (Server, UA)
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::updateAfterRefreshReception] Update CSessionTimerContext (refresh reception)
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::updateSupported] Request timer supported
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::updateMinSE] Min-SE updated : 90
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::updateSessionExpires] Session-Expires updated : 1800
Mon Dec 5 10:54:17 2022 [CSessionTimerContext::setRefreshMethod] Allow refreshMethod=UPDATE
Mon Dec 5 10:54:17 2022 1576 [CDialog::addTransaction] added transaction 215e with branch z9hG4bKPj9990e1d5be1541b7831111ff6b5b806d, with CSeq 23371
Mon Dec 5 10:54:17 2022 1184 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:17 2022 1184 [CCall::checkAuthentication] INVITE
Mon Dec 5 10:54:17 2022 1184[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:17 2022 [getFromHeader] look at the From.
Mon Dec 5 10:54:17 2022 [getFromHeader] displayName=.
Mon Dec 5 10:54:17 2022 [convertCSipURLIntoSipuri] uri = sip:8977@192.168.1.10.
Mon Dec 5 10:54:17 2022 [getFromHeader] =8977@192.168.1.10.
Mon Dec 5 10:54:17 2022 [getFromHeader] clirPresent=0.
Mon Dec 5 10:54:17 2022 [getReqUriHeader] look at the requri.
Mon Dec 5 10:54:17 2022 [convertCSipURLIntoSipuri] uri = sip:8013@192.168.1.10.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::getUserType] extGw=-1.
1670237657 -> Mon Dec 5 10:54:17 2022 [CMotorCall::analyseRouting] TEL uri=0.
Mon Dec 5 10:54:17 2022 [CMotorCall::analyseRouting] 8977@192.168.1.10 is authenticable.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setExtGw] -1->-3
Mon Dec 5 10:54:17 2022 [isUserInDico] looking for 8977@192.168.1.10 ...
Mon Dec 5 10:54:17 2022 [isUserInDico] found in the dictionnary.
Mon Dec 5 10:54:17 2022 [isAddrInDico] seplos station OK
Mon Dec 5 10:54:17 2022 [getNeqtSeplosStation] stat=13 digit=4 app=0 com=0 data=1 term=159.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::getUserType] From is seplos station crypto=0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::getUserType] extGw=-3.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::controlAuthentication] m_other_calling=0 extgw=-3
Mon Dec 5 10:54:17 2022 1184[CMotorCall::controlAuthentication] from:sip:8977@192.168.1.10:5060
Mon Dec 5 10:54:17 2022 [CMngData::getStackPort] >>>>> transportProtocol: 0, isMTLS: 0, m_uStackSecureMtlsPort: 6261, m_uStackSecurePort: 5061, m_uStackUnsecurePort 5060
Mon Dec 5 10:54:17 2022 [CMngData::getStackPort] >>>>> port: 5060
Mon Dec 5 10:54:17 2022 [CGwMngData::isAuthenticationRequiredForThisClient] 8977@192.168.1.10 .
Mon Dec 5 10:54:17 2022 [CGwMngData::isAuthenticationRequiredForThisClient] -3 need auth=0.
Mon Dec 5 10:54:17 2022 [CGwMngData::isAuthenticationRequiredForThisClient] external gateway -3.
Mon Dec 5 10:54:17 2022 CGwMngData::isAuthenticationRequiredForThisClient: gateway=-3
1670237657 -> Mon Dec 5 10:54:17 2022 1184[CMotorCall::controlAuthentication] ---*--- END-05 ---*--- Control authentication
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setExtGw] -3->-3
Mon Dec 5 10:54:17 2022 1184 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:17 2022 1184 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:17 2022 1184 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:17 2022 1184 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setFilterUsedMode] To be traced = 0
Mon Dec 5 10:54:17 2022 1184[CMotorCall::initOfUserType] station role already defined s=1 d=0 o=0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::initOfUserType] crypted=0 crypting_author=0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onReceiveRequest] accepte? m_other_calling=0 gw=-1.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::toGatewayOrProxy] SIP_PRIVATE_TRANSIT_MODE=2.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::toGatewayOrProxy] request for proxydomain=192.168.1.10.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::toGatewayOrProxy] from = seplos station.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] nb available licenses=0 .
1670237657 -> Mon Dec 5 10:54:17 2022 [CGwServAuthenticate::isUserDeclared] found in the dictionnary.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::compareDialogFromContext] presumed to be the same Dialog
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] Invite => update the inviteContext.
Mon Dec 5 10:54:17 2022 [CForkedBranch::CForkedBranch] context = 0x8de0bbc.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] reqUri stored: sip:8977@192.168.1.18:59400;ob
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] cacUsed = 0 before.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] returnStat = 0 before.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] cacUsed = 0 after.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::methodInviteReceived] CAC = 0
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] Call: 84c32c4358944277aa0bb426f51564c1 eqt: -1 INITIAL_STATE received a message.
Mon Dec 5 10:54:17 2022 [decodeInviteCLIR].
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] UPDATE present in Allow header
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] INFO present in Allow header
Mon Dec 5 10:54:17 2022 am_I_PCS SCSWorking : NO
Mon Dec 5 10:54:17 2022 check_PCSstate
Mon Dec 5 10:54:17 2022 check_PCSstate stat of PCS is : -1
Mon Dec 5 10:54:17 2022 1184[CMotorCall::analyseSessionTimer] Session Timer extGw=-1 sessionDelay=1800 .
1670237657 -> Mon Dec 5 10:54:17 2022 1184[CMotorCall::isExtGwTLSwithREINVITE] ExtGw NOT manged with TLS and refresh REINVITE
Mon Dec 5 10:54:17 2022 1184[CMotorCall::analyseSessionTimer] exit with uacGatewayMode=0 uacRefresher=0.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] Sdp contains 1 media description(s).
Mon Dec 5 10:54:17 2022 [checkSdpValidity] without video control.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] Media 0 type 1 contains 2 formats.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] media audio.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] Format : 8.
Mon Dec 5 10:54:17 2022 [checkSdpValidity] return false.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] Sdp contains 1 media description(s).
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] No Direction in the session part.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] Check the direction in Session part - result:0.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] new media analyzed=0 sdp_index=0 count=1.
Mon Dec 5 10:54:17 2022 [audioMediaSentToCH] media AUDIO detected (previous crypto=0), clearMediaLine=0
Mon Dec 5 10:54:17 2022 [convertCryptoInfoInFile] clearMediaLine2: 0.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] The audio media contains 2 format(s).
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Format 0 is 8 opt syst G711=0.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Format is PCMA.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Format 1 is 101 opt syst G711=0.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] 101.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Format is DTMF:101.
1670237657 -> Mon Dec 5 10:54:17 2022 [convertAudioMedia] Direction is sendrecv.
Mon Dec 5 10:54:17 2022 [convertAudioMedia] Connection address retrieved in sdp: 128.203.52.4.
Mon Dec 5 10:54:17 2022 [convertIPStrIntoTuipv] 128.203.52.4 => 128.203.52.4
Mon Dec 5 10:54:17 2022 [audioMediaSentToCH] sdp index=0.
Mon Dec 5 10:54:17 2022 [display_sdp] address =128.203.52.4
Mon Dec 5 10:54:17 2022 [display_sdp] codecs =0.
Mon Dec 5 10:54:17 2022 [display_sdp] codecs =101.
Mon Dec 5 10:54:17 2022 [display_sdp] direction=0.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] ok.
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] 5-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] only one media taken into account xxx crypto_index=0 clear media=1
Mon Dec 5 10:54:17 2022 [convertSdpIntoTsdp] 3-crypto_info=0xbfffeca4 crypto_index=0 clear media=1
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] NO 100rel REQUIRED for this call.
Mon Dec 5 10:54:17 2022 [CInitialState::receiveinvitemessage allow_update 0 prack_required 0
Mon Dec 5 10:54:17 2022 [receiveinvitemessage] get requri.
Mon Dec 5 10:54:17 2022 [decodeInviteTo].
Mon Dec 5 10:54:17 2022 [decodeInviteReferredBy].
Mon Dec 5 10:54:17 2022 [decodeInviteReferredBy] ReferBy = Zero indirect=4.
Mon Dec 5 10:54:17 2022 [decodeInviteACSBU].
Mon Dec 5 10:54:17 2022 systemOption[BOOL_SIP_DIVERSION_INFO_TRANSIT]=1
1670237657 -> Mon Dec 5 10:54:17 2022 [receiveInviteMessage] concatenating from header
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] temp_fromuserinfo = 8977
Mon Dec 5 10:54:17 2022 [receiveInviteMessage] From_userinfo = 8977
Mon Dec 5 10:54:17 2022 1184[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:17 2022 [ipc_thread] Normal case : evt 10764
Mon Dec 5 10:54:17 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:17 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::insertCallwithEqt] CMotorCall 1464 inserted.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::sendLgEvtSipCreate] Event sent on eqt : 1464
Mon Dec 5 10:54:17 2022 ** SEPLOS/IP-DECT **
Mon Dec 5 10:54:17 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:17 2022 Id : -1
Mon Dec 5 10:54:17 2022 INVITE
Mon Dec 5 10:54:17 2022 REQUEST URI : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:17 2022 FROM : <> 8977@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:17 2022 TO : <> 8013@192.168.1.10:5060 ; user=name
Mon Dec 5 10:54:17 2022 CAC : 0
Mon Dec 5 10:54:17 2022 CAC ADDRESS :
Mon Dec 5 10:54:17 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:17 2022 CLIR : 0
Mon Dec 5 10:54:17 2022 Prack Required : 0
Mon Dec 5 10:54:17 2022 Allow Update : 0
Mon Dec 5 10:54:17 2022 SDP :
Mon Dec 5 10:54:17 2022 ADDRESS : 128.203.52.4 :4008
1670237657 -> Mon Dec 5 10:54:17 2022 ALGOS :
Mon Dec 5 10:54:17 2022 PCMA
Mon Dec 5 10:54:17 2022 101
Mon Dec 5 10:54:17 2022 DIRECTION : SEND & RECEIVE
Mon Dec 5 10:54:17 2022 video index : 0
Mon Dec 5 10:54:17 2022 crypto index : 0
Mon Dec 5 10:54:17 2022 N_GW_EXT : -1
Mon Dec 5 10:54:17 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:17 2022 1184[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:17 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:17 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:17 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:17 2022 INFORMATIONAL
Mon Dec 5 10:54:17 2022 xx : 0
Mon Dec 5 10:54:17 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:17 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] an event 10764 arrived on the eqt 1464 1.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] an event arrived on an invalid eqt 1464 1.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::unRegister] Remove eqt : 1464 diag : -1 from the map.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 -1.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] dialogId update done.
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] NOE-SIP : No updates to Twin
Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] seplos station.
1670237657 -> Mon Dec 5 10:54:17 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:17 2022 [onIncomingEvent] INFORMATIONAL arrived.
Mon Dec 5 10:54:17 2022 [onIncomingEvent] 100 TRYING ignored.
Mon Dec 5 10:54:17 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:17 2022 xx : 83
Mon Dec 5 10:54:17 2022 ADDRESS : 192.168.1.11 :32532
1670237657 -> Mon Dec 5 10:54:17 2022 [receiveInformationalEvent] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::isTLSProtRequiredForExtGw] =0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::updateTransportfromlastInviteContext] lasInviteContext Start
Mon Dec 5 10:54:17 2022 1184[CMotorCall::buildContact] Contact: sip:192.168.1.10:5060
Mon Dec 5 10:54:17 2022 1184[CMotorCall::emitInformationMessage] cause=183
Mon Dec 5 10:54:17 2022 1184[CMotorCall::makeResponseSdpAudioOld] Audio media.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::appendAudioAttributToMedia] Direction: 0.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::appendAudioAttributToMedia] format 101
Mon Dec 5 10:54:17 2022 1184[CMotorCall::makeResponseSdpAudio] fromSdp.getMediaDesciprionCount :1
Mon Dec 5 10:54:17 2022 [sameCodec] accepted Format : 8.
Mon Dec 5 10:54:17 2022 [sameCodec] requested Format : 8.
Mon Dec 5 10:54:17 2022 [sameCodec] same Format.
Mon Dec 5 10:54:17 2022 1184[CMotorCall::mediaAccepted] Media accepted: m=audio 32532 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
Mon Dec 5 10:54:17 2022 1184[CMotorCall::makeResponseSdpAudio] no crypto line, media accepted=0.
1670237657 -> Mon Dec 5 10:54:17 2022 1184[CMotorCall::makeResponseSdpAudioOld] Final Sdp.
Mon Dec 5 10:54:17 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:17 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:17 2022 1184[CMotorCall::emitInformationalMessage] Answer sdp.
Mon Dec 5 10:54:17 2022 [removeAudioMediaPortNull] media no=0.
Mon Dec 5 10:54:17 2022 1184 [CCall::makeGenericResponse] 183
Mon Dec 5 10:54:17 2022 1184 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:17 2022 1576 [CDialog::createResponse] 183
Mon Dec 5 10:54:17 2022 215e [CTransProceedingState::createResponse] CResponse 35CA9 ref=1
Mon Dec 5 10:54:17 2022 35CA9 [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:17 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 834)
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
To: <sip:8013@192.168.1.10>;tag=991fdf61c064cb11a3be7f9e550ecd5e
CSeq: 23371 INVITE
Content-Length: 216
v=0
o=OXE 1670237657 1670237657 IN IP4 192.168.1.10
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1670237659 -> Mon Dec 5 10:54:17 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:17 2022 udp_send fd:5 port 59400 iBytesSend:834
Mon Dec 5 10:54:17 2022 35CA9 [CMessage::onSendSuccess]
Mon Dec 5 10:54:17 2022 215e [CTransaction::onSendSuccess] CMessage 35CA9 send Success
Mon Dec 5 10:54:17 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:17 2022 35CA8 [~CResponse] resp(100) 84c32c4358944277aa0bb426f51564c1 23371 INVITE
Mon Dec 5 10:54:17 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:17 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:17 2022 1576 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:19 2022 udp_recv fd:5
Mon Dec 5 10:54:19 2022 udp_recv fd:5 iBytesRead:389
Mon Dec 5 10:54:19 2022 UdpInputProc iSock:5 iBytesRead:389 Host:192.168.1.18 Port:59400
1670237659 -> Mon Dec 5 10:54:19 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:389
Mon Dec 5 10:54:19 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:19 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=389, mtls = 0
Mon Dec 5 10:54:19 2022 RECEIVE MESSAGE FROM NETWORK (192.168.1.18:59400 [UDP])
Max-Forwards: 70
CSeq: 23371 CANCEL
Content-Length: 0
Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] optimisation value 1
Mon Dec 5 10:54:19 2022 [CIOCom::IsNoeOptionsMsg] Not in same domain FAILED => 192.168.1.10 oxe.ma
Mon Dec 5 10:54:19 2022 [CIOCom::IsNoeOptionsMsg] NoeOpt 0
Mon Dec 5 10:54:19 2022 3573C [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] Received CRequest 3573C ref=1
Mon Dec 5 10:54:19 2022 [CAdnsMngt::checkHostInBlackList] host=192.168.1.18 alcResult= 0
Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] rport1 empty
1670237659 -> Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] Set received param on first Via header : 192.168.1.18
Mon Dec 5 10:54:19 2022 [CDispatcher::onIncomingRequest()]
Mon Dec 5 10:54:19 2022 [CDispatcher::processRequestFromManagerIndex()] start at index 0
Mon Dec 5 10:54:19 2022 102 [CCallManager::onIncomingRequest()]
Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] CANCEL
Mon Dec 5 10:54:19 2022 1184 [CCall::getDialog] Confirmed Dialog is not found (ID = ;81773224f44f4986a3b807271b8b4aa7)
Mon Dec 5 10:54:19 2022 1184 [CCall::getDialog] Returning Initial Dialog Server
Mon Dec 5 10:54:19 2022 1576 [CDialog::receiveRequest]
Mon Dec 5 10:54:19 2022 1576 [CDialog::receiveCancelRequest]
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] STATE CHANGED TO INITIAL
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215f, previousState = Terminated, currentState = Initial, reason = None]
Mon Dec 5 10:54:19 2022 215f [CTransInitialState::receiveRequest] Transaction changes to Trying state
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] STATE CHANGED TO TRYING
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215f, previousState = Initial, currentState = Trying, reason = Request reception]
Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] iErrorCode=488.
1670237659 -> Mon Dec 5 10:54:19 2022 1184 [CCall::checkAuthentication] CANCEL
Mon Dec 5 10:54:19 2022 1184[CMotorCall::controlAuthentication] ---*--- AUTH ---*--- Control authentication
Mon Dec 5 10:54:19 2022 1184[CMotorCall::controlAuthentication] ---*--- END-03 ---*--- Control authentication
Mon Dec 5 10:54:19 2022 1184 [CCall::controlAuthentication] need auth =0
Mon Dec 5 10:54:19 2022 1184 [CCall::checkAuthentication] AUTHENT=0
Mon Dec 5 10:54:19 2022 1184 [CCall::checkAuthentication] iRetValue=0
Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] extGw=-1.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] request received.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] s=1 d=0 v=0 o=0.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] request for gateway.
Mon Dec 5 10:54:19 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:19 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] state = PROCEEDING_STATE.
Mon Dec 5 10:54:19 2022 [receiveCancelMessage] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 PROCEEDING_STATE received a message.
Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] content size (lginfo): 656 ccal crypted= 0
Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] cacUsed=0 eqtCac=-1
Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] displayIPCMessageOut
Mon Dec 5 10:54:19 2022 ** SEPLOS **
Mon Dec 5 10:54:19 2022 [sendLgEvtSip] seplos Event sent on eqt : 1464 Id :1
1670237659 -> Mon Dec 5 10:54:19 2022 [display_ipc_out] ------------ Begin ---------------
Mon Dec 5 10:54:19 2022 Id : 1
Mon Dec 5 10:54:19 2022 CANCEL
Mon Dec 5 10:54:19 2022 [display_ipc_out] ------------- End ----------------
Mon Dec 5 10:54:19 2022 [ipc_thread] Normal case : evt 10765
Mon Dec 5 10:54:19 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:19 2022 [ipc_thread] IPC Thread : TCL thread signaled.
Mon Dec 5 10:54:19 2022 [exec_ipc] in 5615.
Mon Dec 5 10:54:19 2022 [display_ipc_in] ------------ Begin ---------------
Mon Dec 5 10:54:19 2022 neqt : 1464 Id : 1
Mon Dec 5 10:54:19 2022 SUCCESSFUL
Mon Dec 5 10:54:19 2022 xx : 0
Mon Dec 5 10:54:19 2022 RELATIVE REQUEST : CANCEL
Mon Dec 5 10:54:19 2022 CLIR : 0
Mon Dec 5 10:54:19 2022 COLP : 0
Mon Dec 5 10:54:19 2022 CAC-CSBU info : UNKNOWN
Mon Dec 5 10:54:19 2022 [display_ipc_in] ------------- End ----------------
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] an event 10765 arrived on the eqt 1464 1.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] seplos station.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] state = PROCEEDING_STATE.
Mon Dec 5 10:54:19 2022 [onIncomingEvent] SUCCESSFUL arrived.
Mon Dec 5 10:54:19 2022 [onIncomingEvent] relative_request = 10756
Mon Dec 5 10:54:19 2022 [CProceedingState::receiveSuccessfulEvent] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:19 2022 0[CMotorCall::emitSuccessfulMessage] isIpDect=0
1670237659 -> Mon Dec 5 10:54:19 2022 1576 [CCall::findFirstServerTrans]
Mon Dec 5 10:54:19 2022 1576 [CDialog::findFirstServerTrans] Current Request in cancelTransactionMap
Mon Dec 5 10:54:19 2022 1184 [CCall::makeGenericResponse] 200
Mon Dec 5 10:54:19 2022 1576 [CDialog::createResponse] 200
Mon Dec 5 10:54:19 2022 215f [CTransTryingState::createResponse] CResponse 35CAA ref=1
Mon Dec 5 10:54:19 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:19 2022 [DBG: CMessage::freeAttributes Start Alert freeAttributes !!!!!!!!]:
Mon Dec 5 10:54:19 2022 [DBG: CResponse::freeAttributes] Ends
Mon Dec 5 10:54:19 2022 35CAA [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:19 2022 [CIOCom:sip_sendToNetwork] transptype=6
Mon Dec 5 10:54:19 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 407)
SIP/2.0 200 OK
CSeq: 23371 CANCEL
Content-Length: 0
1670237659 -> Mon Dec 5 10:54:19 2022 [CTransport::findConnection] pConnection = 77c4 remoteHost=192.168.1.18, remotePort=59400
Mon Dec 5 10:54:19 2022 [CTransport::getConnection] RemoteHost=(192.168.1.18 59400) already exist, using connection 77c4
Mon Dec 5 10:54:19 2022 [CConnectionUdp::sendToNetwork] The bytes received is not null
Mon Dec 5 10:54:19 2022 udp_send fd:5
Mon Dec 5 10:54:19 2022 udp_send fd:5 port 59400 iBytesSend:407
Mon Dec 5 10:54:19 2022 77c4 [CConnection::resetConnectionTimer] Creating the activity timer
Mon Dec 5 10:54:19 2022 35CAA [CMessage::onSendSuccess]
Mon Dec 5 10:54:19 2022 215f [CTransaction::onSendSuccess] CMessage 35CAA send Success
Mon Dec 5 10:54:19 2022 1576 [CDialog::onSendSuccess]
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onSendSuccess] DNS resolution ok.
Mon Dec 5 10:54:19 2022 215f [CTransTryingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215f, previousState = Trying, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:19 2022 215f [CTransaction::startTimer] Timer J is started (delay = 32000 ms)
Mon Dec 5 10:54:19 2022 1576 [CDialog::updateRouteSet] there are 0 record-route headers
Mon Dec 5 10:54:19 2022 [exec_ipc] in end 5615.
Mon Dec 5 10:54:19 2022 [ipc_thread] Normal case : evt 10767
1670237659 -> Mon Dec 5 10:54:19 2022 [ipc_thread] IPC Thread : Ipc reception 5624.
Mon Dec 5 10:54:19 2022 REQUEST FAILURE
Mon Dec 5 10:54:19 2022 xx : 87
Mon Dec 5 10:54:19 2022 RELATIVE REQUEST : INVITE
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] an event 10767 arrived on the eqt 1464 1.
Mon Dec 5 10:54:19 2022 [onIncomingEvent] REQUEST FAILURE arrived.
Mon Dec 5 10:54:19 2022 [receiveRequestFailureEvent] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 PROCEEDING_STATE received an event.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::getOutgoingCall] outgoingCall:0
Mon Dec 5 10:54:19 2022 [receiveRequestFailureEvent] incoming call.
Mon Dec 5 10:54:19 2022 1184 [CCall::makeGenericResponse] 487
Mon Dec 5 10:54:19 2022 1184 [CCall::getDialog] Confirmed Dialog is not found (ID = 991fdf61c064cb11a3be7f9e550ecd5e;81773224f44f4986a3b807271b8b4aa7)
Mon Dec 5 10:54:19 2022 1576 [CDialog::createResponse] 487
Mon Dec 5 10:54:19 2022 215e [CTransProceedingState::createResponse] CResponse 35CAB ref=1
1670237659 -> Mon Dec 5 10:54:19 2022 [DBG: CResponse::freeAttributes]
Mon Dec 5 10:54:19 2022 35CAB [CMessage::send] sip_sendMessage (192.168.1.18:59400)
Mon Dec 5 10:54:19 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 504)
CSeq: 23371 INVITE
Content-Length: 0
Mon Dec 5 10:54:19 2022 udp_send fd:5 port 59400 iBytesSend:504
1670237659 -> Mon Dec 5 10:54:19 2022 35CAB [CMessage::onSendSuccess]
Mon Dec 5 10:54:19 2022 215e [CTransaction::onSendSuccess] CMessage 35CAB send Success
Mon Dec 5 10:54:19 2022 [CResponse::~CResponse]
Mon Dec 5 10:54:19 2022 35CA9 [~CResponse] resp(183) 84c32c4358944277aa0bb426f51564c1 23371 INVITE
Mon Dec 5 10:54:19 2022 [CResponse::~CResponse Ends]
Mon Dec 5 10:54:19 2022 [CMessage::~CMessage Ends]
Mon Dec 5 10:54:19 2022 215e [CTransProceedingState::createResponse] Final : Transaction changes to Completed state
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] STATE CHANGED TO COMPLETED
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] notifying the parent dialog
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = Proceeding, currentState = Completed, reason = Final resp creation]
Mon Dec 5 10:54:19 2022 215e [CTransaction::startTimer] Timer G is started (delay = 500 ms)
Mon Dec 5 10:54:19 2022 215e [CTransaction::startTimer] Timer H is started (delay = 32000 ms)
Mon Dec 5 10:54:19 2022 1184[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Mon Dec 5 10:54:19 2022 udp_recv fd:5 iBytesRead:391
1670237659 -> Mon Dec 5 10:54:19 2022 UdpInputProc iSock:5 iBytesRead:391 Host:192.168.1.18 Port:59400
Mon Dec 5 10:54:19 2022 [CTransportUdp::receiveMessage] from 192.168.1.18:59400 rc:391
Mon Dec 5 10:54:19 2022 [CIOCom::onReceiveMessage] received from 192.168.1.18:59400, proto=0, length=391, mtls = 0
Max-Forwards: 70
CSeq: 23371 ACK
Route: <sip:192.168.1.10;lr>
Content-Length: 0
Mon Dec 5 10:54:19 2022 3573D [CRequest::CRequest] Creation of a request (RECEIVED FROM NETWORK)
Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] Received CRequest 3573D ref=1
1670237659 -> Mon Dec 5 10:54:19 2022 [CIOCom::receiveRequest] rport1 empty
Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] ACK
Mon Dec 5 10:54:19 2022 1576 [CDialog::receiveAckRequest]
Mon Dec 5 10:54:19 2022 215e [CTransCompletedState::receiveRequest] ACK(UDP) : Transaction changes to Confirmed state
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] STATE CHANGED TO CONFIRMED
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = Completed, currentState = Confirmed, reason = Request reception]
Mon Dec 5 10:54:19 2022 215e [CTransaction::freeTimerToken] Timer G is freed
Mon Dec 5 10:54:19 2022 215e [CTransaction::freeTimerToken] Timer H is freed
Mon Dec 5 10:54:19 2022 215e [CTransaction::startTimer] Timer I is started (delay = 5000 ms)
Mon Dec 5 10:54:19 2022 1576 [CDialog::receiveAckRequest] receiving an ACK on a previously rejected INVITE
1670237659 -> Mon Dec 5 10:54:19 2022 1184 [CCall::receiveRequest] iErrorCode=488.
Mon Dec 5 10:54:19 2022 1184 [CCall::checkAuthentication] ACK
Mon Dec 5 10:54:19 2022 1184[CMotorCall::onReceiveRequest] state = TERMINATED_STATE.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::compareDialogFromContext] same Dialog
Mon Dec 5 10:54:19 2022 1184[CMotorCall::methodAckReceived] Ack => update the inviteContext.
Mon Dec 5 10:54:19 2022 [receiveAckMessage] Call: 84c32c4358944277aa0bb426f51564c1 eqt: 1464 TERMINATED_STATE received a message.
Mon Dec 5 10:54:19 2022 [receiveAckMessage] boolean flag check 0
1670237659 -> Mon Dec 5 10:54:19 2022 1184[emitEventToMonitel] CAC = 0 eqtCAC = -1
Mon Dec 5 10:54:19 2022 ACK
Mon Dec 5 10:54:19 2022 [ipc_thread] Normal case : evt 10773
Mon Dec 5 10:54:19 2022 SIP EQT RELEASED
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] an event 10773 arrived on the eqt 1464 1.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] The call with eqt: 1464 has released its equipment.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] state = TERMINATED_STATE.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::unRegister] Remove eqt : 1464 diag : 1 from the map.
1670237659 -> Mon Dec 5 10:54:19 2022 [CMotorCallManager::eraseCallwithEqt] erase 1464 1.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onIncomingEvent] killSession.
Mon Dec 5 10:54:19 2022 1184 [CCall::killSession]
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:19 2022 215f [CTransaction::freeTimerToken] Timer J is freed
Mon Dec 5 10:54:19 2022 215f [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] STATE CHANGED TO TERMINATED
Mon Dec 5 10:54:19 2022 215e [CTransaction::freeTimerToken] Timer I is freed
Mon Dec 5 10:54:19 2022 215e [CTransaction::changeState] no transaction state, terminated reason : None
Mon Dec 5 10:54:19 2022 1184 [CCall::killSession] notifying the call manager
Mon Dec 5 10:54:19 2022 102 [CCallManager::onCallClosed]
Mon Dec 5 10:54:19 2022 102 [CCallManager::onCallClosed()] Call 1184 closed. Removing call 148768248 from the maps
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onNotifyCallClosed] Call : 84c32c4358944277aa0bb426f51564c1 is closed.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onNotifyCallClosed] call processResponse.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::chooseBestResponse] pForkedBranch=0x8ca1878 iResponseCode=2000.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::chooseBestResponse] next branch.
Mon Dec 5 10:54:19 2022 1184[CMotorCall::processResponse] no response found.
Mon Dec 5 10:54:19 2022 [CMotorCallManager::onNotifyCallClosed] Remove eqt from the map.
1670237659 -> Mon Dec 5 10:54:19 2022 102 [CCallManager::onCallClosed] pCall: 1184 added in the Garbage List
Mon Dec 5 10:54:19 2022 [CTransaction::notifyDialog]
Mon Dec 5 10:54:19 2022 [CTransaction::notifyDialog] notify parent dialog
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215f, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:19 2022 215F [~CTransaction] transaction 23371 CANCEL
Mon Dec 5 10:54:19 2022 35CAA [~CResponse] resp(200) 84c32c4358944277aa0bb426f51564c1 23371 CANCEL
Mon Dec 5 10:54:19 2022 [CRequest::~CRequest]
Mon Dec 5 10:54:19 2022 3573C [~CRequest] req 84c32c4358944277aa0bb426f51564c1 23371 CANCEL
Mon Dec 5 10:54:19 2022 [CRequest::~CRequest] Ends
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState(pTrans = 215e, previousState = null, currentState = Terminated, reason = None]
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState] dialog is terminated
Mon Dec 5 10:54:19 2022 1576 [CDialog::onTransactionState] onDialogClosed
Mon Dec 5 10:54:19 2022 1184 [CCall::onDialogClosed]
1670237659 -> Mon Dec 5 10:54:19 2022 1184 [CCall::onDialogClosed] only initial *********
Mon Dec 5 10:54:19 2022 1184 [CCall::onDialogClosed] All the initial dialogs in the Call are closed
Mon Dec 5 10:54:19 2022 215E [~CTransaction] transaction 23371 INVITE
Mon Dec 5 10:54:19 2022 3573D [~CRequest] req 84c32c4358944277aa0bb426f51564c1 23371 ACK
1670237661 -> Mon Dec 5 10:54:20 2022 [fnInit] *************************** Init timeout.
Mon Dec 5 10:54:20 2022 [fnInit] treatTimeout.
Mon Dec 5 10:54:20 2022 [CMotorInitTimerContext::treatTimeout] emitRegisterMessage gw=1.
Mon Dec 5 10:54:20 2022 [CMotorInitTimerContext::start] delay =6000 gw 1.
Mon Dec 5 10:54:20 2022 [startRegistration] timer value=6000.
Mon Dec 5 10:54:21 2022 102 [CCallManager::removeGarbage] at index i = 0
Mon Dec 5 10:54:21 2022 1184 [CMotorCall::clear_subscription] no subscription managed
Mon Dec 5 10:54:21 2022 1184[CMotorCall::~CMotorCall] Call : 84c32c4358944277aa0bb426f51564c1 is being destructed.
Mon Dec 5 10:54:21 2022 [CMotorCall::getSupervisorKeys] Returning NULL value for supervisor keys
Mon Dec 5 10:54:21 2022 [DBG: CSipSdpMessage::Destructor]
Mon Dec 5 10:54:21 2022 [DBG: CSipSdpMessage::Destructor] Ends
Mon Dec 5 10:54:21 2022 1184 [CCall::~CCall] resources number: 142
Mon Dec 5 10:54:21 2022 1184 [CCall::TestDegradedModeEnd] resources number: 141
Mon Dec 5 10:54:21 2022 1184 [CCall::removeGarbage]
Mon Dec 5 10:54:21 2022 1576 [CDialog::~CDialog] resources number: 280
Mon Dec 5 10:54:21
Re: Help sip extension ale-2 not registered alcatel oxe
Mon Dec 5 10:54:17 2022 SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 834)SEND MESSAGE TO NETWORK (192.168.1.18:59400 [UDP]) (BUFF LEN = 834)
Max-Forwards: 70
CSeq: 23371 CANCEL
to 183 session progress the response should be PRACK
Max-Forwards: 70
CSeq: 23371 CANCEL
I can read also nb licence=0
proomh
Licence what ?
THIS licence in OXE
SP_OPS_Version = 00000
1 Group Telephony = 99999
2 M Phonebook users = 0/ 400
4 Hotel guest sets = 300
5 Multilangual voice prompts = 1
6 Hotel: AHL on V24 = 1
9 PSTN B channel = 99999
10 Voice Guide = 1
12 DISA = 0
13 ECS Engine = 99999
14 Integrated metering report = 1
19 Corporate netw. (ABC,ABCVPN,ISVPN) = 0
20 Automated attendant = 0
21 Nb of VPS ports = 0
29 DECT/PWT Engine = 0
38 Infocenter link = 1
39 Performance = 400
40 Real Time Incidents = 400
41 DECT register = 400
42 Accounting users = 400
44 4059 SBC = 0
45 4059 BLF = 0
46 Fax server ABC-A link = 0
47 Alarms = 400
49 Directory = 400
50 Configuration = 400
51 Real Time Metering on V24 = 400
52 4635 Basic Package = 0
56 4635 Networking OctelNet = 0
57 4635 Fax manager = 0
58 4635 Call manager = 0
59 4635 Hotel manager = 0
60 4635 Nb of ports = 0
61 4635 Nb of hours = 0
62 4635 Nb of languages = 0
63 4635 Attendant manager = 0
65 4635 Recording manager = 0
66 4635 Networking AMIS = 0
75 Networking hospital = 1
76 M CCD Agents = 0
77 CCS mono-site = 0
78 CRI call record interface = 0
79 ISVPN = 0
80 VPN = 0
81 Meet me conf. between 29 parties = 0
82 Nb of DECT terminals = 0
83 Flow Metering on Ethernet = 400
84 4635 users = 0
86 Automatic directory pop-up = 0
87 Beta Test = 0
89 Notification server = 0
90 M Roaming DECT/PWT = 0/ 0
91 Voice guide record from Reflexes = 0
94 WMI Workforce manager interface = 0
97 VPS users = 0
98 Accounting for local calls = 0
99 Accounting for ABC calls = 400
100 CSTA profile = 0
101 CSTA monitoring requests = 0
102 CCS multi-site = 0
103 Real Time Interface = 0
105 Compressed calls = 0
106 Transfix Access X24/V36 = 99999
107 4635 Visual messenger = 0
109 4635 IP Octel Networking = 0
110 4635 Global message redundancy = 0
111 Ubiquity = 0
113 CSTA pilots monitoring = 0
114 TSAPI server = 0
115 CCA softphone = 0
116 ECC My Softphone (4980 Std) = 5000
117 M ECC 4980 Option (4980 Adv) = 0/ 5000
119 4980 nomadic logged = 5000
121 CLIP on VPS = 0
122 ACAPI via CMIP = 400
123 CSTA IVR ports monitored = 0
125 CCweb Agents = 0
126 Hotel AHL link = 1
127 M Encryption DECT/PWT users = 0
128 4615 ports = 0
129 M ECC My Softphone (4980 Grp) = 0/ 5000
130 CSTA voice recording type = 0
131 Remote LIO = 0
132 IP-Trunk = 0
133 Mastered conference = 0
134 Multi-tenant = 0
135 G729A Server = 90
136 Priority = 0
137 Call restriction = 0
138 IP Clients = 7
143 TAPI premium server = 0
145 CSTA Recording B channel = 0
146 PWT mobility (UTAM) = 0
148 IP Call Server = 1
151 4635 VPIM = 0
152 Ith radio = 0
153 SNMP Trap = 1
154 Additional S0 features = 0
155 Additional safety features = 1
156 Ith = 0
157 CCA nomadic = 0
158 CSTA By-pass = 1000
160 CCemail Agents = 0
161 CCoutbound Agents = 0
162 CCoutpredial Agents = 0
164 CSTA Record networked = 0
165 OmniPCX Enterprise release = 50
166 4980 multi device = 5000
167 ACR data base read = 0
168 Nb of HPOV node = 0
169 Voice detection channels = 0
173 M Advanced Reflexes users = 0/ 0
174 M Analog users = 287/ 300
175 M Mobile users = 0/ 0
176 M Advanced IP users = 2/ 7
177 M SIP users = 74/ 93
178 4645 Voice mail engine = 0
179 M 4645 users = 0/ 400
181 OmniPCX Enterprise = 1
182 4645 networking = 0
183 4645 additional language = 0
184 Integrated Gatekeeper = 0
185 SIP Gateway = 1
186 E-CS redundancy = 0
187 H323 (G711) network link = 0
188 SIP network links = 0
189 CCTI agents = 0
190 RSI call center agents = 0
191 Campus DECT = 0
192 DREX Protocol = 0
193 Embedded voice guides = 1
194 4645 Portal users = 0
195 CCD profile = 0
196 RSI Business agents = 0
197 M G729A Client = 5/ 7
198 G723.1 Client = 0
199 Version 4400 R5.0 Ux = 0
200 4400 Mobiles migration = 0
308 M Remote extension = 0/ 0
309 XML telephony = 5000
310 M CLIP Z = 0/ 0
311 ACR Networking = 0
312 Scripting agents = 0
313 eCC Gateway = 0
314 4635 My messaging users = 0
316 M Standard Reflexes users = 0/ 0
317 M Standard IP users = 3/ 0
318 XML IPTouch-IP engine = 0
325 IP-Touch Security Engine = 0
326 M Secured IP-Touch Phones = 0
327 M IP-Touch Security MCM = 0
328 M IP-Softphone Attendants = 0/ 0
329 M IP-Softphone Agents = 0/ 0
330 M Advanced Mobile IP-Touch Users = 0/ 0
332 M PCS max. number = 0/ 0
335 M Greeting Assistant = 0
334 Max. IP recording = 0
336 IME Stations = 0
337 SIP External Voice Mails = 0
342 M ABC-IP Access Number = 0/ 0
343 M MgSec Max Number = 0/ 0
345 M SIP extension users = 74/ 93
348 M Soft MSM lock = 0/ 0
358 M Max number of SIP TLS sets = 0/ 0
359 Max com simultaneous SIP TLS = 0
363 M NOESIP TLS users = 0/ 0
364 Max Attendants 4059EE = 0
371 IPDect Users = 0
384 OXE Media Servers = 0
385 VoIP channels on OMS = 0
386 UC as a Service = 0
396 IPV6 = 0
406 OT gateways allowed = 0
424 Native Encryption Users = 0
428 Sip Trunk Recording = 0
429 Correlator Data = 0
430 SipSoftPhone = 0
467 ARS = 400
468 Product Type = 99999
469 G723.1 Server = 90
this is in your trace
Mon Dec 5 10:54:02 2022 1180[CMotorCall::methodInviteReceived] nb available licenses=0 .
and this is in my trace when i call from a seplos.
670993334 -> 11d4[CMotorCall::onReceiveRequest] state = INITIAL_STATE.
1670993334 -> 11d4[CMotorCall::methodInviteReceived] nb available licenses=13 .
1670993334 -> [isUserDeclared] 519519@pst_n1.alsolb.com
also better if you can change the header uri to phone instead of name
In my understanding, the licenses referenced in the trace are related with sip trunking, but as the problem is related to sip extensions, the issue of being at zero must therefore be out of scope.
BRegards
BRegards
ok sadim , but me too i'm calling from sip extension , is that related to earlier release , actualy oxe is r9.1 a
