OS99-XNI-U48 Module down.
Motello123
Post by Motello123 »
Hi all,
I have a OS9900 running with 8.8.56.R02 release.
I've already performed some upgrades after that this problem come out.
On my OS9900 i've got a OS99-XNI-U48 that goes down.
Sometimes i see the module in "unpowered" state. ( show module status )
Olso it comes down and up for a few minutes causing a network down state.
In attached you can find the logs.
Anyone can tell me something about that?
Thank you.
Motello.
Gleylancer
Re: OS99-XNI-U48 Module down.
Post by Gleylancer »
Are all your PSUs in a working state and not overloaded?
show powersupply
Motello123
--> show powersupply
Total Power Input PS
Chassis/PS Power Used Voltage Type Status Location
1/1 3000 144 230 AC UP Internal
1/4 3000 259 232 AC UP Internal
Total 6000 403
Hi Motello123,
you should open a ticket at ALE to find the reason.
BR Silvio
Return to “OmniSwitch 9900”
