OXE OMS on vmware
morio
OXE OMS on vmware
Post by morio »
hello and hope every one is doing well,
i have been trying to install OMS (Virtual GD) in a vmware. seems everything installs in order but when i type in the omsconfig command its not recognized.
[root@vm-oms2 oms]#
[root@vm-oms2 oms]#
[root@vm-oms2 oms]# omsconfig
If 'omsconfig' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf omsconfig
[root@vm-oms2 oms]# ^C
[root@vm-oms2 oms]#
[root@vm-oms2 oms]# cnf omsconfig
omsconfig: command not found
[root@vm-oms2 oms]#
i even got a small article from ALE support with the same issue but it didnt help. so if there is any one can help it will be a great stress re leaver for me.
thanks in advance
Morio
Konstantinos.E
Re: OXE OMS on vmware
Post by Konstantinos.E »
did you installed the oms with SOT ?
Alca_holic
morio
Post by morio »
hi there Konstantinos.E,, yes i did install it by using SOT _3.1.009.008. created the .ova and run it with the vemware 16 pro and with vmware 16 player. but still the same problem. any hints?
thanks
Konstantinos.E
srange... is your network interface up?
Alca_holic
morio
Post by morio »
hello, yes its is up and i can ping the ip which i provided during the sot installation. has your installations been successful? did you also do it by using sot. can it me that i have missed out some detail during installation. as what it seems it looks like the OMS is not fully installed in my case. any advice?
thanks.
sadim
Post by sadim »
I think only the OS was installed, the post-installation is missing. You can try to do the installation of the OMS itself, using the procedure described in the document im_instalmanual_8AL91032ENBA_2_en.pdf pag 266 - 7. Mount the OXE-MS iso file in the virtual machine:
But be aware that there is a mistake on it, you should to chmod -R a+x ./oms/ and not chmod -R a+x ./tmp/
morio
Post by morio »
hello sadim,
finally i got it running, i downloaded the latest sot and the oms file. and i ran the sot with template. i dont know if that was the issue,, and i also selected the key board as us international. i think that is the main issue. thank you sadim and Konstantinos.E for your support.
now my next target is to have this solution as a mobile test lab so that i will not need a physical server,, thanks again,,
morio
Return to “Other”
