OS6560-P48Z16 - CLI commands
hg363
Post by hg363 »
Hi we use to have 6450 switches with revision 6
They have now been replaced with OS6560-P48Z16 - revision 8
Can some one please tell me what these commands are in Revision 8
Show mac-address table
Vlan 204 port default 1/24
write memory
copy working certified-flash-syncro
Also where can I find CLI commands for revision 8 on the web please?
Gleylancer
Re: OS6560-P48Z16 - CLI commands
Post by Gleylancer »
show mac-learning
vlan 204 members port 1/24 untagged
write memory
copy flash-synchro (also works on AOS6)
The AOS 8 CLI Reference Guide might help.
https://www.alcatelunleashed.com/viewtopic.php?t=31283
hg363
Post by hg363 »
HI Gleylancer that's great, thank you very much.
May I ask you another question. What is the difference between tag and untag?
Gleylancer
hg363 wrote: 28 Jun 2022 09:40What is the difference between tag and untag?
If you want to learn the basics of Ethernet, you could start with 802.1q:
https://en.wikipedia.org/wiki/IEEE_802.1Q
There's also plenty of videos about 802.1q on Youtube.
elam_1011
Post by elam_1011 »
Hi everyone, anyone can help as my company decided to change switch from OS6450 to OS650. i am facing issues to run the following commands in OS6560.
vlan port mobile x/x
vlan port x/x 802.1x enable
vlan port x/x default vlan restore disable
802.1x X/X direction in port-control auto quiet-period 60 tx-period 30 supp-timeout 30
802.1x X/X no reauthentication
802.1x X/X captive-portal session-limit 12 retry-count 3
802.1x X/X captive-portal inactivity-logout disable
8021x X/X supp-polling retry 2
802.1x X/X supplicant policy authentication pass group-mobility default-vlan fail block
802.1x X/X non-supplicant policy authentication pass group-mobility default-vlan fail block
no ip service udp-relay
no ip service secure-https
aaa user-network-profile name "XXX" vlan XXX hic disable
snmp trap absorption disable
swlog remote command-log enable
ntp server x.x.x.x key 0 version 4 minpoll 6
ntp client enable
Engan
Post by Engan »
elam_1011 wrote: 20 Mar 2025 03:38 Hi everyone, anyone can help as my company decided to change switch from OS6450 to OS650. i am facing issues to run the following commands in OS6560.
ntp client enable
Those commands are for AOS 6, you have to check the CLI guide for AOS 8. 802.1x example from this post:
https://www.alcatelunleashed.com/viewtopic.php?t=29469
