Trouble with MIPT 8118 handsets
jonnyred
Post by jonnyred »
Looking for help. After a recent shutdown of our data centre, which meant basculing to our XB servers, and then back after powering up, we have been seeing problems with 8118 and 8128 handsets.
We have two nodes, and so far are only seeing this problem on one of the nodes, and only when we switch to XA.
In working this through we have found that we see problems with handsets that are set to reset authorised updated, to yes on one node, and handsets set to no, on another node. Its very peculier and not consistent at all. When we move Node 2 back to XA certain 8118 and 8128 handsets reboot and then just keep trying to download software, even if update is set to know. Move back to XB and they all come straight back into service. We have checked LANPBX files and they all match.
We do appear to have 8118 MIPT with 6.0.8, 6.1.2 and the latest 6.2.5. If we switch on authorised update none update OTA. We can update manually from the cradle but thats a very big task.
Also noted that our 8158 wont update OTA either.
thanks for any guidance.
Return to “Mobile IPTouch Phones (MIPT)”
