Flash Synchronization failed in Secondary Stack of OS 6350
deep+kumar1102
Post by deep+kumar1102 »
HI team and all
I am facing the below issue , please help me resolve it
OS6350-> write memory flash-synchro
File /flash/working/boot.cfg replaced.
This file may be overwritten if "takeover" is executed before "certify"
Setting CERTIFY Timeout for 800 seconds
from /flash/working to /flash/certified
Copying boot.cfg .................... completed
CERTIFY process completed successfully
Flash Synchronization process started
+++ == CSM == Stack 1 Certify process Completed
+++ == CSM == Stack 2 Certify process Failed
ERROR: Attempt to copy working to cert w/flash synchr failed
While this commands show that this :
OS6350-> show running-directory
CONFIGURATION STATUS
Running CMM : PRIMARY,
CMM Mode : DUAL CMMs,
Current CMM Slot : 1,
Running configuration : WORKING,
Certify/Restore Status : CERTIFIED
SYNCHRONIZATION STATUS
Flash Between CMMs : SYNCHRONIZED,
Running Configuration : SYNCHRONIZED,
Stacks Reload on Takeover: PRIMARY ONLY
Microcode is
KF3base.img 6.7.2.122.R08 16847156 Alcatel-Lucent Enterprise Base Softw
KF3os.img 6.7.2.122.R08 3702108 Alcatel-Lucent Enterprise OS
KF3eni.img 6.7.2.122.R08 6684343 Alcatel-Lucent Enterprise NI softwar
KF3secu.img 6.7.2.122.R08 622909 Alcatel-Lucent Enterprise Security M
Plesae help to resolve this
Re: Flash Synchronization failed in Secondary Stack of OS 6350
frank wrote: 12 May 2022 12:06 Hi.
Please report in the correct forum.
The "talk to the admins" is for board concerns and ideas, not for support.
check in chassis 2 the flash.
rls 2 /flash
rls 2 /flash/working etc.
remove unwanted/old/pmd.... files
rrm ...
than try again with copy flash-synchro
deep+kumar1102
Dear Silvio ,
rls 2 /flash : using this command switch got rebooted but after that is it working fine , but it is rebooted with that command ??
rls - is remote list
Normaly this should no reason for reboot. So I recommend to update the stack to the newest release.
BR Silvio
deep+kumar1102
Yes it should not be rebooted but it is rebooted twice and services got impacted also , after that it is ok .
firmware is also updated one
I am facing this issue in two other switches also . please suggest what to do
the firmware is a new one. Maybe there are pmd-files. Maybe you will find informations in the log about the reason.
You should open a ticket at ALE.
Gleylancer
Post by Gleylancer »
Check via console port what the affected switch does before it reloads for "no reason".
Return to “OmniSwitch 6350”
