Connection to OXO with OMC under WINDOWS 11
stri
Post by stri »
HELLO please I can't connect to OXO with OMC under WINDOWS 11 every time it returns me error password although I'm sure it's the right password
THANK YOU :oops:
Re: Connection to OXO with OMC under WINDOWS 11
if it says wrong password, then it's not the right password.
Check CAPS LOCK to make sure you're not all uppercase
stri
Post by stri »
HI
I have already tried it on 2 different oxo
You mean you can't connect to any of your OXO?
Have you tried default password?
OshKosh
Post by OshKosh »
is the Error Message is "HTTPS [Iogin.4] - Soap login error - Error Code [29]" after attempting to connect to PABX.
Fix: Requires TLS 1.0 to connect to PABX
Win Settings->Internet Properties-> Advanced Tab -> TICK: Use TLS 1.0
