Dect Phone Rooming
ahqswitchroom4466
Dect Phone Rooming
I have OXE 3 Node. but our 1 node's dect phone is not working in other node. our all dect phone number as like *4466 or *2000. how i solve this rooming problem.
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
Re: Dect Phone Rooming
Roaming not working at all or some DECT sets (nodes) working in roaming?
ahqswitchroom4466
All dect phone not working as roaming. Please help us
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
ahqswitchroom4466
Our System version R100
Dect roaming license 240.
When i go from node 1 to node 2 our dect phone show network searching. We test too many dect set. We configure dect set as a Gap Handset and Gap+. But no dect phone working as a roaming phone.
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
Not work with R100, but I hope - principle the same as for OXE.
Main steps:
1 - right value for PARI and PLI (PARI must be with the same digits in the begining, difference will be in the last digits - depends of numbers of nodes and PLI).
2 - DECT sets number - must be present on visited nodes (f.e. like Network number prefixes)
3 - DECT must have roaming rights (before set registration)
4 - on visited must be created DECT set (shell)
5 - on home node shell number - must be present (f.e. like Network number prefixes)
When you visit remote node - if set not find DECT network - you have problem with PARI/PLI.
Main steps:
ahqswitchroom4466
Sir
We have 3 node
All node PLI for CTM: 30
PLI Campus: 31
Node1 Pari Value: 10057573100
Node2 Pari Value: 10057573110
Node3 Pari Value: 10057573114
Campus: off
Your all point check again but dect not working
We have 3 node
PLI Campus: 31
Campus: off
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
ahqswitchroom4466
When i shell set true and go to save but its show me error. Object-1 directory number: Modification forbidden. Gap/Gap+ users present.
Md Afzal Hossain
System Admin
Md Afzal Hossain
System Admin
Can you try with a PLI for CTM equal to 29 in all the nodes
ahqswitchroom4466
Sorry, try with pli for CTM equal to 24 in all the nodes
