Bandwidth Policy per VLAN and Port
mrenner
Post by mrenner »
Hi everyone
I need to implement an bandwith Limit per VLAN on a specific port
i tried it with:
policy condition VLAN401_1-1-18 destination port 1/1/18 destination vlan 401
policy action Limit_1G maximum bandwidth 1G
Executing
policy rule HSB_ETH_LIMIT condition VLAN401_1-1-18 action Limit_1G
gives me
ERROR: HSB_ETH_LIMIT: Can only use 'Destination port' with 'Destination VLAN' when using Multicast/Egress policies
What would be the correct way to implement this?
Michael
Re: Bandwidth Policy per VLAN and Port
destination vlan is not possible (only for qinq). You can use source vlan or destination ip ....
Return to “OmniSwitch 6900”
