Crashed Certiefied
kai
Crashed Certiefied
Post by kai »
I 've some problems with an OmniSwitch 6602-48. When the switch boots, I get the message that there is no certified configuration and the switch goes to Miniboot. How can I put a new certied config on the switch running in Miniboot?
Best regards,
Kai
benny
Re: Crashed Certiefied
Post by benny »
Hi!
Probably you still have the images in the working directory. Please try to boot from the working directory as I described it in the following thread.
viewtopic.php?f=86&t=3178
In case that you are stuck in Miniboot again you have no other choice than transfering the images through zModem over Console connection.
Benny
kai
Post by kai »
Hi Benny,
that's it. Many thanks!
Best regards,
Kai
raven22
Post by raven22 »
Hi!
How can I load image files to certified folder using zModem?
Or perhaps there is a way to copy files using usb flash?
cedric1
Post by cedric1 »
hi
there is no usb on 6600
If you serach there is a post with upload file with Zmodem
viewtopic.php?f=152&t=6241&p=30384&hilit=zmodem#p30384
but insetad of using setenv type c
after this you are prompted to change some setting (baudrate) etc and change flag value 0x0 to 0x1000
enter : @
so you will reboot to miniboot
follow post from beeny (url I paste) to enter in certified directory
cd "certified"
and start zmodem sysStartZmodem
when file is upload enter
reboot
interrupt boot and type again c
change baudrate to 9600 and flag to 0x0
type @
Cedric
