Forward DID to SIP trunk
Hi all,
I have virtualized an OXE and Elastix servers, both run fine and well. Now I am in a need to forward the DID number to the OXE to the SIP trunk (Used to connect the Elastix). Actually this is a test setup, if succeeds will be put to production.
Any help is greatly appreciated.
thanks and regards
anoop
Ps: Step by step instruction is not necessary, tips may work.
thanks and regards
anoop
Re: Forward DID to SIP trunk
NOT CLEAR
is this the wanted scenario?
DID---(isdn or pcm trunk)-->OXE>----sip---->>Elastix-extension
the received did should be translated at oxe level (external numbering plan /did trans) to the elastix extensio n , wich should known in OXE as network number or joined by routing number at translator /prefix plan
Yes, this is the scenario. Thanks for the reply. Let me try.
qReview/Modify: Numbering_Plan_Descriptor (NPD)qqqqqqqqqqqqqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x Description identifier : 35 x
x x
x Name : Algerie_Telcom x
x Calling Numbering plan ident. + NPI/TON Isdn National x
x Called numbering plan ident. + NPI/TON Isdn National x
x Authorize personal calling num use + True x
x Install. number source + NPD source x
x Default number source + NPD source x
x Called DID identifier : 2 x
x Calling/Connected DID identifier : 2 x
x Installation number : 03XXX x
x Default number( num. inst. sup.) : 2XXX x
x
lqReview/Modify: DDI number translator rulesqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x DDI num. transl. identifier : 2 x
x First External Number : 2000 x
x x
x First Internal Number : 18 x
x Range Size : 1 x
x Unique Internal Number + YES
Validating the DID TRANSCODING USE IN THE TRUNKGP 1800
DDI transcoding + True
NPD Selection at TRKGP
x Trunk Group Id : 1800 x
x x
x Public NPD id : 35 x
x Private NPD id : 0 x
x Management Mode + Normal
x x
x x
x
x x
x x
x Range Size : 1 x
x x
Some number are joined by
Numbering Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Number : 2000 x
x x
x Prefix Meaning + Network No. x
x Identifier of Domain : 0 x
x Network Number : 14 x
x Node Number/ABC-F Trunk Group : 1799 x
x Number With Sub Address (ISDN) + NO x
x Type + Fax Server x
x Identifier : 0
OR BY
qReview/Modify: Numbering Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Number : 3898 x
x x
x Prefix Meaning + Routing No. x
x Number of Digits : 8 x
x Default X25 Id.pref. + NO x
x
x x
x Number : 2000 x
x x
x Identifier : 0
OR BY
x x
x Number : 3898 x
x x
x
There is a toll free number comes to the OXE end, I need to route that to an Elastix Call center, that is the prime target. Once the testing successful, I will put it in to the OXE (Real hardware). Now OXE (vm) to Elastix and vice versa ok.
Regards.
anoop
Regards.
anoop
Thanks for the helpful information
Hi all, after days long research following Mr Harouns directions, i was able to direct the PSTN no to my Asterisk server through OXE, many thanks for it. I'm asking one more favor, as mentioned the incoming calls are working as it should, but no success with out going, any one can shed some light ?
regards,
anoop
regards,
anoop
what is your problem with outgoing calls? You cannot dial, or send wrong calling number? Or something else.
Tnx for the response Mr Vad, When I dial from my Asterisk server it doesn't go out. TCPdump shows the information does reach there, but not getting processed anyway. Actually I am no more in a VM, so I cant just do whatever comes to my mind. We only have the basic skills to manage the OXE, like ext creation and alike. Incoming calls from the Telecom provider works like a charm, I'm sure its a configuration issue. It would be great if anyone could say where to look or what to change.
thanks and regards,
anoop
thanks and regards,
anoop
