hello
am using OXE R12.3.1
i have one OXE and 15 OXOs
The PBXs are talking to each other via VPN using SIP protocol
All OXOs are pointed to OXE and call between them are working fine
The problem is when there is a missed call on OXE extension, instead of seeing the callers extension, you see your own extension as missed call. And when the missed call is on OXO extension, what you see is SIP word which is name of my OXE trunk
Note: when the call is calling on both ends, you can see the real name of the caller and when talking is ok
attached are trunk configuration on both OXE and OXO
Cant see missed call ext number from on OXE
- tot3nkopf
Re: Cant see missed call ext number from on OXE
Check your callback translator in OXE. You can also specify the SIP trunk group as private (OXE)
hi can you show us the isdn téléservices(ISDNSUBSCRIB) of an oxe user?
callback translator data ?
how did u dial oxo extension from oxe : routing number , short number , tkgp seize?
Hello Guys
as per the picture attached, the OXE SIP trunk is private, am dialing to OXO using routing number. the numbers to OXO starts with 2000 to 3900 thats in different branches
For the ISDNSUBCRIB i dont know how to see it please advise
As also seen from the image, thats all i can see from the external callback translator
Please advise how i can program it
HI
For isdn subscri
oxe users
x
x ISDN Subscr. x
x x
x External + True x
x Internal + True x
xDISPLAY ay ext. calling number + True
for external callback trans
for private net instance
lqReview/Modify: Ext.Callback Translationqqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x Basic Number : B x
x x
x Nb.Digits To Be Removed : 1 x
x Digits To Add : -------- x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
btw you have a bad config but it works
in the trunk group remote network should be different from N°15( as per doc as i remembred) and at routing number you have network n° =1 !
a good config for a abcf/sip trunk
Trunk Group Id : 1799 x
x x
x Trunk Group Type + T2 x
x Trunk Group Name : Sip
Number Compatible With : -1 x
x Remote Network : 14 x
x Shared Trunk Group + False x
x Special Services + Nothing x
x Node number : 1 x
x Transcom Trunk Group + False x
x Auto.reserv.by Attendant + False x
x Overflow trunk group No. : -1 x
x Tone on seizure + False x
x Private Trunk Group + False x
x Q931 signal variant + ABC-F
routing table
Number : 3898
Prefix Meaning + Routing No. x
x Network Number : 14 x
x Node Number/ABC-F Trunk Group : 1799 x
x Number of Digits : 8 x
x Number With Sub Address (ISDN) + NO x
x Default X25 Id.pref. + NO
and the corresponding network (i have not seen it but did you manage it)
Network Routing Tableqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x x
x Rank of First Digit to be Sent : 1 x
x Incoming identification prefix : -------- x
x Protocol Type + Dependant on Bundle Type x
x Numbering Plan Descriptor Id : 11 x
x ARS Route list : -1 x
x Schedule number : -1 x
x ATM Address Id : -1 x
x Network call prefix : -------- x
x Town Name : -------------------- x
x Send Town Name + False x
x Associated SIP gateway : 1 x -------------->>>should be 0 for your case
x Enable UTF8 names sending + True
For isdn subscri
oxe users
x
x ISDN Subscr. x
x x
x External + True x
x Internal + True x
x x
x x
x x
x x
x Node number : 1 x
routing table
Number : 3898
x x
x x
thanks haroun
my issue is sorted now i can see the missed calls
big up
big up
