Unknown Unicast Flood Blocking (UUFB)
mjgrossman
Post by mjgrossman »
Hello All,
Can anyone clarify if Alcatel has a feature comparable to Cisco UUFB?
The closest I have found is interfaces flood-limit which can be used to limit Unknown Unicast traffic similar to Cisco Unknown Unicast Flood Rate Limiting (UUFRL).
I could not find any settings for completely blocking Unknown Unicast on ports.
Thank you in advance!
Re: Unknown Unicast Flood Blocking (UUFB)
you can limit it to f.e. 500 packets per second:
interfaces 1/1/1-48 flood-limit uucast rate pps 500
Return to “OmniSwitch 6900”
