Write Terminal - MIB OID
hg363
Post by hg363 »
Hi am looking for the Alcatel MIB OID which when run would show me the current configuration on a 6450 switch?
Re: Write Terminal - MIB OID
try this one:
1.3.6.1.4.1.6486.800.1.2.1.11.1.1.1.12
hg363
Post by hg363 »
Hi I did what you suggested and got a 0 for the output
best way to find out the OID/MIB is to use the cli guide. At the most commands you find the MIB.
with the following command at the switch you get the OID
show snmp object identifier <MIB>
Now you can use snmp-walk to find out the wished OID.
Return to “OmniSwitch 6450”
