Put Remote Agent on Withdrawal from CCS
sitig
Post by sitig »
Just wondering if the mentioned subject is achievable, putting a Remote Agent on Withdrawal from CCS.
Cheers.
Every adversity has within it a seed of an equivalent or greater benefit....
oldboy
Re: Put Remote Agent on Withdrawal from CCS
Post by oldboy »
No not via CCS can do it via 8770 or command line, only thing via CCS is logout
sitig
Post by sitig »
Thank you old-boy...
Return to “CCD / CCS / CCIVR”
