6900-T40 initial configuration
fjromanma
Post by fjromanma »
Hi all,
I am having problems with the initial configuration of a 6900-40T switch: In the box there was no USB-RJ45 adapter, and the adapters I have tried don't work with this switch. Is there an alternative method to initially configure this switch? Does the EMP port have a default IP configuration? Is DHCP client active in the factory default settings for the default VLAN?
Thank you very much!
Francisco
Re: 6900-T40 initial configuration
you can create the adapter by youself
https://www.alcatelunleashed.com/viewto ... 900#p84411
DHCP is active in factory default setting. Depending from the release there are some ways to onboard the switch into your system (f.e. into OV or OVC). But the best way is to use for the first start the serial console.
BR Silvio
Return to “OmniSwitch 6900”
