Recording mediatrix FXS line.
ether
Post by ether »
Hi Guys,
Has anyone tried to use the Mediatrix 4102/4018 and record the FXS line (wire tapping) using GUARDREC?
The issue is the mediatrix device is constantly refreshing its FXS line every 20-30mins interval and the recorder is picking up the voltage spike as a noise.
07/01 13:16:37.399  10.205.137.115  local7.debug   syslog: FxsInterface [53BF] [Phone-Fax1] L1 N1 - Event OnTimer(9) on state "ONHOOK IDLE"
07/01 13:16:37.401  10.205.137.115  local7.debug   syslog: LineEngine [53C0] EP1 Reserved.
07/01 13:16:37.404  10.205.137.115  local7.debug   syslog: LineEngine [53C1] EP1 LowLevel report channel open : id=1
07/01 13:16:37.404  10.205.137.115  local7.debug   syslog: EndPoint [53C2] EP1: Line-side companding successully set to uLaw.
07/01 13:16:37.405  10.205.137.115  local7.debug   syslog: EndPoint [53C3] EP1 Jitter Buffer playout_type(Adapt Silence) vp_min_delay(30) vp_nom_delay(60) vp_max_delay(90) concealment(G711A)
07/01 13:16:37.405  10.205.137.115  local7.debug   syslog: EndPoint [53C4] EP1 EnterPreVoiceMode: Going in PreVoice mode
07/01 13:16:37.406  10.205.137.115  local7.debug   syslog: EndPoint [53C5] EP1 ModifyDigitDetectionConfig: Modify digit detection configuration
07/01 13:16:37.409  10.205.137.115  local7.debug   syslog: PotsEndPoint [53C6] EP1 DataTransmission TransType: 12 ModType: 2
07/01 13:16:39.709  10.205.137.115  local7.debug   syslog: PotsEndPoint [53C7] EP1 ReceiveSignalingMsg - eFXX_SIGNALING_POWER_DENIAL.
07/01 13:16:40.009  10.205.137.115  local7.debug   syslog: PotsEndPoint [53C8] EP1 RawData = 82030B01006F
07/01 13:16:40.010  10.205.137.115  local7.debug   syslog: PotsEndPoint [53C9] EP1 Send eFXX_SIGNALING_ONHOOK_TRANSMIT with a duration of 656ms.
07/01 13:16:40.011  10.205.137.115  local7.debug   syslog: PotsEndPoint [53CA] EP1 ReceiveSignalingMsg - eFXX_SIGNALING_ONHOOK_TRANSMIT_START.
07/01 13:16:40.473  10.205.137.115  local7.debug   syslog: LineEngine [53CB] EP1 LowLevel report gen ind2: trans_id=1300 group_status=3 fn_id=7208970
07/01 13:16:40.474  10.205.137.115  local7.debug   syslog: PotsEndPoint [53CC] EP1 - Received VbdGenerationEvent. m_eCallerIdState == 2. m_CallerIdInfoBuffer.m_bDataSent == 1
07/01 13:16:40.475  10.205.137.115  local7.debug   syslog: FxsInterface [53CD] [Phone-Fax1] L1 N1 - Event VmwiTerminated(1) on state "ONHOOK IDLE"
07/01 13:16:40.476  10.205.137.115  local7.debug   syslog: PotsEndPoint [53CE] EP1 Cancelling current VBD generation.
07/01 13:16:40.477  10.205.137.115  local7.debug   syslog: LineEngine [53CF] EP1 Released.
07/01 13:16:40.484  10.205.137.115  local7.debug   syslog: LineEngine [53D0] EP1 LowLevel report channel closed : id=0
07/01 13:16:40.659  10.205.137.115  local7.debug   syslog: PotsEndPoint [53D1] EP1 ReceiveSignalingMsg - eFXX_SIGNALING_ONHOOK_TRANSMIT_STOP.
Can this FXS refresh be disabled?
Thanks and Regards.
Return to “SIP”
