7360 ISAM NT redundancy problems
bluedalmatian
Post by bluedalmatian »
Hi Im trying to setup two FANT-F cards in a 7360 ISAM in active-active redudnacy but currently they arent even working in active-standby mode.
They both have identical software on them and are detected. I can boot the system off either the NT-A or NT-B by removing one of the cards before power up but once its running it wont switch over:
admin equipment protection-group 1 switchover
Error : REDCY MGT error 10 : The standby NT is not in hot-standby
show equipment protection-element nt-a
protection-element table
slot-id    |standby-status   |group-id|redcy-ctrl-status|stdby-chg-reas
nt-a        providing-service 1        normal            none
protection-element count : 1
 show equipment protection-element nt-b
nt-b        idle              1        normal            peer-lckd
show equipment slot nt-b
slot table
slot       |actual-type|enabled|error-status          |availability |restrt-cnt
nt-b        fant-f      no      no-error               available     0
slot count : 1
show equipment slot nt-a
slot table
nt-a        fant-f      yes     no-error               available     0
slot count : 1
Any ideas what the issue is?
Return to “GENERAL”
