I'm having some trouble with a 6850E from a customer not booting.
when i try to power on the switch this is all the information displayed from serial console
U-Boot (6.4.4.213.R01) (for OS6400, OS6850, and OS6855 platforms) (Jan 27 2011 - 05:18:45)
MPC8247 Reset Status: External Soft, External Hard
MPC8247 Clock Configuration
- Bus-to-Core Mult 4x, VCO Div 2, 60x Bus Freq 25-75 , Core Freq 100-300
- dfbrg 0, corecnf 0x1a, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 400000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 66666666
CPU: MPC8247 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz
Board: Alcatel-Lucent OS6850E (Kite2E)
I2C: ready
DRAM: 512 MB
i checked some of the other posts here and it seems that there is more information displayed even when the switch does not boot right but on this case it only displays that, I think that maybe if the flash information cannot be displayed and the boot process does not go after that info, the flash is dead, but I'm not expert on alcatel switches, so I ask if anyone knows if there is anything that can be done with the switch or if it is dead.
after displaying that info, switch becomes unresponsive, no more info is displayed and no response to anything on serial console.
thanks for any help you may provide.
