I bought a new OminPCX Small PBX on eBay. According to the DVD that came with it, the version is 9.2, however, it is brand new and never been used.
I successfully connected to the console using a serial cable, however, I do not know what is the user name and password.
Where can I find the default ones?
I guess that after I manage to login I will need to set up the IP address and then be able to configure it using the OMC application. Is that a fair assumption? If so, what is the command to set the networking?
Sorry for the newbie questions: I do not have any OmniPCX experience, however,I have many years of experience configuring Avaya and Cisco PBXs.
Tnx
Initial setup
Re: Initial setup
Eventually, I've managed to use OMC to connect to the PBX and even managed to upgrade the firmware to 10.3, however, I still can not log in into the console.
1. What username can be used to log in into the console?
2. I very much prefer to use Telnet/SSH to configure the PBX. Is there a way to enable Telnet/SSH for configuration?
Re: Initial setup
There is no console for config, only the omc. As for the upgrade, do you have a license for this release? If not go back to R9, or your system will not work. And R10 is pretty old, you won´t get any updates for this, or new functions.
Re: Initial setup
Thanks.
What type of configuration can be done using the console?
After the boot sequence, I get a prompt for username and password. Which username is relevant for the console login?
Re: Initial setup
there is only one known password, and this is for password reset in newer releases. The login is only for alcatel...
