Enable SSH without removing telnet
glandi
Post by glandi »
HI,
Does someone know if we can enable SSH without disabling telnet on oxe with R12 ?
Or if it's not possible, how can I move the 8760 from telnet to ssh ?
Thanks for your help
Re: Enable SSH without removing telnet
Good question. It's either or, you can't have both running. (You can normally, but ALE does not allow it)
alexeik
Post by alexeik »
You can change the 8770 to ssh
edc1
Post by edc1 »
Hi Alex,
Can you kindly guide me where I that menu is?
I need to enable SSH and disable telnet
thanks
edc1
Post by edc1 »
further to this, ours is an OmniPCX v12 . thanks
alexeik
Post by alexeik »
login as root , then netadmin -m and then security
Return to “Security and Access Control”
