Change PCS IP address
alexandros_z
Post by alexandros_z »
Dear all,
I am trying to install an new PCS for a first time. I have configured the "main" IP address of PCS in the field under CS ... mgr/Passive com. Server/ PCS Addresses.
I want to set it up with the local IP of PCS and not the Main in order to be able to do pcscopy when the PCS hasn't enable telephony.
How can I do this change? It is not allowed to delete the existing PCS because I get the message "PCS used for backup".
Software release:
R12.1-m2.300-19-gr-c83
Thank you in advance for your advises.
Alex
alexandros_z
Re: Change PCS IP address
Dears,
I fixed the issue due to the help of this topic "Change PCS's IP Address"
I deleted the main IP after having deleted the IP domain , but now i am facing an other problem.
I can't configure the local IP of PCS. I receive the message "Address already used"
any idea??
thank you in advance
Alex
alexandros_z
ok ... it is fixed after reboot
Return to “GENERAL”
