Hi All,
I was given an OS6450-P10 and I was wondering if you can provide some guidance on how I can use this for my home office.
Basically, I'd like to connect it to my Spectrum router and utilize the ports for my Wifi Router, Cisco IP Phone, my laptop, and a PC.
Here's how I have it connected:
Spectrum Router -> ethernet cable -> OS6450-P10 -> port1
Netgear Wifi Router -> ethernet cable -> OS6450-P10 -> port2
-All my wireless devices gets an IP address and internet connection
Cisco Phone -> ethernet cable -> OS6450-P10 -> port3
-No IP Address
-My Cisco Phone is going to be connected via MRA.
PC/LT -> ethernet cable -> OS6450-P10 -> port 4&5
-No IP Address
-No internet connection
Any ideas and guidance are appreciated.
Thanks!
OS6450-P10 for home office
- frank
Re: OS6450-P10 for home office
HI!
Do you have any knowledge in data networks ?
If not, reset the switch to its basic configuration and it should be working out of the box.
If you have knowledge, maybe someone can upload documentation.
juanmacipag
Thanks, Anyone has documentation? Basically, Id like the Spectrum relay the DHCP to the switch.
You can download all necessary dokus here https://www.al-enterprise.com/en/search
F.e. https://www.al-enterprise.com/en/-/medi ... 2-reva.pdf
