Loopback software
aviviis
Loopback software
Post by aviviis »
Does 6450 support loop back software ?
Is there any command that i can use to make loopback at l2 ( swap mac) ?
Re: Loopback software
I am not sure which of the commands you realy looking for. But in the guide you find the feature "loopback-test" and "ethoam loopback".
Maybe one of them is the whished one.
Return to “OmniSwitch 6450”
