Hello everyone, hope you are doing great,
We use Omnivista 8770 and 8078s phones, is it possible to set a special phone that forward all numbers with some exceptions?
It's a VIP that want all calls redirected to someone else, except for a list of internal numbers.
Thomas
Se
Re: Se
is it and oxo or oxe?
filtering with boss assistant tandem
in the oxe you have two kind of screening usng filtering tables
screen all kinda of call, the corresponding touch is RISO
unscreen special caller with PRISO touch
see system doc there is well explained
Caraponce
Re: Se
Hi thanks a lot for explanation!
Documentation says I can add up to 15 elements but it is possible to filter more than that?
I thought i could use this option mentionned in the documentation :
">Directory Progr
Filtering acts on the numbers contained in a directory. Enter the number of the directory concerned."
But I dont know where I can create such directory of numbers.
Ty for your precious help.
Thomas
">Directory Progr
Thomas
