Stacking Ports not showing up
mciantar
Post by mciantar »
We are having an issue similar to what is mentioned in the post here: https://www.alcatelunleashed.com/viewtopic.php?t=22815
We have a working stack with 6 devices. We came to add 2 more which were previously a stack by themselves (1-2). When we add either of them, the physical interfaces do not show up.
We have tested with a brand new switch and we were able to join it to the stack without any trouble.
Show Stack Topology Looks fine (even though I do not understand why it is showing StackA and StackB)
-> show stack topology
                                         Link A  Link A          Link B  Link B
NI      Role      State   Saved  Link A  Remote  Remote  Link B  Remote  Remote
                          Slot   State   NI      Port    State   NI      Port
   1 PRIMARY     RUNNING    1    UP          2   StackB  UP          7   StackA
   2 SECONDARY   RUNNING    2    UP          3   StackB  UP          1   StackA
   3 IDLE        RUNNING    3    UP          4   StackB  UP          2   StackA
   4 IDLE        RUNNING    4    UP          5   StackA  UP          3   StackA
   5 IDLE        RUNNING    5    UP          4   StackA  UP          6   StackA
   6 IDLE        RUNNING    6    UP          5   StackB  UP          7   StackB
   7 IDLE        RUNNING    7    UP          1   StackB  UP          6   StackB
But show NI for the non working stack switch shows the following:
-> show ni 7
Module in slot 7
  Model Name:                    OS6450-P48,
  Description:                   48 POE 10/100/1000 + 2 10G  + 2 1/10G STK/UPLINK,
  Part Number:                   903780-90,
  Hardware Revision:             05,
  Serial Number:                 V5084308,
  Manufacture Date:              DEC 20 2017,
  Firmware Version:              ,
  Admin Status:                  POWER ON,
  Operational Status:            UNPOWERED,
  Power Consumption:             67,
  Power Control Checksum:        0x2c4b,
  CPU Model Type   :             ,
  MAC Address:                   2c:fa:a2:b7:10:e2,
  ASIC - Physical 1:             ,
  FPGA - Physical 1:             000/00,
  UBOOT Version :                ,
  UBOOT-miniboot Version :       ,
  POE SW Version :               n/a
    Daughter Board         1
      Model Name:                    OS6450-XNI-U2,
      Description:                   6450 2 PORT SFP+ MOD 10G,
      Part Number:                   903786-90,
      Hardware Revision:             01,
      Serial Number:                 W2881334,
      Manufacture Date:              JUL 13 2018,
      Firmware Version:              ,
      Operational Status:            DOWN
      MAC Address:                   2c:fa:a2:d6:ff:8a,
as compared to this:
-> show ni 2
Module in slot 2
  Serial Number:                 W3881470,
  Manufacture Date:              SEP 23 2018,
  Firmware Version:              ,
  Operational Status:            UP,
  Power Control Checksum:        0x2f9c,
  CPU Model Type   :             ARM926 (Rev 1),
  MAC Address:                   2c:fa:a2:e1:06:9a,
  ASIC - Physical 1:             MV88F6281 Rev 2,
  ASIC - Physical 2:             MV88F6281 Rev 2,
  FPGA - Physical 1:             0011/00,
  UBOOT Version :                n/a,
  UBOOT-miniboot Version :       6.7.1.54.R02,
  POE SW Version :               01.5639.00
    Daughter Board         1
      Serial Number:                 Y0280593,
      Manufacture Date:              JAN 09 2019,
      Firmware Version:              ,
      MAC Address:                   2c:fa:a2:f6:04:ce,
  GBIC  51
        Manufacturer Name:             FiberStore,
        Part Number:                   SFP-10G-DAC,
        Hardware Revision:             ,
        Serial Number:                 F1712016975-2,
        Manufacture Date:              171221,
        Laser Wave Length:             n/a,
        DDM Capable:                   Yes,
  GBIC  52
        Serial Number:                 F1712016973-1,
        DDM Capable:                   Yes,
Also show stacking interfaces shows an error at the bottom
 Slot/Port  6/51 :
          Operational Status     : up,
          Last Time Link Changed : SAT JAN 01 00:01:22 ,
          Number of Status Change: 1,
          Type                   : Stacking,
          BandWidth (Megabits)   :    10000,            Duplex           : Full,
          Rx              :
          Bytes Received  :       25667882206696, Unicast Frames :           2767039236,
          Broadcast Frames:             71969312, M-cast Frames  :            105442588,
          UnderSize Frames:                    0, OverSize Frames:                    0,
          Lost Frames     :                    0, Error Frames   :                    0,
          CRC Error Frames:                    0, Alignments Err :                    0,
          Tx              :
          Bytes Xmitted   :       42508062692251, Unicast Frames :            889629820,
          Broadcast Frames:             93263772, M-cast Frames  :            104781339,
          Lost Frames     :                    0, Collided Frames:                    0,
          Error Frames    :                    0
ERROR: Not a stack configuration.
The problematic switch is connected to 6/52.
Any recommendation on how to resolve this issue?
Re: Stacking Ports not showing up
Have you build-in the xni-u2 module with power-down of the switch? the NI-7 does not show any uboot/miniboot version. Maybe you need to update them? Have you tested both the new devices (ni7 and ni8) together without connection to the old stack? Is this working? Sometimes it helps to reboot the whoole stack.
your output of show stack topology means f.e. slot5 stack-port B is connected to slot6 port A, 6B to 7B, 7A to 1B etc.
Best regards
Return to “OmniSwitch 6450”
