Entity State Changing
Eppetiano
Post by Eppetiano »
Hello all,
does anyone know if there is any away to change entity state using a prefix? My point is that i need to remove a 4059 IP attendant and replace it for a 8038 set. The problem is that the previous attendant used to change the entity state and now i must offer this feature on the new 8038 set.
Thanks in advance!
Miguel
Re: Entity State Changing
You want to use 8038 as usual IP set? Not like attendant?
mustafa.ahmad
Post by mustafa.ahmad »
If you configure 8038 as Attendant set, then it can change the entity state, otherwise not possible from normal IP phone.
mustafa.ahmad wrote: 11 Aug 2020 09:44 If you configure 8038 as Attendant set, then it can change the entity state, otherwise not possible from normal IP phone.
Is it possible to use 8038 (not 8068) as attendant set?
mustafa.ahmad
vad wrote: 11 Aug 2020 23:21
No, sorry i had misunderstood as 8068 .
It will not be possible to change the entity state from 8038
Return to “Entities”
