dear sirs
good day
kindly help me i have sas-t 7210 over temp alarm , amer alarm as the following below
my questions
1- is that effect on service
2- how can i know when this problem happen
3- what is the risk anlaysis for using this router
4- have to change this router
5- is this router work with 100 % or less than
6- how can i know how many fans command please
7- how can i know is fans work or not
thanks
Type : 7210 SAS-T 12F10T 4XFP-1
Coordinates :
CLLI code :
Number of slots : 2
Number of ports : 26
Critical LED state : Off
Major LED state : Amber
Over Temperature state : OverTemp
Base MAC address : xxxxxxxxxxxx
Number of MAC addresses : 300
Hardware Data
Part number : xxxxxxxxx
CLEI code : IPMWH00CRA
Serial number : xxxxxxxxxxx
Manufacture date : 08032017
Manufacturing deviations : (Not Specified)
Manufacturing assembly number :
Temperature : 78C
Time of last boot : 2000/01/01 02:34:06
Current alarm state : alarm active
Environment Information
Number of fan trays : 1
Number of fans : 3
Fan tray number : 1
Speed : full speed
Status : up
over temp alarm
- frank
Re: over temp alarm
78C is too hot. If it's under warranty, get a new one. If not, wait until it crashes..
mohanad osman
Re: over temp alarm
is that effect on routing or not
how can know this router is working with performance 100% or less than
thanks
thanks
Re: over temp alarm
What about environment. HVAC working? temperature in telecom room - not 35 degrees? In cabinet - you have ventilation...
mohanad osman
Re: over temp alarm
no it was 22 degree
is that mean there is an issue with this router shall be change ?
how can i make sure this router has a problem may be impact on his routing function ?
how can i trace this issue in the future
