SSH access for switch management
frobineau
Post by frobineau »
I have an OS 6350-p24 that has been reset to its initial configuration, so it's in a pretty vanilla state.
I have managed to enable console access, and now I'm trying to enable SSH access so that the switch can be managed without a clunky serial cable.
Here are the commands I have run so far on the console:
Welcome to the Alcatel-Lucent OmniSwitch 6350
Software Version 6.7.2.49.R01 GA, March 31, 2017.
Copyright(c), ALE USA Inc., 2017. All Rights reserved.
OmniSwitch(TM) is a trademark of Alcatel-Lucent Enterprise registered
in the United States Patent and Trademark Office.
-> password
Enter old password:   ******
Enter new password:   ***********
Reenter new password: ***********
-> aaa authentication ssh local
-> session timeout cli 10
-> session login-attempt 10
-> no aaa authentication telnet
-> ssh enable
-> ip service ssh
-> no ip service telnet
-> show ssh config
SSH = Enabled
SCP/SFTP = Enabled
Public Key Authentication Enforced = False
TCP-Port Number = 22
-> show ip service
  Name                   Port   Status
  ftp                      21   enabled
  ssh                      22   enabled
  telnet                   23   disabled
  udp-relay                67   enabled
  http                     80   enabled
  network-time            123   enabled
  snmp                    161   enabled
  secure-http             443   enabled
Ok, so SSH seems to be enabled, but how do I actually ssh into the switch? Where do I see / configure an IP address for the switch? Do I have to create a VLAN for it?
I tried creating a Loopback0 interface with an IP address of my choosing, but I still couldn't SSH into the switch after this:
-> ip interface Loopback0 address 192.168.1.30
-> show ip interface
Total 2 interfaces
             Name                   IP Address     Subnet Mask   Status Forward  Device
Loopback                         127.0.0.1       255.0.0.0           UP      NO Loopback
Loopback0                        192.168.1.30    255.255.255.255     UP     YES Loopback0
What am I missing? Are there some concepts I'm completely missing to understand what's going on? I should mention that this is my first managed switch, so I'm very much in a learning phase.
Thanks!
For what it's worth, here's the output of a few other commands that I thought could be relevant:
-> show vlan
                              stree                 mble   src
 vlan  type  admin   oper   1x1   flat   auth   ip   tag   lrn   name
   1    std   on     on     on    on     off   off   off     on   VLAN 1
Total 1 interfaces
-> show configuration snapshot
! Stack Manager :
! Chassis :
system name Switch6350
system timezone MET
system daylight savings time disable
! Configuration:
! VLAN :
vlan 1 enable name "VLAN 1"
! VLAN SL:
! IP :
ip service ftp
ip service ssh
ip service udp-relay
ip service http
ip service network-time
ip service snmp
ip service secure-http
! IPMS :
! AAA :
! PARTM :
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
! SNMP :
! RIP :
! IPv6 :
! IP multicast :
! IPRM :
! RIPng :
! Health monitor :
health threshold memory      90
health threshold temperature 78
! Interface :
! Udld :
! Port Mapping :
! Link Aggregate :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
! System service :
swlog console level info
! SSH :
! Web :
! AMAP :
! Lan  Power :
! NTP :
! RDP :
! VLAN STACKING:
! EFM-OAM :
! SAA :
! Loopback-detection :
! ERP :
! TEST-OAM :
! DHL :
! LLDP :
! DHCP Server :
! Stack Split-Protection Helper :
! Openflow :
! DHCPv6 :
! TWAMP :
Re: SSH access for switch management
try
aaa authentication ssh default
instead of local
you have to configure the ip address for vlan 1. f.e.
ip interface IF1 address x.x.x.x/24 vlan 1
Return to “OmniSwitch 6350”
