Omni Access 4450 Controller with AP92/IAP 203
Also known as OmniAccess Instant AP
gowtham96760
Post by gowtham96760 »
Hi ,
I just want to know is there any easy way I can change my management network and controller IP to another network.
for now ALL AP's are configured with Controller IP and if I change management IP, do I need to reset each AP and add new IP of the controller?
Re: Omni Access 4450 Controller with AP92/IAP 203
For the accesspoints you can use dhcp with the options 43/60 (master ip).
Return to “OmniAccess Wireless Access Points”
