UNIT 0 ERROR Interrupt: CMIC_DMA_STAT = 0x189600e PCI Fatal error on DMA CH0. on boot and crash system
DINOPAIOLI
Post by DINOPAIOLI »
i have a problem on alcatel switch 6850E 24P that it crash during boot.
I reset the configuration but the problem still again. I also restore the factory default config.
The error asks: UNIT 0 ERROR Interrupt: CMIC_DMA_STAT = 0x189600e PCI Fatal error on DMA CH0.
Attached you could see the detail from console.
Re: UNIT 0 ERROR Interrupt: CMIC_DMA_STAT = 0x189600e PCI Fatal error on DMA CH0. on boot and crash system
You might have a bad chip in this chassis. Might want to RMA it and get a replacement.
