QoS Design guide needed
hibym
Post by hibym »
based on the thread on this site (http://www.alcatelunleashed.com/viewtop ... cam#p87307), I search for a qos designguide for OmniSwitch 6850 (AOS 6.4.4).
I found a troubleshooting guide for aos7, so I basically understand what slices are and how they are used.
To be concrete.. I want to understand how and which slices are used (under aos6) and what does "Counters" and "Meters" in the following output mean.
->show qos slice ingress
Slot/                  Ranges          Rules          Counters         Meters
Slice           Type Total/Free  CAM Total/Free      Total/Free      Total/Free
01/0(0)   Firebolt B    16/16      0   128/124         128/124         128/128
                                   1   128/128         128/128         128/128
                                   2   128/128         128/128         128/128
                                   3   128/128         128/128         128/128
                                   4   128/128         128/128         128/128
                                   5   128/128         128/128         128/128
                                   6   128/128         128/128         128/128
                                   7   128/128         128/128         128/128
                                   8   128/128         128/128         128/128
                                   9   128/128         128/128         128/128
                                  10   128/128         128/128         128/128
                                  11   128/128         128/128         128/128
                                  12   128/128         128/128         128/128
                                  13   128/127         128/127         128/127
                                  14   128/124         128/124         128/128
                                  15   128/124         128/123         128/127
01/0(1)   Firebolt B    16/16      0   128/124         128/124         128/128
Thank you for any advice!
Re: QoS Design guide needed
this informations about slices and meters here are not important in real practice. Only if you have a lot of policies within your switch -but I never reached a threshold here (also with more than 100 rules).
How to configure policies (for qos) you will find in the network guide.
