In the last 2 weeks I´ve been "playing" with a Lab of 3x7750 and 6x7705. Coming from a Cisco world, it´s been a bit confusing, although I actually find that the commands order make a bit more sense in Alcatel.
I´m a bit stuck while configuring a port to connect to a PC, and I think my problem is that I don´t understand the difference between ports in (access/network).
I configure the port as an access and then the interface as below:
port 1/2/1
description "V5GH.17 - 6"
ethernet
mode access
exit
no shutdown
exit
router interface "to_6"
description "to V5GH.17 6"
address 10.10.6.1/24
port 1/2/1
no shutdown
exit
INFO: PIP #1208 Mismatch between the port mode and the interface type - port mode access, interface type networkCan you please help me understand my mistake and if possible what is the difference between access and network?
Many thanks
Francisco
