VM-4635
wisenawaz
VM-4635
Post by wisenawaz »
The call is not released after depositing a voice message into mailbox through analog trunk. The disconnection tone is also added with voice message. This is ok in case of if incoming call is made through PRI and also for extension to extension.
Re: VM-4635
For analogue line - PBX usually not detect disconnect (just busy tone).
You can try to manage "busy tone detection" for TG. Or use external devices (detect busy tone and send "disconnect" to PBX)
Return to “Voicemail (46x5)”
