Routing between IES and VPRN Interfaces
epalma82
Post by epalma82 »
I have three IGP routed IES interfaces (OSPF), and I have a VPRN (100) with various interfaces and static routes to a Firewall.
Is it possible to establish routing between IES interfaces and VPRN 100 ?. I need that the IES interfaces can have connectivity to the Firewall that is in the VPRN 100.
Emilio Palma
Stoffen
Re: Routing between IES and VPRN Interfaces
Post by Stoffen »
Hi.
This can be done by route-leaking. I dont have a SAR to test this with at the moment, but on SR, its done by the following:
1) Create the routing policy to enable VPRN to GRT leak:
  configure
  router "Base"
  policy-options
*A:R1>config>router>policy-options# info
            prefix-list "VPRN2GRT"
                prefix 192.168.1.0/24 exact
            exit
            policy-statement "VRPN2GRT"
                entry 10
                    from
                    exit
                    action accept
                    exit
                exit
            exit
In the VPRN (1234 in my case), enable GRT lookup, create static route for the GRT route(s) and export the VPRN route(s) to GRT:
  configure
  service
  vprn "1234"
*A:R1>config>service>vprn# info
            route-distinguisher 1234:1234
            interface "vprn" create
                address 192.168.1.1/24
                sap 1/1/c3/1:1111 create
                exit
            exit
            static-route-entry 10.0.0.0/16
                grt
                    no shutdown
                exit
            exit
            grt-lookup
                enable-grt
                    allow-local-management
                exit
                export-grt "VRPN2GRT"
            exit
            no shutdown
So, I have a loopback for this test:
*A:R1# show router interface "loop1"
Interface Table (Router: Base)
Interface-Name                   Adm       Opr(v4/v6)  Mode    Port/SapId
   IP-Address                                                  PfxState
   MACSec                        Admin     subport     encap   ca-name
loop1                            Up        Up/Down     Network loopback
   10.0.0.1/32                                                 n/a
Verify that the routes are visible in both GRT and VPRN routing table:
GRT:
*A:R1# show router route-table protocol vpn-leak
Route Table (Router: Base)
Dest Prefix[Flags]                            Type    Proto     Age        Pref
      Next Hop[Interface Name]                                    Metric
192.168.1.0/24                                Remote  VPN Leak  00h04m39s  180
       vprn                                                         0
No. of Routes: 1
VPRN:
*A:R1# show router 1234 route-table
Route Table (Service: 1234)
10.0.0.0/16                                   Blackh* Static    00h17m29s  5
       Black Hole                                                   1
192.168.1.0/24                                Local   Local     00h12m20s  0
       vprn                                                         0
No. of Routes: 2
Test:
*A:R1# ping router 1234 10.0.0.1
PING 10.0.0.1 56 data bytes
64 bytes from 10.0.0.1: icmp_seq=1 ttl=64 time=0.575ms.
64 bytes from 10.0.0.1: icmp_seq=2 ttl=64 time=0.177ms.
64 bytes from 10.0.0.1: icmp_seq=3 ttl=64 time=0.342ms.
64 bytes from 10.0.0.1: icmp_seq=4 ttl=64 time=0.212ms.
64 bytes from 10.0.0.1: icmp_seq=5 ttl=64 time=0.212ms.
If this is not available on the 7705, I guess you need to loop some ports to create the link between GRT and VPRN.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
epalma82
Post by epalma82 »
Hello Stoffen,
Thanks you very much, for your help
Return to “7705 SAR”
