IP Desktop Softphone over VPN
junoooni
Post by junoooni »
I am trying to register my IP Desktop Softphone (on Windows 10) latest version to my office OXO Connect (R3.2). it works well over LAN/WLAN but does not connect through VPN. We are using Fortinet Firewall VPN Client.
Any suggestions?
Ludvigc
Re: IP Desktop Softphone over VPN
Post by Ludvigc »
junoooni wrote: 18 Mar 2020 08:40 Hi
Any suggestions?
Found any fix for this? Having the same issue using Fortinet VPN client.
Just be sure you are setting up correct ports to be part of your firewall rules.
Check documentation about TCP/UDP ports
Ludvigc
Post by Ludvigc »
cavagnaro wrote: 21 Mar 2020 01:28 Just be sure you are setting up correct ports to be part of your firewall rules.
Ports are open, i can ping the TFTP adress but still not working.
out of ideas.
alexeik
Post by alexeik »
what does the display show when connected over vpn?
Ludvigc
Post by Ludvigc »
Just says "Connection lost" for like 5 seconds, then the whole softphone crashes.
alexeik
Post by alexeik »
then it is a firewall... like cavagnaro said check the documentation about what ports are used and check the firewall...
Ludvigc
Post by Ludvigc »
alexeik wrote: 26 Mar 2020 08:42 then it is a firewall... like cavagnaro said check the documentation about what ports are used and check the firewall...
The firewall rule is set to allow all. Trying to figure out what the issue might be
alexeik
Post by alexeik »
local windows firewall?
Ludvigc
Post by Ludvigc »
alexeik wrote: 26 Mar 2020 08:58 local windows firewall?
Tried with local firewall disabled aswell :roll:
Return to “Ip Desktop Softphone”
