8001 phones are not coming UP
LOKESH
Post by LOKESH »
Hi! I am facing a big challenge with 8001SIP Handsets. Handsets( more than 40) worked fine for a year or so, then stopped working suddenly. When I connect the handset to network, LEDs turn Red on the front side of the phone( as shown in the attachment) but it doesn't initialize at all.
Re: 8001 phones are not coming UP
All? Or just one from 40?
Do you have another working SIP phones?
LOKESH
Post by LOKESH »
All 40, they worked fine for a year and so. Then failed within 2 months once it started.
Yes there are 30 more phones which are working.
sadim
Post by sadim »
Can you tell what are the 6 first caracters of the serial number and/or the first 8 caracteres of the mac addr
LOKESH
Post by LOKESH »
SN- ESC175
MAC - 00268BB0
morio
Post by morio »
i had the same issue with one set. it was working fine and after few reboots the phone hanged and all LED was red, never came up, some times it will freeze at initialization. some how, i got it up after using a POE injector and i upgraded the binary. since then no issue.
erosales
Post by erosales »
I have the same problem, I have around 100 phones and around 25 have been initializing. Is it a phone failure? any solution to the problem? regards
hakuna
Post by hakuna »
Any solution for this issue? Please help. Phones going dead.
morio
Post by morio »
hakuna wrote: 05 Jan 2022 06:42 Any solution for this issue? Please help. Phones going dead.
what happens to your phone?
hakuna
Post by hakuna »
I have two types of dead phones:
1- Phone stuck on initializing
2- Phone turns on with lights ON of speaker, voicemail and nothing on display
Thanks!
Return to “SIP”
