8068s attendant can't call CCD Pilot
chinto
Post by chinto »
Hello.
Is there a configuration required to allow the phisical attendat calls CCD Pilot? actually, the attendant see the message "not allowed" when call it.
other users, internal and calls through the autoattendat works fine.
oldboy
Re: 8068s attendant can't call CCD Pilot
Post by oldboy »
under Applications/ccd/Pilot select your pilot go to the bottom and Pilot Supervised Transfer must be turned to True
Return to “Attendant”
