T1 CAS signal trace
sb0526
T1 CAS signal trace
Post by sb0526 »
How to trace the T1 CAS signal for Common Hardware?
i use the trace command follow list
tuner +at
actdbg mf=on
tuner sig=on
sigtrace 4 5 0 1 on (shelf 4 Board 5 Access 0 Channel 1 )
mtracer -a
if i make call to this trunk,i only see the DTMF,How can i see the signal ABCD bit status?
sadim
Re: T1 CAS signal trace
Post by sadim »
Try sigtrace 4 5 0 1 on
BRegards
diegopcsilva
Post by diegopcsilva »
How is the sintax of command tuner +at...
I already tried:
tuner +at 925
tuner +at 925-955
tuner +at 925 955
tuner +at ,925
tuner +at <925 955>
tuner +at,925
I have 4 E1(120 trunks), for sigtrace i need tp specify each one?
sadim
Post by sadim »
tuner +at,925-955
or you can do a shell script
BRegards
here is an exemple
(1)pst_cpu20> trkstat 1800
Sun Mar 15 14:16:49 CET 2020
| T R U N K S T A T E Trunk group number : 1800 |
| Trunk group name : AlgeriaTel |
| Number of Trunks : 30 |
| Index : 1 2 3 4 5 6 7 8 9 10 11 12 13 |
| Neqt : 2514 2498 2510 2496 2515 2505 2504 2502 2501 2499 2500 2513 2503 |
| State : F F F F F F F F F F hs F F |
| Index : 14 15 16 17 18 19 20 21 22 23 24 25 26 |
| Neqt : 2497 2524 2512 2495 2523 2522 2521 2520 2519 2518 2517 2511 2509 |
| State : F F F F F F F F F F F F F |
| Index : 27 28 29 30 |
| Neqt : 2508 2507 2506 2516 |
| State : F F F F |
(1)pst_cpu20> timout 0
timout disabled.
(1)pst_cpu20> tuner +at,2495-2524
(1)pst_cpu20> actdbg mf=on
Sun Mar 15 14:18:54 CET 2020
(1)pst_cpu20> tuner sig=on
(1)pst_cpu20> sigtrace 0 18 0 1
Sun Mar 15 14:19:26 CET 2020
Term number must be between 1 and 31
(1)pst_cpu20> sigtrace 0 18 1 on
Sun Mar 15 14:19:35 CET 2020
(1)pst_cpu20> mtracer -a
Traces Analyser activated
mtracer started ...
(664292:000001) MTRACER host (10.235.96.131, pst_cpu20), version: R9.1-i1.605-41-dz-c7s2
(664292:000001) MTRACER num: 004, time: 2020/03/15 14:19:46, loss: 0%
(664293:000002) MF R2 -- NDDI Neqt : 2497 -- Rec. : B-6
(664293:000003) MF R2 -- NDDI Neqt : 2497 -- Send : silence
(664294:000004) MF R2 -- NDDI Neqt : 2497 -- Rec. : silence
(664294:000005) MF R2 -- NDDI Neqt : 2497 -- End of trace --
(664330:000006) INIT MEVO : uti_inidcom init mevo neqt 2524
(664330:000007) MF R2 -- NDDI Neqt : 2524 -- Start of trace -- Dt : 2478
(664351:000008) INIT MEVO : uti_inidcom init mevo neqt 2512
(664351:000009) MF R2 -- NDDI Neqt : 2512 -- Start of trace -- Dt : 2478
(664357:000010) envoijustif : ptdemi->neqt=2524
(664357:000011) WITH_tephjust->numan[1]=0
(664357:000012) *** retaxe = 0 , nlogass = 65535
(664357:000013) *** warning: no time-slot alloc/desalloc nedeed for this coupler (Cr:0-Cpl:18)
(664373:000014) envoijustif : ptdemi->neqt=2512
(664373:000015) WITH_tephjust->numan[1]=0
(664373:000016) *** retaxe = 0 , nlogass = 65535
(664373:000017) *** warning: no time-slot alloc/desalloc nedeed for this coupler (Cr:0-Cpl:18)
(664380:000018) INIT MEVO : uti_inidcom init mevo neqt 2495
(664380:000019) MF R2 -- NDDI Neqt : 2495 -- Start of trace -- Dt : 2478
664381 193 term 01 |--PRIS_JNCT/PRISE_1-->| |
664381 193 term 01 | |--- 0001 --->|
664381 193 term 01 | |<-----------RON 1001---|
664381 193 term 01 | |-----------TRON 0001-->|
664381 193 term 01 | ( OUT_WAIT_ACK ) |
664381 199 term 01 | |<-- 1101 ----|
664381 199 term 01 | tax|REP OUT_SERV-->| |
664381 199 term 01 |<--- INVIT--| |
664381 199 term 01 | |<-----------RON 1101---|
664381 199 term 01 | |-----------TRON 0001-->|
664381 199 term 01 | ( OUT_DIAL ) |
(664402:000022) MF R2 -- NDDI Neqt : 2495 -- Send : I-10
(664404:000023) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664404:000024) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664405:000025) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664405:000026) MF R2 -- NDDI Neqt : 2495 -- Send : II-1
(664406:000027) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664406:000028) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664407:000029) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664407:000030) MF R2 -->search_ident_number-->rvtemp_ext_en_cours=0
(664407:000031) MF R2 -- NDDI Neqt : 2495 -- Send : I-10
(664408:000032) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664408:000033) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664409:000034) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664409:000035) MF R2 -- NDDI Neqt : 2495 -- Send : I-3
(664411:000036) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664411:000037) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664412:000038) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664412:000039) MF R2 -- NDDI Neqt : 2495 -- Send : I-8
(664413:000040) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664413:000041) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664414:000042) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664414:000043) MF R2 -- NDDI Neqt : 2495 -- Send : I-9
(664415:000044) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664415:000045) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664417:000046) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664417:000047) MF R2 -- NDDI Neqt : 2495 -- Send : I-8
(664418:000048) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664418:000049) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664419:000050) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664419:000051) MF R2 -- NDDI Neqt : 2495 -- Send : I-2
(664420:000052) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664420:000053) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664421:000054) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664421:000055) MF R2 -- NDDI Neqt : 2495 -- Send : I-10
(664423:000056) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664423:000057) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664424:000058) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664424:000059) MF R2 -- NDDI Neqt : 2495 -- Send : I-10
(664425:000060) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664425:000061) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664426:000062) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664426:000063) MF R2 -- NDDI Neqt : 2495 -- Send : I-10
(664427:000064) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-5
(664427:000065) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664428:000066) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664428:000067) MF R2 -- NDDI Neqt : 2495 -- Send : I-15
(664430:000068) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664430:000069) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664431:000070) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664431:000071) MF R2 -- NDDI Neqt : 2495 -- Send : I-7
(664432:000072) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664432:000073) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664433:000074) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664433:000075) MF R2 -- NDDI Neqt : 2495 -- Send : I-7
(664434:000076) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664434:000077) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664436:000078) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664436:000079) MF R2 -- NDDI Neqt : 2495 -- Send : I-10
(664437:000080) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664437:000081) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664438:000082) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664438:000083) MF R2 -- NDDI Neqt : 2495 -- Send : I-6
(664439:000084) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664439:000085) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664440:000086) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664440:000087) MF R2 -- NDDI Neqt : 2495 -- Send : I-10
(664442:000088) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664442:000089) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664443:000090) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664443:000091) MF R2 -- NDDI Neqt : 2495 -- Send : I-4
(664444:000092) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664444:000093) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664445:000094) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664445:000095) MF R2 -- NDDI Neqt : 2495 -- Send : I-6
(664446:000096) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664446:000097) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664448:000098) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664448:000099) MF R2 -- NDDI Neqt : 2495 -- Send : I-4
(664449:000100) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664449:000101) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664450:000102) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664450:000103) MF R2 -- NDDI Neqt : 2495 -- Send : I-7
(664451:000104) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-1
(664451:000105) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664452:000106) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664457:000107) MF R2 -- NDDI Neqt : 2495 -- Rec. : A-3
(664459:000108) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664459:000109) MF R2 -- NDDI Neqt : 2495 -- Send : II-1
(664460:000110) MF R2 -- NDDI Neqt : 2495 -- Rec. : B-6
(664460:000111) MF R2 -- NDDI Neqt : 2495 -- Send : silence
(664461:000112) MF R2 -- NDDI Neqt : 2495 -- Rec. : silence
(664461:000113) MF R2 -- NDDI Neqt : 2495 -- End of trace --
664467 035 term 01 |-- LIB/LIBIMM -->| |
664467 035 term 01 | |--- 1001 --->|
664467 035 term 01 | |<-----------RON 1101---|
664467 035 term 01 | |-----------TRON 1001-->|
664467 035 term 01 | ( WAIT_DISPO ) |
664470 064 term 01 | |<-- 1001 ----|
664470 064 term 01 | tax|HOS IDLE-->| |
664470 064 term 01 |<--- DISPO_MIC--| |
664470 064 term 01 | |<-----------RON 1001---|
664470 064 term 01 | |-----------TRON 1001-->|
664470 064 term 01 | ( IDLE ) |
(664479:000116) envoijustif : ptdemi->neqt=2495
(664479:000117) WITH_tephjust->numan[1]=0
(664479:000118) *** retaxe = 0 , nlogass = 65535
(664479:000119) *** warning: no time-slot alloc/desalloc nedeed for this coupler
Return to “Trunk Groups”
