Provide MoH in Attendant Group
thefil
Post by thefil »
I would like to provide music on hold on incoming calls when attendant consoles are busy. For the time being callers receive ringback tone and they believe that attendant group doesn't answer their calls.
Any suggestion?
thanks in advance
Re: Provide MoH in Attendant Group
hi my be it's not what u want but at least they will hear voice prompt (110 is voice guide to hold for attedant)
qReview/Modify: Prefix Planqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x x
x Instance (reserved) : 1 x
x Number : *09 x
x x
x Prefix Meaning + Incoming Call Greeting Guide x
x Prefix Information : 110 x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
in my case i use DDI for PCM Trunkgrpou
so i translate the numebr to the *09 (u
external number : 2000
sda partiel :
DID_FOUND
(dicho) DID_FOUND
sda : found internal number : *09
sda : found internal number(dicho) : *09
oldboy
Post by oldboy »
You dont need to use incoming greeting guide just check entity voice guides, Operator Waiting Guide should be 110 as advised above (or you can use your own) as this just repeats all operators are busy,
If you MOH is a VG you could also use that
Then modify timer 102 to the time you want it to cut in when the operator is actually busy
Return to “Attendant”
