Mikrotik CRS312 - OS6900-X40
aurik
Post by aurik »
Hello.
I need you'r help for a LACP.
I am trying to create a 802.3ad between those two switches, Mikrotik CRS312 anb OS6900-X40.
I add a linkagg on the 6900 as follow :
linkagg lacp agg 125 size 4 admin-state enable
linkagg lacp agg 125 name "NWPUBDATB"
linkagg lacp port 1/2/1 actor admin-key 125
And I create a bonding whith the 4 combo ports and added it to the Bridge.
bonding parameter.
mode : 802.3ad
transmit hash policy : layer 3 and 4
LACP Rate : 30s
I tried to change the LACP Rate for 1s, move the bonding from the bridge, but the aggregate never go up.
I am a bit lost.
if someone is successful, with success, to build an aggregate between the two, I would much appreciate a little help.
Thank's in advance !
Re: Mikrotik CRS312 - OS6900-X40
you have to setup the acto admin key at the agg too:
> linkagg lacp agg 125 actor admin-key 125
aurik
Post by aurik »
Oh, my God, that's the dumbest mistake I've ever made this year...
I'm so in over my head that I completely missed it, thank you for bringing my stupidity to light ! ahahah
Of course it work perfectly now... ^^
Return to “OmniSwitch 6900”
